Throw Distance Calculator - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 09-21-2016, 08:29 PM - Thread Starter
Quoted: 496 Post(s)
Liked: 187
Did projector central change their projector throw calculator? I am getting a Epson 6020 next week and it showed I could throw a 120" screen at under 12' but would be "too bright". Now it says I cant throw a 120" screen under 13.7'
Theriddler07sms is offline
post #2 of 7 Old 09-21-2016, 09:49 PM
PioManiac's Avatar
Quoted: 3341 Post(s)
Liked: 8449
9 times out of 10 when I see a post similar to this,
someone has neglected to correctly use the zoom slider in the top left corner
edit,
just checked...
The Unfinished Basement Theater & Whisky Guitar Lounge | Bass EQ for Filtered Movies
JVC DLA X750 4K Projector | 120" Powered Drop Screen | 65" LG 65B6P OLED | Panasonic DMP UB900 | Oppo UDP 203 | HDFury Vertex
Yamaha RX-A3070 | 7.4.4.4 | Mission M3i x11 | Funk Audio 18.0 x2 | Velodyne DLS 5000R x2 | Crowson LvL3 MA x4 | miniDSP 2x4HD
PioManiac is offline
post #3 of 7 Old 09-22-2016, 12:54 AM - Thread Starter
Quoted: 496 Post(s)
Liked: 187
edit,
just checked...
Haha, sorry I saw the slider however, in the 3 times I loaded the site, I got two different calculators. Not sure why.
post #4 of 7 Old 09-22-2016, 01:34 AM - Thread Starter
Quoted: 496 Post(s)
Liked: 187
Turns out there is a calculator classic and calculator pro. Google kept taking me to the classic which shows a different throw distance than the pro. Thank you @PioManiac for showing me i wasnt losing my mind.
post #5 of 7 Old 09-22-2016, 06:19 AM
PioManiac's Avatar
Liked: 8449
nope,
works the same for both
Classic:
If you got a max range of ~13' , you probably had the screen width at 120" instead of diagonal
ID:	1675745   Click image for larger version
post #6 of 7 Old 09-22-2016, 07:41 AM - Thread Starter
Quoted: 496 Post(s)
Liked: 187
You are correct. Once again I fail at life.
post #7 of 7 Old 09-22-2016, 08:01 AM
PioManiac's Avatar
Liked: 8449
LoL!
