Optoma UHD60/65 Owners Thread - Page 60 - AVS Forum | Home Theater Discussions And Reviews
 4533Likes
post #1771 of 3506 Old 11-16-2017, 04:46 AM
Quoted: 46 Post(s)
Liked: 4
I am using Mediabridge 91-02X-35B Ultra Series HDMI Cable - 35-Feet.
Do you think the above cable will not work with X800??
Pokmm is offline
post #1772 of 3506 Old 11-16-2017, 06:47 AM
Quoted: 37 Post(s)
Liked: 3
Not sure, there are hundreds of choices out there. I went with a cable i know worked for others. It wasnt a cheap option but i had to bury it in ceiling so i went one avail from Amazon fiber optic hdmi. I do know that ones that say uhd 4K over 25 feet copper cables are hit or miss.
Johnico is offline
post #1773 of 3506 Old 11-16-2017, 08:57 AM
RoNNy379CH's Avatar
Quoted: 270 Post(s)
Liked: 334
Hi vagos1103gr1,
In my case - (Yamaha CX-A5100) i got the official statement from Yamaha. The max. length for RGB 4:4:4 / 12bit / HDR / 4k60 18gbps Signal transfer is max. 7.5m.
No other copper cable with length >7.5m will work so i invest to a 15m optic cable witch works perfect with my CX-A5100 / UHD65 now.
Brand RUIPRO 50ft --> CLICK
I tried many brands and many repeaters or HDMI booster - all with out access.
RoNNy379CH is offline
post #1774 of 3506 Old 11-16-2017, 09:49 AM
Chris Blount's Avatar
Quoted: 109 Post(s)
Liked: 106
Almost any copper cable over 25 feet most likely will not work. You will need a fiber cable.
Chris Blount
Chris Blount is offline
post #1775 of 3506 Old 11-16-2017, 10:13 AM
Quoted: 14 Post(s)
Liked: 8
I use this cable: https://www.monoprice.com/product?p_id=14474, and it works perfectly fine @ 35 feet. 4K, 60Hz, HDR, etc.
Verworren is offline
post #1776 of 3506 Old 11-16-2017, 12:36 PM
vagos1103gr1's Avatar
Quoted: 126 Post(s)
Liked: 39
I use the same cable for 25 ft and in nvidia shield I don’t have the option of 4k60 444 chroma 12 bit. The maximum I can get is 422 12 bit Bt 2020 with some artifacts on several scenes and I have to return to recommended 4k60 420 10 bit bt2020. I am wondering if I go with the fiber is gonna give me that option. I am waiting the Xbox one x to see if Gonna give me 4k60 444 12 bit.
vagos1103gr1 is online now
post #1777 of 3506 Old 11-16-2017, 01:47 PM
Quoted: 36 Post(s)
Liked: 4
Award Winner
Last night the What hifi magazine in the UK disclosed their annual award winners. The UHD65 is their product of the year, in projectors.
https://www.whathifi.com/features/best-29-products-2017
Troy LaMont likes this.
Peter DS is offline
post #1778 of 3506 Old 11-16-2017, 02:03 PM
ehab's Avatar
I am in a country where there are very limited options for projectors so I can not demo the uhd60, so I ask has anyone seen it in comparison to an Epson home cinema 2040 in relation to color accuracy, contrast and skintones. I have the Epson but I want my upgrade to be an upgrade in all areas of picture quality not just resolution.
ehab is offline
post #1779 of 3506 Old 11-16-2017, 02:21 PM
Quoted: 37 Post(s)
Liked: 3
Originally Posted by RoNNy379CH View Post
Hi vagos1103gr1,
Thats the cable i have and it works great.
Johnico is offline
post #1780 of 3506 Old 11-16-2017, 02:44 PM
ttn333's Avatar
Quoted: 190 Post(s)
Liked: 119
I have UHD65, I tried to hook Sony UBP-X800 4K player, but some reason display not coming.. says no source found.
I tried with directly connecting with PJ and tried with through AVR(Denon 4300), but same result (No display).
Any inputs?
I'm using monoprice slimrun fiber on the 65 with both Xbox one x and x800 through the 4300 with no problem here.
NAD T758v3, Emotiva XPA-3, XPA-5, UPA-5, JTR Triple 12 LP L/C/R, Htm-6 surrounds, Volt 6 atmos, SVS PC13 Ultra and JTR Cap 2400 ULF - Denon x2400h, Elac Debut F5, Elac Debut C5, Elac Debut A4, Klipsch r-12swi - Stereo Totem Mite
ttn333 is offline
post #1781 of 3506 Old 11-16-2017, 04:05 PM
nunyabiziz's Avatar
Quoted: 41 Post(s)
I might be wrong but current hdmi 2.0a supports up to max 4k60 4:4:4 8bit, anything more will exceed the cable's max bandwidth of 18Gbps
Sent from my SM-G955U using Tapatalk
nunyabiziz is offline
post #1782 of 3506 Old 11-17-2017, 06:10 AM
Quoted: 14 Post(s)
Liked: 8
I was just about to post this.
@vagos1103gr1
Link for reference: https://www.hdmi.org/manufacturer/hd...i_2_0_faq.aspx
You'll need to drop below 60Hz in order to get 4:4:4 12 bit.
Edit: Fiber or no fiber, the HDMI 2.0 port on your source device will only output a maximum of 18Gbps, so even if you have a cable capable of carrying a much higher data rate, it's still capped at the bandwidth maximum for that HDMI port standard. Use the link I posted above to see what options you have while staying under the data limit.
post #1783 of 3506 Old 11-17-2017, 07:08 AM
coderguy's Avatar
Quoted: 2963 Post(s)
Liked: 1563
Just FYI to anyone needing mounting help with this PJ...
It is now in the calculator in my sig...
carpenn and The.KT like this.
**Updated Projector Calculator Released NOV 2017**
-- www.webprojectorcalculator.com --
coderguy is offline
post #1784 of 3506 Old 11-17-2017, 12:09 PM
Quoted: 126 Post(s)
Liked: 39
The point is on nvidia shield when I drop in to 30 hz I don’t see the option for 444 12 bit. How RoNNy379CH achieved 444 12 bit with his oppo player. Maybe the problem is the hoss 25 ft active hdmi cable from monoprice? Should I invest to fiber optic?
post #1785 of 3506 Old 11-18-2017, 12:01 PM
Liked: 1
Originally Posted by BladeZX View Post
I have the UHD65 and an xbox one X and I have not noticed any input lag.
I play Gears 4 just fine
Hope that helps
Same here- I have been playing COD WWII and Assassins creed- No noticeable lag- I just came from a Sony VPL-HW45 which i loved, but the UHD65 in 4k Gaming is unreal-
ktcoady123 is offline
post #1786 of 3506 Old 11-18-2017, 12:28 PM
Liked: 1
Game Calibration Settings
Hello,
Does anyone have a preferred calibration for gaming on the UHD65? I am using "game mode" and playing with XBOX one X- already looks amazing, just wondering if anyone had any recommended tweaks-
I have not had an issue with LAG either- has not been noticeable to me at all- Thank you
naijalife likes this.
post #1787 of 3506 Old 11-18-2017, 12:47 PM
Dave Harper's Avatar
Quoted: 3159 Post(s)
Liked: 1723
Hi vagos1103gr1,
No cable will work, even ones less than 7.5 meters , and neither will the current crop of HDMI sinks, transmitters, etc. It's well past it's spec ratings. See below.
The option doesn't exist yet in the market, so the current xbox won't ever give you that.
You're not wrong. You're correct.
He didn't achieve that. As said before that is well beyond specs, as said above and as seen in this chart. He is clearly mistaken.
Dave Harper is offline
post #1788 of 3506 Old 11-18-2017, 01:38 PM
Quoted: 37 Post(s)
Liked: 3
Just got my Screen Innovations 3 series drop down tension screen and the uhd 65 picture looks unreal on it.
Blasst likes this.
Johnico is offline
post #1789 of 3506 Old 11-18-2017, 01:49 PM
Quoted: 126 Post(s)
Liked: 39
Thanks Davie for your clarification, so that mean 4k30 444 10 bit can be achieve on uhd65, so why nvidia shield doesnt give me these option when i change to 4k30 ?
post #1790 of 3506 Old 11-18-2017, 02:51 PM
RoNNy379CH's Avatar
Quoted: 270 Post(s)
Liked: 334
I can force the output via Oppo UDP205 to 2160p UHD 60Hz 12bit 4:4:4 with full HDR support.
woodhead2 likes this.
post #1791 of 3506 Old 11-19-2017, 09:13 PM
erikatcuse's Avatar
I have a question on my screen. I Just set up my UHD65 on a temporary shelf and have the Elite Screens Designer Cut cloth (135" diagonal) hanging temporarily on the wall.
Since I can create any size aspect ratio I was looking at building a 2.39:1 screen. I didn?t see any options under aspect ratio to pick this ratio. Is this aspect ratio screen even an option? I started reading about lens memory which this projector does have and I don?t want an anamorphic lens.
This is my first projector and dedicated home theater and I want to make sure I get it right
Erik
HTPC with MCE
UnRaid Media Server - lots of storage and growing
erikatcuse is offline
post #1792 of 3506 Old 11-20-2017, 06:18 AM
Quoted: 301 Post(s)
Liked: 76
Anyone coming from a Benq w1070 how is the PQ vs uhd60-65?
jsil is offline
post #1793 of 3506 Old 11-20-2017, 01:24 PM
naijalife's Avatar
This makes me happy
xpostal likes this.
naijalife is offline
post #1794 of 3506 Old 11-20-2017, 01:46 PM
naijalife's Avatar
My UHD65 comes in tomorrow and I will be getting the Xbox One X this week. I went ahead and purchased the 50 ft Ruipro fiber cable. For my short hdmi runs, will any "4K capable" hdmi be sufficient?
post #1795 of 3506 Old 11-20-2017, 02:41 PM
Quoted: 46 Post(s)
Liked: 4
Hi vagos1103gr1,
Thanks everyone.
Looks like if i want play 4k/UHD content it requires good fiber HDMI cable. But comparing with my current HDMI (Media Bridge) with Fiber (RUIPRO HDMI Fiber Cable), did not noticed much difference in terms of specs (expect [email protected] Hz/data rate)
Any how i will order RUIPRO HDMI Fiber Cable and see the difference.
Sam
Pokmm is offline
post #1796 of 3506 Old 11-20-2017, 06:59 PM
Quoted: 126 Post(s)
Liked: 39
Day night, I came from benq 1070 and after the 2050 and is a big difference. I own the uhd60 but I moved to uhd65 cause better blacks.
xpostal likes this.
post #1797 of 3506 Old 11-20-2017, 08:49 PM
Quoted: 301 Post(s)
Liked: 76
Thanks for the reply.
jsil is offline
post #1798 of 3506 Old 11-20-2017, 09:03 PM
rekbones's Avatar
Quoted: 1210 Post(s)
Liked: 613
Erik
The UHD65 does not have lens memory and is a 16:9 native projector. Without an A lens or a external processor a 2:39 screen is not advisable as you may need to physically move the projector to get a 16:9 image on a 2:39 screen. If you want the real scoop on 2:39 screens then check out the CIH screen section of this forum.
"Smart enough to know better, to old to care" ------ Dedicated Bat Cave Home Theater, JVC RS49U/Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 18TB DroboFS NAS
rekbones is online now
post #1799 of 3506 Old 11-21-2017, 11:32 PM
nykr95's Avatar
I just picked up a UHD60 to replace an EPSON 8350 - have a 100" screen. It's about 15 feet back and no problem putting exactly where the old one was. I wanted to test it to compare whether to get an 82" Samsung but this projector is great.
Better than expected. Now it is evening so I haven't tested during the daytime yet. I have a lot of windows that are wide open during the day.
Quite a bit brighter than the Epson and the 4K is great. The HDR is ok - I downloaded some test video and ran it througg an NVIDIA. The 4K is great the only delta from a flat screen is the blacks are going to be better and of course better daytime viewing. The 4K detail is as good as on a flat screen that I saw at Best Buy - just doesn't pop quite as much. But I have 100" and have room to go a bit bigger. If it ok during the day - I will keep it.
nykr95 is offline
post #1800 of 3506 Old 11-22-2017, 06:02 AM
david8613's Avatar
Quoted: 319 Post(s)
Liked: 67
besides the faux 4k, how does this projector compare to the sony 45es?
david8613 is offline
firmware , hd65 , Optoma , optoma uhd60 , uhd60 apple tv , uhd65
