Optoma HD20 broken? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-07-2017, 03:14 PM - Thread Starter
0rchid's Avatar
Question Optoma HD20 broken?
Hi there,
I've just come home from a trip and found that my Optoma HD20 appears to be broken.
When I turned it on, I don't get the usual Optoma logo, but instead the attached static broken by a black bar.
Prepared to replace - it's served me well since 2012 - but interested in what might have broken, and whether it can be repaired?
I had the 'vertical lines' issue a couple of years ago, which went away when I pushed on top of the bulb, I don't know if that's relevant?
0rchid is offline
post #2 of 7 Old 06-07-2017, 06:16 PM
jasonsong's Avatar
Quoted: 493 Post(s)
Liked: 185
Seems like DMD took a crap.
7.2: Yamaha RX-A830 | Klipsch Synergy F30 + C20 + Sub12x2 + Onkyo HTIB Surrounds | Epson HC2040 Silver Ticket 120 inch Grey Screen
5.1: Yamaha RX-V475 | Mirage Omni 550 Onkyo HTIB Center + Surrounds + 12 inch Sub | Samsung 55 inch Smart 3DTV
jasonsong is offline
post #3 of 7 Old 06-08-2017, 02:10 AM - Thread Starter
0rchid's Avatar
Hmm. I see!
Is there anything I can do about that? Or anything further I can do to diagnose?
0rchid is offline
post #4 of 7 Old 06-11-2017, 04:15 AM - Thread Starter
0rchid's Avatar
Is there any other info that would be useful to gather to try and figure this out? Or is the proj done for?
0rchid is offline
post #5 of 7 Old 06-11-2017, 10:17 PM
rekbones's Avatar
Quoted: 914 Post(s)
Liked: 477
If your comfortable disassembling the projector reseating all of the connectors may cure your problem. Connectors are delicate and parts are broken easily so this is not a job for non technically inclined.
"Smart enough to know better, to old to care" ------ Dedicated Bat Cave Home Theater, JVC RS49U/Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 18TB DroboFS NAS
rekbones is online now
post #6 of 7 Old 06-12-2017, 04:09 AM - Thread Starter
0rchid's Avatar
Thanks very much! I've taken it apart once before, so while not an expert, I'd be happy to give that a go before buying a replacement. Cheers, I will report back!
0rchid is offline
post #7 of 7 Old 06-12-2017, 11:12 PM - Thread Starter
0rchid's Avatar
I fixed it! Thanks very much for the idea. I tore it down to below the main board and gave the Dmd/main board socket a good clean with some Servisol and reseated and it's back to its usual self. And I only damaged one ribbon connector holder and left one spare spacer on reassembly. £500 saved for now.
0rchid is offline
hd20 , Optoma
