Official Epson 5040ub/6040ub owners thread - Page 562 - AVS Forum | Home Theater Discussions And Reviews
 26951Likes
post #16831 of 18082 Old 02-05-2019, 04:32 PM
AdamAttewell's Avatar
Quoted: 751 Post(s)
Liked: 160
Originally Posted by Dirt9 View Post
I'm running a 2.35 113" AT screen.I had the projector mounted at 14' from the screen and was on the upper end of the zoom,its been a year and the picture has been looking great or so I thought!
I just moved it back to 18' and am at the lower end of the zoom now.holy cow the image is ten times better!!!
It looks brighter with way more contrast and much sharper.Just thought i would share this for those that have not mounted theirs yet.
No offence but some placebo is at play here.
The further you move any projector from the screen you will lose Fl/nits because the light has further to travel.
old corps likes this.
AdamAttewell is online now
post #16832 of 18082 Old 02-05-2019, 04:32 PM
Dave Harper's Avatar
Quoted: 3159 Post(s)
Liked: 1723
Here's something to try for HDR.COLOR MODE CINEMA,AUTO BRIGHT,BT2020 HDMI NORMAL.
BRIGHTNESS 97,CONTRAST 0,COLOR SATURATION 60,TINT 100,SHARPNESS 555
COLOR TEMP 5,SKIN TONE 3,COLOR TEMP CUSTOM 49 49 49 35 50 50
POWER CONSUMPTION HIGH,AUTO IRIS NORMAL,GAMA 0 -32 -14 -14 -14 -14 -15 +22 +32
RGB (R) 32 79 50 (G )48 93 50 (B) 47 73 50 (C) 25 87 50 (M) 43 87 50 (Y) 22 83 50
IRIS 0,SUPER WHITE OFF,
This is a combo of settings that have already been posted by others,try it out
idk but it seems like something is amiss and you’re looking for trouble with brightness at 97 and contrast at 0. Washout city!!!
Originally Posted by Tweakophyte View Post
The gamma settings don't call out their standard (i.e. show +1, 0, -1 vs 2.2, 2.4). Does anyone know the conversion?
By the way, I played around with the original and orcus mod of the HV settings last nigh and found them very dark compared to an unmodified setting. This was when feeding them the SDR/BT.2020 signal. I did not play with turning on HDR. If I am reading correctly, you are saying your settings * require * an HDR signal and may need some tweaking with the optimizer, correct? Are you also suggesting the have the player map at 1000 nits versus the projector mode of 300nits?
From here I want to understand that if I want to use SDR/BT.2020 I should stick to a more conventional set-up with the standard gamma? Either here or on the Panny820 thread several were saying the SDR/BT.2020 was a better way to go for a projector, since a PJ has limited light output. I forget if you opined on that.
Sorry I didn't buy this last year so your thoughts would have been fresher. :-) Sorry if this is a rehash of everything you've been saying. My goal is to limit the number of settings I need in various scenarios of 4K, 1080p, Netflix, Amazon coming out of the player, and a few TV modes.
Thanks again!
Yes, again.....you MUST input a full HDR signal (NOT SDR!!!) for my settings to resemble anything decent!
I believe when you’re in HDR/BT2020 mode and turn on the HDR Optimizer on the UB820, The display type settings aren’t activated if I recall, so this way it bases its tone mapping on a 1,000 nit display.
If you want to use SDR BT2020 from the UB820 then DO NOT use my settings and gamma! Use a standard SDR mode like you would any other SDR source like regular Blu-ray and HD, but select the Cinema or Digital Cinema Modes on the 5040 so the BT2020/DCI-P3 Filter rolls into place to get BT2020 color mapping.
Dave Harper is offline
post #16833 of 18082 Old 02-05-2019, 04:41 PM
Quoted: 36 Post(s)
I know it sounds way off but with the second gamma point at -32 the brightness at 97 counters and really drives the whites without any wash out.setting the contrast at 0-10 bring the white detail back in,
Dirt9 is offline
post #16834 of 18082 Old 02-05-2019, 04:45 PM
Quoted: 36 Post(s)
That's what I originally thought also,if you zoom all the way in on your screen and re focus the image will not be as bright try it
Dirt9 is offline
post #16835 of 18082 Old 02-05-2019, 04:50 PM
Quoted: 36 Post(s)
Im a noob here but there is something to this weather it be the sweat spot of the lens or a more focust light beam?
Dirt9 is offline
post #16836 of 18082 Old 02-05-2019, 04:54 PM
avtoronto's Avatar
Quoted: 156 Post(s)
Liked: 58
I'll admit I am not on firm ground on this, but my understanding is if the player outputs an HDR/BT2020 signal, it always tone maps. If you select the 1,000 nit setting, that's what it will tone map to based on the information on the UHD disc. If you select SDR/BT2020, it ignores the nit setting completely and it does not tone map at all. This is why the advocates of the SDR/BT2020 approach state that only the display device does the tone mapping, so it is only being done once.
I am perfectly willing to be corrected on this, but based on what I've read here and on the 820 thread, this is what I've learnt.
Elunevision 4K 112" Audioweave motorized screen, Epson Pro Cinema 4040 projector, Emotiva XPA-5 amplifier, Denon AVR X4400h receiver, XTZ M6 LCR, XTZ S5 surround, XTZ 1X12 and Definitive Technology Powerfield subwoofers, RSL C34E Atmos speakers, Apple TV 4K, Panasonic DP-UB820
avtoronto is offline
post #16837 of 18082 Old 02-05-2019, 04:55 PM
Quoted: 36 Post(s)
I have no experience calibrating and those settings are not,but this really does work lol
Dirt9 is offline
post #16838 of 18082 Old 02-05-2019, 05:18 PM
Liked: 1723
Ohhhhhhh Kaaaaayyyyyy then. If you think that’s giving an optimal picture then. I can’t see how something isn’t getting totally messed up in that scenario by flipping gamma and brightness around. That would really affect greyscale too by pushing up the cuts with a brightness that high.
I equate this to pushing the gas to 70 mph and hitting the brake at the same to to get you back down to 55 mph, when all you had to do was hit the gas enough to go 55 mph in the first place !
You could be right and I am confusing them myself. I haven’t tried the SDR/BT2020 setting for a while now. I always use HDR/BT2020 for HarperVision.
One thing I do know though is that it is doing tone mapping from HDR to SDR when you set it to SDR/BT2020. That’s kind of the whole point of it really. Like I do with HarperVision.
post #16839 of 18082 Old 02-05-2019, 05:21 PM
avtoronto's Avatar
Quoted: 156 Post(s)
Liked: 58
Yes, you must be correct on this. I didn't think it through.
post #16840 of 18082 Old 02-05-2019, 05:30 PM
Liked: 1723
Here is a good note from the Lumagen Radiance Pro manual that explains it pretty well:
OrcusVaruna likes this.
post #16841 of 18082 Old 02-05-2019, 05:36 PM
Quoted: 36 Post(s)
Just for fun,someone should try these and tell me im crazy!
Dirt9 is offline
post #16842 of 18082 Old 02-05-2019, 05:56 PM
Quoted: 4884 Post(s)
Liked: 1847
I don't have a UB820, but my understanding is the opposite. If you select SDR/BT2020, the player does all the tone mapping, and the display doesn't do any, it just applies gamma 2.2 or 2.4 to the video stream just like SDR, other than using BT2020 colour space instead of Rec709.
Lesmor likes this.
Dominic Chan is online now
post #16843 of 18082 Old 02-06-2019, 01:35 AM
Quoted: 242 Post(s)
Can someone who have tried firmware 1.13 tell me what that update was about? I can't see it on the swedish page though.
Skickat från min SM-G960F via Tapatalk
westbergjoakim is offline
post #16844 of 18082 Old 02-06-2019, 06:11 AM
Tweakophyte's Avatar
Quoted: 94 Post(s)
Liked: 49
Originally Posted by JumpDontThink View Post
I've read through this thread many times. Used many of the posted user settings. Experimented for 2 years with this PJ to get HDR looking good and never been truly content. But I think I've stumbled across something which looks good.
The main points
UB820
Colour output: SDR/BT2020
HDR Type: Basic Luminance LCD & Projector
HDR Optimiser: On
Dynamic range conversion: -6
Epson
Digital Cinema Mode
High Lamp
Auto iris
Super white on
Gamma -2
Then adjust brightness and contrast settings against some patterns for your environment.
Then I just simply copied my colour settings from my SDR calibration.
This is helpful. While I don't mind experimenting with all of the shared settings (and permutations thereof) I want a very basic setting to refer to. I'm still looking for a 4K calibration disk so I can do the basics. From there I'll be able to really tweak the settings.
Separately, I've updated my 820 and I think the HDR settings (that you get when you hit the HDR button) has changed.
Panny UB820, Denon X6300H in 6.1.4 mode, Epson 5040UB, SVS PCUltra paired with a MiniDSP HD and BEQ (of course!)
Working on making things blacker...
Tweakophyte is offline
post #16845 of 18082 Old 02-06-2019, 10:04 AM
Quoted: 31 Post(s)
Finally got around to adding some black to my HT.
It's given my 5040ub new life! I was doing it a serious disservice until now.
https://imgur.com/gallery/N9WE70k
ayrton, Lithium, welldun and 3 others like this.
rinse82 is offline
post #16846 of 18082 Old 02-06-2019, 10:35 AM
Liked: 0
5040UB initial Setup
Hi All,
I just picked up a 5040, and I need some assistance in getting the settings correct. I have attached pictures below showing my plasma and projector on at the same time. As you can see, the projector is not performing near as well, so I need to get it right.
also, the image on the projector is not near as crisp as I anticipated compared to the plasma.
I prefer dynamic, high lamp, since I mostly watch sports and TV shows, with occasional movies. I have a 4K HMDI cord, projector is 15 feet back from the white screen with 1.1gain.
If anyone can help me, it would be greatly appreciated.
ID:	2521146   Click image for larger version
ID:	2521148   Click image for larger version
ID:	2521150   Click image for larger version
SCHMIDTYBOOSH is offline
post #16847 of 18082 Old 02-06-2019, 11:37 AM
roland6465's Avatar
Quoted: 417 Post(s)
Liked: 412
Looks great! Darkening the room is probably the best bang-for-your-buck upgrade you can make for PQ.
It was several months after we moved into our new house that we were ready to setup the theater room, and I was working weekend breakfast/lunch shifts in a kitchen, and my awesome wife surprised me by painting 3 walls gray and the front wall and ceiling near-black one weekend. Love that girl!
ID:	2521210   Click image for larger version
ID:	2521214   Click image for larger version
rupedogg24 likes this.
roland6465 is online now
post #16848 of 18082 Old 02-06-2019, 11:54 AM
sddp's Avatar
Quoted: 316 Post(s)
Liked: 127
With light traveling at 186,000 miles per second and he moved it only 4' back:
1 mile is 5,280 feet
5,280 feet divided by 4 feet is 1,320 feet
If you take that 1,320 feet and calculate that a Starbucks Venti Latte now costs $5.35 (up 35 cents from just a few years ago and add the amount of feet you need to walk and stand in line at Starbucks M-F, that's $1.75 each week and that is an additional $91 a year.
I just wanted to shed some light on this matter
FYI: E=MC2
EPSON 5040UBE | DENON X6400H | XBOX ONE X\PS4 | EMOTIVA XPA-7 GEN 2 |EMOTIVA XPA-3 GEN 3 | ELITE SCREEN 150" ZEREO EDGE W/LED KIT
9.3.4 SURROUND SYSTEM ALL KLIPSCH | L&R RF-7II | CENTER RC64II |FRONT HEIGHTS 2 x RB-81II | 4 SURROUNDS RS-62II | 4 ATMOS CDT-5800 | SUBS R112SW & 2 x R115SW
VEFXI 3D-BEE DIAMOND (2D TO 3D CONVERTER) | DARBE VISION DVP-5000S | LOGITECH HARMONY 800
sddp is offline
post #16849 of 18082 Old 02-06-2019, 12:13 PM
avtoronto's Avatar
Quoted: 156 Post(s)
Liked: 58
Spears & Munsil is expected to release a UHD for HDR calibration next month, per an item coming out of this year's CES.
welldun likes this.
post #16850 of 18082 Old 02-06-2019, 12:25 PM
Quoted: 751 Post(s)
Liked: 160
FYI: E=MC2
Well the guys over at Projector central must have it all wrong then as if you use their calculator you get the following results:
113" 2.35 screen - 14' from the screen = 52fL
113" 2.35 screen - 18' from the screen = 45fL
7fL is 7fL under whichever light you look at it under.
sddp likes this.
post #16851 of 18082 Old 02-06-2019, 12:55 PM
pete ramberg's Avatar
Quoted: 31 Post(s)
Pretty sure the OP is confusing light propagation time with the inverse square law of light propagation.
Light travel time is totally irrelevant here. The inverse square law would be relevant, except that the zoom lens negates the inverse square law and is what causes the drop in light intensity.
That's why it is always better to have the PJ as close to the screen with as wide of a zoom angle as possible.
This is about optics, not light propagation!
pete ramberg is offline
post #16852 of 18082 Old 02-06-2019, 01:15 PM
Quoted: 36 Post(s)
Take a flash light like a original mag light that you can adjust the light beam and shine it at a wall.Adjust the beam as small as possible,keeping the flashlight in the same place now make the spot on the wall as large as possible,the perceived brightness is less.I would think the same principle would apply for a projectors light beam.
Dirt9 is offline
post #16853 of 18082 Old 02-06-2019, 01:22 PM
Quoted: 36 Post(s)
Take a flash light like a original mag light that you can adjust the light beam and shine it at a wall.Adjust the beam as small as possible,now make the spot on the wall as large as possible,the perceived brightness is less even though the amount of light hitting the wall would measure the same.I would think the same principle would apply for a projectors light beam.
Now take a riffle scope or a camera with zoom and zoom all the way in and take note of the image quality,while doing so you will notice the image quality is less the more you zoom because of the imperfections in the glass lens are magnified.I would think the same would apply to a projector lens while the 7fl of loss goes unnoticed.
Dirt9 is offline
post #16854 of 18082 Old 02-06-2019, 02:49 PM
Quoted: 31 Post(s)
Gang. Light intensity is inversely proportional to the square of the distance to the screen. But, the zoom lens completely negates this because you are adjusting the zoom to compensate for the distance/size of image.
Light intensity loss is due to the optics of the zoom lens, not light speed or propagation.
post #16855 of 18082 Old 02-06-2019, 02:50 PM
Quoted: 31 Post(s)
This is an example of the inverse square law of light intensity. But, it assumes that the light is not altered by a variable focal length lens.
If the projector has a fixed focal length lens, then moving the projector would invoke the inverse square law (like your flashlight example). A zoom lens negates it.
post #16856 of 18082 Old 02-06-2019, 03:22 PM
Quoted: 751 Post(s)
Liked: 160
Thanks Peter for all the info, I know I got it wrong about the speed of light but I am right in saying that moving the projector further from the screen will reduce the brightness of the image?
post #16857 of 18082 Old 02-06-2019, 03:36 PM
Quoted: 36 Post(s)
I agree that moving the projector back has less light output,what I was originally trying to say for me in my particular scenario is using the sweet spot of the lens has made the image have more contrast and a crisper picture while the 7fl loss goes unnoticed
Dirt9 is offline
post #16858 of 18082 Old 02-06-2019, 05:00 PM
Quoted: 31 Post(s)
Exactly. If you move the PJ back twice as far, then the light intensity is reduced by a factor of 4 (2 squared). But, a zoom lens would of course be used to re-size the image and make it the same size as before the move.
In any case, the more the zoom feature is used to re-size the image, the more light is lost.
Rule of thumb: place the PJ as close as you can to the screen and use as wide of a zoom as possible.
AdamAttewell likes this.
post #16859 of 18082 Old 02-06-2019, 07:43 PM
Quoted: 364 Post(s)
Liked: 251
I love that explanation, I have been trying to find an eloquent way to explain this concept of an SDR container for an HDR signal. Thank you
OrcusVaruna is offline
post #16860 of 18082 Old 02-07-2019, 10:05 AM
monkaquinas's Avatar
Quoted: 84 Post(s)
Liked: 40
Yes they’re for a full HDR signal being sent into the display. The reason you set the display to SDR in this case is to be able to manually tone map the signal to be brighter and more conducive to a lower nit display such as your typical Home Theater projector. This is pretty much what players like the Panasonic 820 (and Lumagen and MadVR) are now doing in the source device. It’s just a matter of where it’s done really.
For my BenQ LK970 I prefer it done at the projector, mainly because I have the control over what kind of look I want, and then the 820’s Optimizer maps it to the 1,000 or so nits I calibrated and “HarperVisioned” it to.
This Note from the Lumagen Radiance Pro manual sums it up nicely:
I have found that sending full HDR with the HDR Optimizer engaged on the UB820 into a BenQ LK970 with HarperVision mods to be the best solution and image by far over using SDR/BT2020 from the 820 into the LK970 in SDR mode with a 2.4 gamma.
As I said, I encourage all to try both though as I haven’t done this experiment on a 5040 to see which is better with this model.
To answer your other question, I thought you could get SDR/BT2020 with a 2.4 gamma by just selecting Digital Cinema mode which engages the P3 color filter, then you manually go into SDR mode and select 2.4 as the gamma? I swear that’s all I had to do when I had a 5040 here last time, but it’s been quite a while and my memory could be off.
I just setup Harpervision thanks to the pointer to using Oledurt CMS settings and all I have to say is what a revelation. I've only been in the 4K camp for about 7-9 months since I added the UB820 as my 4K source. I set the 820 to HDR out and SDR out and the HDR signal was dim and the colors dull, "washed out" as has been said before by others. I then reverted to SDR and the image was bright and the colors vibrant, everything popped. It did seem a little too red at Color Sat of 80 and dropped it to 75 and it looked right to my eyes. I do have the 820 set to Projector with the Optimizer off and the Dynamic slider at +10. I'd like to thank everyone here for their advice and thoughts and willingness to share with others. I'll try to post some pics, I spun Infinity War and then the new 4k Superman: The Movie since it's a movie I'm very familiar with. Going to see what this does with MI: Fallout, any other badly encoded movies I should spin?
Dave Harper likes this.
Epson5040UB - DragonFly DFM Tab 92HC High Contrast (.9 gain) 16:9 Screen - Denon AVRS740H - Klipsch Quintet V +
Klipsch KHC-6 In-Ceiling (Atmos 5.2.2) with Polk PSW110 Sub & Monoprice Premium Select 8" Sub (via iFinity Wireless Audio) - Panasonic UB820 - PS3
monkaquinas is offline
5040ub power , atmos
