Official Epson 5040ub/6040ub owners thread - Page 578 - AVS Forum | Home Theater Discussions And Reviews
 26885Likes
post #17311 of 17663 Old 04-30-2019, 03:04 AM
Liked: 1
Originally Posted by djmattyb View Post
Mine does that every once in a while too. Not every time though. I'm not sure what the projector is doing but it will blast the fan a full speed for up to a minute then the bulb comes on. Maybe it's trying to remove dust or something? I'm not really sure.
I apologize for the bad English
I own the European model TW9300 and sometimes I also have the fan problem on power up.
I put a thermometer near the vpr. I noticed that the problem occurs when the temperature near the vpr exceeds 25 C °.
It could be that the VPR starts the fan to lower the temperature inside it before turning on the lamp.
monkaquinas likes this.
Gabriello is offline
post #17312 of 17663 Old 04-30-2019, 12:40 PM
sddp's Avatar
Quoted: 308 Post(s)
Liked: 124
5040 on a 2.35:1 playing XBOX Star Wars Battlefront Ii
Anyone here using this projector on a 2.35:1 screen and play Star Wars Battlefront II on the XBOX?
wanted to know if you only get black bars on the sides?
and other annoying issues?
EPSON 5040UBE | DENON X6400H | XBOX ONE X\PS4 | EMOTIVA XPA-7 GEN 2 |EMOTIVA XPA-3 GEN 3 | ELITE SCREEN 150" ZEREO EDGE W/LED KIT
9.3.4 SURROUND SYSTEM ALL KLIPSCH | L&R RF-7II | CENTER RC64II |FRONT HEIGHTS 2 x RB-81II | 4 SURROUNDS RS-62II | 4 ATMOS CDT-5800 | SUBS R112SW & 2 x R115SW
VEFXI 3D-BEE DIAMOND (2D TO 3D CONVERTER) | DARBE VISION DVP-5000S | LOGITECH HARMONY 800
sddp is offline
post #17313 of 17663 Old 05-01-2019, 08:09 AM
mswoods1's Avatar
I just upgraded to an Epson 5040UB from a Panasonic AE8000U and the difference is astounding! I wasn't expecting much of a difference because the stats on the two projectors are mostly the same. I mainly upgraded for additional features of the Epson, but a few things I've noticed:
  • Color seems a lot better. Blacks appear blacker and colors more vibrant.
  • UHD content is so much better than HD content. I have a 140" 2.35:1 screen and HD content looks like standard def when blown up to that size. Now I only want to watch UHD content.
  • Upscaling of HD content is better than Panny
  • Fan noise is better. Not too much quieter, but the panny had a higher pitched fan noise which drove me crazy.
mswoods1 is offline
post #17314 of 17663 Old 05-01-2019, 08:54 AM
Deejay Freddy's Avatar
Quoted: 40 Post(s)
Liked: 25
I too came from a Panny AE8000U, I noticed the fan is much louder on the epson for me.
Archaea likes this.
7.2.4|Klipsch RP-280F|RC-64III|2 RP-402S SL/SR|2 RP-402S Backs|4 SVS Elevations ATMOS|2 Klipsch R-115SW|SANUS CFR2136 Rack|2 AC Infinity Cloudplate T2|Marantz SR7013|Emotiva XPA-7 GEN 3|Outlaw Model 5000|Panamax M-5300-PM|Monster HTS 3600|Epson 5040UB|Logitech Harmony ELITE|NVIDIA Shield PRO|Xbox One X|Sony PS4|HTPC I7 KODI|
Deejay Freddy is offline
post #17315 of 17663 Old 05-01-2019, 10:23 AM
evanft's Avatar
I just picked up a open box 5040ub. Does anyone have any settings using the Eco power mode? I'm in a completely light controlled room with a 100" screen, so I don't need the full output of high or medium.
evanft is offline
post #17316 of 17663 Old 05-01-2019, 10:55 AM
DavidinGA's Avatar
Quoted: 220 Post(s)
Liked: 75
Originally Posted by terminal33 View Post
I happen to take a couple of pics (Aquaman 4K disc) last night with the HDR Optimizer On and Off on the 820. These aren't the greatest pics or the best example, but it does show a difference, so hopefully it helps. With the Optimizer Off, the white was blown out. With it On, you can see detail in the white. (It is more noticeable in person, or course.)
Epson Settings
Super White: Off
Dynamic Range: Auto (Bright)
Panny Settings
Output: HDR2020
Dynamic Range Adjustment: 4
*The thing I found out was that I needed to have Super White Off in the Epson to show the effect of the HDR Optimizer. With...
- Super White On and HDR Optimizer On = less detail in white, similar to the 1st pic below
- Super White On and HDR Optimizer Off = detail did show in white, similar to the 2nd pic below
I may be wrong, but from what I read it seems that with Super White On, the Epson tries to prevent blown out whites. So with SW On, along with the Optimizer On, it does not produce as much detail in the whites because they're both trying to prevent blown out whites. I'll test some more tonight on that theory, but maybe others can too. Basically the HDR Optimizer worked better when Super White was set to Off in the Epson.
My next thing will be to have Super White Off and the Panny set to output SDR2020. I haven't tested that yet. (I did watch Aquaman and Bumblebee with the Panny outputting SDR2020, but I had Super White On for those movies.)
Viewing on my phone, it looks like hdr OFF looks way better.
Sent from my Pixel 2 XL using Tapatalk
Source: HTPC w/madVR, Video: Epson 4000, 150" 16:9, Audio: Onkyo RZ 830 avr, 5.1.4 Atmos setup. 5 speaker Energy C Series: L/R C300's, C C-C100, SR/SL C50's, 4 in-ceiling Micca R-8c. Subwoofer: MiniMarty um18 w/NX3000D.
DavidinGA is offline
post #17317 of 17663 Old 05-01-2019, 02:43 PM
Polish Hammer's Avatar
Quoted: 14 Post(s)
Originally Posted by sddp View Post
What issue did you hear about the 5040 nd the XBOX?
I had the XBOX One S on the 5040 and then got the XBOX ONE X when it came out and have no issues using it on the 5040UBE. I use it for gaming and movies
The other folks summed it up pretty well. What I'm trying to figure out is just how much of an issue it actually is for me. I don't really do much gaming at this point in my life. If/when I use the XBOX it is to stream Netflix or Amazon Prime Video, or to send something from my Plex server. I didn't know how much HDR content was used on Netflix or Amazon so didn't know if it would even impact me. We will occasionally watch BluRays on the XBOX as well, but not too often. Based on all that, do you folks think this issue is something I should be worried about?
To the person that mentioned the 5050UB, I just read a review on it. Sounds nice (and a little more future-proofed) but I have to figure out if a 50% jump in price is worth it at this time.
Polish Hammer is offline
post #17318 of 17663 Old 05-01-2019, 02:45 PM
Liked: 0
Question
[quote=imagic;57953720]Looking for home theater enthusiasts to join us in NYC on May 7... register if you can attend.
Hello all,
I am a lurker interested in purchasing my first projector. I've been trying to choose between the HT3550 and the Epson models (4010/5040/5050), with some other models popping up here and there, and at the moment I am leaning towards an Epson. I created an account to register for the above event as I am located in Brooklyn and would very much love to see the 5050 in action. Does anyone know when the invitations/confirmations will be sent out? If I am not selected to attend, I might just focus on picking up a secondhand 5040 on eBay in the next couple of days; there's one I've been keeping my eye on and I am mostly ready to pull the trigger. Thanks for any info you are able to provide!
doctorsamadams is offline
post #17319 of 17663 Old 05-01-2019, 10:33 PM
darkangelism's Avatar
Quoted: 125 Post(s)
Liked: 56
I think I need to replace the bulb soon, image is dimmer and at 3400 hours, prices seem all over the place, is their a preferred place?
darkangelism is offline
post #17320 of 17663 Old 05-01-2019, 10:45 PM
AdamAttewell's Avatar
Quoted: 646 Post(s)
Liked: 132
Got mine from Epson direct myself but I am in the UK.
AdamAttewell is offline
post #17321 of 17663 Old 05-02-2019, 05:59 AM
Quoted: 36 Post(s)
I just replaced mine about a month ago, ordered from B&H. They are an authorized Epson dealer and have OEM bulbs. The process is super easy. Picked up a couple of replacement air filters as well.
urcha is offline
post #17322 of 17663 Old 05-03-2019, 12:52 PM
Liked: 0
Originally Posted by Polish Hammer View Post
Hey everyone, I'm considering replacing my 13+ year old Panny PT-AE900u with the Epson 5040ub. Simply put right now I'll be running an Xbox One S and Xfinity cable through a Yamaha TSR 7850 into the projector. BluRay and PLEX media will be played through the Xbox, Netflix and Amazon Prime Video can run through the Xbox or the cable box. I've read about some issues with the Xbox and this particular projector, but I can't figure out if that just has to do with gaming or some other issue. Can you good folks help me understand the upside/downside to what I'm proposing here? Any suggestions? Any articles or things I should read to help me figure this out?
Thanks in advance!
I'm using an Xbox One S with this projector. The HDMI input is limited to 10Gbps, which limits the 4K signal. I'd go with the new 5050ub.
Darrell Money is offline
post #17323 of 17663 Old 05-06-2019, 09:08 PM
Willy212's Avatar
Quoted: 35 Post(s)
Liked: 45
can anyone recommend me some 3d glasses being sold on amazon?
under 60$ i'm thinking of trying out "Hi-SHOCK 3D Active Glasses Scarlet Heaven"
since it does have big lens most 3d glasses have small ones .
Willy212 is offline
post #17324 of 17663 Old 05-07-2019, 07:02 AM
tlogan6797's Avatar
Quoted: 155 Post(s)
Liked: 168
I bought the Epson branded glasses and they work great. Please post a review if you try these. They are about half the price if the Epsons, so it would be nice to find good glasses that are cheaper when it comes time to replace.
Willy212 likes this.
Tom Logan
Need motivation? Get LOGANED
tlogan6797 is offline
post #17325 of 17663 Old 05-07-2019, 08:24 AM
Mr.G's Avatar
Quoted: 1265 Post(s)
Liked: 1353
can anyone recommend me some 3d glasses being sold on amazon? Under 60$ i'm thinking of trying out "Hi-SHOCK 3D Active Glasses Scarlet Heaven" since it does have big lens most 3d glasses have small ones .
About your only option is to try a pair and if they work buy more. Unfortunately what has happened during the past year or two is that many 3D glasses manufacturers have dropped out of the market. I was able to purchase 5 pairs of ValueView 3D glasses in January 2018 but now it's a brand that's no longer marketed. A good part of the blame can be put on Hollywood and HDTV manufacturers dropping out of the 3D game.
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
post #17326 of 17663 Old 05-07-2019, 01:49 PM
PeterOrr's Avatar
Quoted: 32 Post(s)
Thumbs Up for Epson
Purchased 5040ub in March 2018. My bulb failed at 1402 hours, always set on eco mode= should last 3000+ hours. Called Epson and they agreed an early failure although bulb warranty is only 90 days. They shipped me a new bulb overnight at no cost.
My second Epson and will continue to purchase from this company!
Mr.G and old corps like this.
PeterOrr is offline
post #17327 of 17663 Old 05-07-2019, 03:16 PM
rfb6435's Avatar
Quoted: 203 Post(s)
Liked: 89
I use Samsung SSG-3100GB glasses which work great. They are usually available for $20 or less on ebay. I see a bunch of broken ones for repair so they do apparently break but I haven't had it happen yet and they are cheap enough to where it isn't a big concern (just buy a backup pair or two).
I tend to use these instead of the authentic epson glasses because I like the lack of the bottom frame. I also started wearing glasses last year and these tend to fit over my glasses better than the epson ones.
These use a CR2025 battery but I am able to squeeze in a CR2032 instead for extra capacity. I actually like that they use a normal battery especially when I have friends over because I don't have to worry about whether or not the 3rd/4th/5th pair of glasses are charged up or not.
I also have a pair of 3Active glasses which work well too but they are kind of big and clunky.
-Rich
tlogan6797 likes this.
Quad Marantz AVR 9.2.(4+2) Atmos/DTS:X using Dual sr7010's + Dual scAtmos nr1403's
Marantz MM8003 150W/ch Amplifier Driving (L/C/R/SL/SR/SBL/SBR)
HTD Speakers L3 Tower L/R, L3 Center, Dual 12" L3 Subs, L2 Tower SL/SR, L2 Bkshlf SBL/SBR, Flat Panel WL/WR, Angled 6.5" In Ceiling FH/RH, 8" In Ceiling TM
Epson 5040UB Faux-K/3D with 106" Multi-Format Screen.
rfb6435 is offline
post #17328 of 17663 Old 05-07-2019, 03:20 PM
rfb6435's Avatar
Quoted: 203 Post(s)
Liked: 89
Mine also just started doing this.... It seems like it adds a minute or more to the startup time before the lamp turns on.
Has anyone figured out what it is?
Perhaps I should check the dust filter?
-Rich
rfb6435 is offline
post #17329 of 17663 Old 05-07-2019, 06:43 PM
Quoted: 125 Post(s)
Liked: 56
-Rich
I think it is doing a full power on versus a suspend, for me it always happens after power outages.
post #17330 of 17663 Old 05-07-2019, 10:40 PM
filipp2442's Avatar
Quoted: 29 Post(s)
Anyone know if this mount will work with the 5040UB? This is my old mount on my Optima and I just ordered a 5040UB; https://www.monoprice.com/product?p_id=8801
filipp2442 is offline
post #17331 of 17663 Old 05-07-2019, 10:49 PM
Archaea's Avatar
Quoted: 3769 Post(s)
Liked: 3553
Yes you’ll get black bars on the sides when displaying 16x9 content on a 2.35:1 screen. There is no question there. That’s the way it works.
Archaea's 9.8.4 Home Theater Room
(13) JBL CBT 70j-1 | Denon x7200wa | Sherbourn PA 7-350 amplifier | (8) Ultimax 18" sealed subwoofers | (4) iNuke DSP 6000 amplifiers | (4) MB Quart 12" subwoofers mounted direct mounted to Berkline theater chairs BOSS style | Epson 5040UB Projector | Jamestown 144" acoustic transparent 2.35:1 screen w/ Seymour XD fabric
Archaea is online now
post #17332 of 17663 Old 05-07-2019, 10:51 PM
Archaea's Avatar
Liked: 3553
Same here
And coming from a Panasonic with 1700 hours the Epson 5040UB is a slight tick up. Not a massive improvement IMO.
post #17333 of 17663 Old 05-07-2019, 10:55 PM
Archaea's Avatar
Liked: 3553
That’s junk and no.
I’ve used that mount before. Never again.
Buy a Chief mount. You can get one on eBay for $70 ish. Well designed, solid, you could hang on the thing. Set screws to dial and lock in adjustment with precision on all three axis.
https://www.legrandav.com/search?tab...bc&brand=Chief
post #17334 of 17663 Old 05-07-2019, 11:04 PM
filipp2442's Avatar
Quoted: 29 Post(s)
That’s junk and no.
Ugh, I was really hoping to not have to make new holes/patch/etc since it'll be expensive for me to pay for someone to do that. Are there any Amazon mounts that are $50-$80 that are recommended? Would prefer to just get it with 2 day shipping.
post #17335 of 17663 Old 05-07-2019, 11:47 PM
Quoted: 182 Post(s)
Liked: 61
Can FI be activated on 24hz refresh rate on 24 (23.976) fps material?
Does it need a higher refresh rate than the fps of the material to be interpolated?
noob00224 is online now
post #17336 of 17663 Old 05-08-2019, 04:15 AM
roland6465's Avatar
Quoted: 392 Post(s)
Liked: 398
If you want to hang your $2000 projector with a $50 mount just for the shipping time, more power to ya. I liken it to someone with a $1000 iPhone who won't buy an Otterbox because they're $60. You get what you pay for.
roland6465 is offline
post #17337 of 17663 Old 05-08-2019, 06:49 AM
tlogan6797's Avatar
Quoted: 155 Post(s)
Liked: 168
-Rich
These really work with the Epson 5040? The Epson 5040 is RF and these are blue tooth. I thought they were different frequencies and incompatible. Maybe the RF is a hidden feature?
Tom Logan
post #17338 of 17663 Old 05-08-2019, 09:17 AM
Quoted: 182 Post(s)
Liked: 61
According to the manual the refresh rate needs to be set at 24hz.
How can it create extra frames if the source is also 24hz?
Does the projector in this mode increase the actual refresh rate?
post #17339 of 17663 Old 05-08-2019, 10:48 AM
Archaea's Avatar
Liked: 3553
Here’s what you want.
https://rover.ebay.com/rover/0/0/0?m...2F132832787032
I do not know the seller or have anything to gain by linking this. It’s just a simple eBay search and good price. MSRP is $300 on that mount and it’s worth MSRP. At $50ish it’s a no brainer.
post #17340 of 17663 Old 05-08-2019, 05:18 PM
filipp2442's Avatar
Quoted: 29 Post(s)
Made an offer of $25 to another seller for it and he took it so got the Chief CHF2500 for $25 + $20 shipping. I hope everything works out with the ceiling and the 5040 I ordered...
Archaea likes this.
5040ub power , atmos
