Sony ES45 or Epson 5030 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-22-2016, 05:06 PM - Thread Starter
vid53's Avatar
Quoted: 63 Post(s)
Hi Everyone
I am getting ready to purchase either one of these projectors. My preferences is a bright sharp picture. I always put my TVs on dynamic settings. The projector is 14 feet away from a 120 inch Jamestown Acoustic Home Theater Screen in the basement. The ceiling is white and the walls light gray.For the most part the lights will be off. Both of these projectors seem very good but i was wondering if the Epson is much brighter. Hope some of you can give me your advice.
Thank you
vid53 is offline
post #2 of 4 Old 09-23-2016, 12:24 PM
spiroh's Avatar
Quoted: 64 Post(s)
Liked: 25
I think you need to look at calibrated lumens to get a better idea on brightness. I believe if you look at that category the 45es is a little better over the 5030. I have white ceilings and gray walls and the 45es is working out great for me.
spiroh is offline
post #3 of 4 Old 09-23-2016, 01:43 PM
rekbones's Avatar
Quoted: 942 Post(s)
Liked: 488
You need to read this thread, I know its long but will give you all the pros and cons. Remember the 45es has some improvements over the 40es. https://www.avsforum.com/forum/68-dig...ight=sony+es40
"Smart enough to know better, to old to care" ------ Dedicated Bat Cave Home Theater, JVC RS49U/Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 18TB DroboFS NAS
rekbones is offline
post #4 of 4 Old 09-23-2016, 06:05 PM - Thread Starter
vid53's Avatar
Quoted: 63 Post(s)
vid53 is offline
