Optoma UHD i5 4k (0.47) LED projector - AVS Forum | Home Theater Discussions And Reviews
 13Likes
post #1 of 129 Old 05-16-2018, 06:54 AM - Thread Starter
roni44's Avatar
Quoted: 92 Post(s)
Liked: 72
Hey guys, just want to share a information I got from local Optoma reseller (Taiwan). Besides what I have shown in the pictures I really don't have other information of pricing, release date and etc.
Specs I believe most of you able to figure it out even tho it's in Chinese and it's rated 30,000 hours. It does have built in OS/android, support Alexa, and auto focus.
ID:	2403416   Click image for larger version
ID:	2403418   Click image for larger version
ID:	2403420   Click image for larger version
roni44 is offline
post #2 of 129 Old 05-31-2018, 03:49 AM
Quoted: 274 Post(s)
Liked: 93
FYI
http://www.optoma.com.cn/product/i5/
• TI DMD 0.47 "chip for Texas instruments
• use Texas instrument BrilliantColorTM technology
• LED light source, more bright color, energy saving and environmental protection
• iso 1500 ISO21118 lumen high brightness output
•PureMotion makes the picture more fluent and smooth, and makes the main body of the moving film more vivid and three-dimensional
•HDR High Dynamic Range brings better contrast between light and dark to the picture, presenting a more natural, real and bright picture, allowing users to see more details of the picture
• 1080P blue-ray 3D support
• support Video/Audio/Photo/office
• support dolby 5.1 vocal track
• built-in 8W*2 speakers to meet the audio-visual needs of the living room
• built-in WIFI and bluetooth to meet wireless needs. Standby status can serve as bluetooth speaker
• electric/automatic focusing makes debugging more convenient
• built in Android, pre-installed at the factory, you can choose popular movies, TV dramas and movies according to your own preferences. There are all kinds of applications and new experiences every time
• support vertical trapezoid correction function to adjust the image distortion caused by the tilt of the projector
XGimi CC, XGimi Z6, UKCSIS, Vmai M200 Pico
Xbox One S, LG SH4
wheelee is offline
post #3 of 129 Old 05-31-2018, 05:09 AM
travis_bickle's Avatar
Quoted: 24 Post(s)
i wonder how 3d works, because the manual states 60hz max at 1080p
travis_bickle is offline
post #4 of 129 Old 05-31-2018, 11:54 AM
Quoted: 519 Post(s)
Liked: 295
Though I'm not particularly hopeful about the input lag on these, 1500 LED lumens (if accurate) is a definite buy for getting rid of lamps. Hopefully get P3 gamut too but the site doesn't mention gamut, at least not the words "DCI P3".
Things are heating up (metaphorically) for lasers and LEDs now, finally.
It looks like this model has no lens shift and they are using keystone in their pics to elevate the image.
What's the point of 4K with electronic keystone?
It does appear to have other good features, MEMC, and 3D + 0.47 4K probably means 1080p 120hz 2D support as well. Input lag will be something to watch. The throw ratio doesn't seem particularly short, so I might be interested in this one, if it's cheap enough. Of course the contrast is likely poor, but maybe with dynamic LED dimming it would have decent dynamic contrast.
BattleAxeVR is offline
post #5 of 129 Old 05-31-2018, 06:42 PM
tony_tc_lau's Avatar
According to this online shop: $8,999 RMB which is roughly $1,400 US
https://item.jd.com/7617983.html
tony_tc_lau is offline
post #6 of 129 Old 05-31-2018, 07:50 PM - Thread Starter
roni44's Avatar
Quoted: 92 Post(s)
Liked: 72
Originally Posted by wheelee View Post
FYI
Hi @wheelee , thanks for the translation. This is the model I'm hoping to replace my W2000/HT3050 if the images are very close to UHD50/51a. One other nice thing is Optoma Headquarter TW is right across street from where I live, I can just drop it off for any servicing and updates.
roni44 is offline
post #7 of 129 Old 05-31-2018, 09:07 PM
Quoted: 274 Post(s)
Liked: 93
It's nice that big names are starting to go LED/ Laser & with android OS which makes their pj's an allinone media center BUT it seems that this model is only destined for the china market? It's also strange that those big name brands can't make their pj's multimedia friendly with a simple playback from a USB stick.
anyways we can hope that there is an international version of this model, when are you going to demo the i5?
Xbox One S, LG SH4
wheelee is offline
post #8 of 129 Old 05-31-2018, 09:30 PM
ErinLu's Avatar
Liked: 0
As I know UHD51A can simple playback from a USB stick.
ErinLu is offline
post #9 of 129 Old 05-31-2018, 09:41 PM - Thread Starter
roni44's Avatar
Quoted: 92 Post(s)
Liked: 72
I'm not even sure if TW will get i5, but I will look hard to demo locally.
roni44 is offline
post #10 of 129 Old 06-01-2018, 03:36 PM
jjsaustin's Avatar
Quoted: 35 Post(s)
Liked: 30
Here are the rest of the specs
Display technology
TI” DMD 0.47” TRP S410 4K UHD
Resolution
3840 * 2160
Output brightness
1500 ISO21118 lumens
Displayable color
1073.4 million colors (10 bit)
Projection lens
F:1.7,f: 12.615
Projection distance
1.2m~8.1m (optimized wide 80"@2.2m)
Projection size (diagonal)
30" to 300"
Projection ratio / Offset
1.2/103%
Keystone correction
V: ±30°
Image format
16:9 compatibility 4:3
scanning frequency
H: 31.000~135.000KHz, V:24Hz ~ 120Hz
Computer compatible format
VGA, SVGA XGA, HDTV(720P), WXGA, WXGA+, SXGA, UXGA, HDTV(1080p), WUXGA, UHD
Video compatible format
SDTV 480i/p, 576i/p, HDTV 720p(50/60Hz), 1080i(50/60Hz), 1080p(24/50/60Hz)
UHD 2160p(24/50/60Hz)
I/O interface
HDMI 2.0 x2, USB-A 2.0 (FW Upgrade) x1, USB-A 3.0 x1 (5V/1.5A), Headphone x1, SPDIF out x1, RJ45 x1,
Built-in speaker
8W *2
Evenness
85%
Lamp size/life
LED light source/20000h
Noise value/power consumption
28dB(ECO)/145W Max. 165W @ 220VAC, < 0.5 W (Standby)
Rated voltage
100V ~ 240V ± 10%, 50-60Hz
Volume (width x depth x height) / weight
220(W) x 220(D) x 125mm(H) (with foot) /< 4.2Kg±0.5 (Net weight)
Lifting screws
M4 x 10mm x4
jjsaustin is offline
post #11 of 129 Old 06-01-2018, 06:23 PM
Robert Clark's Avatar
Quoted: 100 Post(s)
Liked: 73
I wonder why it's so fat?
Robert Clark
Robert Clark is offline
post #12 of 129 Old 06-01-2018, 08:59 PM
rocklee's Avatar
Quoted: 494 Post(s)
Liked: 125
FYI
It's 9000rmb, about the same price as the other faux 4K projectors. Some other details that I found:
- 1500 lumens
- auto-closing lens
- built-in android system was limited compared to other system
- difficult to find system details like memory usage
- sound quality was lacking (need equaliser)
- build quality was lacking (paint peeling and scratches found)
The issue with this one is:
- built-in Android won't go well on this sub since everybody hates the idea
- long throw while most brands in China are going with UST
- too many competition
Optoma seems to be trying to create something for the Chinese market while trying to sell their other stuff. Will be interesting to see how it will play out but it might be too late for them.
rocklee is offline
post #13 of 129 Old 06-04-2018, 07:58 PM
Quoted: 274 Post(s)
Liked: 93
Better cooling system?
Xbox One S, LG SH4
wheelee is offline
post #14 of 129 Old 06-07-2018, 02:54 AM
dreamer's Avatar
Quoted: 1497 Post(s)
Liked: 604
1.2/103%
No zoom lens, looks like. Must be mounted 1.2x screen width, period ?
Kirk Ellis
BenQ TK800 VuTec 122" Screen, Harmon Kardon AVR 247
Psycoustic Mark III L&R Towers, Boston Center, Energy Take 5 Surrounds
dreamer is offline
post #15 of 129 Old 06-07-2018, 10:06 AM
Ruined's Avatar
Quoted: 2640 Post(s)
Liked: 1265
I dont have much info on this but i am guessing this unit does 500-700 lumens calibrated based on past optoma LEDs. Note this does not appear to use more powerful HLD LEDs.
Likely designed to be a entry level family led projector.
Ruined is offline
post #16 of 129 Old 06-07-2018, 11:51 PM
Quoted: 274 Post(s)
Liked: 93
check out the comments & pictures (chinese, use translate)
scroll all the way down
https://item.jd.com/7617983.html#none
Xbox One S, LG SH4
wheelee is offline
post #17 of 129 Old 06-08-2018, 03:04 PM
Comments seems to be overall very positive, regarding color, brightness and even sound. However, not sure if this is intended to be sold outside of China (Chinese streaming service app pre-installed) ...
post #18 of 129 Old 08-09-2018, 07:55 PM - Thread Starter
roni44's Avatar
Quoted: 92 Post(s)
Liked: 72
I had chance to see i55/UHL55(Taiwan) in person yesterday. Screen was 92in and distance to projector 2.5 meter. Overall, the image was great and price is fair. Retail @ 43000NT (1400USD). And the Taiwan sales team confirm it will be in North America shortly. For others that looking into Xgimi, Jmgo and etc, I really think Optoma is better choice since they have strong distribution network and after service. Also, just like 50/51/51a, i55/UHL55 comes with proper calibration mode which current Chinese LED based projector don't.
ID:	2439830   Click image for larger version
ID:	2439832   Click image for larger version
ID:	2439834   Click image for larger version
Sonyad likes this.
roni44 is offline
post #19 of 129 Old 08-09-2018, 09:49 PM
rocklee's Avatar
Quoted: 494 Post(s)
Liked: 125
For the price it is so-so. The design is very similar to the H1/H2 but significantly more expensive. This should have been a UST from the start.
Also you are wrong again, many of the projectors from Chinese brands have no problems getting calibration.
rocklee is offline
post #20 of 129 Old 08-09-2018, 10:37 PM - Thread Starter
roni44's Avatar
Quoted: 92 Post(s)
Liked: 72
Well, besides Jmgo UST, I have not seen faux 4K LED around this price, agreed on the outlook design, I much prefer H1/H2. And agree on UST, that's why I'm waiting on @Wheelee to see Jmgo faux 4k UST in action before I pull the trigger.
Based on my previous experience with mine H1S, Xigmi only offers minimal on calibration, even in service mode, Xgimi locked which can't do anything about it. If Xgimi's newer model comes with more in-depth calibration option, awesome. And you are correct, besides Xgimi, I have not really played with other Chinese projectors, and I will take that back.
roni44 is offline
post #21 of 129 Old 08-09-2018, 11:13 PM
rocklee's Avatar
Quoted: 494 Post(s)
Liked: 125
The XGIMI can be configured in 2 ways depending on whether the source is via HDMI or digitally, it is after all an LED projector. Everything from contrast to hue to color temperature can be configured. Most modern projectors do not suffer from the same lighting/coloring issues of past projectors and are brighter and more accurate than before. Furthermore, the H1 supports 27 certified picture and color enhancement technologies and follows the color standard DCI-P3 to "customize each frame with optimal color tone, recreating the true color tone from every original source". This is good news for all of us because it means less tinkering with picture settings.
rocklee is offline
post #22 of 129 Old 08-09-2018, 11:19 PM - Thread Starter
roni44's Avatar
Quoted: 92 Post(s)
Liked: 72
Good for you guys, glad you guys don't have tinkering with setting and satisfy with quality. Unfortunately, H1S just wasn't mean to be for me, and thank you for your time.
roni44 is offline
post #23 of 129 Old 08-10-2018, 08:58 AM
Tuan's Avatar
Quoted: 290 Post(s)
Liked: 259
Send a message via Skype™ to Tuan
JRock3x8 likes this.
Tuan is offline
post #24 of 129 Old 08-12-2018, 07:42 PM - Thread Starter
roni44's Avatar
Quoted: 92 Post(s)
Liked: 72
Originally Posted by Tuan View Post
Hi @Tuan , do you know the suggested retail price for i55/UHL55 in the US?
roni44 is offline
post #25 of 129 Old 08-13-2018, 12:50 PM
Tuan's Avatar
Quoted: 290 Post(s)
Liked: 259
I know nothing, I hear nothing, I see nothing. But stay tuned for a couple weeks .
Tuan is offline
post #26 of 129 Old 08-13-2018, 07:59 PM - Thread Starter
roni44's Avatar
Quoted: 92 Post(s)
Liked: 72
Alright, we just have to wait and see.
roni44 is offline
post #27 of 129 Old 08-24-2018, 09:51 AM
Quoted: 37 Post(s)
Liked: 2
Taiwanese specs are out: https://www.optoma.com/tw/product/uhl55/
A few articles also state Alexa and Google Assistant support; along with apps like Netflix, NBA, Spotify...etc. This is getting more exciting. (reference: http://www.stufftaiwan.com/2018/08/1...C%83%E5%A5%BD/ )
It does seem that it's not using the official Android TV system, and instead it's a modified for TV version of Android 6.0. The apps seem to be the one you can get through Aptoid marketplace (therefore, whether the Netflix app may not be the one supporting 1080p and above).
That said, we won't know for certain until it's officially released and also ported for international release. I won't be surprised that it is in the middle of getting certifications for the international release.
If it does have official Alexa and Android TV support (along with Netflix, Hulu...etc), this may just sell like hot cakes.
springroll2000 is offline
post #28 of 129 Old 08-24-2018, 11:24 AM
JRock3x8's Avatar
Quoted: 1899 Post(s)
Liked: 633
BOOOOOOOOOOOO!
Bad pun! (Ok I actually kinda liked it)
Unrelated : @Tuan - you're so coy!
also have to agree that if the screen ratio is fixed I don't follow why this is not a UST.
JRock3x8 is offline
post #29 of 129 Old 08-24-2018, 12:02 PM
Tuan's Avatar
Quoted: 290 Post(s)
Liked: 259
*sigh*
Tuan is offline
post #30 of 129 Old 08-25-2018, 07:41 PM
JackB's Avatar
Quoted: 1589 Post(s)
Liked: 382
Tuan,
Any chance we might see this at Cedia? Will Optoma be exhibiting there?
Jack
JackB is offline
