Epson 5040UB ($2999) - e-Shift 4K, HDR10, WCG, Powered lens position memory - Page 94 - AVS Forum | Home Theater Discussions And Reviews
 1366Likes
post #2791 of 3506 Old 10-04-2016, 06:35 AM
mase1981's Avatar
Quoted: 148 Post(s)
Liked: 80
Those with the 5040ub (or if anyone with the 6040ub).
which BD player is confirmed to have full 4K HDR?
There are way too many pages to scroll to try and find the answer, trying my luck....
I have the XBOX ONE S but i understand HDR doesnt work with the 5040UB. Which BD Player is confirmed to be working?
is it ONLY the Philips BDP7501, or is there a cheapest option that is confirmed to be working? (my sincere apologies for the i am sure already asked question).
mase1981 is offline
post #2792 of 3506 Old 10-04-2016, 07:14 AM
Quoted: 353 Post(s)
Liked: 147
I cannot seem to find any answer to this.
I have a BC300 RF emiiter (optoma) and the ZF300 glasses.
Does this projector have a VESA 3D port that I can hook this emitter up to and use my current glasses (I have 10 pairs of very expensive RF glasses) or do I HAVE to use the Epson RF glasses with this projector?
longhornsk57 is online now
post #2793 of 3506 Old 10-04-2016, 07:36 AM
zombie10k's Avatar
Quoted: 5238 Post(s)
Liked: 5493
hi, there is no 3D VESA port. The ZF300 glasses are proprietary RF to the Optoma transmitter. If keeping these glasses is important, you may want to consider some of the alternative projectors that do have the VESA port (JVC RS400 and BenQ W8000 are 2 possible options).
longhornsk57 likes this.
zombie10k is online now
post #2794 of 3506 Old 10-04-2016, 09:19 AM
Mike Garrett's Avatar
Quoted: 11829 Post(s)
Liked: 9358
Originally Posted by ccotenj View Post
new owner (thanks mike!), replacing my mitsu hc9000 that died. sit 9' from 110" screen.
i really like this. very nice picture out of the box. bright, i have a HP screen, and had to close the iris down, even with lights on in the room.
quick question. sitting here playing with the various enhancement settings. when using 4k enhancement, the pj makes a noticeable noise. i'm running in cinema mode, default settings. it isn't coming from an increase in fan speed, the pitch is higher. source is 1080p.
normal?
tia.
Originally Posted by ndabunka View Post
Not normal. See others in the "5040ub Owners Thread" who have had their projectors swapped out. Are you running in eco, normal or high lamp mode when you experience the additional noise when changing to 4K enhancement?
A little bit of noise is normal. A loud noise is not normal. When engaging E-shift the projector usually make a higher pitched noise, but it should not be loud. One poster had one that was loud and he exchanged it and said the replacement did not make any noise. Either that poster can't hear the high pitched noise or he got a projector that does not make noise, which would be the exception, since it should make a little bit of noise.
ccotenj likes this.
Mike Garrett is online now
post #2795 of 3506 Old 10-04-2016, 10:13 AM
ccotenj's Avatar
Quoted: 170 Post(s)
Liked: 353
hey mike. thanks for the info.
yeah, this was loud. "hear it clearly from 15 feet away" loud. i'll be fine with a higher pitched noise at a "reasonable" loudness, my brain will tune it out anyway.
the fan is in eco-mode sure is quiet though. i basically can't even hear it.
fedex guy is delivering replacement today, so i will report back later.
- chris
https://www.avsforum.com/t/1332917/ccotenj-finally-gets-a-projector
ccotenj is offline
post #2796 of 3506 Old 10-04-2016, 10:20 AM
Threefiddie's Avatar
Quoted: 418 Post(s)
Liked: 198
google just announced chromecast ultra 4k hdr...
wonder if the hdr will work with the 5040 at all.
Threefiddie is offline
post #2797 of 3506 Old 10-04-2016, 10:21 AM
Liked: 9358
Just did not want everyone thinking it should be completely silent and all of a sudden Epson has a flood of returned projectors. Things like that have a tendency to drive costs up, which would mean, Epson's future replacement for the 5040/6040 would be at a higher price.
post #2798 of 3506 Old 10-04-2016, 10:56 AM
ccotenj's Avatar
Quoted: 170 Post(s)
Liked: 353
yeah, understood.
it is here and it is MUCH better. before, i could hear it over the fan when set medium mode. now, medium mode drowns it out entirely. i'd expect to hear something in eco mode, as noted, the fan is really quiet. no complaints here, the bit of noise it makes filters out as background.
now to level, align, etc. again.
ndabunka likes this.
- chris
ccotenj is offline
post #2799 of 3506 Old 10-04-2016, 11:58 AM
ndabunka's Avatar
Quoted: 572 Post(s)
Liked: 231
The Phillips is BY FAR the "least expensive" UHD player that currently implements standardized output that the 5040ub accepts. The Panasonic has also been shown to work well but it is TWICE the price of the Phillips. If you are going to be "bleeding edge", you often have to PAY dearly for it so $299 for the Phillips is pretty cheap for what it is
mase1981 likes this.
Epson 5040ub Projector, Elite Screens 120" Saker AUHD, Yamaha RX-A3060, B&W Speakers: Signature 7's, FMP4, CWM7.5s, CCM65s, Rythmik 15" CI Sub, 30' Monoprice Cabernet Ultra CL2, Tiara CI-Pro Series In-wall wiring, Phillips BDP7501 UHD BD Player, Niles 1230 WHA Amp, Xbox, WiiU, TiVo Premiere
ndabunka is offline
post #2800 of 3506 Old 10-04-2016, 02:17 PM
Quoted: 353 Post(s)
Liked: 147
Great gotcha!
post #2801 of 3506 Old 10-04-2016, 02:19 PM
Viche's Avatar
Quoted: 780 Post(s)
Liked: 184
Curious...any clue as to what could be causing the noise in some units, but not others?
Viche is offline
post #2802 of 3506 Old 10-04-2016, 05:21 PM
carp's Avatar
Quoted: 3513 Post(s)
Liked: 3196
Originally Posted by royboy365 View Post
Both projectors are rated at 2500 lumens so it would depend on which settings you decide to view on.
I can easily watch my 5040 on 100" 1.1 gain white elite screen during the daytime with lots of ambient sunlight (but not direct sunlight given the house orientation) as there are no shades in the room it is located in.
Get the projector from some place that it is easy to return if you're not happy with it. Chances are you won't be returning it.
My other projectors are BenQ 1085ST, Panasonic AE8000 and Epson 1080UB and the 5040UB is the brightest in that room and I now use the others elsewhere.
Sounds like the 5040 combines the blacks of the 5030 with the brightness of the 3500? Wow... having seen the 5030 before that's quite an accomplishment. Not that it has the best blacks ever, but they are good and the brightness of the 3500 is amazing.
carp is online now
post #2803 of 3506 Old 10-05-2016, 06:47 AM
mase1981's Avatar
Quoted: 148 Post(s)
Liked: 80
Getting my projector (6040ub) tomorrow !!!
Purchased the Phillips BD UHD player last night...
A quick question for those who have the Phillips if they can please confirm...
Are you guys going through a receiver or directly from BD Player into projector?
Purchased the phillips to get HDR 4k since the xbox one S is known to NOT work.
But i will have it running through Yamaha 2060BL and i was wondering if the Yamaha is supported to be working with the Epson and have 4K HDR. i really hope the Yamaha will not kill the HDR etc...
Trying to get the best working setup ! driving me nuts and i dont even have the projector yet lol .
mase1981 is offline
post #2804 of 3506 Old 10-05-2016, 11:16 AM
JewDaddy's Avatar
Quoted: 394 Post(s)
Liked: 177
I have a Yamaha 3050 and the HDR with the Phillips player works great
JewDaddy is offline
post #2805 of 3506 Old 10-05-2016, 11:18 AM
mase1981's Avatar
Quoted: 148 Post(s)
Liked: 80
Prefect! Thank you for confirming. Then my 2060 should be fine.
mase1981 is offline
post #2806 of 3506 Old 10-05-2016, 03:20 PM
Ronman79's Avatar
Quoted: 300 Post(s)
Liked: 192
@gnolivos , I saw it somewhere that you got black panels for the 5040.....do tell...
Equipment List: Theater - JVC DLA-X770R / Denon X4300H / Panasonic 820 4K BD Player / Polk Audio RTiA9 Towers / Polk CSiA6 Center / Polk 65RT (6), FXi5 (2) Atmos and Surrounds / (4) Polk PSW505 12" Subs / Black Flame Painted Screen Wall / Nvidia Shield TV / Dish Hopper 3 - 4K/ XBOX One S / Harmony Elite / Echo Dot / Tripp Lite UPS Backup / Furman Conditioner / App and Tap controlled Philips Hue Lighting / Monoprice Cabling
Ronman79 is offline
post #2807 of 3506 Old 10-05-2016, 03:28 PM
gnolivos's Avatar
Quoted: 372 Post(s)
Liked: 292
Actually the pricing was for the 5030. Mistake. Looking for 6040 now. It will need front and back panels too. I expect $250
Setup: Epson 5040 UB, 110" SilverTicket AT screen, PS3 bluray, Yamaha RX-V673 AVR, Polk and Athena speakers, Batcave room.
The Moderno Theatre! Slideshow (here!)
Pixar screenplay slideshows here!
gnolivos is offline
post #2808 of 3506 Old 10-05-2016, 05:47 PM
aaranddeeman's Avatar
Quoted: 1874 Post(s)
Liked: 675
Great.
But will it cost $250 and warranty?
aaranddeeman is offline
post #2809 of 3506 Old 10-05-2016, 06:24 PM
ndabunka's Avatar
Quoted: 572 Post(s)
Liked: 231
Originally Posted by aaranddeeman View Post
Great.
The costs will be MORE than $250 as that price was for the smaller, older 5030 parts and it was only for 2 of the FOUR parts needed so it could be as much as $500. What is this about "and warranty"? Are asking if changing out the casing will void the warranty?
ndabunka is offline
post #2810 of 3506 Old 10-05-2016, 07:38 PM
Liked: 675
It will void the warranty, IMHO.
post #2811 of 3506 Old 10-05-2016, 08:47 PM
ndabunka's Avatar
Quoted: 572 Post(s)
Liked: 231
Likely. The cost might also be less. Should still be interesting to learn if it's an option though.
ndabunka is offline
post #2812 of 3506 Old 10-06-2016, 04:48 AM
gnolivos's Avatar
Quoted: 372 Post(s)
Liked: 292
Can anyone confirm whether the 5040 can talk to a PS4 via CEC over HDMI? I'm considering a PS4 pro as a media streamer and game device, but want to control it via Harmony. Since PS4 has no IR, I'm thinking CEC may be the ticket.
gnolivos is offline
post #2813 of 3506 Old 10-06-2016, 05:14 AM
Liked: 675
When I had PS3, I bought a IR adapter (usb) from Radio shack (something like $10 or so). It worked great.
I don't know if such an adapter is available (and will work for PS3).
I have it lying around somewhere after I traded by PS3.
I can give it (away) to you. You can take a shot if that works.
Edit: This is that adapter. Just for reference.
post #2814 of 3506 Old 10-06-2016, 06:32 AM
gnolivos's Avatar
Quoted: 372 Post(s)
Liked: 292
Hey thanks for the offer. I do actually have a very similar one on my PS3, but I don't think it will work with the PlayStation 4. I will give it a try though when my PS4 arrives.
gnolivos is offline
post #2815 of 3506 Old 10-06-2016, 06:48 AM
WestCDA's Avatar
Quoted: 68 Post(s)
Liked: 79
Sony finally released a bluetooth remote a while back, but for IR it looks like this new PDP unit might be the ticket. Unlike the few other IR solutions that have trickled out, this one will cover the full range of PS4 operations, including power ON/OFF, with a Harmony remote. Licensed by Sony, ships in December.
PDP PS4 IR Receiver
gnolivos likes this.
WestCDA is offline
post #2816 of 3506 Old 10-06-2016, 07:10 AM
gnolivos's Avatar
Quoted: 372 Post(s)
Liked: 292
PDP PS4 IR Receiver
That's the ticket! $29. Nice.
gnolivos is offline
post #2817 of 3506 Old 10-06-2016, 07:24 AM
Liked: 9358
I think the question would be why are some not making noise or is the sound high pitched enough that some can't hear it.
post #2818 of 3506 Old 10-06-2016, 08:03 AM
rjguk's Avatar
Quoted: 63 Post(s)
Liked: 30
I've been investigating the 'whine' noise from my TW7300 (That's the 4040 in the US). So far I've discovered that it doesn't do it on a 1080i/50 source (Sky satellite) at all. On a 1080p/60 source (Amazon Fire 4K box) it does it all the time. It doesn't depend on whether 4K enhancement is on or any other setting that I can determine, just whether it is a 50 or 60Hz input.
I just made some measurements. Sky is the orangey line, Amazon Fire is the green line. All measurements in Eco mode, calibrated UMIK-1 mic pointing towards the rear of the inverted ceiling-mounted PJ.
This is 40 to 300 Hz, unfiltered and unsmoothed. The main feature is the sharp peak at 179.8 Hz on the Amazon line. That's exactly 3x the input frame rate of 59.94 Hz, the peak is about +10dB.
Everything else is fairly random in comparison. There's nothing particularly noticeable at other low multiples of the refresh rate.
This is 700-1000 Hz, unfiltered and unsmoothed. The big peak is on the Amazon line at 899.1 Hz, which is exactly 15x the input frame rate of 59.94 Hz. This is about 25 dB higher than with Sky in that area. The rest is fairly random fan noise.
Reproducing the 179.8 and 899.1 Hz tones with a tone generator gives the same 'whine' that I'm hearing from the PJ.
So, that's the 'whine'. Now I need to find out whether this noise with 60Hz inputs is a fault or not.
dvdwilly3 likes this.
rjguk is offline
post #2819 of 3506 Old 10-06-2016, 08:12 AM
royboy365's Avatar
Quoted: 112 Post(s)
Liked: 74
IMHO I don't think the sound is that high pitched. I have hearing damage from having made my living in nightclubs when I was younger and cannot hear higher pitches. I usually watch shows with CC turned on, nevertheless the noise from my unit was so annoying that I stopped using the 4k Enhancement feature unless I was watching a 4k film.
royboy365 is offline
post #2820 of 3506 Old 10-06-2016, 08:20 AM
shepdog's Avatar
Quoted: 125 Post(s)
Liked: 142
I think this may be true.
I can't hear it and my wife can't hear it but my son says he can hear it.
Even with the audio turned off, I can't hear anything.
Very interesting.
shepdog is offline
