Optoma HD20 Bulb Assembly - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 07-11-2016, 06:35 PM - Thread Starter
Liked: 0
I have an HD20 that I have replaced the bulb in around three times and while I was replacing it this last time a piece broke off of the insulator. I can't find that part anywhere. Can this part be purchased somewhere or do you have to buy the entire assembly to get it? I have currently tried using epoxy to glue the piece back together but I'm not sure if that will hold once the projector heats up. Thanks for any help.
Bama350z is offline
