Official Epson 5040ub/6040ub owners thread - Page 582 - AVS Forum | Home Theater Discussions And Reviews
 26962Likes
post #17431 of 18188 Old 05-19-2019, 10:11 PM
Liquid$team's Avatar
Quoted: 224 Post(s)
Liked: 112
Originally Posted by GCS View Post
Yeah the PS issues are a deep concern obviously.
And your comments about getting the picture on the 5040 right are my other concern. I truly don't have hours on end to spend tweaking settings and changing things. I have too much going on in life to deal with that and I want to be able to sit down and enjoy my watching not go that isn't right let me fiddle with this and that etc. And of course the family wouldn't have a clue what the fuss would be about either.
I definitely do not want to deal with refurb roulette on the 5040 either. Just reading about how many people have had to swap theirs out is ridiculous. If I wanted to spend 5k+ I would look at Sony or JVC but that is not my budget range at all so its the 5050 (max budget), used 5040 or 4010 (which I have kind of ruled out as the 5040 seems a fair bit better) or I stick stick with my 4 year old Epson 3000 and do w/o.
For once I am being real stingy about spending money on my HT - crazy I know. Guess I need to hope someone puts the 5050 on sale would love one right at $2500 if possible. I missed the ones at $2799 which isn't tremendous but every little bit helps.
The 5050's are still for sale at $2799. You didn't miss it. Everybody has them at that price.
Liquid$team is offline
post #17432 of 18188 Old 05-19-2019, 10:20 PM
Zoltrix's Avatar
Quoted: 108 Post(s)
Originally Posted by john hunter View Post
Hi Zolt,
I got my 9300w about 3 months ago for about AUD 4k.
Knew the ones were imminent but on an 8ft wide CS screen the differences would be minimal and not worth the substantial price difference.
Been very happy with it.
Thanks for the info John. Are you playing a lot of 4k content on it ? And any HDR content?
Zoltrix is offline
post #17433 of 18188 Old 05-20-2019, 11:36 AM
Mr.G's Avatar
Quoted: 1339 Post(s)
Liked: 1801
Originally Posted by filipp2442 View Post
Finally got my 5040UB ceiling mounted about 19' away from the screen and unfortunately it seems to be short of the 150" of my screen, maybe gets to around 130-140" with there being distance on the top/bottom. Anyone have any ideas for me or a setting I could maybe change? Unfortunately can't mount it back any further.
Is this for a regular 16:9 screen or scope? For 150" (16:9) screen you are well within the throw range at 19 feet.
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
post #17434 of 18188 Old 05-20-2019, 05:32 PM
john hunter's Avatar
Quoted: 80 Post(s)
Liked: 25
Have been sitting on about a dozen 4k UHD's while trying to sort out my mount for my A lens but still having fun watching bits and pieces.
Great HDR using some of the settings in this thread.
Harpervision is a great start but Nielvm's UHR and SDR settings worked the best for me with a little adjustment.
Blue Planet looked superb.
john hunter is offline
post #17435 of 18188 Old 05-20-2019, 05:34 PM
xbladr's Avatar
Quoted: 149 Post(s)
Liked: 63
Where are nielvms settings? I'll give them a shot. They must be newer and not added to the document
Sent from my SM-N950U1 using Tapatalk
xbladr is offline
post #17436 of 18188 Old 05-20-2019, 05:41 PM
Liked: 0
Originally Posted by ComradeBrehznev View Post
I would like to request 5040ub owners to listen to recordings of my projector to help determine whether there is an issue. The Epson tech support claim it is 60Hz hum, but that is completely wrong. I hear a lower frequency noise that seems like it would be the fan bearings not the fan blades. It occurs with no input, it's not the 4K shifting noise some have mentioned. It is worse at low speed since there is less fan blade blowing noise. You may have to turn your volume high. Thanks.
This recording is the fan noise, followed by power off so you hear the lens close and then the fan noise slow down and stop. Does yours sound like that? It's loud enough to be bothersome.
dropbox.com/s/89aa3q6g39vvedf/Proj%20Noise%20Power%20Off.m4a?dl=0
Hello,
I have exactly the same issue.
Can some other people confirm this noise is NOT normal?
@ComradeBrehznev : did you manage to find a solution?
Thank you very much
wullon is offline
post #17437 of 18188 Old 05-20-2019, 07:43 PM
Quoted: 80 Post(s)
Liked: 25
If you look around pages 555 and 558 you'll find Niel's settings. He did two ,the second tightened the first and those worked better for me with the black level adjusted.
post #17438 of 18188 Old 05-20-2019, 08:00 PM
xbladr's Avatar
Quoted: 149 Post(s)
Liked: 63
Thx I'll take a look
xbladr is offline
post #17439 of 18188 Old 05-21-2019, 09:47 AM
filipp2442's Avatar
Quoted: 29 Post(s)
It should be 150" 16:9, I just measured it and its around 136x78 but at around 19 feet the projector doesn't use up the whole 78", it can fill the whole 136" but doesn't seem to stretch the image enough for up/down on the full 78".
filipp2442 is offline
post #17440 of 18188 Old 05-21-2019, 10:16 AM
Mr.G's Avatar
Liked: 1801
The Epson calculator lists a throw range of 14' 9.8" - 31' 0.9" for a 150" 16:9 screen.
At 19 feet the 5040UB accommodates a screen width of 13' 11.3" - 6' 8.2" and screen height of 7' 10.1" - 3' 9.1". A diagonal screen size from 191.9" - 92 ".
Is this a brand new projector or purchased used? If used, try resetting to factory specs - page 120 of the owner's manual.
Mr.G is offline
post #17441 of 18188 Old 05-21-2019, 02:06 PM
filipp2442's Avatar
Quoted: 29 Post(s)
I bought it refurb from the Epson store. Did the reset, seems like its because I have to do -20 on Keystone that it shrinks it and won't fit.
post #17442 of 18188 Old 05-21-2019, 02:27 PM
filipp2442's Avatar
Quoted: 29 Post(s)
Different issue but I can't seem to get HDR to show. I'm using a gaming laptop with a 1050 ti through HDMI to my Yamaha TSR-7850 to the 5040UB. In the screenshot below it shows MadVR saying there is HDR but the projector not showing HDR and I can't seem to get the Nvidia control panel to show the "full" range instead of just limited?
ID:	2569810   Click image for larger version
post #17443 of 18188 Old 05-21-2019, 03:18 PM
xbladr's Avatar
Quoted: 149 Post(s)
Liked: 63
-20 keystone? Why in the world do you have to do that? We need to see your setup.
Can you change the refresh rate of the pc to 24ghz and see if that changes anything? Not sure that it would but because of the limited bandwidth on the 5040 hdmi port it may. Also I don't know anything about that Yamaha but can you get hdr to a TV or anything else over the same port on it? The reason I ask is because there was an hdmi range setting on my friends Sony receiver we had to configure to show hdr
xbladr is offline
post #17444 of 18188 Old 05-21-2019, 03:56 PM
filipp2442's Avatar
Quoted: 29 Post(s)
See attached two photos of how its mounted and how the image looks with 0 keystone. For me to get the picture to look line up the edges, it needs around -28 keystone.
I have the refresh rate set to 24hz in Nvidia Control panel and the native resolution like my previous photo shows so that doesn't seem to help. I tried looking up in the manual on the Yamaha but can't seem to find what to change if there's a setting to adjust. https://usa.yamaha.com/files/downloa...om_U_En_B0.pdf
It says the Yamaha supports 10 bit + HDR; https://usa.yamaha.com/products/audi...850/index.html
ID:	2569858   Click image for larger version
post #17445 of 18188 Old 05-21-2019, 03:59 PM
Archaea's Avatar
Quoted: 3914 Post(s)
Liked: 3716
@filipp2442 ,
your projector should be mounted with the lens vertical and parallel to the plane of the projector screen.
You don't want to angle your projector like that. Rather you should use Lens Shift to lower the image, under the focus menu.
Keystone is generally bad for image clarity, and text readability -- don't use it, or use it minimally.
roland6465, gene4ht and xbladr like this.
Archaea's 9.12.4 Home Theater Room
(13) JBL CBT 70j-1 | Denon x7200wa | Sherbourn PA 7-350 amplifier | (8) Ultimax 18" sealed subwoofers | (4) iNuke DSP 6000 amplifiers | (4) MB Quart 12" subwoofers mounted direct mounted to Berkline theater chairs BOSS style | Epson 5040UB Projector | Jamestown 144" acoustic transparent 2.35:1 screen w/ Seymour XD fabric
Archaea is online now
post #17446 of 18188 Old 05-21-2019, 04:11 PM
xbladr's Avatar
Quoted: 149 Post(s)
Liked: 63
Archae is spot on. Center the projector to the wall its on. On both y and x axis. You do not want any tilt or yaw. Then you can use lens shift to center it on the screen.
Secondly I'm sure the Yamaha can support it but it may say something in the manual. I can try to check it tonight but maybe reach out to Yamaha support and ask
xbladr is offline
post #17447 of 18188 Old 05-21-2019, 04:40 PM
filipp2442's Avatar
Quoted: 29 Post(s)
@filipp2442 ,
Ahhhhhhhhhh thank you guys so much! Yes I fixed it on the ceiling and now it shoots the full 150" with 0 Keystone after some adjusting.
Ok let me see if I can call Yamaha now. So you think its a Yamaha AVR issue and not the gaming laptop?
jbnpaul likes this.
post #17448 of 18188 Old 05-21-2019, 04:46 PM
xbladr's Avatar
Quoted: 149 Post(s)
Liked: 63
Absolutely no idea lol. It was just a thought. I dont know if that gaming laptop can pass hdr. I don't know enough about it. I'm just tossing out suggestions
xbladr is offline
post #17449 of 18188 Old 05-21-2019, 04:51 PM
filipp2442's Avatar
Quoted: 29 Post(s)
Ok I'm on hold with Yamaha right now, this is the laptop; https://www.bestbuy.com/site/acer-ni...?skuId=6212602
post #17450 of 18188 Old 05-21-2019, 05:10 PM
--Sclaws's Avatar
Quoted: 84 Post(s)
Liked: 65
Dumb question.. Is HDR enabled in Windows? It's not in the nvidia control panel.
gene4ht likes this.
Epson HC5050UB | 110" DEA Infinity Edge FF | Marantz NR-1607 | Kodi HTPC | Panasonic DP-UB820 | PS4 Pro
JimK
--Sclaws is offline
post #17451 of 18188 Old 05-21-2019, 05:56 PM
filipp2442's Avatar
Quoted: 29 Post(s)
I was able to find HDR/WSR to enable on the windows Display and if I enable that it looks like HDR is enabled but it still shows "limited" under the nvidia control panel dynamic range.
If I change back the Nvidia Control panel to use default color settings but keep HDR enabled on windows the projector shows Color Depth 8 bit + BT.2020 HDR(picture 1). If I keep HDR enabled on Windows and change the Nvidia Control Panel to 10 bit, 4:2:2 and "limited" under dynamic range since it doesn't give me an option to do "full" the projector says 12 bit 4:2:2 BT.2020 HDR.
I'm confused now if I should leave it on one of these(Picture 1 or Picture 2) or if I still haven't figured out how to get full dynamic range + HDR + 10 bit + 4:2:2
ID:	2569910   Click image for larger version
post #17452 of 18188 Old 05-22-2019, 12:46 AM
Zoltrix's Avatar
Quoted: 108 Post(s)
Cool, and what devices are you connecting to play your HDR content?
Zoltrix is offline
post #17453 of 18188 Old 05-22-2019, 02:59 AM
Dave Harper's Avatar
Quoted: 3159 Post(s)
Liked: 1723
Limited is what you want. That setting has nothing to do with HDR. That is setting where your black and white clipping points are. PC signals generally use Full Range 0-255 for 8 bit and video uses the Limited Range 16-235 in 8 bit Video. 0 and 16 are the encoded black levels for each and 235 and 255 are the peak white levels encoded for each type of signal.
This signal you say you’re getting is what you want to use:
“12 bit 4:2:2 BT.2020 HDR” in Limited Range for the HDR video.
10 bit 4:2:0 BT.2020 HDR is what it’s encoded at anyway on a UHD Blu-ray Disc or through streaming like Netflix, Amazon, etc.
filipp2442 and xbladr like this.
Dave Harper is offline
post #17454 of 18188 Old 05-22-2019, 05:50 AM
Archaea's Avatar
Liked: 3716
Limited traditionally kills the black floor it seems to me?
I switched mine to full and liked it better, because blacks were actually black. But I’ll admit to having 1% of your video knowledge Dave, so maybe it’s some other setup option I have wrong that makes me like full better than limited.
post #17455 of 18188 Old 05-22-2019, 10:58 AM
gkman1's Avatar
Quoted: 25 Post(s)
Long time for lamp to turn on/orange light time to time??
Anyone else having issues where the bulb is taking a few minutes to come on...Also, from time to time, the orange flashing light will come on at start up....I remove the filter, put it back in, and it works fine....Any thoughts or recommendations??/ Thx
gkman1 is offline
post #17456 of 18188 Old 05-22-2019, 11:45 AM
Liked: 1723
Well the source and the display have to be using the same mode, so if your source is sending full and you put the display at limited then you may have issues.
I haven’t used an HTPC in a long time but I know with some PCs you do need to send Full and then set the display accordingly. I think XBox is the same. The most important thing is to make sure they match.
post #17457 of 18188 Old 05-22-2019, 06:14 PM
Quoted: 80 Post(s)
Liked: 25
Just an Oppo 203 set to 4k with the Epson doing the tone mapping as per Hapervision or Niel's settings.
Both seen to think that the mapping in the recent Panasonic players don't add much if anything.
post #17458 of 18188 Old 05-22-2019, 11:38 PM
Archaea's Avatar
Liked: 3716
Would you guys send this refurb 5040UB back? This is my fourth refurb. The color uniformity is off on this one. Am I just being too picky? Do all of these units have these types of issues and people just don't notice or care? Epson keeps telling me every refurb they ship goes through high quality control and should have no issues, same as new - but I can't be that unlucky... right?
It's noticeable on a PC desktop slightly, as it turns pinkish the on the right hand side. I can't see it in a game, but I can see it on avsforum, or on my PC desktop, or on my DVD player's home screen.
Post 301 has pics.
https://www.avsforum.com/forum/199-f...l#post58086802
post #17459 of 18188 Old 05-23-2019, 12:23 PM
Quoted: 224 Post(s)
Liked: 112
Im debating between a 6040 and a 6050..... Am I correct in assuming the 5040 will not play 4K HDR content?
Projector:Epson 6050ub Screen:Elite screens manual SRM Pro series 120" TV: Vizio P75f Pre/Pro:Marantz AV7705 Amplifier:Monolith 7x and Emotiva A-700 for ATMOSSpeakers:Klipsch THX8000-L (LCR) R5800 side surrounds, 5650-S rear surrounds Klipsch 5800-C for ATMOSSubwoofers:PSA v1811x2 Bluray Player:Panasonic ub820 Media Streamer:Fire TV cube
post #17460 of 18188 Old 05-23-2019, 12:33 PM
monkaquinas's Avatar
Quoted: 84 Post(s)
Liked: 40
The 5040 can play 4k with HDR, it has a chipset that will not accept 4k 60f. The 6040/6050 has a chipset that can. If you pair the 5040 with the UB820 it will play UHD discs with great HDR tone mapping for less than the 6040/6050. Streaming on the UB820 is good, not GREAT.
Epson5040UB - DragonFly DFM Tab 92HC High Contrast (.9 gain) 16:9 Screen - Denon AVRS740H - Klipsch Quintet V +
Klipsch KHC-6 In-Ceiling (Atmos 5.2.2) with Polk PSW110 Sub & Monoprice Premium Select 8" Sub (via iFinity Wireless Audio) - Panasonic UB820 - PS3
monkaquinas is offline
5040ub power , atmos
