Official Epson Home Cinema HC2100/2150 (TW5600/5650/5400) Owners - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 98Likes
post #91 of 615 Old 11-28-2017, 06:48 AM
sjwoo's Avatar
Nine years ago, I bought the HomeCinema 720 for $1299. That's been my projector until I got the 2150 on Black Friday from Best Buy for $649.
According to the CPI inflation calculator, the 720 would be $1481.14 if bought today.
I can't believe that the 2150, which costs LESS THAN HALF of the 720, has more than twice the brightness (I mean in the lowest "Cinema" mode, I almost need my shades!), twice the resolution, is 3D...I have no words. This projector is just amazing, and I'm so glad I got it.
The only issue was that I had to ceiling mount it, so that cost another $17. I'd built a little shelf for the 720, so now I guess a plant will grace its surface.
Looks like it just went back up to $699, but it's still a steal as far as I'm concerned.
Car67 likes this.
sjwoo is offline
post #92 of 615 Old 11-28-2017, 07:02 AM
sjwoo's Avatar
I just picked up a spare bulb, too for 10% off -- the coupon code WEPAAR works (at epson.com). I'd gone through 4 bulbs for the 720. For the cost of those bulbs, I could've bought this projector!
Car67 likes this.
sjwoo is offline
post #93 of 615 Old 11-28-2017, 01:54 PM
Liked: 0
I bought Epson 2150 from BB last week. Now i'm planning to buy a 110 inch Silver ticket fixed screen.
i have a question here.... I can have have only a max throw distance of 11 feet 10 inch in my basement room, but Projector Central is recommending 13.2 ( with 1.31 zoom).
If I go with 11' 10" throw distance, I have to increase the zoom to 1.46 Zoom (as per ProjectorCentral).
Will increasing the zoom impact my picture quality? I'm in basement room and its mostly dark, no issues with light.
Or should I buy 100 inch screen or 106 inch?
Please advice
Thank you !!
AdarshP is offline
post #94 of 615 Old 11-28-2017, 02:08 PM
Quoted: 126 Post(s)
Liked: 34
Bought 2150 over the Thanksgiving weekend. I'm using the Cine3D grey screen so my old BenQ 2050 feels a little too dark. This one is bright enough to overcome this problem while giving me a decent enough black level. Pretty happy.
ID:	2322460   Click image for larger version
ID:	2322462   Click image for larger version
tearfalls is offline
post #95 of 615 Old 11-28-2017, 02:54 PM
Plasma George's Avatar
Quoted: 41 Post(s)
Curious, how long did you have the Benq ?, I'm surprised you're in the market to replace a PJ, when the replacement is still a current model.
https://www.avsforum.com/forum/19-ded...iii-build.html
There are 2 types of people in this world - home theater enthusiasts and idiots
Plasma George is offline
post #96 of 615 Old 11-28-2017, 03:12 PM
serith's Avatar
Quoted: 816 Post(s)
Liked: 848
Please advice
Thank you !!
should be fine. i run 110" @ 12' 6" myself. if you do get the silver ticket i would highly recommend the 1.0 gain screen. 1.1 @ that distance is too bright. i'm actually considering getting the 0.95 screen myself to further help with black levels.
7.0.6 / 1700 ft³ / PSA MTM-210T³ / Epson HC 2150 / 147" AT 2.39:1 Spandex Screen / Seatcraft Rialto³ / Velvet Everywhere / Chasing LFE
serith is offline
post #97 of 615 Old 11-28-2017, 07:54 PM
Dave in Green's Avatar
Quoted: 3787 Post(s)
Liked: 3001
... i have a question here.... I can have have only a max throw distance of 11 feet 10 inch in my basement room, but Projector Central is recommending 13.2 ( with 1.31 zoom). ...
The projection calculator at projectorcentral.com does not recommend throw distance. When you enter your projector model and screen sizes it displays a range of throw distances that the projector can accomodate with its zoom lens. It simply defaults to the center point of the zoom range, but you can place the projector anywhere within that range.
Dave in Green is offline
post #98 of 615 Old 11-28-2017, 10:02 PM
Liked: 3
Originally Posted by serith View Post
i've tinkered with the settings on my pj extensively. i'll happily share the settings with you if you want to try them out. heading to sleep now but will post them tomorrow if you want. i have tailored my settings for the best black levels possible (i think).
Can your share your settings please if you don't mind? I am too lazy to mess around. Thanks in advance
krishelnino is offline
post #99 of 615 Old 11-29-2017, 04:33 PM - Thread Starter
Quoted: 173 Post(s)
Liked: 50
Finally got my Elunevison Reference 4k 120" screen today. This is how it looked in my driveway where they left it. Sunday is the day for everything to get ran and installed.. 8 years in the making.
Sent from my SM-N950U using Tapatalk
evilmonstertruk is offline
post #100 of 615 Old 11-29-2017, 06:04 PM
Liked: 1
Well I've had my 2150 exactly 5 days and I had it stop working. Called tech support and they think it's a faulty lamp so in 2-5 days I'll find out. Pretty disappointing. Hopefully its the only problem I have.
GreenTerror is offline
post #101 of 615 Old 11-29-2017, 07:09 PM
Quoted: 126 Post(s)
Liked: 34
I've had BenQ for about 18 months. The reason I'm in the market to replace BenQ is mainly because I switched to a Cine3D grey screen and BenQ looks a bit too dark since.
post #102 of 615 Old 12-01-2017, 03:48 AM
theofilos's Avatar
Liked: 1
I have calibrate my epson 5650 [2150]. At default cinema settings the image was flat with no depth with strong green and yellow. After calibration i noticed a big improvement in color and depth in the image. Today a will measure contrast with and without the iris.
theofilos is offline
post #103 of 615 Old 12-01-2017, 04:33 PM - Thread Starter
Quoted: 173 Post(s)
Liked: 50
What knd of calibration did you do? Full calibration?
post #104 of 615 Old 12-02-2017, 01:08 AM
theofilos's Avatar
Liked: 1
I calibrate the color temp, gamma and colors in brightness saturation and hue in all modes. Even Dynamic give me tha same picture as cinema and only at 90-100 ire the green saw up a little. The difference is only in white but i think i can fix it. The biggest changes i did was in color brightness, it was too much and the colors was flat with no shades. Bright cinema has wrong gamma, after 50 ire is under 1,8. Its a trick so the image looks brighter.
post #105 of 615 Old 12-02-2017, 07:26 AM - Thread Starter
Quoted: 173 Post(s)
Liked: 50
Are you in the Maryland area...
post #106 of 615 Old 12-02-2017, 07:44 AM
theofilos's Avatar
Liked: 1
No, i am from Greece.
post #107 of 615 Old 12-02-2017, 08:21 AM - Thread Starter
Quoted: 173 Post(s)
Liked: 50
Damn. It's hard to find people to do calibration. I don't trust Best buy for some reason. They gave me a list of the tools the guy has and it seemed like he had everything but just something about it.
post #108 of 615 Old 12-02-2017, 12:55 PM
theofilos's Avatar
Liked: 1
I can give the settings and if they dont work with your setup you can just reset!
post #109 of 615 Old 12-02-2017, 12:57 PM - Thread Starter
Quoted: 173 Post(s)
Liked: 50
True. I would appreciate it. I wonder how big the variance is between projectors? I know TVS can be really big
post #110 of 615 Old 12-02-2017, 03:32 PM
theofilos's Avatar
Liked: 1
Here is cinema mode.
Brightness 50 [Adjustable]
Contrast 50 [Adjustable]
Color Saturation 50 [Adjustable]
Tint 50
Sharpness 0 [Adjustable]
Color temp 3
Customized:
Offset R 48
Offset G 50
Offset B 50
Gain R 50
Gain G 42
Gain B 51
Image Enhancment: [Adjustable]
Noise Reduction 0
MPEG Noise Reduction 1
Detail Enhancement 70
Advanced:
Gamma Customized:
0 -1 1 0 0 0 0 0 +1 Yes cinema mode has great gamma
RGBCMY:
Hue Saturation Brightness
R 48 52 35
G 50 48 35
B 60 35 50
C 48 50 10
M 42 49 30
Y 55 20 80
Epson Super White: off [Adjustable]
Signal:
Advanced:
HDMI Video Range: Expanded [Adjustable]
The image i get with these settings is almost the same in all modes when i calibrate them.
HDMI Video Range Epson Super White and Brightness are the settings that you must adjust to your setup.
Good luck!
evilmonstertruk likes this.
post #111 of 615 Old 12-02-2017, 04:15 PM - Thread Starter
Quoted: 173 Post(s)
Liked: 50
Tint 50
Color temp 3
Customized:
Offset R 48
Offset G 50
Offset B 50
Gain R 50
Gain G 42
Gain B 51
Noise Reduction 0
Advanced:
Gamma Customized:
RGBCMY:
R 48 52 35
G 50 48 35
B 60 35 50
C 48 50 10
M 42 49 30
Y 55 20 80
Signal:
Advanced:
Good luck!
Awesome. Thanks dude. Tomorrow is my day to set all this up. I will let you know how it goes.
post #112 of 615 Old 12-03-2017, 09:56 AM
Liked: 3
Tint 50
Color temp 3
Customized:
Offset R 48
Offset G 50
Offset B 50
Gain R 50
Gain G 42
Gain B 51
Noise Reduction 0
Advanced:
Gamma Customized:
RGBCMY:
R 48 52 35
G 50 48 35
B 60 35 50
C 48 50 10
M 42 49 30
Y 55 20 80
Signal:
Advanced:
Good luck!
Thanks ! Not sure if anyone know this, but here is a way to enable BT on the 2100/2150. I have tried on my 2150 and it works. I don't take any credit for this, discovered this on another forum
1. Switch on the PJ
2. Press and hold the Menu-Button for 8 sec.
3. Press the ESC-Button twice
Now a new Window with Informations about the Beamer appears. With the
"Arrow-right" and "Arrow-left"-Button you can see several other Information-Windows.
4. Press again the Menu-Button for 8 sec.
5. Press again the ESC-Button twice.
Now a new Windows appears.
On the left side you see 8 lines named "DIP-SW1" to "DIP-SW 8".
To enable BT menu set DIP-SW 7 BIT 2 from 0 to 1.
6. Restart PJ
7. Go to Menu -> Setting -> Bluetooth to enable this option.
post #113 of 615 Old 12-03-2017, 12:30 PM
Car67's Avatar
Quoted: 71 Post(s)
Liked: 39
Thanks for the bt info, seems the same tweak of the old 2040, unfortunately it didn't work with audio devices without copy protection, I guess it is the same for the new models.
Epson TW5350(HC 2045), Darbee DVP-5000S, Himedia Q5 Pro, Sony BDP-S6700, 3D RF glasses: Epson, Samsung, Xpand. Fuji FinePix REAL 3D W3, LG Otimus 3D Max, 3D Tablet F892B
YT 3D Video Library
Car67 is offline
post #114 of 615 Old 12-03-2017, 01:48 PM - Thread Starter
Quoted: 173 Post(s)
Liked: 50
This is how far I got. Ran my HDMi cables. Ran power for the new outlets. But that's about it.. Ugh, was really hoping to finish it today.
Sekosche likes this.
post #115 of 615 Old 12-03-2017, 07:35 PM - Thread Starter
Quoted: 173 Post(s)
Liked: 50
Well. Watching ST2 through a Amazon Fire TV 2 and it looks amazing. Unbelievable for the price. The Elunevison Reference was well worth the money. The image is super sharp with zero noise. Far from done but extremely happy.
post #116 of 615 Old 12-04-2017, 01:11 PM - Thread Starter
Quoted: 173 Post(s)
Liked: 50
Please advice
Thank you !!
For my 120inch 12ft or more was needed. I will do more testing tonight for you if you need it.
post #117 of 615 Old 12-04-2017, 07:49 PM
Sekosche's Avatar
Quoted: 1439 Post(s)
Liked: 3634
@AdarshP will likely be ok with a “110 screen from 12’, but it may be close. I’m throwing 12.5’ away from a 100” screen and there’s well over a foot or more beyond that when zoomed in (didn’t measure though).
Speakers: PSA MTM-210T x2, MTM-210C, MT-110SR x2; Atmos-SVS Satellite x2, DIY Volt-10 x2
Subs: PSA V1801 x2, DIY: 18" RSS460HO, 15" RSS390HO x2, BOSS w/JBL CX1200 x6
MA’s: Crowson Tech x2
Processing: Denon X4200, NU6KDSP, 3KDSP
Video: Epson 3700; Screen: Silver Ticket 106" High Contrast
Sekosche is offline
post #118 of 615 Old 12-04-2017, 08:44 PM
Sekosche's Avatar
Liked: 3634
We watched The Life of Pi tonight as a family, and I thought the picture was excellent and really popped in bright cinema mode with low ambient lighting.
For only $650, this PJ is incredible. Are the colors and black levels acceptable out of the box? For the most part, I believe they are. Of course there’s considerable room for improvement, but at this price point, I’m floored at what kind of image the 2150 projects.
The wife and family are enjoying “my latest home theater obsession” a lot more than expected. In fact, I may be allowed to ditch the family room TV and move to a fixed screen from the 100” Elite pull down; I could go up to 106-110” after gaining an extra foot of depth.
Sekosche is offline
post #119 of 615 Old 12-06-2017, 04:49 AM
Sekosche's Avatar
Liked: 3634
I’m installing a Silver Ticket High Contrast 106” fixed frame possibly today (delivery pending) to replace the CineWhite 100” Elite pull down; it should offer significant improvements in black levels, contrast, and help a bit more with day time viewing in my family room without having to go to an ALR or black screen. I hope it’ll be a good compromise in screen tech and color for the best results in my room when paired with the Epson 2150.
I’ll try and get a few comparison pics or videos with both screens to show the differences in ambient light and with lights off in a multi purpose room with lots of reflections, light colored walls, ceiling, etc.
https://www.amazon.com/gp/aw/d/B01MQGEFXS
Versus
https://www.amazon.com/gp/aw/d/B008X...pop_mb_pd&th=1
Sekosche is offline
post #120 of 615 Old 12-06-2017, 05:46 PM
serith's Avatar
Quoted: 816 Post(s)
Liked: 848
upgraded to a high contrast silver ticket screen, and this is what they gave me: https://imgur.com/a/LewnO
there was no way to remove the pattern (that looks like fish scales), or the two vertical lines on the other side of the screen. sent it back in hopes the next is better. i will say that black levels were noticeably improved though which is nice (.95 gain vs 1.0)--probably would not recommend this unless your room is 100% light controlled as the overall image brightness is reduced obviously.
*edit*
and no, the vertical lines & pattern were extremely visible even with the material stretched & hung--before anyone jumps to that conclusion.
serith is offline
