Optoma UHD60/65 Owners Thread - Page 62 - AVS Forum | Home Theater Discussions And Reviews
 4524Likes
post #1831 of 3433 Old 11-28-2017, 06:47 PM
nunyabiziz's Avatar
Quoted: 41 Post(s)
Sounds like a cable issue and the Marantz might be down-converting the signal.
Sent from my SM-G955U using Tapatalk
Don Rombach likes this.
nunyabiziz is offline
post #1832 of 3433 Old 11-28-2017, 10:04 PM
Quoted: 27 Post(s)
Liked: 3
The cable I am using is a 3ft HDMI 2.0, I have 3 if them, tried all 3 with same result. Same cables get 4k60 on my Sony X800 Blu Ray player. Do you really think it?s worth getting new cables? The ones I bought meet the right specs.
DubDriver17 is offline
post #1833 of 3433 Old 11-28-2017, 10:53 PM
Quoted: 37 Post(s)
Liked: 3
I read that 3 foot cables can give folks problems. Try a 6 footer.
Johnico is offline
post #1834 of 3433 Old 11-29-2017, 03:18 AM
JRock3x8's Avatar
Quoted: 1861 Post(s)
Liked: 622
Originally Posted by ukaussi View Post
even Phil Spencer tweeted on my pic.
https://twitter.com/XboxP3/status/932393185795391488
I have a giant mancrush on Phil. I would have printed that and framed it.
JRock3x8 is offline
post #1835 of 3433 Old 11-29-2017, 01:41 PM
MillerTimeISU's Avatar
Quoted: 58 Post(s)
Liked: 52
Originally Posted by Chris Blount View Post
YES! ... and not just from the XBOX ONE. All of my boxes (Apple TV 4K & ROKU) displays that darn searching for source a lot when trying to use apps like CBS, Netflix, etc). Sometimes for no reason. Sometimes it just stops happening then starts up again.
When I first got the projector, it wasn't an issue but lately its been getting worse.
Originally Posted by lunatik4444 View Post
Hello! I am considering picking up a UHD60 and have a question for you. I would like to have a 150" screen but i only have a little over 15 feet away in which to do a ceiling mount. I see that you have a 100" screen, does that mean i might not be able to do it? this calculator says i would have to use a 1.58 zoom to accomplish, with 6" from floor to bottom of screen as i only have about 7' 10" ceiling. will the 1.58 zoom affect the image quality or have any negatives?
Another question i have and i'm really not sure of the technical term for it, but how big is the cone from the projector to the screen? in other words, how far away from the screen does someone have to be in order to not walk in the path of the image to where others can see their shadow? thanks a million for your help!
http://www.webprojectorcalculator.com/
Richard
I have UHD60 and 150" acoutically transparent screen and have my projector mounted at 19'-0" from screen wall.
Theater build thread: It's MillerTime Build Progress!
Got Kids or need a Custom Yeti Mug???
Shark Tank Wife's company she owns
Lincoln&Lexi
MillerTimeISU is offline
post #1836 of 3433 Old 11-29-2017, 01:55 PM
Quoted: 58 Post(s)
Liked: 52
UHD60 owners with Xbox One X
When you start this source what does the projector show in the lower right-hand corner for "SOURCE RESOLUTION?" Seems like my Xbox One X is showing 2160P, while my Google Chromecast Ultra is showing 3840P when I switch to the source in the lower right-hand corner.
Just wanted to understand if everyone else is seeing this or not? When I run the Xbox One X 4k advance setttings it has all the 4k items checked off in green.
Lincoln&Lexi
post #1837 of 3433 Old 11-29-2017, 02:05 PM
lunatik4444's Avatar
Quoted: 25 Post(s)
hi! I was using the above calculator to get the distance, but it's 4' off from yours. Is it because you're not using as much zoom? or did i mess up somewhere. thanks!
lunatik4444 is offline
post #1838 of 3433 Old 11-29-2017, 02:30 PM
Quoted: 58 Post(s)
Liked: 52
I only adjusted the manual on the bottom of the projector about half a turn. I do not have any digital zoom from the setting applied.
Lincoln&Lexi
post #1839 of 3433 Old 11-29-2017, 03:33 PM
ukaussi's Avatar
Quoted: 18 Post(s)
[email protected] (which is 4K)
MillerTimeISU likes this.
_________________________________________
130" of 4K HDR picture via XBox One X - Optoma UHD60
Monoprice SlimRun AV HDR Cable for HDMI Enabled Devices, [email protected], YUV4:4:4, 30ft
ukaussi is offline
post #1840 of 3433 Old 11-29-2017, 04:16 PM
Quoted: 58 Post(s)
Liked: 52
Wonder why the Chromecast Ultra displays the high value when the source pop-up is shown when switching to it?
Lincoln&Lexi
post #1841 of 3433 Old 11-29-2017, 05:12 PM
rmerlano's Avatar
Quoted: 104 Post(s)
Liked: 36
Originally Posted by madbrain View Post
For HDR you'll want an HDR calibration disc, which doesn't exist yet.
http://diversifiedvideosolutions.com/dvs_uhdhdr-10.html
Oppo UDP-203 - Receiver Denon X4300H - Projector Optoma UHD65 - Projection Screen Elite Screen Mate White 150" gain 1.1
5 Channels Amplifier Emotiva XPA-5 - NAS Qnap 412 4x3TB Disks.
JBL Synthesis : LS80, LS Central, Subwoofer 1 x HSU VTF-15H MK2 setup for ATMOS 7.2.4
rmerlano is offline
post #1842 of 3433 Old 11-29-2017, 07:23 PM
Quoted: 46 Post(s)
Liked: 4
I got the RUIPRO HDMI cable and my UHD65 not recognizing any idea? Is issue with cable? I tried the cable to tv and getting display without issue in tv. I tried other hdmi cable to my projector, no issue with display. Confused... not sure 65 not getting any display/sound when using RUIPRO HDMI cable..
Appreciate any help..
Pokmm is offline
post #1843 of 3433 Old 11-29-2017, 07:51 PM
Don Rombach's Avatar
Quoted: 18 Post(s)
Yikes. That sounds like a dilemma.
Hoping you get a answer as I'll be setting up my 65 with the same cable Saturday.
You do have the cable input/output ends correct I assume.
Big D
Don Rombach is offline
post #1844 of 3433 Old 11-30-2017, 06:03 AM
Quoted: 25 Post(s)
Thanks Miller!
post #1845 of 3433 Old 11-30-2017, 08:00 AM
Quoted: 46 Post(s)
Liked: 4
Yes, this is really confused and put me in dilemma.
Pokmm is offline
post #1846 of 3433 Old 11-30-2017, 08:01 AM
Quoted: 46 Post(s)
Liked: 4
Pokmm is offline
post #1847 of 3433 Old 11-30-2017, 08:29 AM
Quoted: 182 Post(s)
Liked: 70
Your Chromecast is 8K
Sent from my SGP771 using Tapatalk
XBR55X700D/Optoma UHD60
Denon AVR-X8500H
14 Gigaworks S750 Cubes
Acoustimass 15 Series 2 Sub
Too much to list here :)
Anh Nguyen is offline
post #1848 of 3433 Old 11-30-2017, 04:43 PM
Quoted: 18 Post(s)
So what source is it that won't sync to the PJ?
I gather you are having this problem with a direct feed from source to PJ? If so, perhaps try it with either a compliant HDMI switch or AVR?
Thinking it's a glitch in the RUPRO cable chipset specific to your combo. If so, maybe adding another layer between the two may help.
Big D
post #1849 of 3433 Old 11-30-2017, 07:14 PM
Quoted: 37 Post(s)
Liked: 3
Interesting. I have the same cable and Im running it straight from my Sony x800 to uhd65 and it works. Im going to hook it up to my Denon avr 4300 tomorrow. See if it still works. These handshacks get finicky.
Not sure what Ill do if it doesnt work seeing my cable is buried in ceiling.
Johnico is offline
post #1850 of 3433 Old 11-30-2017, 09:32 PM
Redskin's Avatar
Quoted: 65 Post(s)
I just picked up a UHD65. Can this projector be shelf mounted up close to the ceiling, or do I need to buy a ceiling mount?
Greg
Redskin is offline
post #1851 of 3433 Old 11-30-2017, 09:45 PM
bix26's Avatar
Quoted: 753 Post(s)
Liked: 402
Greg
You will need to hang it on the ceiling, it only has a minor amount of lens shift.
bix26 is offline
post #1852 of 3433 Old 12-01-2017, 04:16 AM
Quoted: 18 Post(s)
Just found out my 2 short HDMI cables are delayed in transit till Monday.
Can someone confirm that the cheapo looking cable that comes with the UHD65 actually is 2.2?
If not, I need to pick one up on the way home from work.
Big D
post #1853 of 3433 Old 12-01-2017, 06:43 AM
Besmeses's Avatar
Liked: 2
Yes, the HDMI cable that comes with UHD65 is HDCP 2.2 compliant. I am able to watch movies and games at 4K60. I'm also using the Monoprice Certified Premium High Speed HDMI Cables to connect my Panasonic UB900 and Roku Ultra to my receiver (Yamaha A1060). All work flawlessly.
Besmeses is offline
post #1854 of 3433 Old 12-01-2017, 07:43 AM
Star56's Avatar
Location: In my armed redoubt deep in the mountains of northern Ohio
Quoted: 166 Post(s)
Liked: 122
Greg
I have mine shelf mounted up next to the ceiling. Works great.
42" in the dining room. 50" in the bedroom. 86" in the living room. 65" in the family room. 70" in the family room. 106" in the family room "This is the voice of world control" Video Modes:EDTV-XGA-HDTV-4K HDR
Star56 is offline
post #1855 of 3433 Old 12-01-2017, 07:54 AM
Quoted: 18 Post(s)
Great.!
Thanks so much.
Big D
post #1856 of 3433 Old 12-01-2017, 08:45 AM - Thread Starter
BondDonBond's Avatar
Quoted: 746 Post(s)
Liked: 677
I have the same cable to my 65.
So another cable to the projector works fine but not the RUIPRO. If so it has to be the cable.
Home Theater: JVC RS2000, Stewart 120" 2:35 StudioTech 130, Panamorph DCR Lens, B&W 802 Nautilus, HTM1, 4-B&W 805's for surround, 4-Martin Logan 22's ceiling speakers ATMOS, 2- PB-16 Ultra Subs, Marantz 8802A, MacIntosh 8207 AMP and Proceed AMP 5, Panasonic 820, Apple TV, XBox One, HTPC with MadVR, Qnap NAS
BondDonBond is offline
post #1857 of 3433 Old 12-01-2017, 09:57 AM
Quoted: 46 Post(s)
Liked: 4
Yeah.. thats what i thought.. but RUIPRO cable works for my TV but not works for my 65.
Pokmm is offline
post #1858 of 3433 Old 12-01-2017, 10:00 AM
Redskin's Avatar
Quoted: 65 Post(s)
Great, thanks! I had my older Marantz 720p projector shelf mounted in the back of the room. I have since taken it down, but my try that first before spending cash on a mount.
Redskin is offline
post #1859 of 3433 Old 12-01-2017, 10:44 AM
Quoted: 46 Post(s)
Liked: 4
Contacted seller, they ready to replace the cable. will update once i receive replacement cable.
Pokmm is offline
post #1860 of 3433 Old 12-02-2017, 02:26 AM
Liked: 4
I have the RUIPRO connected to my 60 and works just fine.
Saadooness is offline
firmware , hd65 , Optoma , optoma uhd60 , uhd60 apple tv , uhd65
