Official BenQ HT3050 Owner/Settings Thread - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 18Likes
post #61 of 75 Old 03-23-2018, 06:46 PM
pablovi's Avatar
Quoted: 36 Post(s)
Hello everyone, I’m the new owner of a BenQ W2000+ projector, so I post this here, since it’s the closest projector to mine, for, the same company.
I’m having problems since today, I haven’t got an issue since last weekend that I installed everything.
But today I started playing with my AV Receiver (Integra DTR 30.6) HDMI output settings, I chose to use it as a splitter and chose to output both the Main And Sub outputs at the same time, it was working good, until I turned off my PJ and started watching tv, the PJ will turn itself on after a few seconds of being turned off, I thought, it must be turning it self on becuase it’s getting a signal on the HDMI, so I changed the output again back to only main, but it’s still happening! The PJ keeps tuning itself on randomly, even if it’s no the getting any signal from the Receiver, beacuse it says not signal when it turn itself on. Even physically changing the HDMI cable on the PJ from 1 to 2, caused it to turn itself on again.
So, maybe my AV Receiver is broken and it’s sending some kind of signal to my PJ? Maybe that’s the case.
But is it normal that this PJ turns itself on on it own? When detecting a video signal? Or what could be causing it to turn itself on? Is there a setting or something else to prevent that? Other than disconnecting it from the power outlet after every use?
I don’t know if it’s a coincidence or not, but today I tuned the High Altitude mode on. And I’m sure I need it, I live at 2,300m above sea level.
Thanks for any reply
pablovi is offline
post #62 of 75 Old 03-24-2018, 12:48 AM
pablovi's Avatar
Quoted: 36 Post(s)
Never mind, disregard the last post. It had nothing to do with the HDMI signal. The power button on the PJ was stucked, so it’s kept powering itself on. Now it’s fixed.
roni44 likes this.
pablovi is offline
post #63 of 75 Old 08-20-2018, 11:54 AM
Liked: 0
Has anyone been seeing issues with HDMI drop outs? I just purchased my HT3050 about two months ago, connected to RX-V383 Yamaha receiver ,with Xbox ONE and Amazon FireTV connected to it for HDMI Switching capabilities. I end up noticing it a lot more when using the Xbox One, where the projector will display "searching for source", then either it will find the source or come back saying the source not detected. I can mitigate by unpluging the HDMI cable from the projector and plugging it back in. During this time the audio is still playing fine through the Yamaha. So, now I'm curious if its the HDMI cable or the Projector itself. I bought a MonoPrice Luxe Series Active High Speed Cable 30ft, so I would hater for it to be the cable since its ran through an enclosed ceiling, I did leave pocket holes just in case a new one had to be fished through. Any ideas or help would be appreciated, right now I'm merely fishing for thoughts or if anyone else has experienced this. My plan is to bypass the receiver first before replacing the cable.
cledwards00 is offline
post #64 of 75 Old 09-08-2018, 11:19 AM
stoca01's Avatar
Has anyone tried to watch 4k content on this pj?
I have a nvidia shield tv going to a onkyo 920, and wondering whether a 4k video will look ‘correct’ in terms of colors.
I need to go through some hops to rip a uhd movie to try out, so thought of asking here.
This is mainly to take advantage of the atmos/dtsx audio track of uhd blurays.
stoca01 is offline
post #65 of 75 Old 09-08-2018, 11:46 AM
pablovi's Avatar
Quoted: 36 Post(s)
I don’t think you can just send it a 4K signal. I have the Xbox One X, and bought some 4K Blurays, I can play them fine and the Xbox downconverts them to 1080p and 709 if it doesn’t finds a compatible display. But they don’t look good, they look washed out, converting a higher gamma like HDR to SDR is hard and needs to be done manually. So, the more HDR a movie has, the worse it will look, like Mad Max Fury Road, it’s unwatchable, Blade Runner 2049, doesn’t look as bad, but still is not accurate, Dunkirk looks almost the same, since it doesn’t use HDR. But doesn’t have Atmos anyway. So, in the end, I ended up using the regular Bluray instead of the 4K. Mad Max has Atmos in both. And the other look better in 1080p anyway.
So, no, it’s not worth it.
sage11x likes this.
pablovi is offline
post #66 of 75 Old 09-08-2018, 12:49 PM
sage11x's Avatar
Quoted: 2946 Post(s)
Liked: 3017
You can’t send the HT3050 a 4K/HDR source. It won’t accept it. So if you’re streaming or playing a video game, the max resolution you can achieve is HD. If you want to watch a source that is ONLY available in 4K/HDR, say a 4K Blu-ray Disc, most devices will down-convert 4K/HDR to HD/SDR... and that’s where your problems start.
While scaling 4K down to HD isn’t hard, converting HDR to SDR, correctly without banding, is proving difficult. The only devices I know of that seem to do this satisfactorily are the new, very expensive, 4K Blu-ray players from Panasonic. My Sony X800 botches it and even the lauded Oppo leaves a lot to be desired.
pablovi likes this.
What to do if you find yourself stuck with no hope of rescue:
Consider yourself lucky that life has been good to you so far. Alternatively, if life hasn't been good to you so far, which given your present circumstances seems to be more likely, consider yourself lucky that it won't be troubling you much longer...
-- Excerpt from the Hitchhiker's Guide to the Galaxy.
sage11x is offline
post #67 of 75 Old 11-15-2018, 09:17 AM
Liked: 0
Did you managed to solve this? i have the same problem, changed cable, changed receiver and still drop outs.
It's so frustrating
vandyke23 is offline
post #68 of 75 Old 12-03-2018, 12:20 PM
pablovi's Avatar
Quoted: 36 Post(s)
Does anybody know the lamp life of this PJ? I have the W2000+. But it’s the most similar to this one. I’m pitting about 120 hours a month, so I need to figure out how much will it last me, and when do I need to change it.
Also, can it be done by the user? Or do I have to take it to service?
pablovi is offline
post #69 of 75 Old 12-03-2018, 06:50 PM
roni44's Avatar
Quoted: 92 Post(s)
Liked: 72
Normal: 3500hrs
Eco: 5000hrs
Super Eco: 7000hrs
Yes, it can be done by user.
pablovi likes this.
roni44 is offline
post #70 of 75 Old 12-04-2018, 12:01 AM
pablovi's Avatar
Quoted: 36 Post(s)
Originally Posted by roni44 View Post
Normal: 3500hrs
Eco: 5000hrs
Super Eco: 7000hrs
Thank you very much!
pablovi is offline
post #71 of 75 Old 07-06-2019, 10:14 AM
Liked: 0
Benq HT3050 Red Lamp / Power LEDs Flashing 584 bulb hours
I bought a HT3050 a little over 2 years ago. It currently has 584 lamp hours according to the service menu. After turning it on the fans are all going at full blast, the picture does come up for a few minutes, then it shuts itself down and the power and lamp LEDs are both flashing red. I also looked at the error codes section of the service menu and it said there was one Lamp Fail error and three PWROUT SPEED errors. Is this indicative of a bad lamp after only 584 hours, or could it be something else? Any help is appreciated.
CUandy04 is offline
post #72 of 75 Old 07-07-2019, 02:35 PM
Dave in Green's Avatar
Quoted: 3952 Post(s)
Liked: 3118
The user manual indicates that there is no situation where the lamp warning light flashes red. There is only one situation where the lamp warning light even flashes -- it flashes orange when the lamp is not lit up. But this only occurs when the power lamp is off, not flashing red.
The only mention of simultaneous red flashing lights is with power and temp warning lights. These simultaneously flash red and the lamp warning light is off when there's a Lamp 6 error (the actual fan speed is +/-25% outside the desired speed). This could be related to a slowly failing fan that's not running at the correct speed. It could also be caused by corrosion on a fan connector or an extreme dust buildup in one or more of the fans. According to the user manual it is not related to the lamp.
benqesupport.blob.core.windows.net/esupport/Projector/UserManual/Projector_um_User%20Manual_20151204_103859HT3050_2 0151117%20Update_EN.pdf
Dave in Green is offline
post #73 of 75 Old 01-13-2020, 05:06 AM
Liked: 0
I am interested in buying the benq w2000 (=HT3050). Is this projector definitely discontinued?
projectorcentral.com/BenQ-W2000-projection-calculator-pro: BenQ W2000 Projector (discontinued)
projectorcentral.com/BenQ-HT3050-projection-calculator-pro: BenQ HT3050 Projector (discontinued)
Benq HT2050 = BenQ-W2000+?: projectorcentral.com/BenQ-HT2050-projection-calculator-pro: BenQ HT2050 Projector (discontinued)
if the benq w2000 is discontinued, There is no substitute for the benq w2000?
If I quivoque with a word I'm sorry, I don't speak English well.
birdmanradio is offline
post #74 of 75 Old 01-13-2020, 10:18 AM
Quoted: 944 Post(s)
Liked: 267
The W2000 is no longer being made, but maybe it could be found at some stores.
HT2050A=W1120
HT2050=W1110
W2000+ is an upgrade to the W2000, don't think there is an equivalent HT model.
The W2000/HT3050 is factory calibrated, but the factory environment doesn't probably match the user's room.
The others are not factory calibrated, but still look ok.
Other options in the Benq lineup would be the W1050/HT1070A and W1090/HT1070.
You could switch over to 4K and there would be more options.
Depends what type of projector is required, what's the room like, dimensions, use case?
birdmanradio likes this.
noob00224 is online now
post #75 of 75 Old 01-14-2020, 03:33 AM
Liked: 0
Noob00224 Thanks for answering, I'm going to think about it.
HT3050
