AE30000U Bulb needed - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-02-2016, 01:38 PM - Thread Starter
Liked: 0
Time to change the bulb on my Panasonic AE3000U. I have heard a lot of bad things about some of the replacement bulbs out there and would like to know what brand bulb you recommend using and location to purchase this bulb frome
rkkoeb1 is offline
post #2 of 7 Old 04-03-2016, 06:23 AM
Mr.G's Avatar
Quoted: 1265 Post(s)
Liked: 1353
Provantage. Good reputation.
http://www.provantage.com/panasonic-...0~7PANP07V.htm
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
post #3 of 7 Old 04-03-2016, 07:53 AM
Michael Sargent's Avatar
Quoted: 232 Post(s)
Liked: 219
Originally Posted by Mr.G View Post
I agree about Provantage.
And your question about brand is key. Always used real parts from Panasonic. Provantage sells real Panasonic parts, but at a great price.
Mike
Michael Sargent is offline
post #4 of 7 Old 04-03-2016, 05:50 PM - Thread Starter
Liked: 0
I see it sells for $300. Is that about right? I have bee looking around and see this bulb for much less.
rkkoeb1 is offline
post #5 of 7 Old 04-03-2016, 06:13 PM
Quoted: 232 Post(s)
Liked: 219
That sounds like the right price for a real Panasonic part. When you find them for less, they are counterfeit parts (not Panasonic). They might work, but if you read other peoples experiences you will find many people who have been ripped off by these counterfeit parts. Sometimes all that happens is that the bulb doesn't last very long. But sometimes they melt parts of the projector, or explode!
Spend the money on the real part (but spend wisely and get the real part for the best price you can).
Mike
post #6 of 7 Old 04-04-2016, 06:41 PM - Thread Starter
Liked: 0
What do you recommend for hours to change my bulb out at? I believe I am at 1600 hours right now
rkkoeb1 is offline
post #7 of 7 Old 04-05-2016, 06:50 AM
Quoted: 232 Post(s)
Liked: 219
It will tell you when the bulb needs to be changed. Generally it's around 2,000 hours but is longer if you use econo mode.
Of course, replacing the bulb early will give you a huge increase in brightness. My testing on an AE4000 showed a new bulb was 2 1/2 times brighter than a 2,000 bulb.
Mike
