Official Epson 5040ub/6040ub owners thread - Page 484 - AVS Forum | Home Theater Discussions And Reviews
 26901Likes
post #14491 of 17705 Old 05-16-2018, 04:57 AM
roland6465's Avatar
Quoted: 395 Post(s)
Liked: 401
Just a tad off topic, but since my FireTV 4K just figured out that my 6040 doesn't do 50 or 60Hz HDR, I need a new streamer for Prime video. Is the Roku Stick+ adequate? Does it have a setting for UHD/24 like the ATV? Could it be a bigger pain than the FireTV? Does it have issues with the HDMI-in of the Oppo 203?
Thanks, I know I could ask in 4 different forums, but y'all have all this stuff. Thanks again.
roland6465 is online now
post #14492 of 17705 Old 05-16-2018, 02:23 PM
Quoted: 68 Post(s)
upscaler settings
I am running a xbox one s and there is an atv on the way thru a Denon AVRX4300H. Can someone please recommend what device I should use to do the up-scaling? The source? the AVR? or the 5040ub?
Keith Ferguson is offline
post #14493 of 17705 Old 05-16-2018, 02:44 PM
roland6465's Avatar
Quoted: 395 Post(s)
Liked: 401
Well, my in-laws had a roku stick+ they hated, and I can’t get HDR from Prime, Netflix, or YouTube. It checks my cable and “approves” UHD/HDR/30, but won’t do 24?
What I want is something that will play Prime in 4K HDR, with DD+. Is that too much to ask?
biga6761 likes this.
post #14494 of 17705 Old 05-16-2018, 03:38 PM
Lithium's Avatar
Quoted: 63 Post(s)
Liked: 65
Without a linker to 'downgrade' a 60fps HDR signal to 8-bit you are probably not going to have much luck (and a lot of annoying handshaking) with streaming devices as most apps are not optimized to send the proper 24fps, 12-bit signal the Epson requires.
If you are looking for an all-in-one solution, the best option in my opinion is the Samsung UBD-K8500. It will stream Netflix and Amazon HDR 24fps @ 12-bit. Youtube, not as well. My old post with player settings can be found: here.
Lithium is offline
post #14495 of 17705 Old 05-16-2018, 05:06 PM
Quoted: 222 Post(s)
Liked: 202
Wouldn't the AppleTV4K be able to do that easily? I know it can for iTunes movies and for Netflix, but I haven't tried to watch HDR on Amazon Prime as there isn't any of that content in my country (I'm not in the US).
Equipment: Epson 9300W projector, Panasonic UB-424, AppleTV4K, Procella Audio Speakers...
Uppsalaing is offline
post #14496 of 17705 Old 05-16-2018, 05:55 PM
roland6465's Avatar
Quoted: 395 Post(s)
Liked: 401
Yes, it does perfectly. Unfortunately, the Prime app is hit or miss with 5.1+ audio. If I'm getting 4K HDR, I want more than 2.0 audio. What I don't understand is why I can supposedly get HDR at 30Hz, but not 24 with the stick+.
Uppsalaing likes this.
post #14497 of 17705 Old 05-16-2018, 06:00 PM
roland6465's Avatar
Quoted: 395 Post(s)
Liked: 401
Ugh. That's what I was afraid of. All I can hope is that Apple buys Amazon and the ATV app is finally fixed. The wife will absolutely not go for another attempt. And I hate that, because other than no Atmos (which I don't have yet) and the crap that is the Prime app, the ATV is about perfect.
post #14498 of 17705 Old 05-17-2018, 05:13 PM
marco1975's Avatar
Quoted: 306 Post(s)
Liked: 235
have just noticed there is a new firmware update (V1.12) that came out 20-april. what are included in this update fixes etc.?...iam hoping that they have found a fix for the high speed fan noise at the start up .
marco1975 is offline
post #14499 of 17705 Old 05-18-2018, 08:31 AM
Mr.G's Avatar
Quoted: 1268 Post(s)
Liked: 1375
The V1.12 firmware was first mentioned in this thread on April 25, 2018. People who have installed this firmware have not noticed any substantial change.
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is online now
post #14500 of 17705 Old 05-18-2018, 08:36 AM
Quoted: 364 Post(s)
Liked: 251
V12 came preloaded on my most recent warranty replacement and it must be a background stability update or label changes as I’ve noticed nothing different.
OrcusVaruna is offline
post #14501 of 17705 Old 05-18-2018, 08:46 AM
Quoted: 68 Post(s)
Any help?
What no love? I did hours of research on multiple sites and threads. I have been doing my own testing with inconsistent findings, need to start over with a better variable control and documentation (didn't think it would be this involved).
A few notes of what I am seeing so far:
Xbox one s - I get different results with disc vs. streaming services letting either the projector or the xbox doing the up-scaling. I just noticed last night that there is a lip-sync issue starting to show up when I switch between devices handling the up-scaling.
ATV should be here soon
Haven't tried letting the AVR do any up-scaling yet (controlling variables for now)
post #14502 of 17705 Old 05-18-2018, 10:20 AM
avtoronto's Avatar
Quoted: 139 Post(s)
Liked: 56
See post 14374.
old corps and Uppsalaing like this.
avtoronto is offline
post #14503 of 17705 Old 05-18-2018, 11:25 AM
Quoted: 26 Post(s)
Lamp or power supply?
Second post for me, in forums 5040ub lamp went out, only 1K hours on low.
Solid orange for lamp and Epson said to call back if replacement bulb doesn't fix. Took lamp out and reseated per her instructions, then they give me the "call us back if it doesn't fix it" message. Bulb looked a little discolored and didn't use a magnifying glass to look at filament. Any users have the same, only to find out it was a power supply?
Thanks in advance!
misterg51 is offline
post #14504 of 17705 Old 05-18-2018, 12:08 PM
Quoted: 364 Post(s)
Liked: 251
I find the epsons upscale capabilities to be horrendous. It introduces so much noise to the image of whatever content you are playing. I find I get a much better image when I use both the atv and Xbox one x to up resolution to 4K and then range match for applicable content.
Keith Ferguson likes this.
post #14505 of 17705 Old 05-18-2018, 01:18 PM
roland6465's Avatar
Quoted: 395 Post(s)
Liked: 401
L-O-everloving-L!
6040 #5 threw up a dead pixel today. This was a new-in-box replacement with 84 hours on it. I've got them working on another new unit, hopefully shipping today. I'm waiting on a call back.
20 years ago I would have driven to Indiana by now to raise hell, but at this point in my life and this ongoing issue, I'm just amused.
post #14506 of 17705 Old 05-18-2018, 01:26 PM
Quoted: 68 Post(s)
[QUOTE=OrcusVaruna;56208352]I find the epsons upscale capabilities to be horrendous. It introduces so much noise to the image of whatever content you are playing. I find I get a much better image when I use both the atv and Xbox one x to up resolution to 4K and then range match for applicable content.
So do you leave the pj 4k enhancement off for everything, all sources? If I run a roku 3 (no up-scaling) would I then let the AVR do the work or go to the pj?
post #14507 of 17705 Old 05-18-2018, 01:47 PM
Quoted: 222 Post(s)
Liked: 202
L-O-everloving-L!
They should give you the new model Epson whenever it comes out... Just for the sake of all the trouble you've had to go through...
WynsWrld98 and old corps like this.
post #14508 of 17705 Old 05-18-2018, 02:57 PM
Quoted: 364 Post(s)
Liked: 251
[quote=Keith Ferguson;56208788]
Yes I leave 4K enhancement off with 1080p sources like my ps4 non pro. The eshift capability (when the projector is fed a 4K signal from he source) on the other hand is outstanding even when fed an upscaled 4K signal like YouTube tv. It sharpens the image without the noise of 4K enhancement.
post #14509 of 17705 Old 05-18-2018, 03:14 PM
roland6465's Avatar
Quoted: 395 Post(s)
Liked: 401
L-O-everloving-L!
Yeah, right. When the last one’s power supply died, I talked my way up the chain and was offered 75% of my purchase price as a one time offer. Didn’t have an extra 2 grand for a JVC or Sony, so here I am awaiting #6 on Monday or Tuesday.
post #14510 of 17705 Old 05-18-2018, 03:28 PM
gibsonm21's Avatar
Quoted: 13 Post(s)
Thanks in advance!
Yup. Mine had a solid orange lamp light & flashing blue status light. My bulb was fine. Epson sent me the new bulb but I swapped the unit out under my BB protection plan.
gibsonm21 is offline
post #14511 of 17705 Old 05-18-2018, 03:49 PM
Quoted: 26 Post(s)
So, the new bulb didn't fix it, and it was the power supply? Thanks!
Marantz AV7004 Oppo UDP 205 B&K 200.7 S2 Marantz MM7055 M&K S-150THX 7.2.4 w/350 &100 subs Furman IT-REF 15I XBOX-OneX Apple 4K TV Sony PS4 Samsung 4K 65" Epson 5050UB Apple HomePod (4) Harmony Elite Amazon Alexa Xfinity X1 4K Audioquest wire A-Z (there is a difference) Spectracal CalMAN Home Enthusiast X-rite i1 Photo Pro 2
post #14512 of 17705 Old 05-18-2018, 05:28 PM
Quoted: 26 Post(s)
Those with power supply failures, after putting in new bulb, solid orange lamp, and blinking status? The other light on mine does not come on, so I'm wondering.
post #14513 of 17705 Old 05-19-2018, 05:35 PM
BlueTip's Avatar
Another dead 5040ub power supply :-(
The power supply appears to be dead on my replacement 5040ub after only five months with less than 200 hours on the bulb.
@roland6465 I can't imagine going through five replacements :-O.
I will be calling Epson on Monday, but as a loyal Epson customer, I feel a bit let down to say the least!
BlueTip is offline
post #14514 of 17705 Old 05-20-2018, 05:07 AM
marco1975's Avatar
Quoted: 306 Post(s)
Liked: 235
With all the firmware update that has been released since, i just can't beleive it that epson havn't fix the High Noisy fan speed and black screen at the start up issue yet...
post #14515 of 17705 Old 05-20-2018, 05:48 AM
Quoted: 364 Post(s)
Liked: 251
I don’t believe that’s a firmware issue it’s a symptom of a power supply that’s about to kick the bucket. Both of my previous power supply failures presented with this issue before dying.
post #14516 of 17705 Old 05-20-2018, 05:53 AM
Quoted: 364 Post(s)
Liked: 251
I feel like we should all start asking for upgrade discounts when we call in for our replacements. If enough of us ask for it maybe they will give us a reduced entry price when the new model is finally released (50% off maybe? ). It’s worth a shot at least, especially since they finally acknowledged that it’s a known problem during my last warranty replacement call in late March.
old corps likes this.
post #14517 of 17705 Old 05-20-2018, 08:34 AM
marco1975's Avatar
Quoted: 306 Post(s)
Liked: 235
Not necessarily, as there are lot of unit exhibit this symptom without any sign of power supply failure, i have had mine for allmost a year now and it had the issue from day one, apart of the issue bing annoying, the projector is working like champ.
bluer101 likes this.
post #14518 of 17705 Old 05-20-2018, 08:34 AM
marco1975's Avatar
Quoted: 306 Post(s)
Liked: 235
post #14519 of 17705 Old 05-20-2018, 08:36 AM
marco1975's Avatar
Quoted: 306 Post(s)
Liked: 235
Not necessarily, there are lot of unit in this thread exhibit this symptom without any sign of power supply failure, i have had mine for allmost a year now and it exhibit the issue from day one, apart of the issue bing annoying, the projector is working like champ.
post #14520 of 17705 Old 05-20-2018, 10:16 AM
roland6465's Avatar
Quoted: 395 Post(s)
Liked: 401
It's been random with the ones I've had. #1 did it from day 1-power supply died. #2 didn't do it once in the 2 weeks I had it- dust blob. #4 didn't do it for months, then did for about 5-6 startups- power supply. #5 did it once in 84 hours, and I was afraid I was in for a power failure, but- dead pixel.
5040ub power , atmos
