Epson Home Cinema 3700 - Page 30 - AVS Forum | Home Theater Discussions And Reviews
 224Likes
post #871 of 885 Old 02-20-2020, 09:54 PM
Liked: 0
Hey long time owners of Epson 3700, can you all tell me the average lamp life you are getting on your projectors?
Ethan1995 is offline
post #872 of 885 Old 02-28-2020, 02:08 PM
Cla55clown's Avatar
Quoted: 409 Post(s)
Liked: 128
Originally Posted by 4rpr View Post
How is this?
I know this is old but where did you get that alignment pattern from? Is it buried in a menu on the Epson somewhere?
Cla55clown is offline
post #873 of 885 Old 02-28-2020, 05:18 PM
xiaNaix's Avatar
Quoted: 52 Post(s)
Liked: 46
There should be a "Pattern" button on the remote.
Cla55clown likes this.
Sony BDP-S6700 (Region Free) | Dune Solo 4K | Zidoo X9S
Epson Home Cinema 3100 | Silver Ticket STR-169110 110" Screen
Yamaha RX-A770 | Chane A2.4 L-C-R | Fluance XLBP Wide Dispersion Bipolar Rears | Hsu VTF-2 MK5 Sub
xiaNaix is offline
post #874 of 885 Old 03-07-2020, 07:04 AM
elee532's Avatar
Quoted: 211 Post(s)
Liked: 45
I'm thinking about replacing my 3700 with the new 3800.
I had my Control4 system programmed to control the 3700 using an IR extender. Anyone happen to know whether the 3800 uses the same remote codes so that I can just slide it in to replace the 3700 without and reprogramming?
On a related note, it looks like the 3800 is the same size as the 3700. Can anyone confirm will it fit in the same location as my current 3800 and fit my screen the same way RE: zoom and lens shift settings?
elee532 is offline
post #875 of 885 Old 03-07-2020, 03:55 PM
Quoted: 1367 Post(s)
Liked: 398
For the first question maybe inquire here:
https://www.avsforum.com/forum/68-di...vealed-21.html
For the second one, the HC3700 and HC3800 have the same lens shift, but slightly different throw ratios:
1.34:1 - 2.17:1 for the 3700
1.32:1 - 2.15:1 for the 3800
Size:
16 cm x 41 cm x 30 cm (HxWxD) for the HC3700
17 cm x 41 cm x 33 cm (HxWxD) for the HC3800
noob00224 is online now
post #876 of 885 Old 03-07-2020, 04:18 PM
elee532's Avatar
Quoted: 211 Post(s)
Liked: 45
Size:
Slid into place and worked like a charm!
Only problem is, I bought with because I thought I needed a 4K projector to get Atmos working with Disney+, but still no Atmos. 🤨 Could it be because the 3800 is somewhat of a "fake" 4K?
elee532 is offline
post #877 of 885 Old 03-07-2020, 04:22 PM
Liked: 398
The kind of 4K the Epson does is not relevant. It can accept a 4K signal, so the issue is somewhere else.
Don't use Disney+, but Atmos with streaming does exist, but only DD+ Dolby Digital Plus / E AC3.
Maybe this thread:
https://www.avsforum.com/forum/184-v...thread-14.html
post #878 of 885 Old 03-07-2020, 09:17 PM
elee532's Avatar
Quoted: 211 Post(s)
Liked: 45
Maybe this thread:
Is there a setting I might be missing somewhere in the 3800 to turn HDR "on?" Thank you!
elee532 is offline
post #879 of 885 Old 03-07-2020, 09:35 PM
Liked: 398
Best to inquire on the HC3200/3800 thread.
post #880 of 885 Old 03-14-2020, 10:23 PM
Sekosche's Avatar
Quoted: 1473 Post(s)
Liked: 3747
Only problem is, I bought with because I thought I needed a 4K projector to get Atmos working with Disney+, but still no Atmos. Could it be because the 3800 is somewhat of a "fake" 4K?
I have had no problem receiving Atmos streams on Disney+ with my Epson 3700 through a Roku premier and Denon x4200. However, that’s the only streaming service that will automatically pull down the Atmos feed without a 4K PJ as far as I‘m aware with my setup.
I hope you get this issue resolved soon!
Speakers: PSA MTM-210T x2, MTM-210C, MT-110SR x2; Atmos-SVS Satellite x2, DIY Volt-10 x2
Subs: PSA V1801 x2, DIY: 18" RSS460HO, 15" RSS390HO x2, BOSS w/JBL CX1200 x6
MA’s: Crowson Tech x2
Processing: Denon X4200, NU6KDSP, 3KDSP
Video: Epson 3700; Screen: Silver Ticket 106" High Contrast
Sekosche is online now
post #881 of 885 Old 03-21-2020, 07:27 AM
elee532's Avatar
Quoted: 211 Post(s)
Liked: 45
I did resolve my issue, thanks.
First, I found that by changing the Nvidia Shield's resolution setting to 4K 23.976Hz or even 1080p 59.940 Hz, I could now get Atmos. The 4K 59.940/60/50 Hz settings did NOT give me Atmos.
This was a good step, but the Shield ran slow at 4K 23.976Hz, which was annoying.
I did some more poking around in the Epson projector and my Denon receiver. I found The Denon had a 4K option for 'standard' and 'enhanced'. I switched it to enhanced, but doing so caused the video to go blank.
I had two runs of HDMI cable going to the projector, so I decided to try the second one. This allowed me to successfully set the Denon to 'enhanced.'
Now, back to the Shield and I was able to successfully set the Shield's resolution to 4K 59.940 Hz.
Projector now shows an HDR10 input and Dolby Atmos still working. Yay!
elee532 is offline
post #882 of 885 Old 03-24-2020, 08:47 PM
Quoted: 79 Post(s)
Liked: 40
Lamp not bright enough in medium
I had been using this projector (mostly) in low lamp mode until, in very early Feb, the brightness faded. I was advised to switch to medium lamp mode and I'm now in the exact same situation re. brightness.
I can run it now in high lamp mode and get the desired brightness. Any idea how long this will last and if there are any concerns with running it in high lamp mode? I am at approximately ~2800 hours on the projector. Thanks!
liverpool_for_life is offline
post #883 of 885 Old 03-25-2020, 02:23 AM
Liked: 398
It might be time to replace the lamp and keep this one as a spare.
If the room has ambient light reducing it would also help. As well as painting the walls in a darker shade. And getting a positive gain screen if that's possible (or painting).
But getting a new lamp is cheaper than some of these options.
liverpool_for_life likes this.
post #884 of 885 Old 03-25-2020, 04:08 AM
Quoted: 79 Post(s)
Liked: 40
I understand that and have paid for one. Unfortunately, the country I live in is under a complete lock down for the next 3 weeks (the day after I paid for a replacement).
First 2 have been done, which is how I was able to get away with using it in low lamp mode for so long.
While I understand this is a difficult question to answer, I was really hoping for an approximate number of hours that I can expect to use the bulb in high lamp mode, given my usage.
post #885 of 885 Old 03-25-2020, 04:17 AM
Liked: 398
Estimates are not exact, and lamp brightness can vary from lamp to lamp.
If you need to put it on High I'd say it's not long until it breaks.
3,500 h durability, 5,000 h durability (economy mode)
Probably 500h more or so.
3700 , Epson , focus , home cinema , powerlite
