Review: Benq HT2050A - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 78Likes
post #271 of 281 Old 04-29-2019, 07:36 PM
sage11x's Avatar
Quoted: 2751 Post(s)
Liked: 2736
Originally Posted by cnjvh View Post
This should be easy to find but it's eluding me. What size is the chip in the 2050a? The data sheets from the Benq site just mentions DLP technology but doesn't state the chip size. The user's manual doesn't mention it either.
0.65 inch 1080p. Technically it’s a darkchip3 but I think TI has abandoned that nomenclature.
What to do if you find yourself stuck with no hope of rescue:
Consider yourself lucky that life has been good to you so far. Alternatively, if life hasn't been good to you so far, which given your present circumstances seems to be more likely, consider yourself lucky that it won't be troubling you much longer...
-- Excerpt from the Hitchhiker's Guide to the Galaxy.
sage11x is offline
post #272 of 281 Old 04-29-2019, 07:52 PM
cnjvh's Avatar
Quoted: 14 Post(s)
Thank you!
No earth robot is going to tell ME which button to press!!
cnjvh is offline
post #273 of 281 Old 05-04-2019, 08:18 AM
barryecohen's Avatar
Quoted: 74 Post(s)
Liked: 36
So this may be a silly question, and I think I know the answer, but I'll ask and wait for a reply before I put holes in my ceiling
I ask because this projector has an off-set lens, and my old PJ's lens was centered, but...
When mounting the projector, should the lens or projector case, be centered to the screen?
Thanks, Barry
So much media, so little time...
My Media Room...
barryecohen is offline
post #274 of 281 Old 05-04-2019, 09:44 AM
bud16415's Avatar
Quoted: 2128 Post(s)
Liked: 1074
Thanks, Barry
Lens
barryecohen likes this.
Bud
bud16415 is offline
post #275 of 281 Old 06-15-2019, 10:03 AM
tony_tc_lau's Avatar
Originally Posted by darthdesi View Post
Did I get a defective unit? Are these stuck dlp mirrors? They aren't square though.. it looks like crap inside the lens reflecting light..
Do you guys have light leak in your units? Do you see a long line of light way above the projected image?
I just received the HT2050A and notice the same long line of light shown in the second image of your original post (attached below) that seems to be a result of internal reflection.
I understand that you got a replacement projector that is better than the original one. Does your new projector still show the long line of light under some conditions? I would like to found out whether this characteristic is a defect or just part of the projector's quirks that we have to accept.
Tony
tony_tc_lau is offline
post #276 of 281 Old 06-15-2019, 11:16 AM
kreeturez's Avatar
Quoted: 505 Post(s)
Liked: 406
Tony
Definitely not normal: could be a faulty DMD.
RMA for a replacement.
BenQ HT2050A Projector; Kodi (on Ubuntu, OpenELEC & S802) via Sony STR-DH540 AVR with Boston Acoustics SoundWare XS SE 5.1 Audio + Jamo 210 Sub. Emby for Mobile Streaming.
kreeturez is offline
post #277 of 281 Old 06-15-2019, 06:01 PM
Liked: 0
Hello, I bought the 2050a with a 125" Elite screen. I would like to ceiling mount the projector 18.5' feet away from screen above couch thinking it wouldn't be a problem, my ceiling is only 6'9", but doing a dry run the picture is still much bigger than the 125" screen no matter what I do. I assumed I could place projector far away and be able to adjust the size but that's not happening. I checked the projection distance table and a 120" screen has the projector 13 feet away from the screen. Do I have to move the projector 5 feet closer for the picture to fit the screen? Or am I missing something in the menus to make the picture smaller? The zoom is at the minimum. Thank you
redsox115 is offline
post #278 of 281 Old 06-16-2019, 03:50 AM - Thread Starter
dreamer's Avatar
Quoted: 1495 Post(s)
Liked: 598
Yes, it must be closer.
Kirk Ellis
BenQ TK800 VuTec 122" Screen, Harmon Kardon AVR 247
Psycoustic Mark III L&R Towers, Boston Center, Energy Take 5 Surrounds
dreamer is offline
post #279 of 281 Old 06-16-2019, 03:33 PM
Liked: 0
Thank you
post #280 of 281 Old 08-22-2019, 12:15 PM
updawg86's Avatar
I got my ht2050a replaced as dust got behind the leans and made spots on the picture. When I received my replacement unit I noticed my firmware version is now at 1.01. I cannot find a changelog anywhere nor the firmware. Anyone have an idea what changed? Thanks!
updawg86 is offline
post #281 of 281 Old 08-25-2019, 10:26 AM
DJCUnited's Avatar
I have an 2011 Epson 3010 with iris, would this BenQ be better? The 3010 just needs a new bulb.
DJCUnited is offline
