Powerlite 3010 (H421A) Temp and Lamp lights flash red - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 10-05-2016, 07:28 PM - Thread Starter
asand211's Avatar
When I turn the unit on it appears to start to warm up and then the lamp and temp lights both start flashing red and it shuts down. Epson says that error requires a factory repair. I'm hoping someone here can guide me to the problem so I can possibly repair it. It's tough because I don't know exactly what is failing due to the information provided by EPSON. Thanks in advance.
asand211 is offline
post #2 of 7 Old 10-17-2016, 07:21 PM - Thread Starter
asand211's Avatar
Not a single response?
asand211 is offline
post #3 of 7 Old 10-18-2016, 05:23 PM
Verge2's Avatar
Quoted: 916 Post(s)
Liked: 244
Error codes in the manual, did you think to look in there?
Verge2 is offline
post #4 of 7 Old 10-18-2016, 05:38 PM - Thread Starter
asand211's Avatar
First thing I did. Manual tells you nothing about that particular code other than to send it in to them to be repaired. I was hoping someone could clarify as to exactly what that particular error code points to. I'm guessing the main board, however, that's not a cheap part so I don't want to buy and hope.
asand211 is offline
post #5 of 7 Old 10-18-2016, 07:34 PM
Verge2's Avatar
Quoted: 916 Post(s)
Liked: 244
You can start buying replacement parts off eBay and trying them one by one. I'd start with a ballast. This could get expensive FYI.
Verge2 is offline
post #6 of 7 Old 07-04-2020, 10:16 PM
Liked: 0
I know this is an old post. Have you solved the problem? I am having the same problem with same projector. Hope I will get your reply.
seattleweather is offline
post #7 of 7 Old 07-05-2020, 07:35 PM
tibimakai's Avatar
Quoted: 240 Post(s)
Liked: 70
Check out the manual. There is a troubleshooting section and it shows different error codes, how they look and what they represent.
http://files.support.epson.com/pdf/p...&pagemode=none
Just an example, if a fan does not spin at a specific RPM, it will throw a code.
Living Room: Samsung UN65JS8500,Onkyo TX-NR676,Klipsch R-28F,Klipsch RC-62II,Klipsch R-14S,Polk Audio 80 FX/RT(Atmos)
Bedroom: Samsung UN55MU6290,Onkyo TX-RZ610,Klipsch RP-160m,Onkyo & Fluance speakers
Garage: Epson 5040UB,Elite Screens 125" motorized screen,2xKlipsch RP-8000F,4xKlipsch RP-150M,Klipsch RP-450C ,2xKlipsch CDT-3800CII/2xCDT3650CII,Klipsch R115SW/R110SW
tibimakai is offline
