People that own home projectors, how big are your screens? - Page 6 - AVS Forum | Home Theater Discussions And Reviews
 77Likes
post #151 of 187 Old 08-07-2017, 03:15 AM
k3nnis's Avatar
Quoted: 642 Post(s)
Liked: 60
Originally Posted by Star56 View Post
I sit about 9' from a 106" screen and it is wonderful, yes even with scope movies. 95% of the people who have entered my theater reject the 9ft seat because they find it all too BIG. They sit back at 14ft.
This is all very subjective. Scope at 10ft from 120" diag is going to be enormous for 99% of the population.
Ok thanks.
k3nnis is offline
post #152 of 187 Old 08-07-2017, 07:42 AM
Tony~M's Avatar
Quoted: 50 Post(s)
Liked: 44
Talking It's Huge....UUuuge!!!
Wow a 143 foot diagonal screen, that is really biggly, or is that Uuuuge in the new Presidential vernacular?
Originally Posted by sandman1500 View Post
Hey All,
I have a 143' diagonal screen (2.34.1) with Screen Goo painted directly to the wall. I love it!
Enjoy
Tony~M is offline
post #153 of 187 Old 08-10-2017, 10:46 PM
Quoted: 261 Post(s)
Liked: 202
You probably want to project as large a screen as your space allows given projector ability; maximize it all. Went from 72 dlp rptv to 100inch projector; it was grand and in about 2-3months i realized i had the room and capability for max 135 which i did jump to and glorious it was. My goal is to do 150 and probably max at 200 in future, i love the big screens at home and at theaters!! You wont regret it. It seems big at first but you get used to it quickly. Everything else is tiny in comparison
am2model3 is offline
post #154 of 187 Old 08-11-2017, 06:29 AM
Gary Lightfoot's Avatar
Quoted: 1302 Post(s)
Liked: 1054
If you're already sitting at the best distance for your current screen, and find sitting closer is less comfortable, going for a larger screen will make you want to move your seats further back to retain the same viewing comfort and image size on your retina (all else being equal). It may also add some wow factor when walking in the room and seeing a larger screen.
So you may find sitting 10 feet from a 10ft wide screen is ideal for you, then realise you can fit a 15ft wide screen, but then have to move your seats to 15 feet back to retain the same comfort as before. In doing that, nothing has changed visually when viewing a movie.
If you can sit closer with a larger screen, then you probably weren't sitting as close as you could with the previous screen, or something else has changed, like perhaps the vertical viewing angle which is more limiting that the horizontal.
Originally Posted by elmalloc
Who says Cameron is "right" and why do we care about him so much - lol!
I trust Gary Lightfoot more than James Cameron.
Gary Lightfoot is offline
post #155 of 187 Old 08-11-2017, 06:45 AM
Rgb
Rgb's Avatar
Quoted: 658 Post(s)
Liked: 864
Bigger than you expect but smaller than I want.
But seriously, I use an Elite Screens ~8.5' image width electric.
I use the IR electric feature to program stops into a Harmony remote for 2.35/etc. for the bottom "mask" and use a roll down black felt top mask, automation TBD. There are dark curtains behind the screen to provide the dark "mask" for variable heights.
I was thinking of getting a used electric of similar/larger width and use the black backside (perhaps with added felt/velvet) as a motorized top mask, assuming different IR or RF codes.
Rgb is offline
post #156 of 187 Old 08-11-2017, 10:02 AM
drjay71's Avatar
Quoted: 87 Post(s)
Liked: 40
150" diagonal screen paired with a JVCX500 projector. Sit 10 and 14 feet back
ID:	2266352   Click image for larger version
Aceklub96 likes this.
drjay71 is offline
post #157 of 187 Old 08-17-2017, 05:22 PM
sandman1500's Avatar
Liked: 2
Hahaha.....I appreciate it Tony. It should have been 143'' screen, but the pictures say it all!!
Enjoy!
sandman1500 is offline
post #158 of 187 Old 08-17-2017, 07:41 PM
Quoted: 46 Post(s)
Liked: 7
Enjoy!
Hi, what projector do you use. Picture looks beautiful as well. Is Moana from netflix? Thanks
Docdhina is offline
post #159 of 187 Old 08-18-2017, 10:04 AM
starshipvelcro's Avatar
Quoted: 45 Post(s)
I recently switched out a 120" 16:9 screen for a 138" 2.35:1 screen and it's fantastic. I'm sitting 13-14 feet back at the eyeballs.
Marantz SR6011 // Marantz MM7025 // Marantz UD5007 // Panasonic UB900 // JVC X770R/RS520 // Ascend Acoustics 340SE & 170SE 7.1 //JBL 226CT Atmos // HSU VTF2 MK5 // RBH I12
starshipvelcro is offline
post #160 of 187 Old 08-18-2017, 11:01 PM
Liked: 2
Thanks! The projector is a Epson 5030ub and Moana is a blu-ray being played on the Xbox One.
post #161 of 187 Old 08-19-2017, 06:48 PM
Quoted: 46 Post(s)
Liked: 7
ok thanks
Docdhina is offline
post #162 of 187 Old 08-19-2017, 08:43 PM
Limp Fox's Avatar
Quoted: 150 Post(s)
Liked: 40
Originally I was thinking about going smaller than 120" because my current, old+cheap James Town white screen with Mitsubishi HC1600 (oldddd) give me eyestrain at 13 1/2'. Looking over fellow enthusiasts screen size and seating distance I'm wondering if I in fact could stay the same size or go bigger if using a superior screen and pj?
I am planning on purchasing a BD Slate .8 screen along with either a 2017 JVC x970 or equivalent 2016 model. The reason for the screen I chose is because it will be in our family room; an area that is has 2 big windows and no light control. I'm sure upgrading the screen from the white JT alone will make an added improvement.
What do you all think about this? With a newer pj, one that's far better than what I have, along with the screen allow me to keep a 120" screen or even bigger? The wall where the current screen is at and where the new one will go is roughly 15' wide and 8' tall.
Thank you.
Judd
US ARMY: 11C4P08 (RET)
Limp Fox is offline
post #163 of 187 Old 08-19-2017, 09:01 PM
Skylinestar's Avatar
Quoted: 1311 Post(s)
Liked: 268
I have a 9' wide screen in my 10' wide room. The room is width limited, so I go as big as I can.
Skylinestar is offline
post #164 of 187 Old 08-19-2017, 09:13 PM
lizrussspike's Avatar
Quoted: 1226 Post(s)
Liked: 1832
106" @ 12 feet.
lizrussspike is offline
post #165 of 187 Old 08-19-2017, 10:02 PM
mzs22's Avatar
Quoted: 230 Post(s)
Liked: 91
106" 16:9 going to switch to 125" 2:35.1 seating distance 13'
mzs22 is offline
post #166 of 187 Old 08-19-2017, 10:38 PM
subacabra's Avatar
Quoted: 1689 Post(s)
Liked: 4912
Whopping 106" at 9 feet.
Although I've only used the pj a few times since getting my Sony x900e 65" lol
subacabra is online now
post #167 of 187 Old 08-20-2017, 04:51 AM
Old A/V Addict's Avatar
Quoted: 35 Post(s)
Liked: 62
142" scope screen viewing at 10'. Did some temporary masking with black curtains down to 125" scope at same viewing distance and liked it better. Still seemed immersive without being overpowering.
Oppo 203>Marantz 7704>JVC RS520
Old A/V Addict is offline
post #168 of 187 Old 08-20-2017, 09:51 AM
Liked: 0
BenQ 1090 -- I have 130'' 16:9 ratio
Vanbita is offline
post #169 of 187 Old 08-23-2017, 08:01 AM
DrMac210's Avatar
Used to have a 98" 16:9 at 13 feet.
Recently bought a new house with more room, so I am upgrading to a 120" 16:9 at 11 feet.
DrMac210 is offline
post #170 of 187 Old 11-18-2017, 10:48 AM
hibeta's Avatar
138" curved 2.35 at 13'.
hibeta is offline
post #171 of 187 Old 11-18-2017, 02:19 PM
bix26's Avatar
Quoted: 731 Post(s)
Liked: 391
120” 16:9 from 10’-11” away. TV is perfect but when I watch movies in letterbox kinda wish I could go bigger. Still way better than any TV out there though.
bix26 is online now
post #172 of 187 Old 11-18-2017, 02:40 PM
hd0823's Avatar
Quoted: 848 Post(s)
Liked: 1589
165 inch 16:9 diy Seymour center stage xd . First row is 11 feet second 17 and bar is 19 to 20 feet.
Sent from my SM-N950U using Tapatalk
hd0823 is online now
post #173 of 187 Old 11-18-2017, 10:25 PM
coderguy's Avatar
Quoted: 2455 Post(s)
Liked: 1324
8 feet from 106" screen...
At first, you may find a screen looks too big, but once you get used to it, you'll probably sit closer than your first inclination.
**Updated Projector Calculator Released NOV 2017**
-- www.webprojectorcalculator.com --
coderguy is offline
post #174 of 187 Old 11-18-2017, 11:43 PM
blastermaster's Avatar
Quoted: 601 Post(s)
Liked: 765
That is the EXACT same scenario as me! I love it.
blastermaster is offline
post #175 of 187 Old 11-19-2017, 06:10 AM
FiveMillionWays's Avatar
Quoted: 24 Post(s)
110 inches from 14.5 feet away. Using a Sony VPL-HW40
FiveMillionWays is offline
post #176 of 187 Old 11-19-2017, 02:04 PM
Michael Hall 2's Avatar
Liked: 1
150? Carl?s Place Entry Screen Material, Epson Powerlite 707 Gold Projector. Seating distance is 15 ft along with the distance projector from screen.
Michael Hall 2 is offline
post #177 of 187 Old 11-21-2017, 08:28 PM
hibeta's Avatar
"That is the EXACT same scenario as me! I love it."
It is amazing. Sony projector, full room darkening capability...every night is theater night!
hibeta is offline
post #178 of 187 Old 11-22-2017, 08:22 AM
Quoted: 801 Post(s)
Liked: 463
Thank you.
Judd
JVC projectors are not very bright. They would not make a good combination with a .8 negative gain alr screen. Go for 1.4 gain Black Diamond or 1.2 Slate if you're looking for a S.I. alr screen.
LumensLover is offline
post #179 of 187 Old 11-22-2017, 08:45 AM
humbland's Avatar
Quoted: 1063 Post(s)
Liked: 304
Thankful for:
110" 16 x 9 "HD" electric drop
and
125" 2.35:1 "Scope" electric drop
at 14 feet from seating
plus
DLP with lens memory
Happy Thanksgiving to all AVSers!
humbland is offline
post #180 of 187 Old 11-23-2017, 03:02 AM
JRock3x8's Avatar
Quoted: 1858 Post(s)
Liked: 623
you and I are very similar
I love the screen to be as wide or wider than my field of view. I always try to pick a seat at the theater that is as far away from the screen as the screen is wide.
I sit 10' back from a 10' wide 16:9 image but where my setup really shines is when I zoom out to a 12' wide image for 2.35:1. Both images are 60" tall and for ceiling height / back row reasons I can't go bigger than that on the 16:9
edit : PJ is a BenQ W1070, screen is white over black spandex, room is 100% light controlled (important when you want to blow way past the recommended specs for screen size)
JRock3x8 is offline
