Optoma UHD50 - Page 55 - AVS Forum | Home Theater Discussions And Reviews
 537Likes
post #1621 of 1659 Old 02-02-2020, 01:00 PM
Quoted: 1096 Post(s)
Liked: 530
Originally Posted by giorginho View Post
[SPOILER]
A big thanks to anyone who will help me out
I can't really help because the UHD40 and UHD51 are EU only, AFAIK. However you can download the manual for each from Optoma.
Some recent reviews:
https://www.pc-magazin.de/testberich...t-3199906.html
http://audiovision.de/optoma-uhd40-test/
http://audiovision.de/optoma-uhd51-test/
https://www.homecinemachoice.com/con...ojector-review
https://www.pc-magazin.de/vergleich/...715-16851.html
https://www.hifitest.de/test/beamer/...x_17941-seite3
http://audiovision.de/optoma-uhd300x-test/
giorginho likes this.
DunMunro is offline
post #1622 of 1659 Old 02-04-2020, 06:46 AM
briansxx's Avatar
Quoted: 114 Post(s)
Liked: 73
Originally Posted by DunMunro View Post
Any luck with the firmware update?
Have not installed it yet, but looking to do it over the next few days.
All the best,
Brian
briansxx is offline
post #1623 of 1659 Old 02-10-2020, 05:57 AM
Liked: 2
I want to share my experience with this firmware update..
I actually upgraded my UHD300X (which is an EU version of this projector) with this firmware. For some reason, Optoma rarely release any firmware updates for their projectors here in Europe
Anyway when I checked in service menu (Power -> Up -> Down -> Menu) the projector name was UHD50 before the update, all firmware versions were the lowest possible, so I had to go with all steps 1,2 and 3..
Some advice: before the procedure, make sure you have USB to RS232 cable. I bought one from ebay for £3, but did not work, so I had to go with more expensive one with the correct chip - Seems the chip is important, has to support UART..
https://www.amazon.co.uk/gp/product/...?ie=UTF8&psc=1
All steps went fine with no issues apart the very last one where you need to program EDID. It did not go according the guide and received PURPLE and two RED flashes instead RED and 2xGREENs. The projector started up, first I did not have any input signal. After another restart it caught the signal from HDMI. Not sure if the last programming bit was 100% successful, but my computer and xbox1x now showing that the projector is 3D capable. Tried some 3D blurays and it seems to work. The signal just takes little bit longer to get into 3D (longer than normal modes)
Not sure if I will ever use it (3D), but nice to have it just in case
briansxx and DunMunro like this.
ferelen is offline
post #1624 of 1659 Old 02-29-2020, 12:37 PM
Liked: 0
So the uhd300x/uhd40 which are eyropean models of uhd50 can be upgrade with the same filmware;in the file says that the required hardware is usb A to usb A cable and a usb flash disk;
Mass effect is offline
post #1625 of 1659 Old 03-03-2020, 12:28 AM
Quoted: 50 Post(s)
Liked: 6
Im having this issue with the projector . It is over shooting the image and i can see a white border
davorn34 is offline
post #1626 of 1659 Old 03-03-2020, 08:35 AM
Liked: 2
It's not a projector's fault. Most of the recent Optoma projectors do that. I believe other brands as well.. you just need to get used to it or look for other types which doesn't have this overshoot (or at least not that big).
ferelen is offline
post #1627 of 1659 Old 03-03-2020, 08:58 AM
Quoted: 50 Post(s)
Liked: 6
Here are some pictures of the issue
ID:	2692926   Click image for larger version
ID:	2692928   Click image for larger version
davorn34 is offline
post #1628 of 1659 Old 03-03-2020, 09:16 AM
Liked: 2
yep, that's normal. Mine projector has definitely larger overshoot than yours. Eco mode should lower the visibility of that overshoot and when watching movie you will easily forget that it's even there if it still bothers you, the only solution is to look for another model. Replacing the projector for a new one of the same model won't help in this case..
ferelen is offline
post #1629 of 1659 Old 03-03-2020, 09:28 AM
Liked: 530
Given your setup, you can add some black material around the screen. Once a brighter image is displayed the border becomes much less noticable.
for example:
https://www.amazon.ca/Carls-Projecto.../dp/B00JF7IXYY
DunMunro is offline
post #1630 of 1659 Old 03-03-2020, 09:50 AM
Quoted: 50 Post(s)
Liked: 6
Would painting the the wall behind the screen help. Say if i painted it in matte dark grey
davorn34 is offline
post #1631 of 1659 Old 03-03-2020, 11:43 AM
Liked: 530
Yes, I'm certain that a darker wall paint would greatly improve things.
DunMunro is offline
post #1632 of 1659 Old 03-04-2020, 12:35 PM
Quoted: 50 Post(s)
Liked: 6
Can anyone recommend any settings to keep the projector noise down. Model optoma uhd50x
davorn34 is offline
post #1633 of 1659 Old 03-04-2020, 03:35 PM
Liked: 530
You mean UHD50? The UHD50X is not yet on the market, AFAIK.
Also image noise or audible noise?
DunMunro is offline
post #1634 of 1659 Old 03-04-2020, 03:45 PM
Quoted: 50 Post(s)
Liked: 6
No i got the uhd50x it came out in australia. Pretty much the same as the uhd50 just is better for gaming
davorn34 is offline
post #1635 of 1659 Old 03-04-2020, 03:46 PM
Quoted: 50 Post(s)
Liked: 6
https://www.optoma.com/au/product/uhd50x/
I dont no if its audible or image noise its just noisy lol sorry its my first projector
davorn34 is offline
post #1636 of 1659 Old 03-04-2020, 04:34 PM
Liked: 530
OK, that's very interesting.
Audible noise = noise you hear.
image noise = on screen noise that you see.
I note that Optoma has adopted a new case design, that is smaller and lighter than the previous UHD50 case.
Where is the projector mounted (table or ceiling)?
DunMunro is offline
post #1637 of 1659 Old 03-04-2020, 04:38 PM
Quoted: 50 Post(s)
Liked: 6
Its audible noise. Maybe the fan or something else but on low sound scenes you can here it
davorn34 is offline
post #1638 of 1659 Old 03-04-2020, 04:42 PM
Liked: 530
Projectors have to move air through their casing to cool the lamp, so some noise is to be expected. If you have it low table mounted, you might place it on a shelf under the table, to gain some sound deadening effect.
DunMunro is offline
post #1639 of 1659 Old 03-04-2020, 06:05 PM
Quoted: 50 Post(s)
Liked: 6
Its ceiling mounted about 1.5 meters above my head. Looking into getting a hush box or projector enclosure
davorn34 is offline
post #1640 of 1659 Old 03-04-2020, 09:53 PM
Quoted: 59 Post(s)
UHD50X looks amazing.. is it DLP ? what is the price?
macmus is offline
post #1641 of 1659 Old 03-05-2020, 05:13 AM
Quoted: 1367 Post(s)
Liked: 398
How did you come to this conclusion?
Very limited discussion on pricing on this sub forum.
It's MSRP is 3200$.
noob00224 is online now
post #1642 of 1659 Old 03-06-2020, 06:54 AM
Liked: 0
when i set resolution 1080p and 120 hz on uhd40 it goes in 3d mode on xbox one x. when i connect to laptop i set it on lower resolution to achieve 120 hz.but how i see in 3d ;some demos on youtube play anaglyph but the glasses i use dont work.i have 3d glasses from my 3d tv and one whith emitter from my previous projector.
post #1643 of 1659 Old 03-14-2020, 04:32 AM
Liked: 0
Mass effect, which firmware are you using?
Can anybody confirm that 3d at 1080p 120 hz works with the latest firmware?
Many thanks.
Vas22 is offline
post #1644 of 1659 Old 03-15-2020, 12:39 PM
Liked: 0
I have the stock filmware(uhd40).i want to update to c07 filmware(only for uhd50).someone in this thread said that he update the uhd300x (European model) and it works.
post #1645 of 1659 Old 03-21-2020, 12:21 PM
Liked: 0
Originally Posted by CeeJayII View Post
Would anyone be kind enough to post the edid.inf from the uhd 50? I sent mine in for repair and they sent it back with the latest firmware. Now 1080p @ 120hz and generic crt 3D are gone as options in the nvidia control panel. I was able to create a custom resolution of 1080p @ 120hz and it works, but getting generic dlp 3D back seems more of a chore. I'm thinking the edid from prior firmware would do the trick. I'd greatly appreciate any help.
Hi CeeJayII
Did you have any luck or is there any way around? I just bought UHD40 and can't get to start working in 3d Vision. It was the main reason I've upgraded from Benq 710ST. Its probably because the new firmware: System C08/MCU 04. Hope you can help.
Madm1ke is offline
post #1646 of 1659 Old 03-25-2020, 04:28 AM
Quoted: 83 Post(s)
Liked: 6
Hey guys,
I have a movie file that my iMac says is Bit depth = 10, Chroma subsampling = 4:2:0
When I play it through Plex on my XB1X my Optoma UHD40 says it is displaying as 10 bit RGB
When I play the same file through Plex on my Nvidia Shield TV 2019, The Shield says the file is YUV 420, 10-bit Rec. 2020, HDR10 ready
BUT
When I check the display settings on the UHD40 this time, it says it is outputting 8 bit, 4:2:2...
I checked Netflix (Spenser Confidential) on my Shield and the UHD says it's 10 bit 4:2:0
I checked the same movie on Netflix on my XB1X and it also says 10 bit 4:2:0
Does anyone know why movies are correctly showing via my Xbox as 10 bit, and also Netflix on the Xbox and Shield as 10 bit, but for some reason movies through Plex on the Shield only show as 8 bit? Even though the Shield itself says it is at 10 bit?
blondie88 is offline
post #1647 of 1659 Old 03-26-2020, 10:54 AM
Quoted: 83 Post(s)
Liked: 6
Also, I'm getting a little confused, people saying there is no firmware update for the UHD40, only for the UHD50... But I thought the UHD40 is just the European name and the UHD40 and UHD50 are actually the same projector?
Therefore the firmware update for the UHD50 is for the UHD40 right?
post #1648 of 1659 Old 03-26-2020, 11:11 AM
Liked: 530
Not really. Does Optoma EU provide the firmware update? If not then it might not be authorized and might void your warranty.
DunMunro is offline
post #1649 of 1659 Old 03-29-2020, 09:14 AM
Liked: 0
I have run in to an issue trying to update my UHD50 firmware. I can't get step one to run. The DLPC4422 GUI give me this error: Cannot open USB driver - No projectors available.
Has anyone seen this before?
Player_75 is offline
post #1650 of 1659 Old 03-31-2020, 08:39 PM
N8DOGG's Avatar
Quoted: 1432 Post(s)
Liked: 1693
So, I got a 50 for my brother in law. His shelf is right side up just below the screen top. The projector seems to only throw the picture to the top 1/4 of the screen and onto the roof the other 3/4. Is there no way to adjust it down? The lens shift is at max. It's completely level with the screen and just points up. It's super weird. almost like it's fixed into the lens to only be placed either at waist level, or upside down at the top of the screen.
You can see the dust gathering on the top 1/3 of the lens where the light is coning out, rather than the middle. I can't seem to find anything online with the same thing.
N8DOGG is offline
