Official Epson 5040ub/6040ub owners thread - Page 624 - AVS Forum | Home Theater Discussions And Reviews
 27167Likes
post #18691 of 18948 Old 01-23-2020, 04:32 PM
tibimakai's Avatar
Quoted: 210 Post(s)
Liked: 65
Originally Posted by carlobenavidesahavia View Post
Quick question for 5040ub owners will I be able to throw from this room corner because I don't have enough length right infront of the screen but can put it in this corner to be able to reach 12 to 13 feet planning on buying a 115" 2.35:1 silver screen acoustic screen to cover the whole room width and just put the speakers behind the screen.
Sent from my SM-N975F using Tapatalk
Do you even have room above the door, to fit this pj? It is a big pj.
Living Room: Samsung UN65JS8500,Onkyo TX-NR676,Klipsch R-28F,Klipsch RC-62II,Klipsch R-14S,Polk Audio 80 FX/RT(Atmos)
Bedroom: Samsung UN55MU6290,Onkyo TX-RZ610,Klipsch RP-160m,Onkyo & Fluance speakers
Garage: Epson 5040UB,Elite Screens 125" motorized screen,2xKlipsch RP-8000F,4xKlipsch RP-150M,Klipsch RP-450C ,2xKlipsch CDT-3800CII/2xCDT3650CII,Klipsch R115SW/R110SW
tibimakai is offline
post #18692 of 18948 Old 01-23-2020, 05:06 PM
jamesyates's Avatar
Quoted: 176 Post(s)
Liked: 45
Help w/ 1.14 Upgrade
Hi Everyone, Many of you have been able to update to 1.14. I have not from 1.13. This is what I am using.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
https://www.costco.com/sandisk-cz600...100290584.html
When I start the procedure the usb drive does not light up and the projector does not seem to go into update mode. Any ideas? Thanks
jamesyates is offline
post #18693 of 18948 Old 01-23-2020, 06:16 PM
Superman2's Avatar
Quoted: 56 Post(s)
Liked: 31
Does anyone know how to turn off HDR on a 4k Firestick so I don’t have to deal with it with the limitations of the HDMI 10gbs? I gone into settings and turned HDR to adaptive, but that doesn’t work. Anyone using a firestick with their 5040? ( I have the 4010)
Superman2 is offline
post #18694 of 18948 Old 01-23-2020, 06:48 PM
Frichard's Avatar
Quoted: 64 Post(s)
Liked: 25
Set your resolution to 4K @60Hz. HDR wont be pass because of the limitation.
Otherwise the projector can play HDR fine at 4K @30Hz or 1080P @60Hz.
NAD T758 v3 - 2x AUDIOSOURCE Amp100vs
Golden ear Triton 7 - Golden ear supercenter xl
4x Micca M-8C
Paradigm PW-2200
Samsung PN64D550 - Epson 5040ub
Frichard is offline
post #18695 of 18948 Old 01-23-2020, 08:37 PM
Superman2's Avatar
Quoted: 56 Post(s)
Liked: 31
Thank you. I will try that tomorrow.
I’ve all but given up on HDR for a projector.
post #18696 of 18948 Old 01-23-2020, 10:57 PM
carlobenavidesahavia's Avatar
Quoted: 60 Post(s)
Liked: 6
I can reverse that door to open outwards... but if it will be too much of a hassle I might just turn my living room into the home theater....
carlobenavidesahavia is online now
post #18697 of 18948 Old 01-23-2020, 11:06 PM
Quoted: 60 Post(s)
Liked: 6
Originally Posted by DavidinGA View Post
Eh, what are the dimensions of that room? It looks pretty small for a projector setup.
I think you might be way better off tossing an 85" flat panel in there than the PJ....
Yeah thinking about just turning my living room into a home theater I already have a 65" samsung..... really want to get a projector for the next step up.....
post #18698 of 18948 Old 01-23-2020, 11:08 PM
Quoted: 60 Post(s)
Liked: 6
Here are the dimensions of the tiny room length 10-10 feet, width 8-9 feet, height 7-8 feet. Will just put it in the living room if it's not feasivle and turn that room into my gym.
post #18699 of 18948 Old 01-24-2020, 05:11 AM
roland6465's Avatar
Quoted: 443 Post(s)
Liked: 452
Originally Posted by marcosphoto View Post
One of the reasons I bought the 5040 was because of stories about unparalleled customer support, so far I have been less than impressed with the low level support team and I've heard nothing but nightmares about the replacement and refurb units and unhappy customers. So far (knock on wood) I have been ok with mine but I'm very worried what the future holds for my $4000 projector. Maybe should have bought the JVC.
Me, too. My 6040 was my second Epson, and customer service is big with me, and I was happy to upgrade to another Epson. Then I started dealing with their quality control. Those new to the thread can search my previous posts here, but the story ends with my selling my fourth defective refurb to a friend with a bar who didn't care about the PQas much as I do, and got a Sony.
roland6465 is offline
post #18700 of 18948 Old 01-24-2020, 05:57 AM
Azekecse's Avatar
Quoted: 163 Post(s)
Liked: 111
You should use the USB port on the PJ, it looks like you're utilizing the service port. Make sure the f/w is at the root of the drive and remains zipped. I also found that USB 2.0 works better that USB 3.0. Hope this helps.
Peace and blessings,
Azeke
Marantz SR7011: 7.4.4 Martin Logan Edges (4: FR/FL/SR/SL) Martin Logan Axis (2: SBL/SBR) Martin Logan Stage X (Center) Martin Logan 1500X Sub (2) Martin Logan 1100X Sub (2) Sonance VP86R SST/SUR (4: Dolby Atmos) JVC NX5/Elite Lunette 2 120"
Azekecse is online now
post #18701 of 18948 Old 01-24-2020, 07:15 AM
RedPills4All's Avatar
Quoted: 67 Post(s)
I had the same problem. I tried everything, probably about 5 different USB sticks. I even called support and they said I had a bad unit and they wanted to do a return. The projector lights would come on, and then shut off, and no FW update. Someone posted that the stick had to be FAT32, not FAT, so I even tried to carve out a partition on the stick smaller than 4GB, formatted FAT32, and went that route - didn't work.
In the end, based on suggestions from other forum members, the only thing that worked for me was using an old USB 2.0 drive that had a total size less than 4GB, formatted FAT32. I'm not sure if it has to be USB 2.0, but I think the size will matter. Hope this helps!
RedPills4All is offline
post #18702 of 18948 Old 01-24-2020, 07:17 AM
Quoted: 60 Post(s)
Liked: 6
So their refurbished units have a ton of problems maybe I should just go benq or jvc
post #18703 of 18948 Old 01-24-2020, 07:38 AM
Quoted: 17 Post(s)
Liked: 0
I purchased a refurb 5040ub and have been blown away. Hoping the horror stories are a thing of the past and/or a minority. We will see in a year though!
What is the best hd fury device to obtain 4k hdr 10bit 24hz from a xbox one x? Or 4k 60hz 8 bit. That or should I just get a apple tv 4k for movie streaming?
Odysea is offline
post #18704 of 18948 Old 01-24-2020, 07:41 AM
Frichard's Avatar
Quoted: 64 Post(s)
Liked: 25
It's not a thing of the past. I bought my 5040ub less than a month ago and I'm waiting for my third one.
I hope the next one will be perfect.
I wish you luck.
4x Micca M-8C
Paradigm PW-2200
Frichard is offline
post #18705 of 18948 Old 01-24-2020, 07:43 AM
DavidinGA's Avatar
Quoted: 515 Post(s)
Liked: 193
I would go with the living room.
That room might fit the pj and screen put your also going to have a hard time with proper sound setup/quality in such a small space too.
Source: HTPC w/madVR, Video: Epson 5040, 150" 16:9, Audio: Onkyo RZ 830 avr, 5.1.4 Atmos setup. 5 speaker Energy C Series: L/R C300's, C C-C100, SR/SL C50's, 4 in-ceiling Micca R-8c. Subwoofers: 1 MiniMarty um18 w/NX3000D. 2 VBSS 18" Subs w/NX3000D.
DavidinGA is online now
post #18706 of 18948 Old 01-24-2020, 07:46 AM
welldun's Avatar
Quoted: 318 Post(s)
Liked: 158
Originally Posted by mudfrog View Post
When I calibrated my 5040UB using the WOW disc, I did so using Bright Cinema for HDR content and Natural for SDR content. Obviously I was guessing at HDR as I have no idea how to calibrate for that. Does everyone use one input for both HDR and SDR or separate ones?
Also, when watching HDR content, the whites (highlights) seem to be blown out. I'm sure this is due to the HDR not being properly calibrated. Can you copy Bright Cinema so you can have an HDR version that can be visually calibrated using HDR content then have an SDR version for non HDR content that is calibrated with the calibration disc?
try the Spears and Munsil UHD calibration disc. I used it in conjunction with the blue filter from my DVE calibration disc. I calibrated both SDR and HDR and I'm comfortable with the results.
mudfrog likes this.
welldun is offline
post #18707 of 18948 Old 01-24-2020, 07:47 AM
DavidinGA's Avatar
Quoted: 515 Post(s)
Liked: 193
Yeah, the qc is a complete crap-shoot with these refurb's. My first 5040 refurb displayed half the image blurry no matter what I changed through it's optics. My second one that I ended up keeping has some cosmetic issues on the physical case, but I wasn't willing to risk another lottery pick and end up with something worse.
I also keep in mind that should I have problems later down the road (within the 2 year warranty window) their is a high chance Epson won't have any 5040 units left and so I'll get upgraded to a refurb 5050 unit
old corps likes this.
post #18708 of 18948 Old 01-24-2020, 07:48 AM
Frichard's Avatar
Quoted: 64 Post(s)
Liked: 25
Way too smal for this pj. It would also be a waste since you can't get a big screen in that room. Heat would probably be a problem also.
This room would be nice for a tv. You would get a better picture and an appropriate size screen.
4x Micca M-8C
Paradigm PW-2200
Frichard is offline
post #18709 of 18948 Old 01-24-2020, 07:51 AM
Superman2's Avatar
Quoted: 56 Post(s)
Liked: 31
I just did it but still getting HDR per the menu - 4k/60 8 bit 4:2:2 BT.2020 HDR
post #18710 of 18948 Old 01-24-2020, 08:02 AM
Frichard's Avatar
Quoted: 64 Post(s)
Liked: 25
Hmm if I remember correctly it did the trick on my Nvidia Shield . . . maybe I'm wrong!
Is the 5040ub force to SDR?
4x Micca M-8C
Paradigm PW-2200
Frichard is offline
post #18711 of 18948 Old 01-24-2020, 08:12 AM
Superman2's Avatar
Quoted: 56 Post(s)
Liked: 31
I have a 4010, not sure how to force SDR
post #18712 of 18948 Old 01-24-2020, 08:14 AM
Quoted: 1150 Post(s)
Liked: 325
4K 60Hz HDR at 8bit will fit in 10GB bandwidth, it will not fit in 4K 60Hz HDR in 10bit.
noob00224 is online now
post #18713 of 18948 Old 01-24-2020, 08:16 AM
Superman2's Avatar
Quoted: 56 Post(s)
Liked: 31
I’m just trying to eliminate HDR alltogether as it’s too washed out and dark compared to regular SDR. I’d like to keep the 4k if possible, with SDR.
post #18714 of 18948 Old 01-24-2020, 08:22 AM
Frichard's Avatar
Quoted: 64 Post(s)
Liked: 25
Oh!! Didn't notice that!
You should ask that in the 4010 forum then !!
https://www.avsforum.com/forum/68-di...l#post58916234
4x Micca M-8C
Paradigm PW-2200
Frichard is offline
post #18715 of 18948 Old 01-24-2020, 08:25 AM
Liked: 325
What's the source?
post #18716 of 18948 Old 01-24-2020, 08:28 AM
Superman2's Avatar
Quoted: 56 Post(s)
Liked: 31
Pretend I have the 5040.
Source is 4k Firestick. Trying to stop it from using HDR.
For example, with an Xbox I can simple uncheck HDR10 and all is well.
post #18717 of 18948 Old 01-24-2020, 08:37 AM
Liked: 325
Not sure how to strip the HDR and keep the resolution.
The Panasonic UB420/800/9000 has been mentioned in dealing with too dark HDR.
post #18718 of 18948 Old 01-24-2020, 09:22 AM
Frichard's Avatar
Quoted: 64 Post(s)
Liked: 25
Alright, upon reading a little.
There's no way on the firestick to fully disable HDR. Adaptive being your best bet.
Adaptive will send HDR signal only if the display supports it.
So like I said before. Try to force SDR on your 4010.
In the 5040ub it's under Signal > Advanced > Dynamic Range
Superman2 likes this.
4x Micca M-8C
Paradigm PW-2200
Frichard is offline
post #18719 of 18948 Old 01-24-2020, 09:56 AM
Liked: 4
Yup! It's "normal" !
I don't think they do much quality control unfortunately.
I'm waiting on my third projector . . .
LOL Same. We are probably trading with each other. One point I made, was that I was not going to check a website every day and call THEM. They can call me, and they did, third one should arrive by Mon.
lastditch is offline
post #18720 of 18948 Old 01-24-2020, 10:41 AM
Quoted: 17 Post(s)
Liked: 0
Ooh, that is extremely helpful! So if I force SDR my xbox one x should not have an issue with 4k right?
Odysea is offline
5040ub power , atmos , filter
