Epson 5040UB ($2999) - e-Shift 4K, HDR10, WCG, Powered lens position memory - Page 89 - AVS Forum | Home Theater Discussions And Reviews
 1366Likes
post #2641 of 3506 Old 09-28-2016, 10:42 AM
aaranddeeman's Avatar
Quoted: 1874 Post(s)
Liked: 676
Originally Posted by Kelvin1000 View Post
Yes but that could be a factory defect. Has Epson confirmed or has anyone open up the projector to find out?
To that token Epson has yet to confirm on the 18/10.2 Gbps chipset as well..
One thing with Epson though, no matter what happens (within 2 years), you are covered. Not a dime you have to spend. So the dust blob issue should be least of a concern.
aaranddeeman is offline
post #2642 of 3506 Old 09-28-2016, 12:01 PM
PioManiac's Avatar
Quoted: 3340 Post(s)
Liked: 8446
With my Epson (1080UB) the first blob showed up at about the 3 year mark,
It's a good idea to be almost surgical, with a sterile environment when swapping in replacement lamps.
Not saying its the same with the new models, but both my dust blobs showed up shortly after a lamp change.
The Unfinished Basement Theater & Whisky Guitar Lounge | Bass EQ for Filtered Movies
JVC DLA X750 4K Projector | 120" Powered Drop Screen | 65" LG 65B6P OLED | Panasonic DMP UB900 | Oppo UDP 203 | HDFury Vertex
Yamaha RX-A3070 | 7.4.4.4 | Mission M3i x11 | Funk Audio 18.0 x2 | Velodyne DLS 5000R x2 | Crowson LvL3 MA x4 | miniDSP 2x4HD
PioManiac is offline
post #2643 of 3506 Old 09-28-2016, 12:05 PM
Josuah's Avatar
Quoted: 41 Post(s)
Liked: 38
I captured the Epson 5040UB EDID and also performed some experiments with different signals. From what I can tell, the Epson is limited to 300MHz 4Kp30 YCrCb 4:2:0 10-bit. Any attempt to feed it something higher will fail. Higher options are also marked as non-native in the EDID.
4K streaming sources need 4Kp60 4:2:0 10-bit advertised to trigger 4K HDR playback. Which requires 375MHz if I remember correctly. And so it isn't working.
Josuah is offline
post #2644 of 3506 Old 09-28-2016, 12:14 PM
PioManiac's Avatar
Liked: 8446
I "think" the end result is 10-Bit must be reduced to 8-Bit for a 10.2Gbps HDMI chipset
FYI, All "Current" 4K Blurays are 24p BT.2020 4:2:0 10 bit,
and even that may change in the future to a higher spec since it is not limited/regulated
....However 4:2:0 10 Bit is not a valid format for HDMI (as shown above)
So it has to be adjusted in the player, and not all players do it the same...
and not all Projectors are compatible with all formats either (10.2Gbps chip vs 18Gbps chip)
My Panasonic UB900 can playback in 4K/24p HDR/BT.2020 4:4:4/12Bit
or 4K/24 HDR/BT.2020 4:2:2/12Bit , not sure what format options other 4K players are sending.
post #2645 of 3506 Old 09-28-2016, 12:27 PM
Josuah's Avatar
Quoted: 41 Post(s)
Liked: 38
That's right. You can feed the Epson 5040UB a 4Kp60 RGB 8-bit signal. Easy enough to test by setting the Xbox One S to 4K output in its UI which will display properly. EDIT: Ignore [ But that isn't sufficient to trigger 4K streaming. ]
I'm told the first generation 4K Fire TV will trigger it because the 4K Fire TV itself is limited to 4Kp30, so an EDID that advertises 4Kp30 4:2:0 10-bit should allow 4K streaming. But I haven't confirmed this.
EDIT: Turns out I was not on the Netflix 4S+UHD plan. 4K w/o HDR may have been possible with the Xbox One S. 4K w/HDR may have been possible with the NVIDIA Shield.
Josuah is offline
post #2646 of 3506 Old 09-28-2016, 12:32 PM
shepdog's Avatar
Quoted: 125 Post(s)
Liked: 142
That's right. You can feed the Epson 5040UB a 4Kp60 RGB 8-bit signal. Easy enough to test by setting the Xbox One S to 4K output in its UI which will display properly. But that isn't sufficient to trigger 4K streaming.
I will try this when I get home.
shepdog is offline
post #2647 of 3506 Old 09-28-2016, 01:53 PM
Cine4Home's Avatar
Quoted: 540 Post(s)
Liked: 845
Originally Posted by gnolivos View Post
We talked about UPSCALING before, and I don't disagree with your findings.
Here I am talking about talking the 4K signal and displaying it on a 2K capable display. So yeah, it has to downscale somehow. Meaning, it's taking the 8M pixels and displaying 4M through eShift technology.
Simple: It just takes every second pixel horizontally / vertically out of the original 4k Picture.
Ekki
Cine4Home is offline
post #2648 of 3506 Old 09-28-2016, 02:04 PM
gnolivos's Avatar
Quoted: 372 Post(s)
Liked: 293
Ekki
Hehe. A very crude form of downscale indeed. . But seriously, if it took every second pixel vertically and horizontally it would result in a 1k picture.
Setup: Epson 5040 UB, 110" SilverTicket AT screen, PS3 bluray, Yamaha RX-V673 AVR, Polk and Athena speakers, Batcave room.
The Moderno Theatre! Slideshow (here!)
Pixar screenplay slideshows here!
gnolivos is offline
post #2649 of 3506 Old 09-28-2016, 02:10 PM
Cine4Home's Avatar
Quoted: 540 Post(s)
Liked: 845
Originally Posted by ac388 View Post
Hi Ekki,
I thought you said an English site is forthcoming. Did I overlook it ? Sorry that I cannot read German n its a shame that I miss all those hardwork you put in.
Good News:
My friends wrote an article about our joint-venture review in english language:
http://projectiondream.com/en/epson-...s10000-battle/
It also includes the LS10000, have fun!
Ekki
gnolivos and Soulnight like this.
post #2650 of 3506 Old 09-28-2016, 03:00 PM
shepdog's Avatar
Quoted: 125 Post(s)
Liked: 142
Good News:
Ekki
Do you have the color filter mentioned in the review for sell yet?
Will it be available in the US?
shepdog is offline
post #2651 of 3506 Old 09-28-2016, 03:46 PM
Liked: 676
My Sanyo PLV-Z2000 came with a hand blower and there are 3 holes on the pj (behind a door), where you insert the nose of the blower and blow the air out.
Some cleaver means by Sanyo to deal with dust blobs.
Not sure if any other manufacturer has that feature.
post #2652 of 3506 Old 09-28-2016, 04:00 PM
Quoted: 4878 Post(s)
Liked: 1843
Thanks for the review. It's interesting to note that that while 4K Enhancement does reduce the pixel grid significantly, it doesn't seem to do anything to reduce the jaggedness of the displayed characters. I had expected to see the jaggedness reduced when the image is shifted diagonally by 1/2 pixel.
Dominic Chan is online now
post #2653 of 3506 Old 09-28-2016, 04:14 PM
shepdog's Avatar
Quoted: 125 Post(s)
Liked: 142
I tried streaming Marco Polo on FireTv.
4k30. Still showing 8bit SDR 709rec
Not sure why but I prefer the picture of the Roku4
shepdog is offline
post #2654 of 3506 Old 09-28-2016, 04:28 PM
gnolivos's Avatar
Quoted: 372 Post(s)
Liked: 293
True. I still have mine. I never needed to use that feature but it gave me peace of mind to have it!
gnolivos is offline
post #2655 of 3506 Old 09-28-2016, 08:02 PM
ac388's Avatar
Quoted: 200 Post(s)
Liked: 52
Hi Ekki,
Thanks. I really appreciate it n especially still remember me waiting in the wing for an English version. I read thru the whole thing n like the part when u said the FI in this Epson still a bit buggy. Since when I asked this question in my post #226(pt. 2) back in Sept. 7, nobody know what I am talking.
Good News:
Ekki
Man see things as they are n say why. I dream of things that never were, n say why not ....... A Perfect PROJECTOR
ac388 is offline
post #2656 of 3506 Old 09-28-2016, 08:18 PM
Viche's Avatar
Quoted: 793 Post(s)
Liked: 191
This doesn't really matter to me since the projector is perfectly capable of handling 4K UHD Blu-rays and 4K streaming content.
If the 10gps chips are good enough for $15K native 4K projectors, then they are good enough for the $3K Epson and good enough for me!
Either way, I will add it to the list.
20(I think) e-shift on 5040 does not degrade sharpness or add noise (unlike JVC according to the projection dream review of both).
Viche is offline
post #2657 of 3506 Old 09-28-2016, 08:27 PM
Threefiddie's Avatar
Quoted: 418 Post(s)
Liked: 198
so long story short, the 5050 will be able to do it next year. lol
Ronman79 likes this.
Threefiddie is offline
post #2658 of 3506 Old 09-28-2016, 09:33 PM
nickoakdl's Avatar
Quoted: 121 Post(s)
Liked: 96
There won't be a 5050 next year. The 5030 wasn't last year, it was 3 years ago.
Viche likes this.
nickoakdl is offline
post #2659 of 3506 Old 09-28-2016, 09:42 PM
Josuah's Avatar
Quoted: 41 Post(s)
Liked: 38
Thanks for trying it out.
Josuah is offline
post #2660 of 3506 Old 09-29-2016, 02:37 AM
Kelvin1000's Avatar
Quoted: 139 Post(s)
Liked: 112
I have been arguing this point on the perceived sharpness advantage of the Epson over the JVC for quite some time...
The Projector Reviews comparison mentioned it and now the review from Projection Dream confirms it:
And… the picture stays sharp! That was new to us since the E-shift mechanism on the bigger brother Epson EH-LS10000 or on the JVC DLA-X5000 had a tendency to make the picture look a bit more soft. In addition, it does not generate noise in the picture like the JVCs.
ndabunka and Viche like this.
Kelvin1000 is offline
post #2661 of 3506 Old 09-29-2016, 03:20 AM
shepdog's Avatar
Quoted: 125 Post(s)
Liked: 142
Let me add it was a 4K stream, it just did not activate HDR
shepdog is offline
post #2662 of 3506 Old 09-29-2016, 05:08 AM
Liked: 676
Oh man. The JVC fanboys are now going to come after you beating their chest..
ndabunka and Ronman79 like this.
post #2663 of 3506 Old 09-29-2016, 06:06 AM
Quoted: 418 Post(s)
Liked: 198
never say never when they an easily make a revision to support 4k60 4:4:4 and call it something else.
post #2664 of 3506 Old 09-29-2016, 06:42 AM
Kelvin1000's Avatar
Quoted: 139 Post(s)
Liked: 112
If that's the case, then let's give them more reasons! :-)
From the Projection Dream review of the JVC:
Also, the E-shift4 4K simulation (very similar to the E-shift 3 on the JVC DLA-X500) on 1080p sources, does make the pixel structure disappear, but at the cost of making the picture look a bit softer and creating a weird moving picture noise when looking up close to the screen. In addition the E-shift activation adds a new sound/noise coming from the projector and some people may not like it. We recommend to let E-shift deactivated on 1080p content.
Another consideration that is hardly talked about is the Epson advantage with regards to the ANSI contrast figures:
Epson = 330:1
JVC = 235:1
The difference is even more pronounced when ambient light is introduced (which is my case):
The ANSI contrast tells you, how good a projector can display black next to white. The JVC DLA-X5000’s ANSI contrast is good, but not the best. That is why we were able to see vertical streaking in the black parts above and below the white squares of our contrast patterns.
Both of these points support what I was experiencing when comparing these two projectors in my particular viewing environment but boy did I get a lot of pushback from folks telling me that what I was seeing with my own eyes was all wrong...
post #2665 of 3506 Old 09-29-2016, 06:58 AM
luismanrara's Avatar
Quoted: 194 Post(s)
Liked: 130
Epson = 330:1
JVC = 235:1
OH OH...Now you are in deep S...t
Do not steal, The powers that be do not like the competition.
luismanrara is offline
post #2666 of 3506 Old 09-29-2016, 08:31 AM
nickoakdl's Avatar
Quoted: 121 Post(s)
Liked: 96
They could also give you a bar of gold with every projector you purchase.
99% of the public doesn't know or care about what 4:4:4 is. They won't release a new model next year to appease the 1% of the public that does.
post #2667 of 3506 Old 09-29-2016, 08:33 AM
Quoted: 418 Post(s)
Liked: 198
that's like saying apple won't release an iphone 7s.... again it's not a 4k projector. can't expect it to be and support everything but they can easily do a refresh at little cost with 18gb chip. this is the tech world, it evolves and gets minor refreshes all the time.
post #2668 of 3506 Old 09-29-2016, 08:38 AM
nickoakdl's Avatar
Quoted: 121 Post(s)
Liked: 96
Apple has a track record of releasing updated phones every year. Epson has a track record of updating their projectors every couple of years. Won't be next year.
post #2669 of 3506 Old 09-29-2016, 08:39 AM
Quoted: 418 Post(s)
Liked: 198
ok thank you for being an epson employee and clarifying.
post #2670 of 3506 Old 09-29-2016, 08:42 AM
Ix
Ix's Avatar
Quoted: 375 Post(s)
Liked: 301
I don't think any JVC owner, or very few anyway, would argue that in a non-light controlled environment the 5040 isn't good, maybe even better than the JVC(s). The true advantage of the JVC comes out when you have good light control and a theater-like environment - dark walls, little reflection, blackout area, etc. Then the native contrast advantage really comes out in a big way.
5040 is a great PJ. I know, I had one before I replaced it. Had the 5030 for years before that. Having personally seen the 5040 and the RS400 in the same conditions in my theater room I ended up preferring the JVC, but I wouldn't begrudge anyone for a different choice, or think they were "wrong" There are advantages to both and your use case will determine which is better for you.
Ix is offline
