Official Epson 5040ub/6040ub owners thread - Page 585 - AVS Forum | Home Theater Discussions And Reviews
 27012Likes
post #17521 of 18369 Old 06-12-2019, 03:49 PM
jblade44's Avatar
Quoted: 40 Post(s)
Yup 35 returns showed up on epson.ca today and I could not resist... coming from a 2040 refurb with no issues so we will see...
jblade44 is offline
post #17522 of 18369 Old 06-12-2019, 05:37 PM
Liked: 0
Hey folks. Super new to the forum and this thread. I have a 5040UB connected to a receiver connected to my PC. Anyone got any settings for showing through the PC? I have a 2080Ti. I was wondering about the best Nvidia control panel settings as well as maybe MPC-HC settings. Been researching like mad. I dont have a BD player or anything yet. It's hard to search such a large thread
TonytotheB is offline
post #17523 of 18369 Old 06-12-2019, 06:02 PM
Archaea's Avatar
Quoted: 3971 Post(s)
Liked: 3764
Might try this...
https://www.avsforum.com/forum/26-ho...l#post58145158
Archaea's 9.12.4 Home Theater Room
(13) JBL CBT 70j-1 | Denon x7200wa | Sherbourn PA 7-350 amplifier | (8) Ultimax 18" sealed subwoofers | (4) iNuke DSP 6000 amplifiers | (4) MB Quart 12" subwoofers mounted direct mounted to Berkline theater chairs BOSS style | Epson 5040UB Projector | Jamestown 144" acoustic transparent 2.35:1 screen w/ Seymour XD fabric
Archaea is online now
post #17524 of 18369 Old 06-12-2019, 08:09 PM
Quoted: 43 Post(s)
Liked: 7
Originally Posted by muad'dib View Post
For the output issue..
Your not choosing correct settings...
And therefore forcing linker to output one resolution etc...
I like the bluetooth app better, easier...
I get 4k/24 hdr with uhd discs, 4k/60 hdr with games etc... With no adjustment to linker....
Here is screen shots from computer Gui and also Bluetooth Gui..
Just confirming can xbox one x, pc, or ps4 pro with the hdfury linker do 4k25 4:2:2 12 bit hdr or is 4k60 hdr 4:2:0 8 bit the only option for 4khdr xbox one x gaming? I think a lot of 4k adventure games on ps4 or native 4k on pc with current gen graphics card gets around 30 fps anyways. Furthermore, most games are 4:2:0 so 4:2:0 10 bit hdr or 4:2:2 12 bit hdr looks better than 4:4:4 8bit hdr which sometimes show banding.
The epson charts and viche's posts:
https://epson.com/faq/SPT_V11H713020...530-plhc5040ub
Originally Posted by Viche View Post
So here's my latest crack at trying to sum up compatibility between the Epsons and various devices. This isn't perfect. Please post corrections with supporting pictures or documentation. If we can get this close to correct, maybe it can be stickied somewhere.
Source for some of this info: http://www.acousticfrontiers.com/uhd-101-v2/
Baseline info:
• The HDMI chipset within the Epson has a bandwidth limitation of 10 Gbps
• There are limitations to the signal that the Epson can accept due to this chipset
• 4k Blu-rays are encoded as 4k24 / 4:2:0 / 8-bit Rec709 (non HDR) or 10-bit Rec2020 (HDR10) neither of which are supported by the HDMI 2.0 specification
• Some form of signal conversion must occur in order for any device using HDMI 2.0 to accept a 4K Blu-ray signal
• The signal transmitted by the device must fall within the Epson’s 10Gbs HDMI chipset limitation for it to be displayed on the projector
Samsung K8500 4K Blu-ray Player & Xbox One S
• Both convert Blu-rays to 4k24 / 4:4:4 / 8-bit Rec709 which Epson can support
• HDR movies with Rec2020 color are reduced to Rec709, so HDR is stripped
• The resulting image for HDR movies generally appears too dark on the Epson
Phillips, Panasonic, Oppo (hopefully)
• Each convert the signal to 4k24 / 4:4:4 / 8-bit Rec 709 which the Epson supports
• HDR movies with Rec 2020 color are converted to 4k24 / 4:2:2 / 12-bit Rec2020 which the Epson supports
• The resulting image generally appears appropriate other than the Epson not having enough lumens to display HDR as intended
Fury & Oppo (hopefully)
• Both send an Epson compatible signal, but have the ability to strip HDR, while leaving the expanded Rec2020 color intact for those who feel the Epson is too dark for HDR
Roku Ultra (4K)
• Sends 4k24 / 4:4:4 / 8-bit Rec709 which is supported by Epson
• HDR movies with Rec2020 color are reduced to Rec709, so HDR is stripped (despite the screen showing 8-bit HDR BT2020, HDR BT2020 requires at least 10-bit color – is Rec2020 color really being preserved here? )
Amazon Fire Stick
• HDR signal is downgraded to 4k / Rec709
YouTube
• YouTube 4k videos are natively up to 4k60 / 4:2:0 / 8-bit
• If your player can send that native signal, the Epson can handle it
• Players that send the signal properly include: ????
Netflix
• Netflix’s 4k videos are natively ?????
Gaming (PCs, 4k games on PS4 Pro & Xbox Scorpio)
• The Epson’s HDMI chipset (10 GBPS limitation) will only accept 4k60 at 4:2:0 / 8-bit color
• It is unknown whether these gaming devices will send 4k signals in this format. If for example they send the signal as 4k60 / 4:4:4 / 10-bit, the signal will fail or be downgraded to 4k60 / 4:2:0 / 8-bit color
• Either way, 4:4:4 will get downgraded to 4:2:0 and/or color will be downgraded to 8-bit (non-HDR) assuming the source was HDR to begin with
Future video devices:
• High Frame Rate (HFR) 4k Blu-ray will display with nothing higher than 8-bit color on the Epson
• If a future format support 4:4:4, color can be no higher than 8-bit for it to work on the Epson
• Dolby Vision’s goal is to be 12-bit color. This should work with the Epson, assuming the player can send the signal as 4:2:2
IDAnonymous is offline
post #17525 of 18369 Old 06-12-2019, 09:41 PM
parkerNY's Avatar
Quoted: 33 Post(s)
Liked: 37
Originally Posted by PDXscreen View Post
I jumped on the Epson refurbished deal on the 5040 this morning. Before this came up, I was considering a 5050 or even the JVC X790R. I had a hard time justifying the additional $2700 for the JVC especially coming from a circa 2007-2008 Sony HD Projector. Thanks for the heads up on the refurb roulette. I will have to keep a detailed eye out!
Ordered one this morning as well, should be a great value if we are able to end up with good quality refurb units. For the price, I'm willing to deal with a few returns if it comes to that.
parkerNY is offline
post #17526 of 18369 Old 06-12-2019, 11:11 PM
Archaea's Avatar
Liked: 3764
I initially thought I was too, but by my fifth unit I was spent. Hope your luck is better.
roland6465 likes this.
post #17527 of 18369 Old 06-13-2019, 08:23 AM
Viche's Avatar
Quoted: 794 Post(s)
Liked: 191
Haha, forgot about that post. Thanks for quoting me, but the specs on each of those content sources may be out of date now with firmware updates. The main premise is still true, though. That's why I waited for the 5050. Now I'm just waiting for Epson to get past the early adopter pricing phase.
Viche is offline
post #17528 of 18369 Old 06-13-2019, 12:58 PM
tran1981's Avatar
Thanks for the heads up, but my 5th unit I received recently is solid. I hope you have good fortune too on your next exchange. I updated and hopefully concluded my refurb roulette saga in the deal thread here in post 355:
https://www.avsforum.com/forum/199-f...l#post58152566
They shipped replacement overnight and the new unit is dust blob free and seem normal. Color is uniform and no pink discolorations. Will test more.
Archaea likes this.
tran1981 is offline
post #17529 of 18369 Old 06-13-2019, 02:56 PM
Solarium's Avatar
Quoted: 133 Post(s)
I jumped onto the 5040ub refurb train too.
I do have an Xbox One X, which I use for gaming and netflix and 4k bluray's.
Per the chart above, the 5040UB does support [email protected] at 8bit colors, but the 5050UB will support [email protected] at 12bit colors. Is that the right interpretation? If so, how much difference is 12 bit vs 8 bit really? I don't really care about HDR.
HT: LG OLED65B7A, Denon AVR-X7200WA, B&W CM10 S2, CMC2 S2, CM5 S2, HTR-7000 x4 (atmos), SVS SB13 Ultra x2
Desktop: KEF LS50 Wireless, KEF PSW4000 (https://pcpartpicker.com/user/Fridge...s/#view=r2V6Mp)
Portable: Chord Mojo, Shure KSE-1500
Solarium is offline
post #17530 of 18369 Old 06-13-2019, 03:38 PM
Liked: 3
Is the nvidia shield the only box that can do 4/4/2 10bit @ 30hz for 4k hdr ?
I've got the old fire tv gen 1 to work with 4k 4.4.2 10 bit @ 30hz 4k but no hdr.
The newer fire tv 4k you cant select 24-30hz only 50/60.
Dont remember if its 4/4/2 or 4/2/2 10 bit.
PQWil is offline
post #17531 of 18369 Old 06-13-2019, 03:44 PM
Quoted: 43 Post(s)
Liked: 7
do you still have the 5040ub, hdfury link, and xbox one x or pc or ps4? I am just really confused right now and I was wondering if you can check on something for me. I thought for hdr10 to properly display, it needs 10-bit color depth. I see people in the thread say that the xbox one x outputs 4k60 at a bandwidth exceeding the 10Gbps that the 5040ub hdmi 2.0 can support. But the hdfury link can change the edcc to 4k60 8-bit 4:2:0. Can the hdfury link also change the xbox one x output to 4k24 at 4:2:2 or 4:2:0? I know the hdfury link can do the 4k24 4:2:0 hdr for movies. But can it do it for xbox one x games? Or is the xbox one x locked in 4k60 for games and can't be altered by the hdfury link?
I am considering the refurbished 5040ub since the 5050ub is too expensive. I know it is a great contrast projector so I wanted to understand more about the limited bandwidth. I might go with the newer benq ht3550 (around same price) for now even though that has input lag (but i don't really feel the input lag on games i play).
post #17532 of 18369 Old 06-13-2019, 05:00 PM
Solarium's Avatar
Quoted: 133 Post(s)
I'm really confused too... if I don't care about HDR, and just 4k and 60fps, will I still need a HDFury link to use the 5040UB with the Xbox One X?
Solarium is offline
post #17533 of 18369 Old 06-13-2019, 05:13 PM
Liked: 3
you will get 4k 60fps 8 bit, just not hdr or 10/12 bit if i'm correct.
random dude on yt
PQWil is offline
post #17534 of 18369 Old 06-13-2019, 07:40 PM
Quoted: 31 Post(s)
Liked: 128
See if this chart helps...
titan ii is offline
post #17535 of 18369 Old 06-13-2019, 08:25 PM
Quoted: 44 Post(s)
Liked: 2
Finally bought the Epson 5050. I'm installing in the next day or two, anyone have any display setting recommendations?
I have a Screen innovations black diamond 1.2 gain that is about 5 years old (115")
My projector is in the ceiling about 22 foot throw.
Any other installation tips would be great.
BUman is offline
post #17536 of 18369 Old 06-14-2019, 06:54 AM
inspector's Avatar
Quoted: 249 Post(s)
Liked: 156
https://www.avsforum.com/forum/68-di...ub-thread.html
...finally retired and spending time in my dedicated HT!!!
SPARKSPLEX HT - Epson 6040 3D/4K UB Projector; 110" 16x9 Dalite HD Progressive Screen; Sammy 3D/4K K8500 region free; 7.2.4. w/Def Tech speakers, Earthquake P12v2 Subs; Auto Source 100vs Amp; Denon 4300H; MX990 Remote; 5 Bello chairs; Coaire Mini-split.
inspector is online now
post #17537 of 18369 Old 06-14-2019, 08:10 AM
Viche's Avatar
Quoted: 794 Post(s)
Liked: 191
I never owned any of that equipment. Remember, I decided to wait for the 5050. Didn't want to have to deal with all of the confusion you are facing. But if money is an issue, the 5040 refurb looks like an incredible deal. The 5050 doesn't seem to be leaps and bounds better than the 5040 despite what some say. Just call it my intuition. You might want to talk to @JewDaddy about the HDfury + gaming. He tried out a bunch of stuff. Also, I'd be hesitant to sacrifice black level by going the benq route.
Viche is offline
post #17538 of 18369 Old 06-14-2019, 09:06 AM
Quoted: 43 Post(s)
Liked: 7
When the wide color gamut filter is used on the Epson 5040ub, is there a bluish green tint? So the proper way to use it is cinema mode and then turning on the wcg filter? This happens with the benq ht3550. It does seem to make the reds look more red and blues look more blue but for some reason it gives a bluish greenish hue tint on the whole picture so I am not sure why it is accurate reference colors.
post #17539 of 18369 Old 06-14-2019, 10:10 AM
Archaea's Avatar
Liked: 3764
With Epson Super White engaged, my PC windows explorer window has never looked better on a projector. The white background looks truly white. Eshift looks better off on the PC desktop though IMO. Fonts are much more crisp.
IDAnonymous likes this.
post #17540 of 18369 Old 06-14-2019, 11:13 AM
Quoted: 143 Post(s)
Hi all,, I want to try 3D movies on my Epson projector, I have 2 Panasonic TV glasses, I don't know if they will work with the projector, and know how to pair them with the projector because there is no pairing button on the glasses, just on and off button!!
Can someone here please help with this issue?
OMXP is offline
post #17541 of 18369 Old 06-14-2019, 11:31 AM
Quoted: 31 Post(s)
Liked: 128
The single button turns them on and also pairs them (if they are compatible). Have the projector on to 3D then push the button on the glasses.
Sorry about the obnoxious large picture. I only wanted to post the hyperlink (no picture).
titan ii is offline
post #17542 of 18369 Old 06-14-2019, 04:20 PM
YoMaMa84's Avatar
Ordered a refurbished unit on Tuesday as soon as some were available and I got it today. Looks good so far with no issues as far as I can tell. Bulb life was at zero. Honestly, it looks like a brand new unit to me. Wish me luck!
Alex solomon, Archaea and tomd51 like this.
YoMaMa84 is offline
post #17543 of 18369 Old 06-14-2019, 06:59 PM
Liked: 0
Can someone confirm whether or not the chf2500 is compatible with 6040ub? Epson lists chf4500 as compatible.
Sent from my SM-N960U using Tapatalk
queenstarks is offline
post #17544 of 18369 Old 06-14-2019, 09:31 PM
bernito's Avatar
A member posted that he was getting the 5040UB for $900ish? The price on their website is $1,151 and I could not find a coupon code that would work. Do the refurb prices fluctuate frequently? I would buy one right now for $900ish since I need a new bulb for my Panasonic PT-AE3000u.
bernito is offline
post #17545 of 18369 Old 06-14-2019, 11:40 PM
Archaea's Avatar
Liked: 3764
Chief Mount compatibility list.
https://www.legrandav.com/mountfinde...4f&brand=Chief
CHF2500 manual.
https://files.support.epson.com/pdf/.../chf2500sl.pdf
post #17546 of 18369 Old 06-14-2019, 11:41 PM
Archaea's Avatar
Liked: 3764
I don't know where it sourced from, but there was a 15% off coupon for a short while. I have no idea how often they come around.
post #17547 of 18369 Old 06-14-2019, 11:45 PM
Liked: 0
Thanks for your response. Link doesn't work but I've reviewed the manual previously and I saw that 6040ub isn't listed; however, I've seen posts mentioning this wad included with their purchase of the 6040ub so it's unclear
post #17548 of 18369 Old 06-15-2019, 01:03 AM
dimi123's Avatar
Quoted: 210 Post(s)
Liked: 68
Try it with a 2160p resolution signal from the PC. You'll be amazed.
PJ: Epson EH-TW9300W | Screen: 135" 2.40 Stewart StudioTek 100 | Anamorphic lens: Prismasonic Cinomorph P-100M | AVR: Denon AVR-X7200WA | Amp: 3x Naim Nait 5si Stereo Amplifier| HTPC: Intel Core i7, GTX1080Ti | BR Player: Oppo BDP-103D, Oppo BDP-95 | Speakers: JBL Studio L Series, 7.2.4 | Mains Filter: BlackNoise 1000 V2, BlackNoise 2500, ISOL-8 VMC1080 | Cables: Chord Cadenza Reference, Chord Epic Twin, Audioquest NRG-4
dimi123 is offline
post #17549 of 18369 Old 06-15-2019, 06:08 AM
Archaea's Avatar
Liked: 3764
What DPI scaling are you using?
I tried 4k and everything on the desktop (fonts, native text) was so small and blurry at 100% it made me nearly immediately switch back to 1080p.
post #17550 of 18369 Old 06-15-2019, 06:18 AM
dimi123's Avatar
Quoted: 210 Post(s)
Liked: 68
I use 250% internal scaling. No video noise, no blurring.
dimi123 is offline
5040ub power , atmos
