Official Epson 5040ub/6040ub owners thread - Page 56 - AVS Forum | Home Theater Discussions And Reviews
 26901Likes
post #1651 of 17705 Old 10-10-2016, 04:56 PM
Alad's Avatar
[quote=ricjor1;47373633]
Originally Posted by Alad View Post
I've been going back and forth about going from my 5030ub to the 5040ub, because I haven't had an opportunity to compare the two side by side. My friend recently had an opportunity to compare the two and advised me not to make the change...he said there is a difference, but not significant enough to change. In addition, I don't have any 4K sources.
Well all I can say is that at 106" screen and 11 feet viewing distance, the 5040ub and its pixel shifting completely blew my mind and how much better it looked than my beloved 5030ub. My opinion. I then went out and got an Xbox one s for a little 4k source. LOVE IT!
Alad is offline
post #1652 of 17705 Old 10-10-2016, 05:00 PM
k3nnis's Avatar
Quoted: 642 Post(s)
Liked: 60
With the Xbox one S what 4K mode can you run it at with the Epson? 30hz 4:2:0. 10bit?
k3nnis is offline
post #1653 of 17705 Old 10-10-2016, 05:02 PM
Alad's Avatar
My question is:
What is the difference between Cinema and Digital Cinema? And should I be using one over the other?
5040Ube
Marantz Sr5011
Xbox One S (got this just for the 4k/UHD stuff)
PS4
Apple TV
Any one have a clue about this ^^ ??
Also, is it possible to "force" HDR?? When playing a 4k HDR bluray on my Xbox One S, I switched the color space setting on the 5040ub to BT.2020 and it made the colors pop. Am I just screwing with it and faking an "improvement"????
Alad is offline
post #1654 of 17705 Old 10-10-2016, 05:50 PM
gnolivos's Avatar
Quoted: 372 Post(s)
Liked: 292
Both of those modes use the color filter in the light path. I believe no other mode uses it. Don't know the differences though.
I don't think you should be changing the color space settings. They need to match the source, as does Auto mode. I tried what you are saying once, noticed the pop but it looked really unnatural with blown out bright areas and crushed darks. It's not a good look.
Setup: Epson 5040 UB, 110" SilverTicket AT screen, PS3 bluray, Yamaha RX-V673 AVR, Polk and Athena speakers, Batcave room.
The Moderno Theatre! Slideshow (here!)
Pixar screenplay slideshows here!
gnolivos is offline
post #1655 of 17705 Old 10-10-2016, 05:52 PM
rupedogg24's Avatar
Quoted: 143 Post(s)
Liked: 145
Originally Posted by k3nnis View Post
Can you run it at 10bit 4:2:0?
Not from what I can see. Maybe someone has had success on another streamer/player.
Projector: Epson 5040ub DIY 140" Acoustic Screen
AVR: Onkyo RZ1100 (Main)
Blu-ray: PS4 -- Panasonic UB900
Speakers: 5.2.4 Atmos Sound System
Subwoofers: Dual Marty Cubes w/SI 18" - DIY Build w/SI 15"
rupedogg24 is offline
post #1656 of 17705 Old 10-10-2016, 05:53 PM
k3nnis's Avatar
Quoted: 642 Post(s)
Liked: 60
ok thanks
k3nnis is offline
post #1657 of 17705 Old 10-10-2016, 06:42 PM
Josuah's Avatar
Quoted: 41 Post(s)
Liked: 38
Originally Posted by c.kingsley View Post
Which is odd because the original XB1 does 24Hz output on blu ray.
I think the Xbox One S will switch to 4Kp24 for a 4K Blu-ray, but the problem is it won't get that far unless your display first does 4Kp60 10-bit?
Looks like it's an issue with the Netflix app. Here is Man In The High Castle running in UHD HDR on the Amazon App.
Doesn't look like that is really HDR since it says 8-bit. But it is engaging BT.2020 HDR2 mode on the projector.
I think you can run 4Kp60 8-bit RGB. But you won't get BT.2020 or HDR from a 4K Blu-ray or 4K streaming services if I remember correctly.
Kelvin1000 likes this.
Josuah is offline
post #1658 of 17705 Old 10-10-2016, 08:35 PM
ac388's Avatar
Quoted: 192 Post(s)
Liked: 49
Originally Posted by Mike Garrett View Post
I think this will be a daunting task to get everything back together and working perfectly. Also I am pretty sure that it will void your warranty. Imagine telling your car dealer that you took your new car completely apart and now, after putting it back together it has a problem. Do you think your dealer will fix it under warranty?
Agreed. But wonder why people entertain this idea, it's not as easy as changing your phone case !!!
Man see things as they are n say why. I dream of things that never were, n say why not ....... A Perfect PROJECTOR
ac388 is offline
post #1659 of 17705 Old 10-10-2016, 08:42 PM
ac388's Avatar
Quoted: 192 Post(s)
Liked: 49
So you think Epson is faking it ! I thought HDR is like Dolby Atmos that one cannot implement it, but can only get it if the files are encoded with it. Right ???
ac388 is offline
post #1660 of 17705 Old 10-11-2016, 03:27 AM
Quoted: 28 Post(s)
I have read all of both threads and the review links as well as the manual and am concerned about the 24p motion playback. Is there a 4:4 pulldown option in the menu like on my old epson to reduce judder on panning for 24p material ?
rogermoore123 is offline
post #1661 of 17705 Old 10-11-2016, 04:20 AM
gnolivos's Avatar
Quoted: 372 Post(s)
Liked: 292
No there isn't. Epson however has confirmed it does a 10:10 pull down on 24p content. (240hz)
gnolivos is offline
post #1662 of 17705 Old 10-11-2016, 04:58 AM
Quoted: 28 Post(s)
Even better ! That should make for some smooth playback. The people with motion problems with FI turned off must just have incorrect settings somewhere.
Thanks for the quick reply -time to let the moths out of the wallet.
post #1663 of 17705 Old 10-11-2016, 05:10 AM
zombie10k's Avatar
Quoted: 5238 Post(s)
Liked: 5493
hi, you're not alone with the issue you reported with 24p playback. I wonder if there are certain batches affected if everyone isn't seeing the same thing.
Originally Posted by RickAVManiac View Post
I put some hours on the 5040 this weekend and I can say that there something wrong with the 24fps motion on this projector. I read about that in another thread and can confirm the issue is real. When send a 24fps signal (any movie), the motion look like 15 fps. (eshift on or off). Seem also related to image quality. Some 720p sources look like crap, Older 1080p sources look bad, new 1080p source look barely ok and 4k seem just ok. I try to play with all setting but nothing seem to change that. The 60fps signal seem to look ok.
zombie10k is online now
post #1664 of 17705 Old 10-11-2016, 05:39 AM
Liked: 1
Originally Posted by Viche View Post
Still wondering....what are the Samsung and Xbox One sending now that you are using the correct HDMI port? Before you had said that both were sending 1080p / 4:4:4 / 8 or 10-bit / Rec 709...
Viche,
I haven't forgotten you. I am traveling and won't have ability to confirm things for you until the weekend.
Bman.
BmanAVS is offline
post #1665 of 17705 Old 10-11-2016, 05:43 AM
wbcollegekid's Avatar
Quoted: 35 Post(s)
Liked: 30
Streaming with HDR
I think in order to get HDR via streaming, the streaming content will need to be sent from the player at 24p. Netflix needs to better partner with streaming devices to implement this option. Hopefully the new google device will allow for Netflix content at 24p rather than 60p.
ndabunka likes this.
Epson Home Cinema 5040, Yamaha Aventage 3050, Phillips BDP-7501, PlayStation 4, Energy Connoisseur Series 7.1.
wbcollegekid is offline
post #1666 of 17705 Old 10-11-2016, 05:44 AM
bontrager's Avatar
Quoted: 117 Post(s)
Liked: 74
Performed update procedure today. It was a breeze. Love owning a product I can update myself. My old projector didn't allow that. Had to be sent in. Ugh.
Please share how you did this. I went thru the whole menu including the network tab and didn't see anything about an "update" choice.
thank you
bontrager is offline
post #1667 of 17705 Old 10-11-2016, 05:46 AM
bontrager's Avatar
Quoted: 117 Post(s)
Liked: 74
Originally Posted by BmanAVS View Post
Viche,
Bman.
Last week an Epson tech told me that the One S and the Samsung would not work.
Maybe something has changed
post #1668 of 17705 Old 10-11-2016, 05:50 AM
mase1981's Avatar
Quoted: 148 Post(s)
Liked: 80
thank you
you need to download the update, format a USB drive to either FAT or FAT32
move the downloaded file to the USB
take out ur projector power cable
plug in the USB
click the power button and then re attach the power cable
u will see the 3 status lights go on, keep pressing. when they are solid after about 7 seconds release, they will start flashing meaning the update is being written to the device
the projector will turn itself off, when it does take out the usb and power it back on
done.
mase1981 is offline
post #1669 of 17705 Old 10-11-2016, 06:09 AM
gnolivos's Avatar
Quoted: 372 Post(s)
Liked: 292
Hi zombie. Wow that is EXACTLY how I describe the issue myself. Where was this posted? Thanks!!
gnolivos is offline
post #1670 of 17705 Old 10-11-2016, 06:40 AM
chiltonj's Avatar
Quoted: 54 Post(s)
Liked: 47
Don't the 6040 and the 5040 have the same specs?
Per projectorcentral.com, other than being black vs white, the 6040 has the same features as the 5040 with the following extras:
ISF Certification
3 year warranty (vs 2)
Ceiling mount, cable cover
Extra lamp
Available via CEDIA and specialty dealers only
Also noted on the site is that compared to the 5030/6030, the xx40 models are new from the ground up.
http://www.projectorcentral.com/proj...e&entry_id=712
Sent from my SM-G930V using Tapatalk
chiltonj is offline
post #1671 of 17705 Old 10-11-2016, 07:01 AM
bontrager's Avatar
Quoted: 117 Post(s)
Liked: 74
plug in the USB
done.
Keep pressing the power button?????
Thank you!!!!!!!!!
post #1672 of 17705 Old 10-11-2016, 07:10 AM
dvdwilly3's Avatar
Quoted: 516 Post(s)
Liked: 317
ISF Certification
Extra lamp
There is one statement that is wrong here, and I have seen it stated repeatedly...
The 6040UB does NOT include ISF certification.
What is DOES include is..."Exceptional video performance — includes ISF®-certified calibration tools and lockable memory modes to ensure accurate performance"
This quotation is from the 6040UB specifications on the Epson website.
Including the necessary tools for calibration and being calibrated are two different things.
If I am incorrect, I would be more than happy to have someone correct me.
https://www.avsforum.com/forum/68-di...-profiles.html
Atmos Dolby 7.2.4; Epson 6040UB; Panasonic UB820; TiVo Roamio; Roku Stick+
dvdwilly3 is offline
post #1673 of 17705 Old 10-11-2016, 07:11 AM
MUTTS's Avatar
Quoted: 44 Post(s)
Liked: 38
Good morning. Close to pulling the trigger on the 6040 for sports/movies/gaming.
Wondering how you think the image would look from 11.5 feet front row, 18 feet second row on a 153 diagonal 2.35:1 (123 inch diag for 16:9tv).
MUTTS is offline
post #1674 of 17705 Old 10-11-2016, 07:14 AM
DanGraney's Avatar
Quoted: 54 Post(s)
Liked: 32
Sent from my SAMSUNG-SM-N930A using Tapatalk
Hmmm, I didn't seem to get HDR out of Man In The High Castle... I only checked the first episode, however. Running the new Roku Premiere + through a Pioneer SC-97. I'll have to play with my settings, methinks.
rupedogg24 likes this.
DanGraney is offline
post #1675 of 17705 Old 10-11-2016, 07:27 AM
chiltonj's Avatar
Quoted: 54 Post(s)
Liked: 47
Also on Epson's site "...meets the ISF Certification standard". You do understand that being ISF compliant is a) having those calibration tools available within the projector (TV) and b) the training for professional engineers/calibrators. Being able to professionally calibrate to your specific environment means ISF certified. Not being professionally calibrated to your environment just means well, you may not be taking advantage of delivering the most accurate picture quality that is possible which a ISF certified projector can enable.
chiltonj is offline
post #1676 of 17705 Old 10-11-2016, 07:31 AM
Nexgen76's Avatar
Quoted: 732 Post(s)
Liked: 218
You are correct this is what Epson to me at CEDIA.
JVC NX5 Panasonic UB820 PC Madvr
Sliver Ticket 120' Cinema white screen
Aggressive 1299 L/C/R/, Volt 10XL x 2 surround, MKII Atmos Modules x 4(Jav's build)
Pioneer Elite SC-LX801 Acurus A125x5
Ported Primate SI 18" HST subs x 2(DIY) V.B.S.S.x 4(MBM)
Nexgen76 is online now
post #1677 of 17705 Old 10-11-2016, 07:32 AM
WestCDA's Avatar
Quoted: 68 Post(s)
Liked: 79
ISF Certification
Extra lamp
The 6040 also includes image stretch modes for support of anamorphic lenses and widescreen projection, same as the 6030. Those modes are not available on the 5040.
gnolivos and chiltonj like this.
WestCDA is offline
post #1678 of 17705 Old 10-11-2016, 07:55 AM
dvdwilly3's Avatar
Quoted: 516 Post(s)
Liked: 317
My point being that OOB the 6040UB is not ISF calibrated...
As I said previously, the 6040UB is certified as having the tools to be calibrated, but it is NOT OOB calibrated...
That will affect the value proposition for some people. It is not a bad thing...they simply need to be aware of the difference.
post #1679 of 17705 Old 10-11-2016, 08:04 AM
chiltonj's Avatar
Quoted: 54 Post(s)
Liked: 47
Can't be calibrated because again, it's per your environment (lighting, room layout, screen, etc).
Sorry, I guess it could be calibrated OOB to match a certain generic layout with factory presets but that wouldn't do any good.
I think having the ability to professionally configure the projector to truly match my environment is the value proposition.
chiltonj is offline
post #1680 of 17705 Old 10-11-2016, 08:12 AM
dvdwilly3's Avatar
Quoted: 516 Post(s)
Liked: 317
I understand that it could not realistically come OOB calibrated.
But, I have seen countless posts sayiyng that it comes with ISF calibration. It does not.
I agree with you 100% re value proposition...
5040ub power , atmos
