Epson 5050\6050 Rumors? - Page 27 - AVS Forum | Home Theater Discussions And Reviews
 345Likes
post #781 of 866 Old 04-02-2019, 10:11 AM
bix26's Avatar
Quoted: 659 Post(s)
Liked: 341
Originally Posted by blake18 View Post
True, but 4k e-shift has gotten very good, to the point where most people can't tell it's not true 4k. Same can't be said for the contrast on DLPs, it's still abysmal. Epson high end projectors have great contrast and very good e-shift. They really do have both, in real world usage.
I can’t speak on the sharpness of e-shift other than I’m sure it would be adequate for me considering 1080p still looks sharp to me. I sit 9’ from a 120” screen. I do wish DLP had better contrast, but I don’t consider it “abysmal”. If you took the specs out of the equation and did a side by side comparison I don’t think most would see as drastic a difference as the numbers imply. I’m not a DLP fanboy, in fact if I had a dedicated room I’d almost certainly go with a lcd or lcos projector. But for me and i think most people in a living room who prefer a smaller footprint, the advantages of a larger screen outweigh the disadvantages of lower contrast. Using subjective descriptions like “abysmal” might turn new readers away from projection if dlp or low contrast entry level lcd’s are their only option. No matter what price bracket your in, the more people who own projectors the better off all projector enthusiasts are.
curtlots and scottyroo like this.
bix26 is online now
post #782 of 866 Old 04-02-2019, 10:37 AM
Ladeback's Avatar
Quoted: 1321 Post(s)
Liked: 469
Send a message via MSN to Ladeback
9"? That's cloes with a 120" screen. I tried that distance once and it bothered my eyes after a while. I can do 10', but most couldn't so I am now sitting 11' back from a 120" screen. I have seen the 6040 and 5040 in action and really like them over some JVC RS500 and 520 id seen because of the brightness. I didn't really notice the JVc's having any better blacks then people were saying. I have not seen to many DLP projectors and like my current cheap Epson 2040 and and hoping when the 5050/6050 comes can talk my wife into along with Dolby Atmos.
Klipsch KPS-400’s FR/FL with built in 15” 300 watt side firing subs, RC-7 Center, RS-3 Surrounds.
Integra DHC-60.5, 5- Marantz MA700 Mono Blocks, Pioneer DV-F727 301 Disk DVD CD Changer, Pioneer DVL-909 Laserdisc/DVD/CD Player, Sony PS3.
https://www.avsforum.com/forum/19-ded...ck-cinema.html
Ladeback is offline
post #783 of 866 Old 04-02-2019, 11:35 AM
bix26's Avatar
Quoted: 659 Post(s)
Liked: 341
I only sit that close when I’m watching letterbox movies. For TV I sit further back on my sectional. The 2040 has about the same contrast as most DLP projectors so if you can’t convince the wife on the 5050 you might want to check out the BenQ HT3550 that just came out. Probably not as good as the 5050 but still a big upgrade over the 2040.
bix26 is online now
post #784 of 866 Old 04-02-2019, 12:54 PM
Ladeback's Avatar
Liked: 469
I want the 2.1:1 zoom lens, powered lens and lens memory so I can do an AT scope screen. I want to go with a 150" 2.35:1 screen and then a 120" 16:9 will fit inside of it. I may settle for the 4010 or 4050 if the 5050 is to high to start with for me.
Ladeback is offline
post #785 of 866 Old 04-02-2019, 01:31 PM
blake18's Avatar
Quoted: 630 Post(s)
Liked: 351
To me, the difference is huge and very noticeable when it comes to contrast between the two technologies. Also, DLP definitely DOES have very abysmal brightness uniformity and color brightness. It's just awful.
Lumenlab "Community driven video lab".
blake18 is offline
post #786 of 866 Old 04-02-2019, 01:32 PM
blake18's Avatar
Quoted: 630 Post(s)
Liked: 351
I wouldn't do that, the 4000 models have way lower contrast than the 5000 models
blake18 is offline
post #787 of 866 Old 04-02-2019, 04:11 PM
bix26's Avatar
Quoted: 659 Post(s)
Liked: 341
Contrast I’ll give you, when comparing Epsons $2,000 plus projectors, but their entry level projectors almost always have less contrast than equally priced dlp projectors.
Color brightness is usually identical to white brightness on dlp projectors with rgb color wheels. Business and media room projectors with a white segment or rgbw wheel will generally have more white brightness than color brightness. As for uniformity that is really not much of an issue for either dlp or lcd. Lcd imagers are more prone to uniformity issues, as the liquid crystal can be inconsistent. This will get worse over time also. Not really an issue unless your doing 24/7 signage but certainly something that effects lcd more than dlp.
I’m not saying that dlp, lcd, or even lcos projectors are better than one or the other. In fact great projectors can be found using either three of the technologies. As I mentioned earlier, if I was looking into a dedicated theater and had more than $2,000 to spend Epson would be my first consideration. They really have deservedly cornered the $2,000-3,000 market. Going below that DLP vs LCD are very close, and I’d give a slight edge to DLP.
bix26 is online now
post #788 of 866 Old 04-02-2019, 04:31 PM
Quoted: 175 Post(s)
Liked: 62
Below $2,000 I would go with a Sony 45ES. In my opinion, it has much better image quality compared to any dlp in the same price range.
RadiantHT is offline
post #789 of 866 Old 04-02-2019, 04:40 PM
Maximum7's Avatar
Quoted: 36 Post(s)
So basically this 17 page thread has been an argument about contrast between a not yet seen Epson projector and JVC projectors that are at least 1k more.
Oh, and how importand contrast and black levels are.
Don't we already know this crap?
Can anyone speak to motion and movement? Does it get better with the 50 series projectors?
Magnus_CA and Superman2 like this.
Maximum7 is offline
post #790 of 866 Old 04-02-2019, 04:44 PM
bix26's Avatar
Quoted: 659 Post(s)
Liked: 341
You could certainly make a case for that one. The Epson HT4000 and BenQ HT3550 also deserve consideration imo.
bix26 is online now
post #791 of 866 Old 04-02-2019, 04:59 PM
Quoted: 175 Post(s)
Liked: 62
No one has the Epson 5050 yet, with the exception of ScottyRoo who will have it delivered to his house this week. Luminated has the Epson EH-9400. If you are looking for first Impressions, your best bet is to go to the Epson EH-9400 thread on avforums.com. It's the European version of the Epson 5050.
Alaric likes this.
post #792 of 866 Old 04-02-2019, 05:10 PM
Maximum7's Avatar
Quoted: 36 Post(s)
Thanks, but I'm generally asking about the mid range Epsons. Like the 5040, 6040 and 4010 and 5030.
Does the motion and movement get better as you go up the line?
Maximum7 is offline
post #793 of 866 Old 04-02-2019, 05:51 PM
Quoted: 175 Post(s)
Liked: 62
Yes
post #794 of 866 Old 04-02-2019, 06:19 PM
Liked: 3
Just waiting on my mount.....
trailblazer, 04rex and Dferguso like this.
Chris Bradburry is offline
post #795 of 866 Old 04-02-2019, 06:21 PM
Quoted: 175 Post(s)
Liked: 62
Congratulations.
post #796 of 866 Old 04-02-2019, 07:42 PM
JAR5197's Avatar
Quoted: 26 Post(s)
Yes please: How do you knowledgeable members think the motion viewing will be on the 5050?
JAR5197 is offline
post #797 of 866 Old 04-02-2019, 07:45 PM
Quoted: 175 Post(s)
Liked: 62
The motion handling on my Epson 5040 and my Sony 45ES were both excellent. To be honest, my most recent projector with very bad motion handling was my JVC RS520. It was so bad that I could not watch football on it.
post #798 of 866 Old 04-02-2019, 07:47 PM
blake18's Avatar
Quoted: 630 Post(s)
Liked: 351
How'd you get your hands on the 5050UB?!
blake18 is offline
post #799 of 866 Old 04-02-2019, 08:11 PM
Archaea's Avatar
Quoted: 3772 Post(s)
Liked: 3556
I was watching this thread, but Epson is selling the 5040UB for the price of $1150 for refurbs with a full warranty.
That's a tough pill to swallow - paying $3k over $1k for a very small uptick in quality? I read people saying the $3k vs. $2k current street price between the two was hard to justify - even moreso with the refurb price to my opinion.
Anyway - in case there are others on the fence to spend the $3k range -- it might be worth trying to snag one of these 5040UB refurbs when they come back in stock at this price.
https://www.avsforum.com/forum/199-f...l#post57846434
Archaea's 9.8.4 Home Theater Room
(13) JBL CBT 70j-1 | Denon x7200wa | Sherbourn PA 7-350 amplifier | (8) Ultimax 18" sealed subwoofers | (4) iNuke DSP 6000 amplifiers | (4) MB Quart 12" subwoofers mounted direct mounted to Berkline theater chairs BOSS style | Epson 5040UB Projector | Jamestown 144" acoustic transparent 2.35:1 screen w/ Seymour XD fabric
Archaea is offline
post #800 of 866 Old 04-02-2019, 09:00 PM
Quoted: 51 Post(s)
I'm going with the same sized screen as you. I currently have a 135" 16:9 and hate those bars at the top and bottom.
I'm hoping to see the price drop to around $1599 for a new 5040ub.
Gellert is offline
post #801 of 866 Old 04-02-2019, 09:26 PM
scottyroo's Avatar
Quoted: 613 Post(s)
Liked: 813
Epson 5050 arrives tomorrow. Spent some time setting the stage for the shootout tonight.
"The Bunker" | Dedicated Theater Build Under Suspended Slab Garage
Testing: BenQ HT5550 | Epson 5050UB | 160" Dragonfly™ Fixed AT Screen
Denon X6300H | 9.4.4 (7.2.4 Discrete) | 9x Episode 900 Series LCR/Surrounds | 4x Episode 1700 Series ATMOS Heights | 4x Episode 12" Evo Subs
Sony X700 | Xbox One X | NVIDIA Shield TV
scottyroo is offline
post #802 of 866 Old 04-02-2019, 09:33 PM
cubsfan's Avatar
Quoted: 25 Post(s)
Epson site shows that new 5040's are out of stock also. That might mean production has stopped for this model. I'm sure there will be refurbs here and there , because of the power supply issue.
cubsfan is offline
post #803 of 866 Old 04-03-2019, 02:32 AM
Luminated67's Avatar
Quoted: 528 Post(s)
Liked: 333
I second this opinion and I can back this up with actual experience. When I was looking to get a replacement for my Epson TW6100 I was all set in going the 4K route with a DLP projector but the guy that helped install my original setup suggested also looking at the Sony HW45es as he felt it was the way to go, so I arranged a viewing at my local store (took a couple of weeks to organised). What they did was mount both projectors to their ceiling mounts they used for back to back comparisons and feed both projectors from a Cambridge Audio Bluray using a 1080P disc, the Optoma UHD60 used it's internal E-shift to upscale and turn it off for comparison and the Sony straight 1080P, both fired onto the same screen with the Sony lens shift allowing to match exactly the same position on the screen as the Optoma and they used a table tennis bat to quickly cover each lens to compare.
I brought along the brother who had an OLED at the time and was even more accustomed to high quality sharp images than me as a second opinion. Didn't really need his input because to me the difference was quite dramatic, the contrast and blacks plus superior colours of the Sony almost give the impression it's sharper, in any case he fully agreed with my opinion.
I hear you say why didn't you try the Optoma a proper UHD disc? Well I did but the same basic issues I had before were still present, poor contrast and poor colours compared to the Sony.
Alaric likes this.
Epson EH-TW9400 - QualGear Fixed Frame 100” - Sony x700 BRP & Panasonic 420 BRP - Sony 1080 AVR - IPL Acoustics M1TLs & IPL Acoustics AVC Pro Centre, Four KEF surrounds & 2 Sub boxes (10” Sub + 10” Passive Radiator)
Luminated67 is online now
post #804 of 866 Old 04-03-2019, 05:48 AM
JewDaddy's Avatar
Quoted: 394 Post(s)
Liked: 177
Can you please confirm if FI is available when watching a 4K blu Ray??? I know it’s not due to the manual and what other people have said but it would help my curiosity. Thank you!
JewDaddy is offline
post #805 of 866 Old 04-03-2019, 08:05 AM
Quoted: 528 Post(s)
Liked: 333
It is not available with 4K discs or if you let your Bluray player do the upscaling of a 1080P.
Alaric likes this.
post #806 of 866 Old 04-03-2019, 08:15 AM
blastermaster's Avatar
Quoted: 601 Post(s)
Liked: 765
I agree with you on the contrast, which is why I'm looking forward to taking an Epson for a spin on my next projector upgrade. But the brightness uniformity? I can't see any fault with it - movies look pretty amazing on it. It's about 13 feet from my screen which is a 138" curved 2.35:1 AT screen. It's plenty bright and the image is pin sharp. DLP is not awful by any stretch, but when you compare it to the Epson, for example, you can definitely see the lack of black levels, contrast, etc.
Gear: The Brains: Anthem MRX 720. The Brawn: Outlaw 7700. The Fun: Custom PC w/ Logitech 27 & reverse mount pedals, Nintendo Switch, Playstation PS4 Pro. The Visuals: Oppo 203, Darbee Darblet, Optoma HD3300, Panamorph UH480, DIY 138" Curved screen using Semour Centerstage XD AT material. The Audio: 7.1.4: LCR: Tannoy DC12i. Sides: Tannoy IW63DC. Rears: Tannoy DC8i. Ceilings: Tannoy CMS 603/601 DCBM. Subs: 3X Micro Marty and 1X Full Marty.
blastermaster is offline
post #807 of 866 Old 04-03-2019, 09:42 AM
blake18's Avatar
Quoted: 630 Post(s)
Liked: 351
Oh yes, the brightness uniformity is only 59% on the Optoma UHD65, and it tends to be bad on most DLPs, I find it to be very noticeable.
WynsWrld98 likes this.
blake18 is offline
post #808 of 866 Old 04-03-2019, 09:43 AM
tomtoo's Avatar
Quoted: 32 Post(s)
Liked: 27
Let's see some in depth reviews from you boys that have gotten one of these 5050UBs!!!!
tomtoo is offline
post #809 of 866 Old 04-03-2019, 10:18 AM
JAR5197's Avatar
Quoted: 26 Post(s)
Mount It
Planning on getting 5050 soon.
Can the group please give me some ideas for a good mount that I won't have to take out a second mortgage for?
Nine foot ceiling so won't need a long extension.
JAR5197 is offline
post #810 of 866 Old 04-03-2019, 10:23 AM
Janhaus's Avatar
Got mine in yesterday, mount arriving today - excited to get this set up
Janhaus is offline
