Optoma UHD50 - Page 51 - AVS Forum | Home Theater Discussions And Reviews
 519Likes
post #1501 of 1518 Old 08-16-2019, 02:49 PM
ryanazarko's Avatar
Originally Posted by DunMunro View Post
You can set YUV as preferred in the projector:
Menu->display->image settings->color settings->color space -> HDMI YUV (or try auto). Your projector might be set to HDMI color space RGB.
What happens if you turn off HDR at the game source? Also 120hz HDR might exceed your HDMI bandwith and current bit depth or color sampling.
I'll have to play with it when I get home, but if i recall correctly, every time i touched it the colors went wonky, so i left it as auto. Maybe I'd have to change it both on the project and PC simultaneously (although I doubt it, because i don't think the PC knows what the projector is expecting)
As for gaming at 120Hz, If I turn off HDR at the game source, the colors are no longer washed out, but they're also no longer HDR. I doubt its a bandwith constraint because 2160p60 HDR should take double the bandwidth of 1080p120 HDR, and it works.
ryanazarko is offline
post #1502 of 1518 Old 08-16-2019, 02:57 PM
Quoted: 756 Post(s)
Liked: 362
If you set YUV on the projector and send it RGB the color will go wonky, but changing the source output to YUV should fix that instantly. The PJ should detect YUV and change when HDMI color = Auto but maybe not with your PC.
what bit depth and color sampling is the PC sending at 120hz/HDR?
DunMunro is offline
post #1503 of 1518 Old 08-18-2019, 03:03 PM
Quoted: 756 Post(s)
Liked: 362
Avengers Endgame on my UHD50.
I watched Endgame on my UHD50/145in screen, using my Sony UBP-X700 and the 4K HDR BD.
I used the following settings:
HDR Dynamic range = Bright
Gamma = 2.0 ( I have a low gain grey screen)
UltraDetail = 2 (this 4K HDR BD was upscaled to 4K from a lower res master and Ultradetail works well with these)
Dynamic Black = on
Color space = native
Brilliant color = 10
I am still amazed at how well this projector performs when fed 4K HDR content.
I've attached some sample still frames.
Edit: I've attached an image of AEG 2KBD upscaled to 4K to compare to the 4kBD.
ID:	2604516   Click image for larger version
ID:	2604518   Click image for larger version
ID:	2604520   Click image for larger version
ID:	2604522   Click image for larger version
DunMunro is offline
post #1504 of 1518 Old 08-27-2019, 07:52 AM
kofii12345's Avatar
Quoted: 12 Post(s)
Originally Posted by cocarroll View Post
For those with the half-blank screen issue when using FireTV etc, I have found that it seems to be related to using keystone. If you set keystone back to 0 it clears the problem, so you don't have to restart the projector.
(I have a UHD300X - the European version of the UHD40 - and they have yet to bring out a firmware update for us, so this is the only solution at the moment.)
I had similar problem and removing digital zoom solved the issue. I think Optoma soft is very bugged.
When I turn on Dynamic Black I observe increasing and decreasing brightness in one scene. How to handle it and make it more smooth or faster?
I get actuator buzzing very often but not always. What is it depends on?
kofii12345 is offline
post #1505 of 1518 Old 08-27-2019, 10:28 AM
JRock3x8's Avatar
Quoted: 1853 Post(s)
Liked: 618
You should hear the buzz every time the PJ switches into a 2160p mode
JRock3x8 is offline
post #1506 of 1518 Old 08-27-2019, 10:36 AM
Quoted: 756 Post(s)
Liked: 362
Dynamic Black responds to the lighting in the scene and this is normal, and the dimming of the bulb leads to much longer bulb life and higher contrast. I don't think there's anyway to change it's behaviour.
I can't hear any actuator buzz on mine, but the actuator is on when the projector is fed a 4K signal.
DunMunro is offline
post #1507 of 1518 Old 08-28-2019, 07:15 AM
luisfebar's Avatar
Hi, there is any way to fix the terrible turbine noise from this proyector with 4k content?
thanks!
luisfebar is offline
post #1508 of 1518 Old 08-28-2019, 07:21 AM
JRock3x8's Avatar
Liked: 618
thanks!
Nope.
JRock3x8 is offline
post #1509 of 1518 Old 08-28-2019, 07:24 AM
luisfebar's Avatar
Originally Posted by JRock3x8 View Post
Nope.
post #1510 of 1518 Old 08-28-2019, 09:46 AM
Quoted: 756 Post(s)
Liked: 362
If your fan sounds like that, your projector is defective. Mine is silent except when in high altitude mode, and even then it is quieter than most projectors. All the reviews praise the low noise of the UHD50 series.
DunMunro is offline
post #1511 of 1518 Old 08-28-2019, 10:01 AM
JRock3x8's Avatar
Liked: 618
Dan either your hearing is exceptionally tolerant of fan noise or you have one of the only PJs that doesn’t sound like a broken refrigerator.
JRock3x8 is offline
post #1512 of 1518 Old 08-28-2019, 10:06 AM
Quoted: 756 Post(s)
Liked: 362
Read the comments from this youtube video:
I own 5 projectors right now, and the UHD50 (HC2030, HC1040, UHD66, W1070) is by far the quietest of the lot.
This review is in German but at 4:30 they place the microphone close to the projector (UHD3000A) and it is nearly silent:
if yours is noisy it's defective.
DunMunro is offline
post #1513 of 1518 Old 08-29-2019, 04:23 PM
Quoted: 45 Post(s)
Liked: 9
So...I think my lamp went belly up. I had a small power outage with immediate recovery earlier this week. Now my lamp stays on with the power light flashing.
Anybody have recommendations for replacement options?
OrangePhile is offline
post #1514 of 1518 Old 08-29-2019, 05:31 PM
William L Carman's Avatar
Quoted: 152 Post(s)
Liked: 48
I am curious about the correct setting for gamma on the Optoma UHD50. I am projecting an approximately 96” wide 1.78:1 image in a black painted small room in our mobile home. The screen is a 55” x 98” Carl’s Ultra White thumb tacked to the wall. I am getting a really great 4K image now, but I always wonder if it could be improved.
Is there any test disc image I could use to figure out my best gamma setting?
William L Carman is offline
post #1515 of 1518 Old 08-29-2019, 06:42 PM
Quoted: 756 Post(s)
Liked: 362
In my experience gamma is content and environment dependent and there's no one setting that's best, although I tend towards 2.0 on my 145in gray screen. I really wish each BD or 4K HDR BD would have some test content so I don't have to adjust it after it starts.
DunMunro is offline
post #1516 of 1518 Old 08-30-2019, 03:23 AM
JRock3x8's Avatar
Liked: 618
Unplug the power cable from the wall for 60snthen try again.
Had something similar happen with my 1070
DunMunro likes this.
JRock3x8 is offline
post #1517 of 1518 Old 08-30-2019, 05:51 PM
Quoted: 45 Post(s)
Liked: 9
It's been off since last night, I'll go try again....
post #1518 of 1518 Old 08-31-2019, 02:47 AM
JRock3x8's Avatar
Liked: 618
Off is not enough. The red light needs to turn off so the unit can completely reset.
JRock3x8 is offline
