Official Sony VPLHW45ES Owners Thread - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 177Likes
post #541 of 646 Old 01-11-2019, 08:17 PM
madermat's Avatar
Quoted: 59 Post(s)
Liked: 29
hmm strange may not be the bulb maybe the source
madermat is offline
post #542 of 646 Old 01-13-2019, 06:15 AM
Utkarsh Dalmia's Avatar
Hi, having this problem of a pink cloud like blemish in the bottom of the image, only really visible against a white background. Lamp is at 2200 hours. Any idea what it could be ?
Sent from my Redmi Note 4 using Tapatalk
Utkarsh Dalmia is offline
post #543 of 646 Old 01-13-2019, 04:10 PM
73shark's Avatar
Quoted: 561 Post(s)
Liked: 280
Does it flicker on high?
In space, no one can hear you scream . . .
73shark is offline
post #544 of 646 Old 01-13-2019, 09:04 PM
Hi, thanks for taking the time to reply.
There are no other problems with the projector, no flickering etc. By high I assume you mean the lamp mode set to normal rather than low ?
post #545 of 646 Old 01-14-2019, 08:25 AM
Despoiler's Avatar
Quoted: 101 Post(s)
Liked: 74
Originally Posted by Dandion View Post
flickering occurs only when watching television? no flickering when watching netflix or blu ray?
What is your signal chain? How are you watching TV vs netflix or bluray?
|| Samsung N8000 || Oppo Digital UDP-203 || Chromecast Ultra ||
|| Quad S-2 || Pass ACA Amp ||
Despoiler is offline
post #546 of 646 Old 01-14-2019, 09:09 AM
Dandion's Avatar
Quoted: 95 Post(s)
Liked: 40
Talking
Like someone pointed out earlier, the source was my problem.
i watch TV from Cable provider
i watch netflix from Chromecast
I watch blu ray with blu ray player panasonic.
I reset the TV cable box and all flickers are gone!
Daniel
RX-A3050 with 5.2.4
Martin Logan motion 40, 50xt, FX
Dual ULS-15 mk2
JVC DLA X790R, 100'' Elunevision
DVP-5000St
Dandion is offline
post #547 of 646 Old 01-17-2019, 12:26 PM
Quoted: 25 Post(s)
Liked: 0
How you guys setting your focus so its dead on?
dremmick is offline
post #548 of 646 Old 01-23-2019, 06:03 AM
Liked: 0
Question New Sony VPL-HW45 is this noise normal ? Please help
Hi everyone,
I m quite new to this videoprojection setup and have just received a Sony vpl-hw45 with a fantastic image.
I am pretty disapointed though with the noise. The fan noise is OK but there is another noise or buzz that is audible anywhere in the room even if not very loud. It is kind of deal breaker for me so i need to know if mine is faulty or this is the "very quite" projector everyone is bragging about.
Please help because i got to make a decision whether i send it back or not.
I unfortunately can't post a link as this is my first post on the forum and i need to have 5 at least.
Thank you!
All the best
jjapp is offline
post #549 of 646 Old 01-23-2019, 06:05 AM
Liked: 0
I have a dropbox link ready with the noise recorded.
jjapp is offline
post #550 of 646 Old 01-23-2019, 06:25 AM - Thread Starter
Brian Hampton's Avatar
Quoted: 1503 Post(s)
Liked: 918
Welcome.
If you have a SPL meter take a measurement. There are free phone SPL meters also
I use the IOS App db meter
(And sometimes an old RS meter.)
Here's a few VW45 threads.
https://www.avsforum.com/forum/68-di...rs-thread.html
https://www.avsforum.com/forum/68-di...successor.html
Brian Hampton is online now
post #551 of 646 Old 01-23-2019, 06:28 AM
Liked: 0
Thank you Brian. I will check it out tirght now. Maybe i can send you the link in PM ?
jjapp is offline
post #552 of 646 Old 01-23-2019, 02:35 PM - Thread Starter
Liked: 918
The SPL meter data will be more useful.
I have gone from the 45 to a VW285 and I KNOW my new PJ is louder than the 45 was. Once you take a measurement we should be able to tell if it's off base.
post #553 of 646 Old 01-23-2019, 02:56 PM
keeper's Avatar
Quoted: 609 Post(s)
Liked: 251
Just curious how those two pjs compare?
keeper is online now
post #554 of 646 Old 01-23-2019, 03:04 PM - Thread Starter
Liked: 918
Well...
I went from VPH1271, to G70, to VW60, HW30, HW45, VW285ES.
The HW45 is excellent. I would say they perfected the 1080p PJ with the HW45.
The VW285 is more of a beginning of sorts. It's not Sony's first 4K PJ but it is early in the 4K models evolution. It doesn't have the right bandwidth to do 4K HDR at 60Hz without banding. If you keep it to 24 fps it's fine.
The VW285 is a bit louder. It's nearly louder in Low than the HW45 in HIGH. ... Or maybe it is. The noise of the VW285 bothers some people. My older CRT Fps had more fans and I adjusted to the louder VW285 pretty easily. I think it's still under 50db.
The Bulb in the VW285 is supposed to last a lot longer... I don't know about that ... time will tell.
There's a big bug with ATV4K and VW285ES HDR. This may be fixed soon by Sony (it has been fixed with the Laser based models a bit higher up on the product line.) Turning off HDR works and the HW45 isn't HDR so there's no real comparison there.
The VW285 is "REAL" native 4K so there's a lot more pixels. I would say the PQ is higher with every source. 3D I Think is much better on the VW285. I could never dial out the ghosting on the HW45. 3D was better on the HW30 actually.
-Brian
post #555 of 646 Old 01-23-2019, 03:49 PM
keeper's Avatar
Quoted: 609 Post(s)
Liked: 251
Well...
-Brian
Thanks for the info. I have the hw40 and am waiting to see if they update the 45 with a new pj.
post #556 of 646 Old 01-24-2019, 05:26 AM
Legairre's Avatar
Quoted: 1216 Post(s)
Liked: 664
The 40 & 45ES are both incredibly quiet. Can you pm me a link to the noise?
"What do you mean it's too loud? My ears aren't even bleeding yet!"
Dedicated ARC Genesis Thread
Legairre is offline
post #557 of 646 Old 01-24-2019, 06:03 AM
Liked: 0
Hi Legairre, thanks for your message. I actually can't send a pm as i am a newbie with not enough posts (15 needed)
jjapp is offline
post #558 of 646 Old 01-24-2019, 06:08 AM
Liked: 0
I have read around that it could be a problem with the power supply and was advised to get in touch with sony prime support, what i have done.
jjapp is offline
post #559 of 646 Old 01-24-2019, 06:10 AM
Liked: 0
But hey i can post the link now !
https://www.dropbox.com/s/rp0lozexdj...0hw45.m4a?dl=0
jjapp is offline
post #560 of 646 Old 01-24-2019, 07:57 AM
Dave in Green's Avatar
Quoted: 3792 Post(s)
Liked: 3008
@jjapp , that sounds like defective electronics. Could very well be the power supply. Definitely a warranty issue.
jjapp likes this.
Dave in Green is offline
post #561 of 646 Old 01-27-2019, 05:50 AM
Quoted: 23 Post(s)
Liked: 9
Hi everyone,
Thank you!
All the best
FYI My wife has laser hearing and can’t hear our projector in a 400 square for room 4 feet away from it. Even when I sit under it I would have to focus hard to hear it with a show on. My assumption would be there is a problem with it based on your account and my experience.
LeisureDave is offline
post #562 of 646 Old 01-27-2019, 09:21 AM
Quoted: 23 Post(s)
Liked: 9
So regarding picture optimization : everyone seems to think film2 and ref are pretty great out of the box. I have the Disney WOW dvd, is it worth spending the time to run through it? I got tot the black level test and it didn’t need any tweaking- so I figured I’d ask if anyone has found it worth while to further optimize their settings. Thanks
post #563 of 646 Old 01-28-2019, 10:20 AM
Quoted: 23 Post(s)
Liked: 9
Does anyone have 3D glasses sync issues? I am using my Samsung 3100gb glasses and several pairs loose sync during the film and take a lot of effort to re connect. Other pairs do not seem to remember the connecting and act like a first time setup. Anyone else have any issues?
post #564 of 646 Old 01-28-2019, 11:03 AM
madermat's Avatar
Quoted: 59 Post(s)
Liked: 29
i would use your WOW disk i used the speers disk and made some small adjustments contrast went down to 89 and brightness had to go to 52 or 53 i think ,so its worth the time if you like to tinker.
LeisureDave likes this.
madermat is offline
post #565 of 646 Old 01-28-2019, 03:03 PM
Luminated67's Avatar
Quoted: 689 Post(s)
Liked: 384
Would have to agree that Sony perfected 1080p with the 45.
As for noise, mine sits directly over head, like with 2.5ft of where my head is... you can definitely hear it but once the sound system is on even at modest volume the Sony’s noise disappears.
Epson EH-TW9400 - QualGear Fixed Frame 100” - Sony x700 BRP & Panasonic 420 BRP - Sony 1080 AVR - IPL Acoustics M1TLs & IPL Acoustics AVC Pro Centre, Four KEF surrounds & 2 Sub boxes (10” Sub + 10” Passive Radiator)
Luminated67 is offline
post #566 of 646 Old 01-28-2019, 11:22 PM
Liked: 0
Thanks for your input. I ve contacted Sony and i am now waiting for a new unit. I very much hope it will be as silent as everybody says.
jjapp is offline
post #567 of 646 Old 01-31-2019, 04:15 AM
Quoted: 23 Post(s)
Liked: 9
Thanks! I will give it a shot!
post #568 of 646 Old 02-01-2019, 06:48 AM
Liked: 0
Hmmm, how would you describe the noise ? Air bliss or constant fan mecanical noise like the one i recorded ?
I have received a brand new unit and it has the same sound/noise. I don't get it, maybe i am very sensitive because of my work (sound engineer) ? Well actually my wife finds also the noise quite irritating.
Hmmm..
EDIT: Ok i have to be fair, the noise is slightly quieter. More acceptable but still noticable.
jjapp is offline
post #569 of 646 Old 02-01-2019, 07:50 AM
Legairre's Avatar
Liked: 664
Hmmm..
Mine is 4 feet above out heads and even on high lamp mode we'd have to stop talking and really try to hear it. On low lamp mode you can't even tell it's on even if you really listen for it.
When you recorded the sound of the projector how far away from the projector were you?
Legairre is offline
post #570 of 646 Old 02-01-2019, 09:30 AM
Quoted: 689 Post(s)
Liked: 384
Hmmm..
I think you must be very sensitive because even with the projector just above my head I can hear the bluray player spinning up when the sound system is off and it’s 3 meters away right below the screen.
