Portable Mount for outside projector use - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By impulse
post #1 of 9 Old 01-03-2016, 07:44 AM - Thread Starter
JoshFink's Avatar
Question Portable Mount for outside projector use
I'm searched but maybe I'm not using the right terms. Hopefully someone can point me in the right direction.
Right now we like to take the projector outside in the front yard on a work table, project against the garage, add an external speaker and watch movies outside.
This works great except I have this anxiety about someone bumping the table over and the projector and other equipment goes flying.
Any ideas or what has anyone done to make this a little more seamless while also securing it?
Thanks for the help
Josh
JoshFink is offline
post #2 of 9 Old 01-04-2016, 01:08 PM
gregoryperkins's Avatar
Quoted: 682 Post(s)
Liked: 254
You could do a rear projection from inside the garage. Not sure if that would kill the brightness.
gregoryperkins is offline
post #3 of 9 Old 01-04-2016, 01:12 PM - Thread Starter
JoshFink's Avatar
Sorry, I should have specified. I already have a projector, Epson 2040, just need a secure way to move it in and out and keep it safe.
Josh
JoshFink is offline
post #4 of 9 Old 01-04-2016, 01:24 PM
impulse's Avatar
Quoted: 26 Post(s)
Originally Posted by JoshFink View Post
Thanks for the suggestion. I appreciate the reply. I should have specified. I already have a projector, Epson 2040, just need a secure way to move it in and out and keep it safe.
Josh
The 2040 can do rear projection.
I would suggest using 1 layer of light grey spandex to project onto from behind. Like gregoryperkins suggested this would keep all the equipment in the garage out of harms way. The sound also goes through the spandex.
This is how I do my outdoor movies. I bungee the spandex to the garage door rails. Works great!
gregoryperkins likes this.
impulse is offline
post #5 of 9 Old 01-04-2016, 02:33 PM
Quoted: 682 Post(s)
Liked: 254
Bingo. Never tried it myself, but I've seen the option on my projectors.
post #6 of 9 Old 01-04-2016, 02:36 PM
DaGamePimp's Avatar
Quoted: 550 Post(s)
Liked: 583
Fry's sells this one...
http://www.frys.com/product/8488158?...H:MAIN_RSLT_PG
- Jason
HT = Sony HW45ES @133" / Lumagen Radiance / Denon x5200 7.3.4 Atmos / B&K 5000 II amp / Boston VR2/VR12/CR67 speakers / Rythmik 12" subs x2 / CV 15" sub / Sony x800 / Toshiba HD-A3
Media Room = Sony 65x930e / Denon x3300 /Klipsch speakers /Velodyne subs /Sony x700 /PS4 Pro + PSVR/WiiU/PS3/360/Wii/ 2080 TI game PC / Multi-Arcade / Virtual Pinball TRE45ON
DaGamePimp is offline
post #7 of 9 Old 01-07-2016, 09:16 AM - Thread Starter
JoshFink's Avatar
Thanks for the reply's. I'm going to check this out. For some reason I didn't receive a notification about this.
Josh
JoshFink is offline
post #8 of 9 Old 01-07-2016, 02:23 PM - Thread Starter
JoshFink's Avatar
Looking for a place to get this Spandex. Can you recommend one?
JoshFink is offline
post #9 of 9 Old 01-07-2016, 06:54 PM
impulse's Avatar
Quoted: 26 Post(s)
http://spandexworld.com/c3/catalog/product/10921
This is recommended.
impulse is offline
projector
