Controling fans in hushbox via 12V trigger - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By rekbones
post #1 of 8 Old 10-17-2017, 04:08 PM - Thread Starter
kutzon's Avatar
Quoted: 45 Post(s)
Hi guys,
could use some help with correctly wiring a relay. I'm building a hush/dustbox for my projector and want the cooling fans to go on & off with the PJ using the 12V trigger output.
I was advised to get this relay from eBay: http://www.ebay.co.uk/itm/Dc-12V-4-C...o/251614581114
Problem is, I'm not really tech-savvy and it came with no form of instructions whatsoever. I have an idea of how I need to wire it, but I'm not sure it is correct and I really don't want to fry anything. Could anyone please have a look at my awful drawing below and tell me if I'm on the right track, and if not, correct me? Thank you!
My Home Theater setup:
Picture:
Benq W2000 (HT3050) // 130" DIY AT-screen // Sony UHP-H1 // PS3
Sound: Pioneer VSX-AX2AV (7.1) // Infinity Beta 50/C360/ES250, Mission 737R, Dynavoice Thunder T-12 // Sinus Live BassPump III
kutzon is offline
post #2 of 8 Old 10-17-2017, 07:26 PM
rekbones's Avatar
Quoted: 1055 Post(s)
Liked: 546
It looks wired correctly. Ad states either high or low level on in1 so not sure what the four jumpers are on the left are, maybe to switch between high or low or just enable disable?
kutzon likes this.
"Smart enough to know better, to old to care" ------ Dedicated Bat Cave Home Theater, JVC RS49U/Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 18TB DroboFS NAS
rekbones is offline
post #3 of 8 Old 10-17-2017, 11:47 PM - Thread Starter
kutzon's Avatar
Quoted: 45 Post(s)
Rekbones, thanks you very much!!! The jumpers do switch between High or Low (although I'm not sure what that means, exactly, or how it should be set).
I also had someone else take a look at the drawing and he suggested simplifying the wiring by doing like below, difference being the relay do not receive constant 12V DC, just the power from the trigger output when the projector is on. Would that work??
Picture:
kutzon is offline
post #4 of 8 Old 10-18-2017, 08:05 AM
rekbones's Avatar
Liked: 546
No do not wire it this way, the whole point of the relay is to take all of the load off of the trigger output. Wire it the way you first had it.
rekbones is offline
post #5 of 8 Old 10-18-2017, 08:16 AM - Thread Starter
kutzon's Avatar
Quoted: 45 Post(s)
OK, makes perfect sense so will do, thanks a lot!!! Do I need to worry about the jumper? It is set to "High" per default.
Picture:
kutzon is offline
post #6 of 8 Old 10-18-2017, 09:46 AM
rekbones's Avatar
Liked: 546
Assuming you have the polarity correct on the trigger output, high should be correct.
kutzon likes this.
rekbones is offline
post #7 of 8 Old 10-18-2017, 04:03 PM
DTI
DTI's Avatar
Quoted: 34 Post(s)
Hi guys,
This is the one I use on my dust box works beautifully SSR-S25DA
ID:	2300696   Click image for larger version
DIY dust box / hush box / ceiling light... http://imagizer.imageshack.us/v2/640...633/7qBblE.jpg
DTI is offline
post #8 of 8 Old 08-08-2018, 08:23 AM
jimmyk36's Avatar
Quoted: 107 Post(s)
Liked: 57
Cool Hush Box - Do you have any more info on how you built it?
jimmyk36 is offline
