Epson 5040/6040/9300 (UK) Power Supply Failure Rate - Page 9 - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: Has your Epson 5040/6040 experienced failure of the Power Suply
Yes, my power supply failed 69 49.29%
No, my power supply has not failed 71 50.71%
Voters: 140. You may not vote on this poll
 49Likes
post #241 of 242 Old 10-02-2019, 01:55 PM
tibimakai's Avatar
Quoted: 185 Post(s)
Liked: 54
It would be nice, if you could measure some of those voltages, 15V, 17V and 380V.
I would also measure those smd brown capacitors for short.
Capacitors seem like are of good quality, but I would still measure the esr value.
Since there are some leds on, that means that the standby voltage is present and maybe others as well.
Living Room: Samsung UN65JS8500,Onkyo TX-NR676,Klipsch R-28F,Klipsch RC-62II,Klipsch R-14S,Polk Audio 80 FX/RT(Atmos)
Bedroom: Samsung UN55MU6290,Onkyo TX-RZ610,Onkyo & Fluance speakers
Garage: Epson 5040UB,Elite Screens 125" motorized screen,2xKlipsch RP-160M,4xKlipsch RP-150M,Klipsch RP-450C ,2xKlipsch CDT-3800II-Atmos,Klipsch R115SW,Klipsch R110SW
tibimakai is offline
post #242 of 242 Old 10-13-2019, 06:50 PM
rfb6435's Avatar
Quoted: 206 Post(s)
Liked: 94
Originally Posted by n-mod View Post
My 5040 has the power board issue (Power light flashes and doesn't turn on. If it turns on it will die after a few minutes).
I opened it up to check for failed caps, but I don't see any signs of them on the two power boards. Any ideas what might need replacing?
Did it click at all when you tried to turn it on?
Relays are also a common failure point on power supplies. I recently replaced a bad relay on a Marantz AVR.
If the capacitors test as good the relay is worth looking at.
It should be easy enough to desolder it and apply voltage to the field wires to test it. I have a variety of wall warts of different voltages depending on what i need. If you need a specific voltage then goodwill often has a rack of old wall warts for a couple buck each.
-Rich
Quad Marantz AVR 9.2.(4+2) Atmos/DTS:X using Dual sr7010's + Dual scAtmos nr1403's
Marantz MM8003 150W/ch Amplifier Driving (L/C/R/SL/SR/SBL/SBR)
HTD Speakers L3 Tower L/R, L3 Center, Dual 12" L3 Subs, L2 Tower SL/SR, L2 Bkshlf SBL/SBR, Flat Panel WL/WR, Angled 6.5" In Ceiling FH/RH, 8" In Ceiling TM
Epson 5040UB Faux-K/3D with 106" Multi-Format Screen.
rfb6435 is offline
