Optoma UHL55 - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 11Likes
post #31 of 47 Old 12-26-2018, 05:12 PM
Federico's Avatar
Color wheel?
Does this projector use a color wheel?
Federico is offline
post #32 of 47 Old 12-26-2018, 05:22 PM
JackB's Avatar
Quoted: 1764 Post(s)
Liked: 420
No. It is an LED projector. They don't need a color wheel.
Jack
JackB is online now
post #33 of 47 Old 12-26-2018, 06:12 PM
Federico's Avatar
"No. It is an LED projector. They don't need a color wheel."
Thanks for the information.
Federico is offline
post #34 of 47 Old 03-15-2019, 09:51 AM
Quoted: 14 Post(s)
Liked: 0
Is there an Optoma UHL 55 owners thread in this forum? I can't seem to find it.
bogs8812 is offline
post #35 of 47 Old 03-15-2019, 10:58 AM
Sonyad's Avatar
Quoted: 253 Post(s)
Liked: 143
This was the other UHL55 thread https://www.avsforum.com/forum/68-di...projector.html
Sonyad is offline
post #36 of 47 Old 01-14-2020, 01:08 PM
Liked: 0
Any thoughts on how this would compare to the Epson HC 2150? I was going to get the 2150 but the UHL55 is currently only a little bit more.
Shane Fog is offline
post #37 of 47 Old 01-17-2020, 03:42 PM
Quoted: 189 Post(s)
Liked: 52
Has anyone do a direct comparison with this to the Optoma UHD51A? Which one is better overall for picture quality? For 3D and 4K HDR playback? I need to buy soon. Any help would be appreciated!
cky2354 is offline
post #38 of 47 Old 01-21-2020, 08:26 AM
Liked: 0
is it advisable to buy optoma uhl55? vibrant colors ,black, contrast ..i owned LG PF85U before iam considering upgrade to optoma UHL55 or LG HU80KA laser projector..which one is goodbuy?
dss862 is offline
post #39 of 47 Old 02-15-2020, 08:34 AM
David Biagas's Avatar
Quoted: 203 Post(s)
Liked: 64
Originally Posted by cyrilryo View Post
Hi, newbie here, owned this UHL55 projector for a week, and have a few posts on the i5 thread. Seems this is the more proper thread for discuss this global version of i5.
Post some test shoots from my phone at here again. They are from an inferior quality ALR screen cloth I just got for try out on these kind of screen, although the screen has some defects the UHL55 did shines with this kind of screen, so potential buyer may consider to get a proper ALR screen for best viewing experience, if your viewing location and projector location meets the limited sweet spots for these kind of screen.
Ready player One UHD BD play from XB1X, shoot at night with living room lights off
From XB1X youtube apps, in 4K and livng room lights on
The YouTube videos you posted in the i5 thread totally convinced me to get this projector... thanks for sharing!!
Optoma UHL55 || Marantz SR6013 & Outlaw 7000x || Panasonic UB420 || Apple TV 4k || DCM 7.2.4 setup
Vizio M70-D3 || Marantz SR6012 & Outlaw 5000 & Onkyo M282(x3) || Panasonic UB820 || Apple TV 4k || DCM 7.2.4 setup
Vizio M75-E1 || Onkyo TX-NR686 || LG UBK80 || Apple TV 4k || DCM 3.2 setup
David Biagas is online now
post #40 of 47 Old 02-17-2020, 06:13 PM
Liked: 0
I wonder, does anyone experience uneven focus for UHL55?
I received one, and the picture can only be made sharp partly - if I make left part precisely sharp, the right becomes blurry, and vice versa.
I can make center text sharp, but then both left and right parts are somewhat blurry.
Is it normal by all means, or should not happen.
I previously had Optoma LH150 (battery full hd projector) and its focus was much better.
Pavel Bulanov is offline
post #41 of 47 Old 02-21-2020, 12:39 PM
Quoted: 203 Post(s)
Liked: 64
I have to use the manual focus with mine... but once I do it’s fine.... I haven’t mounted it yet so I’ll have a better idea of how the autofocus works once I do...
post #42 of 47 Old 02-22-2020, 07:25 AM
Liked: 0
I also only rely on manual focus, as auto-focus works only on short distances (and even there it's not reliable)
The problem I had was that no matter I tweak it, it's either very sharp on the left side (and blurry on the right), or sharp in the center (and slightly blurry on both left and right), or very sharp in the right (and blurry on the left). It's the same no matter of the projection distance (short or long). There is no focus position that makes whole picture sharp.
I position the projection straight in front of the wall (not use any horizontal or vertical corrections), so that's not the issue.
I also tried multiple different sources, i.e. chromecast, fire stick or xbox one x.
post #43 of 47 Old 02-22-2020, 04:50 PM
Quoted: 203 Post(s)
Liked: 64
I have to use the manual focus with mine... but once I do it’️s fine.... I haven’️t mounted it yet so I’️ll have a better idea of how the autofocus works once I do...
I’m not having that problem at all... how long ago did you buy it? Any chance you can get it repaired under warranty or exchanged for a new one?
post #44 of 47 Old 06-14-2020, 07:01 AM
Liked: 0
Hi, is it possible to place this projector example to the book shelf and project over sofa under it? (Sorry about my english).
Ville Vahvaselkä is offline
post #45 of 47 Old 06-30-2020, 04:04 PM
Quoted: 203 Post(s)
Liked: 64
The bluetooth on my projector is no longer working. It's just stuck on disabled. I've tried resetting the project and nothing seems to fix it. Anyone have any suggestions? I've put in an extended warranty ticket through CPS, but I'm not happy about having to do that.... The remote works like crap through IR..... might be time to invest in a universal remote, but it not working really sucks...
post #46 of 47 Old 07-01-2020, 03:03 PM
Quoted: 203 Post(s)
Liked: 64
Anyone have experience using a harmony remote with this projector? I’m assuming it works via IR.... wondering if the range will be just as bad as it is with the regular remote....
I don’t really need Bluetooth functionality if I can get the harmony to work...
post #47 of 47 Old 07-05-2020, 11:27 AM
Quoted: 203 Post(s)
Liked: 64
Alright sending it back... never ordering another refurb again! This is the second one that goes bad on me!!
