Official Epson 5040ub/6040ub owners thread - Page 602 - AVS Forum | Home Theater Discussions And Reviews
 26963Likes
post #18031 of 18206 Old 10-09-2019, 08:28 AM
Archaea's Avatar
Quoted: 3917 Post(s)
Liked: 3730
Originally Posted by scottjwoodford View Post
I'm noticing a weird issue on my 5040. I'm using a scope screen and zoom method. I use blanking to crop the slight overshoot that occurs when watching different formats (2.35, 2.4, etc), and for the most part it works great. When there is a normal light scene, the blanking cuts the image right to the edge of the screen perfectly. However, during a dark scene, I notice the black bars still overshoot the screen despite blanking settings being used. It's almost like blanking is only working for light scenes but not dark ones. Any ideas why this is happening?
You are seeing the light floor of the projector.
The image is being digitally cut off but the light leakage is still occurring without the digital image. It’s the same reason that if you turn on the projector with no source connected and turn the background screen to black that it’s just a dark grey.
To eliminate that you have to go to a laser projector or a more expensive LCOS type JVC — something like the JVC RS-540 will get you to a place where you won’t see the projector light floor.
Archaea's 9.12.4 Home Theater Room
(13) JBL CBT 70j-1 | Denon x7200wa | Sherbourn PA 7-350 amplifier | (8) Ultimax 18" sealed subwoofers | (4) iNuke DSP 6000 amplifiers | (4) MB Quart 12" subwoofers mounted direct mounted to Berkline theater chairs BOSS style | Epson 5040UB Projector | Jamestown 144" acoustic transparent 2.35:1 screen w/ Seymour XD fabric
Archaea is online now
post #18032 of 18206 Old 10-10-2019, 12:52 PM
DavidinGA's Avatar
Quoted: 414 Post(s)
Liked: 137
Iris Settings Question...
Where does everyone run their iris settings at and what is your viewing environment (bat cave, dark walls/ceiling, light walls/ceiling, etc)?
I've heard you can pump up your contrast by running negative iris numbers, but I'm not terribly familiar with the pro's/con's of doing so.
I have a light-colored multi-use room, but the first few feet of my screen is draped in triple black velvet (floor/ceiling/walls); so I'm not sure where I would fall for iris settings with my environment.
I run a 150" display and I'm measuring 98nits in my go-to setting on my Epson 5040 (using madVR for DTM) so I can afford a drop in lumens if it facilitates an improvement in CR.
Source: HTPC w/madVR, Video: Epson 5040, 150" 16:9, Audio: Onkyo RZ 830 avr, 5.1.4 Atmos setup. 5 speaker Energy C Series: L/R C300's, C C-C100, SR/SL C50's, 4 in-ceiling Micca R-8c. Subwoofer: MiniMarty um18 w/NX3000D.
DavidinGA is online now
post #18033 of 18206 Old 10-10-2019, 02:29 PM
SALadder22FF's Avatar
Quoted: 164 Post(s)
Liked: 48
I just got my refurbished 5040UBe in and hooker in via HDMI to my receiver and it is not giving me a 4k picture from my Xbox one x. Can someone tell me why it's giving an input signal of rgb-video and not 4k
Sent from my SM-N950U using Tapatalk
Epson 5040UBe, 120" Black Diamond Zero Edge 7 Screen 1.4 gain with LEDs
Marantz SR6011 Reciever, Xbox One X Project Scorpio Edition, Nvidia Shield,BDI Ola 8137 stand, Logitech Harmony One Remote with Alexa,
Klipsch Dolby Atmos 7.1.2 surround sound
SALadder22FF is offline
post #18034 of 18206 Old 10-10-2019, 05:30 PM
djmattyb's Avatar
Quoted: 13 Post(s)
Maybe you have it plugged into the wrong HDMI on the projector? Make sure to use HDMI1 and not HDMI2
djmattyb is online now
post #18035 of 18206 Old 10-11-2019, 01:13 PM
NickB2305's Avatar
I have the preset PDF, which breaks down settings for HDR and SDR. Is there a setting that's a good happy medium for both? My family won't have any idea if they are watching HDR or SDR so I'd like a "good enough" setting to just leave it set to.
-Nick
NickB2305 is offline
post #18036 of 18206 Old 10-11-2019, 01:33 PM
Quoted: 5020 Post(s)
Liked: 1933
There is no common "happy medium" setting, but the projector should automatically between the SDR and HDR modes, depending on the source.
Dominic Chan is online now
post #18037 of 18206 Old 10-11-2019, 01:34 PM
Morphx2's Avatar
Quoted: 101 Post(s)
I do bright cinema Harper setting for everything
Sent from my SM-G975U using Tapatalk
Morphx2 is offline
post #18038 of 18206 Old 10-11-2019, 01:35 PM
Morphx2's Avatar
Quoted: 101 Post(s)
I lowered from high lamp to medium too
Morphx2 is offline
post #18039 of 18206 Old 10-11-2019, 01:50 PM
DavidinGA's Avatar
Quoted: 414 Post(s)
Liked: 137
I use this for everything:
Natural
Medium lamp
Color Space - 2020
Dynamic Range - SDR
BUT...I used madVR (build 96) DTM for everything.
Without madVR I used to have to change stuff around quite often between sdr and hdr source material which was really really annoying.
post #18040 of 18206 Old 10-12-2019, 08:58 AM
BradP's Avatar
Quoted: 148 Post(s)
Liked: 25
Anyone have a link or advice on tips for programming a Harmony IR blaster (remote mini blaster) to properly power off an Epson 5040UB or really any epson projector? The blaster I have in the room does a great job powering the unit ON, however the off command as part of the off sequence does not seem to reach the projector. Using the off command from my phone in the Harmony app turns the projector off instantly, so I know the blaster is working and the power off command is correct, it just doesn't seem to fire properly as part of the power off sequence (and Harmony seems to have removed the ability to send additional power off commands as part of an off sequence which is really dumb, unless I am missing it).
Anyway, any tips anyone might have for getting the right delays or additional commands into the power off sequence for the epson from the Harmony would be greatly appreciated. I'd like to be able to stop using 2 remotes to power off my room!
BradP is offline
post #18041 of 18206 Old 10-12-2019, 10:38 PM
Brettmckinney's Avatar
Quoted: 54 Post(s)
Liked: 43
So I actually just came here to post the EXACT same thing. Man, so frustrating! So I've been trying as much as I can to get it power it off but yeah, nothing seems to work. I re-taught the 'off' command by pointing the Epson remote at the hub that didn't work either.
Would love to know if anyone has figured this out! It's awesome having the 'turn on projector' command to turn it on, set my avr to the input and dim my lights off. Just wish I could turn it off without having to grab another remote!
Brettmckinney is offline
post #18042 of 18206 Old 10-12-2019, 10:50 PM
Morphx2's Avatar
Quoted: 101 Post(s)
I dunno, my harmony turned it off fine. Not a combo of commands though, just the turn off command
Morphx2 is offline
post #18043 of 18206 Old 10-13-2019, 08:10 AM
Stereojeff's Avatar
Quoted: 231 Post(s)
Liked: 132
Same here. No on or off problems with Harmony remote and my Epson 6040. The standard Epson codes have worked fine from the first set-up.
Jeff
Stereojeff is online now
post #18044 of 18206 Old 10-13-2019, 09:13 AM
Quoted: 518 Post(s)
Liked: 116
do you have a link to those settings? thanks!
aeneas01 is online now
post #18045 of 18206 Old 10-13-2019, 09:18 AM
Morphx2's Avatar
Quoted: 101 Post(s)
I dunno if this is the most up to date list. Try them all. 50406040settings.11.22(1).pdf
Morphx2 is offline
post #18046 of 18206 Old 10-13-2019, 09:28 AM
farmecologist's Avatar
Quoted: 12 Post(s)
Liked: 3
Hi all,
I have had my refurb 5040ub for a a couple months now. Love the projector! However, lately I have been experiencing flicker on Power Consumption=Eco mode, somewhat less flicker on Medium mode, and no flicker on High mode. I did some research and found that flicker can be a common problem with 'low power' modes for projectors in general. However, I have not experienced this with any projector until now.
Since the projector is under warranty, I'm assuming I should contact Epson and see what they have to say? Does anyone have experience with the 5040UB and ficker issues? Do they have you try a new bulb before sending it in?
Thanks in advance for any insight you can provide!
farmecologist is offline
post #18047 of 18206 Old 10-13-2019, 09:28 AM
Quoted: 518 Post(s)
Liked: 116
i'm using both hdmi inputs on my pj (6050) and they seem to perform identically, they both support 4k hdr,is the 5040 different?
post #18048 of 18206 Old 10-13-2019, 09:31 AM
mwaarna's Avatar
Quoted: 14 Post(s)
So I purchased one of these 5040 epson projects at launch and the bulb finally died.
The projector has been amazing and lately with gaming dark scenes have been hard to see even with full brightness in the game.
As the projector bulb is dead I cannot see how many hours, after replacement will I see how many hours the old bulb had on it?
I do not have a spare on hand.
Where is everyone buying their bulbs at?
Looks like retail is 299 and epson appears to be out of stock.
https://epson.com/Accessories/Projec...b/p/V13H010L89
Amazon has it for 254:
https://www.amazon.com/Epson-V13H010.../dp/B01NBF5IV5
BH Photo also has it back ordered:
https://www.bhphotovideo.com/c/produ...9_elplp89.html
I see lots of non-genuine ones on sale for much cheaper, but I will avoid the non-oem bulb/housing setups.
Current Setup:
Polk LSI15,LSiC, LsiFX, SVS PB-12 Plus/2, Marantz 7703, Epson 5040, Elite Screens Saker Tab Tension 110" AT Screen, Earthquake Cinenova 5
Selling(PM if interested available as of 12-2016):
Onkyo Pro PR-SC885P and Pair of Polk LSI 15's.
mwaarna is offline
post #18049 of 18206 Old 10-13-2019, 09:34 AM
Quoted: 518 Post(s)
Liked: 116
I dunno if this is the most up to date list. Try them all. Attachment 2627304
thanks!
post #18050 of 18206 Old 10-13-2019, 09:44 AM
mwaarna's Avatar
Quoted: 14 Post(s)
Originally Posted by JustAnEE View Post
2 days past 2 years and I now have the dreaded "replace lamp soon" message. Image is still plenty bright in Natural, I only use Bright Cinema if the room lighting is high (or sunlight making its way in) and no flickering I've noticed before previous epson failures..
Question: Is the projector just basing it on hours or is it "smarter" and based on some sort of self-tests? Extra risk (explosion/damage) to keep the bulb in longer?
If it's purely an "hours" based replacement message, seems reasonable to keep running it a few more 1000.
But if it's based on lamp self-tests (power consumption/etc), maybe it's time to order the replacement.
Hours from service menu:
Total Operation time: 4729H
Lamp Op. Time 4904H
(3D/H/M/L/UL): 0H/ 1H/ 668H/ 4059H/ ----H
Lamp ON/Lamp OFF: 763Times / 760Times
Looks like BHP has the best OEM replacement cost at $237. Guess that's better than $300.
BH Photo looks like it is 299 and back ordered:
https://www.bhphotovideo.com/c/produ...d3b59790a6fca8
Amazon looks to have it for 257:
I am now shopping around for one, its really hard to see if they are legit oem bulb/housing.
Where did you end up getting your replacement if you already got one?
Current Setup:
mwaarna is offline
post #18051 of 18206 Old 10-13-2019, 07:13 PM
BradP's Avatar
Quoted: 148 Post(s)
Liked: 25
Jeff
Are you guys powering the Epson projectors off with your remote with IR in the room or via a mini blaster? Power off command isn't sending as part of a power off script from my mini blaster, but when I use my phone (not IR) to send the power off command from the mini blaster it works first try. So so weird.
BradP is offline
post #18052 of 18206 Old 10-13-2019, 07:15 PM
Morphx2's Avatar
Quoted: 101 Post(s)
Just hitting power off from my harmony while in the same room.
Morphx2 is offline
post #18053 of 18206 Old 10-13-2019, 08:02 PM
Stereojeff's Avatar
Quoted: 231 Post(s)
Liked: 132
I use a mini-blaster. Same performance from my iPhone X or the Harmony Hub.
Jeff
post #18054 of 18206 Old 10-13-2019, 08:07 PM
Morphx2's Avatar
Quoted: 101 Post(s)
Anyone use a higher than 1.0 gain?
Morphx2 is offline
post #18055 of 18206 Old 10-14-2019, 04:34 AM
Quoted: 54 Post(s)
Liked: 43
I have no problem turning it off with the app or harmony remote but in the 'activity' I have it will turn it on, but not turn it off.
post #18056 of 18206 Old 10-14-2019, 05:05 AM
BradP's Avatar
Quoted: 148 Post(s)
Liked: 25
This. My exact same problem with my Harmony ultimate. Activity will not turn the Projector off but turns it on just fine. I have tried messing with delays and even added two power off button presses to the off sequence for the device itself separated by a one second delay and still no changes. It’s as if the off activity doesn’t even fire the power off command. It works instantly when I use the off command manually with my iOS app.
BradP is offline
post #18057 of 18206 Old 10-14-2019, 07:29 AM
Quoted: 31 Post(s)
Liked: 8
Anyone have an issue with the image going black for a second or two randomly when watching something? I have the PJ connected to a newer Marantz receiver connected to the shield. I've already tried replacing the HDMI cables both between the receiver and shield and the receiver and the PJ.
Is there a way to troubleshoot this further that I should be looking at? Any help would be very much appreciated!
dangerdan92 is offline
post #18058 of 18206 Old 10-14-2019, 08:16 AM
DavidinGA's Avatar
Quoted: 414 Post(s)
Liked: 137
Mine is supposed to be a 1.1 gain screen.
post #18059 of 18206 Old 10-14-2019, 09:30 AM
Stereojeff's Avatar
Quoted: 231 Post(s)
Liked: 132
Stewart Studiotek 130 1.3 gain 80" x 45" (92" diagonal)
Jeff
post #18060 of 18206 Old 10-14-2019, 08:54 PM
mwaarna's Avatar
Quoted: 14 Post(s)
FYI called Epson to see if they have any of the parts in stock, they did not but they referred me to their authorized dealers of Epson parts.
https://epson.com/Support/wa00399
Compass Micro has the original bulb replacement for 219:
https://compassmicro.com/lamp-assemb...ma-5040ub.html
And another company on their referral list has it for 179 but it is back ordered:
https://encompass.com/item/11449072/Epson/1697999/
Ended up ordering from Compass Micro.
old corps likes this.
Current Setup:
mwaarna is offline
5040ub power , atmos
