ML750ST 17ms input lag - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 09-19-2016, 03:27 AM - Thread Starter
Liked: 0
Hi,
I need a projector with low input lag for a science virtual reality project. SXGA resolution is fine. Luminance isn't critical either, I will project onto a small screen of ~ 20cm width. (I am willing to adjust the internal lenses if necessary and possible.)
searching online, I am across the optoma ML750ST which is advertised with 17ms input lag.
(As a new user, I am not allowed to post links but you can find the specs on the optoma web page obviously)
Several online reviews repeat that figure but I am not sure I trust it because this would represent a drastic improvement over any other projector tested on projectorcentral for example. Typical seems more like 30ms - for really good projectors. The ~17 ms suggest that the input lag is exactly one frame at 60Hz. Or maybe someone mistook input lag for frame rate somehow and this perpetuated throughout the advertisement?
I was hoping anyone here might own this projector and could share a measurement or some thoughts?
jlarsch is offline
input lag , Optoma
