BenQ W6000 cleaning? (and noise reduction) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-02-2018, 05:57 AM - Thread Starter
Liked: 0
Any tips/guide on how to clean my BenQ W600?
Picture is good, but i think there's a lot of dust in there, and fan are sometimes making noise like it hits a wire or something.
I am normally OK with opening electronics for cleaning, but I am a bit afraid of breaking things like the color wheel and the DLP processor.
warfly is offline
post #2 of 2 Old 08-02-2018, 06:46 AM
rekbones's Avatar
Quoted: 1079 Post(s)
Liked: 555
First and most important "DON'T EVER BLOW ANY KIND OF COMPRESSED AIR INTO PROJECTOR !!!!!" as this will most likely push dust into the optics. Disassemble as much as you feel comfortable with and use a vacuum and brush but also caution as a vacuum will generate static. A humid environment will help with most of the static.
"Smart enough to know better, to old to care" ------ Dedicated Bat Cave Home Theater, JVC RS49U/Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 18TB DroboFS NAS
rekbones is offline
