Affordable small projector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-18-2015, 06:19 AM - Thread Starter
Liked: 0
Hi AVS forum
We're a group of students from Copenhagen academy of design and production, and we are doing a project where we need at projector.
We're doing a portable projector for boardgames, and therefore we need a small projector, but since none of us has any knowlegde on projectors we figured asking here .
We're looking for something small with most bang for buck, and we was thinking about making a max. size at 20x20x15 cm/8x8x6 inches. The image quality isn't a big issue since we dont need that high resolution.
Hope you can help us with our project.
Let me know if you need more information.
Andreas Binge Holm is offline
post #2 of 4 Old 11-18-2015, 07:48 AM
Ftoast's Avatar
Quoted: 2688 Post(s)
Liked: 877
Will the screen be able to be kept in the dark when in use so lights aren't washing out the image?
What screen-size do you want.
What sort of budget are you trying to fit?
With a pretty lit room many of the small projectors would have trouble lighting up a screen over 55" while fighting the lights.
If the room can be darker (at least the screen area) or a more expensive projector can be used, something around 90"-100" shouldn't be a problem...even larger if the content is mostly bright or colorful.
Easy $25 DIY black (or any color) ALR paint +$40-$50sprayer screen mix smooth/clean and very easy to learn spraying with little/no mess.
Simple $25-40 DIY black/dark-grey ambient-light rejecting screen, grab two things from a local store..mix..roll..done.
Quick <$250 dedicated black-fabric theater room "A store that sells blinds can help your picture more than a store that sells projectors many times." -bud16415
Ftoast is offline
post #3 of 4 Old 11-19-2015, 03:56 AM - Thread Starter
Liked: 0
We're looking for something under 55', and a length between screen and wall should be around 3-5 feet and we are aiming for it being used at night, but with background illumination
It could be best to get something around 100-200 $, but we could go up to around 400 $ if thats what needed.
post #4 of 4 Old 11-19-2015, 09:23 AM
Ftoast's Avatar
Liked: 877
From about 5ft back you'll usually be looking at a 50" image-size, though some of the best cheaper options will need to be a little over 6ft back because the LG ph300 (around $300) and the 480p-resolution LG pv150 ($200 new or $100 used from Amazon) use longer throw-ratios.
Those cheaper LG's only have coaxial, HDMI, and an USB slot for inputs though. You'll have to look at an adapter or a different model if you need VGA or RCA inputs.
Your size and room requirements sound perfectly manageable, and your price limit isn't badly restrictive for what you're asking for.
Ftoast is offline
boardgames , kea , project , small
