Optoma UHD51A: 4K HDR 3D DLP Projector... w/ Alexa - Page 44 - AVS Forum | Home Theater Discussions And Reviews
 582Likes
post #1291 of 1819 Old 08-28-2018, 04:26 PM
Ken McPherson's Avatar
Quoted: 254 Post(s)
Liked: 146
Originally Posted by rickinflorida View Post
I can't hdr to turn on its grayed out.
What do you think is wrong?
The Shield does not support the VP9 profile 2 which is required for Youtube HDR. https://www.reddit.com/r/ShieldAndro...e_app_get_hdr/
If you want to test HDR, get a free one month trial at Netflix. Be sure to get a 4K subscription. https://help.netflix.com/en/node/16282
Ken McPherson is offline
post #1292 of 1819 Old 08-28-2018, 06:34 PM
rickinflorida's Avatar
Bingo! I went into Netflix searched for a HDR movie and screen flashed and I was in HDR. Wow YouTube needs to catch up with technology and get their crap together.
Now just have to figure out how to calibrate it. All those settings and don't know where to start!
Thanks for all your help!
Rick
Ken McPherson likes this.
rickinflorida is offline
post #1293 of 1819 Old 08-30-2018, 01:51 AM
Quoted: 564 Post(s)
Liked: 106
Hey guys, just wanted to know how good is the 3d on this projector?
ultraflexed is offline
post #1294 of 1819 Old 08-30-2018, 02:05 PM
guitarman512's Avatar
Its great with a good Blu Ray 3D disc. Pictures are bright and colourful. A bit of aliasing with lesser SBS rips though. Due to the frame rate issues fast movement is a bit jerky though, as it would be with any PJ that doesn't do frame interpolation. Check my You Tube review.
guitarman512 is offline
post #1295 of 1819 Old 09-01-2018, 09:08 AM
Liked: 0
Just went to order one and the price jumped back up 200 dollars. I'll wait a bit.
Damon Atkinson is offline
post #1296 of 1819 Old 09-01-2018, 09:13 AM
robbynaish's Avatar
Quoted: 31 Post(s)
How much cost 3d glass? We can use only the originals?
robbynaish is offline
post #1297 of 1819 Old 09-01-2018, 10:05 AM
Quoted: 254 Post(s)
Liked: 146
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
robbynaish likes this.
post #1298 of 1819 Old 09-01-2018, 11:46 AM
robbynaish's Avatar
Quoted: 31 Post(s)
Uhd51 and uhd51a have the same 3d options/characteristics ? I found the difference with uhd50 but no with the uhd51
Ps. After some research I think Italian uhd51 is the USA uhd50
post #1299 of 1819 Old 09-02-2018, 10:29 AM
Sonisame's Avatar
Send a message via Skype™ to Sonisame
Rick
Update to the latest tryout build of windows-10: HDR, youtube HDR, netflix HDR are all working flawlessly. 3D seems to be broken with this latest patch, but I see another update pushed by MS(last night) hopefully that fixes 3D(auto resolution switching to 1080p).
Sonisame is offline
post #1300 of 1819 Old 09-02-2018, 11:18 AM
Quoted: 254 Post(s)
Liked: 146
Great news! Any chance you could share your settings both for the Nvidia Control Panel and the UHD51a that gave you those results? So far, I haven't come close to getting HDR to work with Windows 10. (I understand I may need to get the update before everything works properly.)
post #1301 of 1819 Old 09-02-2018, 12:06 PM
Darth Indy's Avatar
Quoted: 20 Post(s)
So when ceiling mounting /back wall mounting this projector with it upside down, how far above the screen top does the projector have to be? Spent all night mounting it only to fire it up and the image is way below the screen and the vertical lens shift cant get it the pic high enough up either, sighhhh.
Darth Indy is offline
post #1302 of 1819 Old 09-02-2018, 03:01 PM
Quoted: 254 Post(s)
Liked: 146
The center of my lens is just under 8" from the ceiling and the top edge of my 110" screen is 13" from the ceiling. I am able to adjust both higher and lower from the top edge of the screen using the knob.
post #1303 of 1819 Old 09-02-2018, 07:17 PM
Liked: 0
Optima recommends that the lens is at the top of the screen. In other words 0"
Lemonhawk is offline
post #1304 of 1819 Old 09-02-2018, 11:24 PM
Sonisame's Avatar
Here is one link
https://support.microsoft.com/en-us/...color-settings
I am using Windows 10 Pro build 17738.rs5_release.180810-1706.
On UHD51A menu under projector settings, projector HDMI EDID 2.0 and HDMI 1 EQ Auto. I do remember playing with settings on my sony receiver(STDRN 1080) to passthrough enhanced(444, 8 bit and more) signal, without that enhanced mode turned on receiver was not letting HDR passthrough.
To add my Zidoo x9s and Samsung UHD player are also playing HDR just fine with YVR 444 8 bit. RGB mode will not play nice with HDR.
ID:	2450310   Click image for larger version
ID:	2450312   Click image for larger version
ID:	2450314   Click image for larger version
ID:	2450316   Click image for larger version
ID:	2450332   Click image for larger version
ID:	2450334   Click image for larger version
ID:	2450338   Click image for larger version
ryudoadema likes this.
Sonisame is offline
post #1305 of 1819 Old 09-03-2018, 10:59 AM
Quoted: 254 Post(s)
Liked: 146
Here is one link
Very helpful. Thanks so much!
post #1306 of 1819 Old 09-03-2018, 01:53 PM
Darth Indy's Avatar
Quoted: 20 Post(s)
Thanks for the replies. If I align the lens with top of my screen (border or actual top where image will start?) doesn't the image actually shoot way down so will have to use lens shift to move pic upwards to fill screen? or do I account for that by mounting with the lens alittle above where screen starts? Sorry for all the dumb questions on mounting, lol. Ive had many projectors before but have never had to ceiling mount one. Always had LCD projectors and either used a tall shelf at back of room or a component shelf on wall at back of room. Neither option works for me with this projector so guess gonna have to ceiling mount it. I have been using it on a desk at back of room but having it that low like that the seating blocks lower part of screen unless moving all seating way off too sides.
post #1307 of 1819 Old 09-03-2018, 05:14 PM
Quoted: 254 Post(s)
Liked: 146
Yes. If you align the center of the lens with the top of the screen (defined as where the image starts), with the UHD51A perfectly level (which it must be to avoid keystone problems), the image will be well below where it should be.
The 8" measurement I gave you is accurate for a 110" screen in which the image starts at 13" below the ceiling, with a throw of 116" and zoom at 1.31x. All of these factors will impact the correct projector to ceiling distance.
post #1308 of 1819 Old 09-05-2018, 08:20 AM
Tuan's Avatar
Quoted: 282 Post(s)
Liked: 254
Send a message via Skype™ to Tuan
We have a new UHD51ALV that's similar, but has a RGBWRGBW 8-segment color wheel to produce 3,000 lumens of brightness https://www.optoma.com/us/product/uhd51alv/
Archie72 likes this.
Tuan is offline
post #1309 of 1819 Old 09-05-2018, 11:21 AM
robbynaish's Avatar
Quoted: 31 Post(s)
I don't understand why so many models so similar.
In Italy we have even the uhd51 that is very close to the Alexa. Now this Alv that seems has only more lumens... Some idea of price?
post #1310 of 1819 Old 09-05-2018, 02:59 PM
Shape of Grey's Avatar
Quoted: 70 Post(s)
Liked: 52
Anyone with this PJ in a dark light controlled room? I just bought a pair of Ultra Clear DLP glasses. They worked great first time I fired them up. Then over the weekend, I repainted the room walls and ceiling to flat black and Grey (they very light blue before) . Since then, picture looks better... But when I tried 3D, I immediately felt like something was off. My eyes were straining to focus and it felt as if there were two different motions..... If that makes any sense.
This being my first 3D experience at home, I'm guessing that this is what happens whe the glasses are out of sync. Does anyone run this PJ in a minimally reflective environment without issues? Or know what to check to troubleshoot?
Living Room-Sony 65" XBR900E, Denon X3300W, Nvidia SHIELD. 5.1.2-Ascend Acoustics CBM-170SE L/R, CMT-340Center, HTM-200SE Surround, RSL C34E Atmos, Sealed UM18-22 Sub.
"Micro Theater"-Optoma UHD51A, DIY 120" Spandex AT Screen, Denon X4400H, Sony UBP-800X, Nvidia SHIELD. 7.2.4 - DIYSG HTM-10 LCR, RSL CG3 Surround, Micca M-8C Atmos , 2 4cuf Sealed 18-22 Ultimax.
Shape of Grey is offline
post #1311 of 1819 Old 09-05-2018, 03:56 PM
Quoted: 254 Post(s)
Liked: 146
You need to toggle left-eye/right-eye sync. Your 3d media player should have a setting that lets you reverse them.
post #1312 of 1819 Old 09-05-2018, 03:56 PM
Liked: 1
Hey guys, I am now deciding between the Optoma UHD60 and the Optoma UHD51A.
3D Would be nice but the extra lumens from the 60 would be great too as I want to often host people over to watch games etc.
Are there any specific comments regarding if the UHD60 picture is better? I am torn and I was going to just pick up the UHD51a as the features seemed nice.
Anyone else already go through this process?
HighEntropy is offline
post #1313 of 1819 Old 09-05-2018, 04:01 PM
Quoted: 254 Post(s)
Liked: 146
Take a look at post #1313 above.
post #1314 of 1819 Old 09-06-2018, 12:06 AM
Quoted: 57 Post(s)
What is the diffrence between UHD51a ?
It's 3 color wheels ? :O
macmus is offline
post #1315 of 1819 Old 09-06-2018, 05:52 AM
sage11x's Avatar
Quoted: 2750 Post(s)
Liked: 2733
This is an issue with the HDMI 2.0/HDCP 2.2 port. One of the reviewers I trust mentioned that he was able to solve the sync issues with the UHD51a by going into the EDID settings and toggling the port from 2.0 to 1.4a. Just remember to switch it back when you want to watch 4K content again.
What to do if you find yourself stuck with no hope of rescue:
Consider yourself lucky that life has been good to you so far. Alternatively, if life hasn't been good to you so far, which given your present circumstances seems to be more likely, consider yourself lucky that it won't be troubling you much longer...
-- Excerpt from the Hitchhiker's Guide to the Galaxy.
sage11x is offline
post #1316 of 1819 Old 09-06-2018, 09:53 AM
Quoted: 254 Post(s)
Liked: 146
Or you can just toggle left-eye/right-eye sync and get the same result with fewer steps and no need to change back when using 4K content.
post #1317 of 1819 Old 09-06-2018, 10:06 AM
Quoted: 254 Post(s)
Liked: 146
PureMotion works in both 2D and 3D and is optimized for 1080p24.
But they can't make Puremotion work with 3D in UHD51a? I wonder why?
post #1318 of 1819 Old 09-06-2018, 11:15 AM
Quoted: 70 Post(s)
Liked: 52
I will explore both options over the weekend. It's just strange to me that it would exhibit those issues after painting the room... Nothing else has changed and it was working fine the day before it was repainted. I'm also going to make sure I plugged the HDMI into the same port as I had to disconnect the wiring for the paint process.
post #1319 of 1819 Old 09-06-2018, 11:47 AM
Quoted: 254 Post(s)
Liked: 146
I suspect "painting" was just a coincidence. I watch 3d regularly, and I haven't seen any kind of pattern as to when I have to toggle left-eye/right-eye sync versus not. As sage11x says, there is something going on with the HDMI 2.0/HDCP 2.2 port sync.
Shape of Grey likes this.
post #1320 of 1819 Old 09-06-2018, 09:04 PM
hpmoon's Avatar
Quoted: 54 Post(s)
Liked: 32
Well that's odd. I came here now expecting quite a storm about the new UHD51ALV also mentioned above by Tuan, but I'm hearing crickets. Big lumens improvement, but I'm seeing from a glance that 6-segment RGBRGB might be better than the new model's 8-segment RGBWRGBW: https://www.avsforum.com/forum/166-l...signation.html
hpmoon is offline
blu ray , hdcp , hdmi , hdmi 2.0 , projector
