Xgimi Lune 4K Owners Thread (No Price Talk) - Page 8 - AVS Forum | Home Theater Discussions And Reviews
 45Likes
post #211 of 252 Old 03-12-2019, 06:28 AM
Sengaya's Avatar
Liked: 1
Lightbulb LUNE 4K HDR setup and RGB + Gamma settings
Hello Everyone
I received my LUNE 4K yesterday and tested a lot (thanks for the comments inside the thread, it helped a lot)
The control menu of the LUNE 4K is very confusing and complex, but you can find the most important picture settings and it is also possible to play HDR via external players, without any quality restrictions.
I try to give an overview about the fundamental settings and issues I faced if the wrong settings were choosen.
I have no picture wall yet so the images are based on LUNE 4K which was projecting on an uneven, yellowish wall
My Setup:
Zidoo Z9X HDMI OUT --> Denon X1500H --> LUNE 4K HDMI 2 IN/ARC
Zidoo Settings (as an example of other devices):
Firmware Version 2.1.40 is used
Display Resolution is 3840x2160P @ 24Hz
YCbCr 444 @ 10bit and 0-255 range
SDR to HDR mapping causes picture artifacts thatswhy Ineeded to use AUTO settings on Zidoo side
Zidoo HDR Auto Mode
Due to the setup it was needed to adjust the audio delay slightly
The delay was between 25ms and 50ms... I used 25ms setting to solve it.
LUNE 4K basic settings:
In the LUNE 4k there are four different setting menus for the color settings.
The basic settings can be adjusted inside the "quick-menu".
Therefore you should select your favourite input port of the LUNE (in my case the hdmi2).
The connected source need to be active, otherwise you are not able to open the LUNE setting.
Press SHORT time the setting button of your remote
The following menu should appear on the left side
Enter the third collumn first and make shure it is set to HDMI 2.0
Now you need to go one step back and enter the first menu and change your settings if you like to.
I prefered to deactivate all enhancers. I kept the standard color, due my screen not arrived yet.
With this basic settings I am able to get Full HDR and the picture looks pretty and colorful.
If you like to adjust the colors of the LUNE 4K more precise, you need to use the hidden menus of the device.
Please do pictures of the default settings before you touch them! If you change the following settings, they maybe not reset within factory reset!!! All changes are made at your own risk!
LUNE 4K advanced color settings:
Go to settings and select the "about" menu
After you entered the menu you should see
Now you should press and hold the left button on your remote
The factory setting menu should appear (black backround color)
It seems to be the basic menu for the major adjustment of the device because test patterns are included and the voltage power of the RGB sentivity can be fine adjusted.
If you like to have a look for it...
Go to the following item and enter it:
Under calibration data menu you will find the default settings of your device. You can do a picture of it if you need a fall back later on.
You are also able to fine tune the parameters but I would not do it inside this menu, therefore we have other possibilities.
Go back to the "about" menu
Press and hold the right button of your remote
The Design menu should appear
Select the first collumn Factory menu
Under ADC Adjust you are able to finetune your RGB (like for calman ect.)
You can do it for SD and HDR mode
Under W/B Adjust you are able to select the RGB parameters more individuel for the different color modes
Now you are able to set your own RGB values and gamma correction.
It i is my first post so please do not hestitade if I you have comments.
PLEASE NOTE THAT All changes are made at your own risk. I assume no liability for any damages on your devices.
simpleHT likes this.
Sengaya is offline
post #212 of 252 Old 03-12-2019, 11:23 PM
Quoted: 223 Post(s)
Liked: 51
Originally Posted by Sengaya View Post
Hello Everyone
My Setup:
Attachment 2537806
Attachment 2537804
Attachment 2537800
Attachment 2537808
Zidoo HDR Auto Mode
Attachment 2537810
Attachment 2537824
Attachment 2537796
Attachment 2537798
Attachment 2537802
Attachment 2537796
Attachment 2537812
Attachment 2537794
Attachment 2537838
Attachment 2537830
Attachment 2537828
Attachment 2537834
Attachment 2537832
Attachment 2537822
Attachment 2537792
Attachment 2537830
Attachment 2537826
Attachment 2537836
Attachment 2537820
Attachment 2537790
Attachment 2537816
Attachment 2537814
Attachment 2537818
Well done, Sengaya. Best post I've read in a long time.
The ability to access these low level setting will elevate the Lune4K into the elite class. Lune's main deficiency is its HDR/HLG performance, and dealing with SDR/BT2020 signal. Looking forward to read how this can be improved.
Looks like it's time to pick up another unit.
qoopy is offline
post #213 of 252 Old 03-22-2019, 08:20 AM
oBMTo's Avatar
How does this compare to the Xiaomi MIJIA 4k UST? Was originally going to a put a preorder in for Benq HT3550 put my mounting options may be limited and may require a shorter throw for a 120" screen. Was hoping either the Xgimi or Xiaomi would be a viable alternative.
oBMTo is offline
post #214 of 252 Old 05-02-2019, 09:29 PM
Quoted: 274 Post(s)
Liked: 93
LUNE 4K Pro (100-inch hard screen set version)
Anyone know the difference?
XGimi CC, XGimi Z6, UKCSIS, Vmai M200 Pico
Xbox One S, LG SH4
wheelee is offline
post #215 of 252 Old 05-02-2019, 10:09 PM
schumy's Avatar
Quoted: 87 Post(s)
I asked Taobao store just now, they said the only difference is the brightness, everything else is the same. It is also black in colour obviously. see attached table they sent me.
Query if the extra brightness justified the premium (about USD$1500 more than Lune4K).
schumy is offline
post #216 of 252 Old 05-02-2019, 11:15 PM
aerodynamics's Avatar
Quoted: 311 Post(s)
Liked: 136
Of course I would see this the same day I ordered the Lune 4K. Although at +$1500, I'm not too upset. Interestingly, that is the first spec sheet I've seen that specifically says it covers 100% of the DCI-P3 gamut. If true, the Lune 4K has a one-up on all other UST models on the market.
Chiq B5U | 100” Snowhite UST Screen | Pioneer Elite LX-503 | 7.2.4 Surround | Sony Core Series LCR + Atmos | Cambridge Min 12 Side Surrounds | Monoprice Rear Atmos Surrounds | Bic V1020 x2
aerodynamics is offline
post #217 of 252 Old 05-03-2019, 08:35 AM
big_k's Avatar
assuming the spec sheet is truthful. Hopefully you can share how you like the projector! I am shopping for a projector in a similar price range
big_k is offline
post #218 of 252 Old 05-07-2019, 10:00 AM
Quoted: 69 Post(s)
Just joining this thread as I am basically having a close eye on UST 4k projectors currently, with the new Xiaomi Mija 4k being my favorite. However, the Xiaomi / Vava4k are quoted to be having 102ms of input lag - can anyone advice on (or has anyone ever measured) the input lag on the Xgimi Lune (Pro?), besides from this 15ms number that has never been confirmed?
drdoom2k is offline
post #219 of 252 Old 05-23-2019, 11:33 PM
Sengaya's Avatar
Liked: 1
Hi
i installed my screen now.
I was able to setup the colors and white balance as discribed before.
Ill give you some impressions about the gamut via calman results later today. I check if it possible to measure P3 too.
About the delay... the lip sync delay was between 25-50ms. Do you have any idea how to measure the inputLag overall? If yes, I would be able to measure it for you i guess.
BR
Sen
Know why, not just how
Sengaya is offline
post #220 of 252 Old 05-24-2019, 12:19 AM
Quoted: 311 Post(s)
Liked: 136
Well the site I ordered it from canceled my order. I knew the price was too good to be true. I’ve had one hell of a time trying to purchase this projector. Since February, I’ve made 3-4 attempts on various websites to order and every time there was an issue, whether CC not accepted, orders canceled, etc. No one wants me to have this projector! Guess it wasn’t meant to be.
post #221 of 252 Old 05-30-2019, 08:41 PM
Liked: 0
Hello guys, Im very new to the projector world. I was wondering if anyone has compared this to the JmGo S3 ? Im more particular to the lumens brightness as I have no way to fully darken my room. Thanks in advance.
Docjao is offline
post #222 of 252 Old 07-11-2019, 01:07 AM - Thread Starter
Quoted: 37 Post(s)
Liked: 9
Hi
BR
Sen
Updating to latest firmware on my Denon 4400 solved the issue entirely
Ofir Kris is offline
post #223 of 252 Old 07-11-2019, 01:10 PM
Quoted: 223 Post(s)
Liked: 51
Suggestion for non-ALR screen
After sitting in the store for 10 months, the XY screen is finally mounted on a ikea stand for testing.
Here are some initial observations:
1. It's quite useless for daytime use. Someone has commented on the chinese forums that the ability of the horizontal lenticular structure of XY screen to reject light coming from the side is limited. The circular Fresnel type screen would be more effective.
2. Sharpness appears to have suffered a bit.
3. The first image projected look a bit aggressive, with hint of sparkles.
4. SD colour seems to have suffered a bit.
5. Getting a decent HDR image requires the contrast to be cranked up and brightness lowered, resulting in clipped whites and crushed blacks, perhaps also due to the limited dynamic range of the LUNE. Blue also needs to be cranked up and green reduced. ATM this is a process by trial and error due to lack of calibration tools, and appears to be content dependent. It's time to mess with the factory setting menu.
6. Using the x700 to force the Lune to operate in bt2020 mode appears to obtain better results for bt709 contents. Attached are some of these pseudo bt2020 screenshots.
7. Would like to try out a normal screen to be used in dark surrounding. Any suggestions? White/grey/silver? Gain?
ID:	2589816   Click image for larger version
ID:	2589818   Click image for larger version
ID:	2589820   Click image for larger version
ID:	2589822   Click image for larger version
ID:	2589826   Click image for larger version
ID:	2589828   Click image for larger version
ID:	2589830   Click image for larger version
qoopy is offline
post #224 of 252 Old 07-11-2019, 06:17 PM
Quoted: 274 Post(s)
Liked: 93
what about this screen?
Xbox One S, LG SH4
wheelee is offline
post #225 of 252 Old 07-13-2019, 12:59 AM
schumy's Avatar
Quoted: 87 Post(s)
Just updated firmware, glad that it has fixed the movie play back lip sync problem, and now offers English language in the setup manual.
Anyone tried the new Pro model, is it worth the premium over the standard 4K model?
schumy is offline
post #226 of 252 Old 07-16-2019, 04:01 AM
Quoted: 223 Post(s)
Liked: 51
Looks like the CCTV4K and GDZY4K streams are now working.
ID:	2591278   Click image for larger version
qoopy is offline
post #227 of 252 Old 07-16-2019, 05:26 AM
Liked: 0
where to get 4k projector less than $2000?
Giovano Santos is offline
post #228 of 252 Old 07-17-2019, 01:58 AM
Quoted: 223 Post(s)
Liked: 51
Chinese online retailers, or the usual suspects.
qoopy is offline
post #229 of 252 Old 07-21-2019, 02:25 PM
fanisnyc's Avatar
Quoted: 22 Post(s)
Hi guys. I got the lune 4k as well as an xy screen from China. I am.kind of jnew to the projector world.
Now Iin the next few days I will be mounting the screen into the weak. As I haven’t done it well can anyone help me with the right process to doing right. From what I understand I can’t adjust the screen height through the projector? Correct? Any tips and help will be very appreciated
Thank you!
fanisnyc is offline
post #230 of 252 Old 07-22-2019, 10:26 PM
Quoted: 223 Post(s)
Liked: 51
If you place the Lune on the floor, the 120" projected image will be about 45cm from the ground. Using a platform with 4 adjustable feet will make the process of alignment much simpler.
XYscreen assembly is quite straight forward. Detail instruction can be found on youtube.
Have fun.
qoopy is offline
post #231 of 252 Old 07-24-2019, 02:04 AM
fanisnyc's Avatar
Quoted: 22 Post(s)
So in other words I first place the projector (i have a media console) turn it on, see where the picture goes and place the screen accordingly? Anything else i need to know?
Have fun.
fanisnyc is offline
post #232 of 252 Old 07-26-2019, 09:03 PM
Quoted: 223 Post(s)
Liked: 51
More on XYscreen
1. While a lot has been written about the XPRx4 chipset's ability to resolve fine details, it's apparently not the case here. The screen seems to make matter worse. A test pic is attached for anyone who may be interested.
2. Screen brightness also takes a bit hit. Actual measured screen gain of just 0.5 for these lenticular type screens has been posted on some chinese internet forums. For night time viewing, a normal white/grey screen may be a better option. The attached HDR screen shot is taken with default setting.
ID:	2595088   Click image for larger version
ID:	2595090   Click image for larger version
ID:	2595092   Click image for larger version
ID:	2595094   Click image for larger version
qoopy is offline
post #233 of 252 Old 08-03-2019, 01:08 PM
Quoted: 223 Post(s)
Liked: 51
Youtube 4K HDR
1. Although YoutubeTV installed successfully after first adding the framework and play services, playback would hanged after a couple seconds. This could be due to lack of support for Opus audio format. It also defaulted to selecting bt709 format instead of HDR.
2. Smart Youtube TV fared slightly better. The default audio format is MP4, but failed to reproduce the colour of v92 format correctly.
So for now, an external device is needed for Youtube 4K HDR playback. Attached are some screen caps of HLG clips using the UB820.
ID:	2597954   Click image for larger version
ID:	2597956   Click image for larger version
ID:	2597958   Click image for larger version
qoopy is offline
post #234 of 252 Old 08-06-2019, 02:09 PM
Quoted: 223 Post(s)
Liked: 51
Some PQ shots
ID:	2599794   Click image for larger version
ID:	2599796   Click image for larger version
ID:	2599798   Click image for larger version
ID:	2599800   Click image for larger version
qoopy is offline
post #235 of 252 Old 08-07-2019, 07:39 AM
schumy's Avatar
Quoted: 87 Post(s)
Youtube 4K HDR
I have been using Smart YouTube TV which I am happy with due to the convenience and the only downside is no HDR (colour is washed out). The 4K SDR output is already decent enough for me cause it is only YouTube videos not UHD movies.
schumy is offline
post #236 of 252 Old 08-09-2019, 10:06 AM
Quoted: 223 Post(s)
Liked: 51
4K HDR contents on youtube has much higher bit rate that other streaming services. Quality is good, but getting the colour to be displayed correctly has been a challenge on the lune4k, and I suspect other chinese made devices as well. The opus audio format is also not supported. It's not clear if these issues are Android TV related, or specific only to these devices. Interested to know if anyone has been able to get around these.
qoopy is offline
post #237 of 252 Old 08-09-2019, 03:50 PM
Liked: 0
Where is in a service menu can be a parameter for rotating screen on 180 degree?
In my firmware this option in a main user menu are absent.
Name:	photo_2019-08-10 01.48.39.jpeg
Kaputmaher is offline
post #238 of 252 Old 08-10-2019, 07:18 PM
Quoted: 223 Post(s)
Liked: 51
You could try updating the firmware to see if the setup menu appears.
Otherwise, if your unit understands chinese, the voice command "投影方式" will bring up the mounting options.
ID:	2601618   Click image for larger version
qoopy is offline
post #239 of 252 Old 08-11-2019, 02:46 AM
Liked: 0
Thank you for answer. My Lune seller from Russia helped me also by almost same command.
It can be helpful in that case because in the latest firmware function of rotating screen is disappears from menu:
Go to Google Translate on your phone or computer.
Put "detect language automatically."
Enter: 进入投影方式
Hold the microphone button on the projector remote control for a couple of seconds.
After triggering the projector Chinese “Siri”, play this phrase from Google Translate.
The projector enters the flip and mirror projection mode.
post #240 of 252 Old 08-17-2019, 11:57 PM
Quoted: 223 Post(s)
Liked: 51
Youtube vp92 HDR
The Lune4k fails to reproduce the colour of youtube vp92 hdr video properly. Here a comparison between bt209 and ARIB STD-B67.
ID:	2604160   Click image for larger version
qoopy is offline
