Official Epson 5040ub/6040ub owners thread - Page 62 - AVS Forum | Home Theater Discussions And Reviews
 26949Likes
post #1831 of 18050 Old 10-14-2016, 08:04 PM
gnolivos's Avatar
Quoted: 372 Post(s)
Liked: 293
Originally Posted by spirithockey79 View Post
On a separate note, I have a BT 2020 vs Rec 709 question and you seem to have some pretty good knowledge based on reading your prior posts. I'm watching the Huntsman Winters War on Blu-ray but can't select 4k enhancement presumably because the source resolution is higher than 1080p. So I thought I would mess with the color space and change to BT 2020 and it looks pretty awesome. Colors are probably more saturated than they should be but still looks good. Is this normal? I thought the only benefit of BT 2020 was with 4k and HDR. Remember I don't have a 4k Blu-ray player.
I'm using Natural but I've read posts about the benefit of Cinema because of the P3 filter, but I still think Natural looks better than Cinema. Am I not combining the various settings appropriately?
My knowledge on this is very limited to be honest. My understanding is that for all blurays the color space is based on rec 709. In any case what I do know for sure is that you want to match the color space to the source. If you have a rec 709 source you want to make sure the Epson is set for 709. The easiest way to handle this is to leave in auto mode.
I too once tried changing the color space to something different and at first I thought it looked better with more pop, but shortly after noticed that it was crushing the dark areas and blowing out light areas. Not good at all, and I reverted.
After testing several modes, my recommendation for movie watching it is the Cinema mode. It does have the P3 filter which darkens things a little bit but in my dark theater room I use Cinema mode with low lamp setting and in fact have to close the iris!! So bright.
My next choice is Bright Cinema with some warming tweaks of the color temperature. I use this if I have any ambient light for watching sports with friends etc.
I don't use any other modes.
Ronman79 and royboy365 like this.
Setup: Epson 5040 UB, 110" SilverTicket AT screen, PS3 bluray, Yamaha RX-V673 AVR, Polk and Athena speakers, Batcave room.
The Moderno Theatre! Slideshow (here!)
Pixar screenplay slideshows here!
gnolivos is offline
post #1832 of 18050 Old 10-14-2016, 08:33 PM
spirithockey79's Avatar
Quoted: 192 Post(s)
Liked: 72
Ok, thanks for the tips. I've been switching back and forth and I think I agree with you on Cinema. I also have dark theater and have iris at about -15. Question - do you have super white set to ON? The default was off but setting to ON makes the picture so much better IMO - having off just lightens the picture so much.
If I hear back from Epson I'll be sure to provide an update.
spirithockey79 is offline
post #1833 of 18050 Old 10-14-2016, 08:37 PM
gnolivos's Avatar
Quoted: 372 Post(s)
Liked: 293
I think Super White setting needs to match your player. I have a PS3 with such a setting. (Going From memory here).
Anyway, whatever setting you use , make sure you calibrate Brightness and Contrast using Disney WoW or similar tool. Most Pixar discs have this.
gnolivos is offline
post #1834 of 18050 Old 10-14-2016, 08:42 PM
ndabunka's Avatar
Quoted: 572 Post(s)
Liked: 231
I use DIGITAL CINEMA almost exclusively and believe that it also has the P3 filter in place. IMHO Bright Cinema is WAY too bright in pretty much all cases for any practical use in my HT including during the day with shades partially open. I run my lamp in ECO and MEDIUM modes only switching to HIGH for 3D content during daylight hours. At night or with the shades fully closed, 3D still pops even in medium mode.
I leave the Iris in AUTO 100% of the time and it works wonderfully. No reason at all to lock it open or closed thereby un-necessarily reducing contrast. Part of the reason I bought this particular projector was to get those high contrast levels that can ONLY be provided through the use of a Dynamic Iris. Granted, I was spoiled by first having the VPL-HW50ES with the DI but this Epson even outperforms the Sony! Very happy with this projector to this point.
morellihugo likes this.
Epson 5040ub Projector, Elite Screens 120" Saker AUHD, Yamaha RX-A3060, B&W Speakers: Signature 7's, FMP4, CWM7.5s, CCM65s, Rythmik 15" CI Sub, 30' Monoprice Cabernet Ultra CL2, Tiara CI-Pro Series In-wall wiring, Phillips BDP7501 UHD BD Player, Niles 1230 WHA Amp, Xbox, WiiU, TiVo Premiere
ndabunka is offline
post #1835 of 18050 Old 10-14-2016, 09:27 PM
MaximTre's Avatar
Quoted: 110 Post(s)
Liked: 49
Originally Posted by k3nnis View Post
Nice. So with the Samsung and Epson, what bit and chroma is it showing uhd bluray at? 4:2:0 10 bit?
And is Netflix 4K HDR working on the Samsung and at what setting?
BD UHD -> 12bit/4:2:2/24hz signal
No hdr flag for netxflix but, does the ks8500 netflix app support hdr?
I was told it doesn't.
MaximTre is offline
post #1836 of 18050 Old 10-14-2016, 09:31 PM
MaximTre's Avatar
Quoted: 110 Post(s)
Liked: 49
Originally Posted by filter_sweep View Post
For those of us who haven't purchased a UHD player yet, can you elaborate? Any special settings / configuration needed? What signal does the 5040 say it's receiving along with HDR (8, 10 or 12 bit)? Looking to pick up a player on Black Friday and if the Samsung is now at parity with the Philips then it will increase my chances of getting a good deal.
It' s 12bit, 4:2:2, 24hz signal.
No special setting, everything on auto as before the update.
MaximTre is offline
post #1837 of 18050 Old 10-14-2016, 09:39 PM
MaximTre's Avatar
Quoted: 110 Post(s)
Liked: 49
Originally Posted by ndabunka View Post
What's true? What works now that didn't before?
The Samsung KS8500 player received a software update yesterday.
After the update, the hdr signal is correctly passed to the epson using a cable connection.
Ronman79, royboy365 and travi_74 like this.
MaximTre is offline
post #1838 of 18050 Old 10-14-2016, 09:59 PM
morellihugo's Avatar
Quoted: 27 Post(s)
3D content and frame interpolation, what setting do you think is better, low, normal??? 3D cinema or dynamic?
morellihugo is online now
post #1839 of 18050 Old 10-14-2016, 10:16 PM
Ronman79's Avatar
Quoted: 300 Post(s)
Liked: 192
Originally Posted by dsewardj View Post
Just installed this bad boy last night and I am very pleased. This is by far the best upgrade to my setup ever. Below is the setup:
- Screen Innovations Slate 1.2 motorized 110" screen
- Onkyo TX-NR646 receiver
- Polk Audio speakers (they do their job;
Hey, depending on what you have, Polk does some really good stuff, with really good value. I love my Polks. And, congrats! Nice setup. Have fun!
Sent from my XR6P10 using Tapatalk
Equipment List: Theater - JVC DLA-X770R / Denon X4300H / Panasonic 820 4K BD Player / Polk Audio RTiA9 Towers / Polk CSiA6 Center / Polk 65RT (6), FXi5 (2) Atmos and Surrounds / (4) Polk PSW505 12" Subs / Black Flame Painted Screen Wall / Nvidia Shield TV / Dish Hopper 3 - 4K/ XBOX One S / Harmony Elite / Echo Dot / Tripp Lite UPS Backup / Furman Conditioner / App and Tap controlled Philips Hue Lighting / Monoprice Cabling
Ronman79 is offline
post #1840 of 18050 Old 10-14-2016, 10:20 PM
Ronman79's Avatar
Quoted: 300 Post(s)
Liked: 192
@MississippiMan , check this out.
Ronman79 is offline
post #1841 of 18050 Old 10-14-2016, 11:00 PM
nickoakdl's Avatar
Quoted: 121 Post(s)
Liked: 96
Is that with just UHD discs or with Netflix, Amazon Prime, and VUDU as well?
ndabunka likes this.
nickoakdl is offline
post #1842 of 18050 Old 10-14-2016, 11:45 PM
hatlesschimp's Avatar
Quoted: 505 Post(s)
Liked: 541
Battlefield 1 is pretty sweet on the 6040ub! Input lag and pixel refresh rate are excellent.
gnolivos, Ronman79 and dsewardj like this.
hatlesschimp is offline
post #1843 of 18050 Old 10-15-2016, 01:18 AM
MaximTre's Avatar
Quoted: 110 Post(s)
Liked: 49
Can't comment on amazon ad vudu app (not available here), but netflix app of the player doesn't support hdr at all (tested on a last generation Samung TV too, just in case)
MaximTre is offline
post #1844 of 18050 Old 10-15-2016, 01:24 AM
k3nnis's Avatar
Quoted: 642 Post(s)
Liked: 60
So which media player or blu ray player supports Netflix 4K HDR at present?
k3nnis is offline
post #1845 of 18050 Old 10-15-2016, 01:52 AM
Jasinto's Avatar
Quoted: 20 Post(s)
nvidia shield tv does but I read here before not with epsons , i have the nvidia shield but not the epson for check
Saludos
gnolivos likes this.
Jasinto is offline
post #1846 of 18050 Old 10-15-2016, 02:08 AM
k3nnis's Avatar
Quoted: 642 Post(s)
Liked: 60
Ok thanks. If someone could check with the Epson that would be great
k3nnis is offline
post #1847 of 18050 Old 10-15-2016, 02:43 AM
dsewardj's Avatar
Thanks, and I didn't mean to disparage Polk Audio. The front speakers are Polk Audio Monitor70 Series II and for the price they have proven to be great entry level speakers. They can be a bit too bright at times, which does not bother me when watching movies or playing games, but when I listen to music I tend to notice more. After reading the rave reviews about the ELAC Debut F5 it is very tempting.
Ronman79 likes this.
dsewardj is offline
post #1848 of 18050 Old 10-15-2016, 08:48 AM
Quoted: 27 Post(s)
The new Roku Premiere+ and Roku Ultra, both support HDR on Netflix and Amazon video. I have the premiere+...
post #1849 of 18050 Old 10-15-2016, 12:33 PM
k3nnis's Avatar
Quoted: 642 Post(s)
Liked: 60
Thanks. Can you show a screenshot of the Epson information ie what bit and chrome and Hz it's playing netflix4k HDR at?
k3nnis is offline
post #1850 of 18050 Old 10-15-2016, 12:36 PM
jamieuk147's Avatar
Quoted: 76 Post(s)
Anyone kind enough to tell there calibrated settings?? As I find the cinema mode very red, especially people's skin tones.
Also..... Would I let my oppo do the upscaling 4Kx2k or best letting the Epson?
jamieuk147 is offline
post #1851 of 18050 Old 10-15-2016, 02:06 PM
Black Banshee's Avatar
Quoted: 17 Post(s)
Liked: 34
Rs-232?
Has anyone else tried to control their 5040 via rs-232? I'm trying to set that up but the projector won't respond to commands and I couldn't find a setting in the menu to enable rs-232 or is it always supposed to be on?
Edit: doing some research it looks like you need to use a null modem db9 cable, not the standard pass-thru rs-232. Just ordered a db9 cable and will confirm.
Black Banshee is offline
post #1852 of 18050 Old 10-15-2016, 03:06 PM
Quoted: 98 Post(s)
Is anyone projecting to a 100" 16:9 screen from an 11'-6" to 12'-0" distance with no issues? I am limited to that throw and wanted at least a 100" screen. That range is within the throw ratio of the 6040 according to the specs and at the lower range of the ALR screens I'm looking at (1.5x W.O.S.), but I want to know if there are any real work issues being on the low end of the throw range instead of on the sweet spot.
techjoy is offline
post #1853 of 18050 Old 10-15-2016, 04:52 PM
Quoted: 239 Post(s)
Liked: 127
Ok..this will sound silly..but has anyone had the idea of having 2 epsons 5040ub creating one single image. That way we would be able to double the lumens and create the ultimate bright image for an HDR viewing? I work for Cirque du soleil and we use 4 projector per image , because the amount of brighness we need on those images. I guess it would be tricky to match and align the pixels but if it works I think $6,000 for a 5,000 lumens 4k HDR is not bad. Would this make any other improvements aditional to more light output? anyone has done this before?
canillo is offline
post #1854 of 18050 Old 10-15-2016, 05:09 PM
dvdwilly3's Avatar
Quoted: 516 Post(s)
Liked: 318
The settings from Sound and Vision testing are a good starting place.
http://www.soundandvision.com/conten...xspXjRzYTps.97
I used those for the Customized memory setting, except that I used the Natural picture setting instead of Cinema.
I am still playing with settings...they are almost infinitely variable...
It is difficult to get a bad picture out of this projector.
https://www.avsforum.com/forum/68-di...-profiles.html
Atmos Dolby 7.2.4; Epson 6040UB; Panasonic UB820; TiVo Roamio; Roku Stick+
dvdwilly3 is offline
post #1855 of 18050 Old 10-15-2016, 05:19 PM
aaranddeeman's Avatar
Quoted: 1874 Post(s)
Liked: 676
You have already done it. So what is stopping you now?
gnolivos and Ronman79 like this.
aaranddeeman is offline
post #1856 of 18050 Old 10-15-2016, 05:47 PM
Quoted: 239 Post(s)
Liked: 127
beacuse Im a performer not the projector guy. So I havent done it my self. And we use commercial $100,000 projectors. Wanted to see if anyone has done it in a home set up an gotten any good results
canillo is offline
post #1857 of 18050 Old 10-15-2016, 06:00 PM
Quoted: 192 Post(s)
Liked: 72
Should be no problem. I have a 110" 2.35 screen at pretty much max closeness/zoom for 5040, which is like 11'6". No issues at all with picture. At 12' you might be able to go up to 120".
post #1858 of 18050 Old 10-15-2016, 06:14 PM
Hawkmarket's Avatar
Quoted: 283 Post(s)
Liked: 113
I like your thinking! I'm not sure if it's practically possible in a home environment to align them perfectly or what that takes but I'm sure it's a rather sophisticated process. In addition, as I understand it you won't be getting anywhere near 5,000 lumens of HDR with two of these projectors. More like 1,500 peak.
Hawkmarket is offline
post #1859 of 18050 Old 10-15-2016, 06:28 PM
Liked: 676
Ah okay.
As mentioned in the post above, alignment is going to PITA. And yes no 5000 lumens for HDR.
jamieuk147 likes this.
post #1860 of 18050 Old 10-15-2016, 06:43 PM
royboy365's Avatar
Quoted: 112 Post(s)
Liked: 74
I'm projecting 100" from 11' on my first screen and 150" from 25' on my second screen and both look excellent.
I find it interesting that you mention a sweet spot as I was always under the impression that the sweet spot was as close to the screen as possible to get the most amount of lumens on the screen. The distance you mentioned is only a foot away from the closest you can be for 100".
royboy365 is offline
5040ub power , atmos
