Official BenQ HT3050 Owner/Settings Thread - AVS Forum | Home Theater Discussions And Reviews
 18Likes
post #1 of 75 Old 03-16-2016, 09:17 PM - Thread Starter
scotty3x3's Avatar
Quoted: 116 Post(s)
Liked: 36
Never started one of these before, so I just copied the format from the HT2050 thread. Thanks khaberst!
Noticed there was no "Official" thread for the HT3050. If there is another place for this please let me know.
BenQ HT3050 Projector Specifications
(show metric units)
MSRP(USD): $999Street Price(USD): $999
Status: ShippingFirst Ship: Oct 2015 Product Sheet
Warranty: 1 YearLast Ship: **
Replacement Lamp Model Number: 5J.JEE05.001
Brightness:2,000 Lumens
Color Light Output:**
Contrast(Full On/Off):15,000:1
Auto Iris:**
Native Resolution:1920x1080
Aspect Ratio:16:9 (HD)
Video Modes:720p, 1080i, 1080p/60
576i, 576p, 480p
480i
Data Modes:MAX 1920x1200
3D Modes:Full HD 3D
Digital Inputs:HDMI / MHL
HDBaseT:No
Max Power:330 Watts
Voltage:100V - 240V
Size(inches) (HxWxD):4.8 x 13.8 x 10.9
Weight:8.1 lbs
Lamp Life(Full Power):3,500 hours
Lamp Life(eco-mode):6,000 hours
Lamp Type:**
Display TypeLP (1)
Color Wheel Segs:6
Color Wheel Speed:6x
Standard Zoom Lens:1.30:1
Standard Lens Focus:Manual
Optional Lenses:No
Lens Shift:Vertical
Throw Dist (feet): 4.4 - 19.6
Image Size(inches):40.4 - 234.7
Throw Ratio(D:W):1.15:1 - 1.50:1
Audible Noise:29.0 dB
Eco-Mode:27.0 dB
Speakers:10.0 W × 2
Digital Zoom:**
Digital Keystone:Horz & Vert
Projector Central Review:
http://www.projectorcentral.com/benq...tor-review.htm
Below are the videos I've found on YouTube so far. The last video is one that I created just today and it gives a basic overview of my theater but the second half is the projector in action. As if cell phone video of a projector is a viable source to see quality. Maybe it will be of use to someone.
scotty3x3 is offline
post #2 of 75 Old 03-16-2016, 09:19 PM - Thread Starter
scotty3x3's Avatar
Quoted: 116 Post(s)
Liked: 36
I know the Cinema mode has been 'calibrated' from BenQ and has been said to be pretty accurate, but has anyone seen any 'other' calibrated settings?
post #3 of 75 Old 03-16-2016, 09:50 PM - Thread Starter
scotty3x3's Avatar
Quoted: 116 Post(s)
Liked: 36
Wow. Looks like my video was removed for having a scene from Mission Impossible playing. I'll try to take the scene out and repost with another video of some sort that won't violate terms of use.
post #4 of 75 Old 03-25-2016, 04:09 PM - Thread Starter
scotty3x3's Avatar
Quoted: 116 Post(s)
Liked: 36
Ok. I edited the video I recorded and reuploaded to YouTube. Main post has been edited.
post #5 of 75 Old 03-28-2016, 08:46 AM
triggernick's Avatar
Quoted: 38 Post(s)
Liked: 43
Using PS3 as a source and I am having trouble getting 3D to work. The message I am getting is:
Any ideas?
triggernick is offline
post #6 of 75 Old 03-29-2016, 01:58 PM
Quoted: 38 Post(s)
Liked: 43
I bipassed my receiver to eliminate that as a variable, by connecting the projector straight to the PS3. Still getting the same error message. Anyone have any luck getting the PS3 to play 3D Blu Ray discs? Any ideas? The troubleshooting I have found say to go to video settings and set it to "automatic". I do that, then they say it prompts you to enter the size of the screen used, mine doesn't do that, and goes to "finish" or "audio settings". Help?
post #7 of 75 Old 03-29-2016, 02:46 PM - Thread Starter
scotty3x3's Avatar
Quoted: 116 Post(s)
Liked: 36
I do not have a PS3, but I can try a 3D Bluray on my Samsung Bluray player when I get to the house and post results.
post #8 of 75 Old 03-30-2016, 08:32 PM
Quoted: 38 Post(s)
Liked: 43
Turns out it was a bad HDMI cable and my receiver can't pass a 3D signal (Onkyo 1007). I got a new hdmi cable to work with the PS3 directly to the projector, then Not when going through the Onkyo. Looks like I'm in the market for a new receiver! Going 4K and Dolby Atmos to future proof a little, any recommendations??
post #9 of 75 Old 03-31-2016, 12:56 PM - Thread Starter
scotty3x3's Avatar
Quoted: 116 Post(s)
Liked: 36
Sorry I didn't get around to testing mine out for you.
I have the Denon AVR-X4100 which supports Dolby Atmos but won't support the next DTS that is coming up. But for what mine does, I absolutely love it.
post #10 of 75 Old 03-31-2016, 04:48 PM
Quoted: 33 Post(s)
Liked: 0
Can any of the owners post a video clip of a blu ray playing on the 2050 or.3050?
sugirthan7854 is offline
post #11 of 75 Old 04-01-2016, 09:33 AM
jwheeler's Avatar
I have a question about this projector. I currently have the BenQ HT1075 that I have had replaced once because of a temperature sensor issue and the replacement is doing the same thing. Benq support is offering to give me an HT3050 as a replacement, which they say is a huge upgrade from the 1075 but it doesnt have horizontal keystone correction. I currently use my 1075 on a side table beside the couch to project onto a screen. I do have to correct for the projector being off center so I find it odd that a current projector does not have the ability to correct for off center viewing, especially when their less expensive model does. Does anyone have any experience with this?
jwheeler is offline
post #12 of 75 Old 04-01-2016, 09:44 AM
Dave in Green's Avatar
Quoted: 3953 Post(s)
Liked: 3128
According to the specs on the BenQ website the HT3050 has both horizontal and vertical keystone while the HT2050 has only vertical keystone.
Kenny52 likes this.
Dave in Green is offline
post #13 of 75 Old 04-01-2016, 12:27 PM
jwheeler's Avatar
In the videos and supported by the specs it appears the projector does have manual horizontal keystone correction. BenQ support is very responsive so I think I will go with this model and see how it compares.
jwheeler is offline
post #14 of 75 Old 04-01-2016, 05:13 PM - Thread Starter
scotty3x3's Avatar
Quoted: 116 Post(s)
Liked: 36
I had to swap my HT1075 twice for the exact same reason. Initially BenQ wanted to swap mine for an HT2050 which does NOT have horizontal keystone. The HT3050 does and I went back and forth with them for a week before they agreed to give me the 3050 instead of the 2050. So just make sure they are sending you the 3050 which DOES have the horizontal keystone.
post #15 of 75 Old 04-08-2016, 04:11 PM
colts19's Avatar
Quoted: 14 Post(s)
I just ordered a refurbished ht3050 from BenQ. Does anyone have their 3050 ceiling mounted and if so what ceiling mount are you using. I have never bought a refurb before. Hoping it works out well.
colts19 is offline
post #16 of 75 Old 04-10-2016, 07:59 PM - Thread Starter
scotty3x3's Avatar
Quoted: 116 Post(s)
Liked: 36
I bought the NPL-003 mount from mountdirect.com along with the matching extension pole. It's basically a universal mount that comes with a lot of parts for different projectors and you pick the ones you need to get it mounted. It took a while for me to figure out the best way to mount it, but once it was mounted I have to say I'm happy with it. It moves in all of the directions that the highly recommended chief mount does. It's not the prettiest thing in the world, but it's great for the relatively low cost.
post #17 of 75 Old 08-12-2016, 06:58 PM
Liked: 0
Hey! I'm new here.
Just have one simple question: I accidentially reset my Rec.709-Mode (Menu -> Reset Current Picture Mode) right after unpacking my new HT3050. Now all values under Color Mangement (Primary Colors, Hue, Saturation, Gain) are set to 200 which seem to be the standard values across all picture modes. Is this normal? Is my unit still Rec.709-calibrated? Or have I deleted the calibrated settings? If so, is there any way to do a factory reset?
Many thanks in advance & sorry for the Pidgin English,
widerschein
widerschein is offline
post #18 of 75 Old 11-19-2016, 09:37 AM
derod68's Avatar
HDMI settings on this PJ default to Auto. Does anyone use on video and if so, do u find it crushes blacks? More pop but lose detail and hard to get right. Surprised no one mentions this. Otherwise great pics!
Sent from my SM-G935T using Tapatalk
derod68 is offline
post #19 of 75 Old 02-22-2017, 11:53 AM
Smurfin's Avatar
Quoted: 12 Post(s)
Hi all
Just wondered if someone could check their firmware version? I've just bought a refurbished unit, manufacture date is April 2016 but firmware version is 1.00 (I returned another one which was 1.02) - anyone know the difference between firmwares?
Smurfin is offline
post #20 of 75 Old 02-22-2017, 05:43 PM
Liked: 0
is this a good projector for home theater
thomasfarkos is offline
post #21 of 75 Old 02-24-2017, 06:14 AM
widowmaker03's Avatar
I'm a newbie to projectors but have researched and decided to purchase a new BenQ HT3050. I plan on using it as a full-time viewer for watching DirecTV, Bluray/Bluray3d, and playing Xbox. I'm not concerned about shortening the bulb life versus enjoying the projector. Any advice would be appreciated.
widowmaker03 is offline
post #22 of 75 Old 06-19-2017, 09:35 AM
perkele's Avatar
Quoted: 61 Post(s)
Liked: 53
Originally Posted by widerschein View Post
Hey! I'm new here.
widerschein
Damn, I did this too. Every value is now 200. If anybody could give me the cinema rec 709 values (hue, saturation, gain), i would really appreciate it.
perkele is offline
post #23 of 75 Old 06-19-2017, 09:57 AM
sage11x's Avatar
Quoted: 2964 Post(s)
Liked: 3055
The rec709 mode is factory calibrated so resetting it should have no effect on the picture (unless you made your own adjustments).
You should never copy other people's picture setting from the internet. Because of manufacturing variances there is no way to tell if settings that worked on one unit will work for another. In fact, I've seen wild discrepancies between posted adjustments for the same LCD/plasma/projector.
Best thing to do is buy yourself a tune up disc like Disney wow or DVe or download the free avs709 disc here on this forum and run through it. Ideally your pre-cal mode should not require any adjustments or require very minor adjustments. On my plasma which has a THX mode running through the tune up disc required no adjustments. On my HT2050 which does not have a pre-cal mode I had to make very minor adjustments to the picture in it's most accurate 'cinema' mode to get the projector dialed in.
What to do if you find yourself stuck with no hope of rescue:
Consider yourself lucky that life has been good to you so far. Alternatively, if life hasn't been good to you so far, which given your present circumstances seems to be more likely, consider yourself lucky that it won't be troubling you much longer...
-- Excerpt from the Hitchhiker's Guide to the Galaxy.
sage11x is offline
post #24 of 75 Old 06-19-2017, 09:59 AM
kreeturez's Avatar
Quoted: 505 Post(s)
Liked: 406
The true test will be if everyone has the same settings (200 for everything) out of the box. I should be able to confirm shortly...
BenQ HT2050A Projector; Kodi (on Ubuntu, OpenELEC & S802) via Sony STR-DH540 AVR with Boston Acoustics SoundWare XS SE 5.1 Audio + Jamo 210 Sub. Emby for Mobile Streaming.
kreeturez is offline
post #25 of 75 Old 06-19-2017, 10:47 AM
perkele's Avatar
Quoted: 61 Post(s)
Liked: 53
True, true. But i still want the factory default settings. I mostly want to know if i imagined the differences, i could have sworn they werent at value 200 out of the box and im noticing differences in skin tones and green saturation. Its possible its entirely placebo.
Good, thanks!
perkele is offline
post #26 of 75 Old 06-19-2017, 11:26 AM
kreeturez's Avatar
Quoted: 505 Post(s)
Liked: 406
Originally Posted by perkele View Post
Good, thanks!
I posted this in the other thread... Should've been here:
I've just unboxed the HT3050. My kids took one look and forced me to take the HT2050 down and replace it with this one because "the gold is awesome!"
Guess the new room will get the old one now
Unfortunately it looks like the settings are projector-specific: it came with a factory calibration report citing the projector's serial number. But they're all close to 200 so you're probably not far off.
Attached are my out-the-box settings in any case!
perkele likes this.
post #27 of 75 Old 06-19-2017, 11:32 AM
perkele's Avatar
Quoted: 61 Post(s)
Liked: 53
Thanks kreeturez. Also i'd be interested to know how much variance there is between the units, so other owners could post their factory settings too.
I find it odd that you can reset the factory calibration just like that, it was i miss click from my part and i was going to select "no" when it asked me if i was sure but accidentally highlighted the wrong one .
Anyway the difference is marginal at best and for all i know its closer to rec 709 now in my space. Not a big deal but still weird. Also im not 100% sure they werent already at those values. I think they werent, i went through them couple times when i checked the settings.
perkele is offline
post #28 of 75 Old 06-19-2017, 01:58 PM
kreeturez's Avatar
Quoted: 505 Post(s)
Liked: 406
Just finished ceiling-mounting and aligning.
I recall reading that input lag was quite high on the HT3050/W2000 (whereas it's much lower on the HT2050/W1110) but this was meant to be fixed in firmware. My unit is manufactured in April with firmware 1.03
Here're some basic results - these are taken in Game mode, with out-the-box settings, using HDMI 1. I seemed to get higher figures when using the MHL-capable port (HDMI 2)... But HDMI 1 seems to compare favorably to my HT2050/W1110, so gaming is definitely a go.
post #29 of 75 Old 06-20-2017, 07:08 AM
perkele's Avatar
Quoted: 61 Post(s)
Liked: 53
I just hard reset the projector to factory defaults from the service menu and now my cinema rec. 709 mode has same values as kreeturez's unit. Hard reset also resets color wheel delay so i wouldnt recommend doing it, or at least take a note what it is before resetting. Although mine was actually a slighly off out of the box, i had very slight "pink face" problem some described in ht2050 thread which is caused by the incorrect cw delay.
Doing the reset current picture mode once again resulted me in having everything set to 200 value.
kreeturez likes this.
perkele is offline
post #30 of 75 Old 06-22-2017, 04:07 PM
kreeturez's Avatar
Quoted: 505 Post(s)
Liked: 406
Excellent. I wonder if the service menu is where that factory calibration is done, perhaps?
I've been doing quite a bit of gaming on this unit and have been pretty happy with its performance: I've re-run some lag testing today without my AV Receiver (turns out it adds a bit of lag even on its low-latency 'Fast Direct' mode) and I'm now consistently reading under 20ms - similar to the HT2050, and a solid result for gaming.
Otherwise, there's not tons of noticeable difference between this and the HT2050. The speakers on this model are way better (probably because there're two of them) - but almost everyone has surround sound. It's a bit heavier. My little ones like the gold trim. It's actually got an internal 3rd HDMI input (which supports MHL as well) for concealing a wireless receiver - along with a powered USB port - under the lamp cover - but hardly anyone uses wireless. (A Roku stick or Chromecast would fit in there, though).
In terms of picture quality, the two-point calibration out the box is spot on; and as a result I can leave Brightness and Contrast on 50, rather than the small bump-down in contrast and bump-up in brightness I required on my HT2050.
Since increasing the latter slightly hurts black levels (by turning them a touch grey), I'm actually getting slightly better calibrated black-level performance on this model as a result.
Color accuracy is good, but it was nearly as good on the HT2050. I'd need to run them side-by-side to tell the difference.
The factory calibration isn't perfect, though: I had to slightly correct for color clipping for both YUV (Red and Blue) and RGB (just Green) inputs. That should've been done at the factory.
I'm certainly satisfied, but for most people, unless there's a warranty difference (3 years vs 1, like in my case), I'd recommend the HT2050 for its slightly cheaper price tag and mostly similar performance.
sage11x likes this.
HT3050
