Suggestions on cleaning proj LCD panel? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-29-2016, 06:45 AM - Thread Starter
Jeff D's Avatar
I'm looking for anyone with experience servicing the epson powerlite 1080. I've had some overheating issues so I've opened mine for a cleaning and to check the fans and thermistor functionality. In the process it appears I may have touched one of the LCDs! I don't have any idea how to fix this and would like to know if anyone has suggestions.
It looks like the panels are protected by a sheet of glass which would be nice if that's true. The SM doesn't talk about the panels at all so I'm not clear what Compressed air isn't getting the dust off so I'm thinking about lightly using a microfiber cloth to grab what's stuck on there unless there are better suggestions.
The center LCD (green?) looks kind of strange compared to the other two. I've attached pictures in case anyone can tell me there's something odd there.
ID:	1217858   Click image for larger version
Jeff D is offline
post #2 of 4 Old 01-29-2016, 07:08 AM
airscapes's Avatar
Quoted: 489 Post(s)
Liked: 404
Well it looks to me like you have pictures of polorizer filters not the LCD. That looks like a failed polorizer. The LCDs are small and mounted in a prism right in front of the lens area.
The polarizers split the white light into Red Green and Blue sending each color of light to the respective LCD in the prism.
It has been years since i was in side a LCD projector so I could be wrong..
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 120"
http://www.airscapesart.com
airscapes is offline
post #3 of 4 Old 01-29-2016, 07:26 AM - Thread Starter
Jeff D's Avatar
Wait a second.... are these things pictured light filters or diffussers? It looks like the LCDs are mounted to the other part of the light engine.
Jeff D is offline
post #4 of 4 Old 02-01-2016, 11:18 AM - Thread Starter
Jeff D's Avatar
Sorry I missed your post and basically discovered exactly what you said.
Polarizers appear to be doing the job, R, G and B visible, LCDs are kicking out an image so picture is good.
Still trying to get the root problem fixed, and decided the polarizing glass and paired LCDs could be cleaned with care using air and micro fiber cloth.
Jeff D is offline
