BenQ W2700 Anticipation - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 12Likes
post #31 of 43 Old 11-03-2018, 04:34 AM
JonnyVee's Avatar
Quoted: 274 Post(s)
Liked: 163
Originally Posted by kraine View Post
There is no chance that the W2700 will be out in November. It will be available in Europe on Februar 2019 :
http://www.passionhomecinema.fr/blog...adre-lumineux/
Upside is I have more time to start saving my pennies.
Rec Room: JVC x790 w/120" Silver Ticket screen, Denon x4400H 5.1.4 with Kef Q100 L/R, Q200 centre, T101 surrounds, Ci160er rear atmos, Energy Rc-Mini - front atmos, SVS PC-2000. Family Room: LG 65B7P OLED, Denon s730H 5.1 - Kef Q500, Q200c, Energy v-mini - surrounds. Calibration Gear: X-Rite i1Display Pro, Calman Home Enthusiast, trial & error, and a patient wife.
JonnyVee is offline
post #32 of 43 Old 11-03-2018, 05:27 AM
JonnyVee's Avatar
Quoted: 274 Post(s)
Liked: 163
Originally Posted by josfuq View Post
It's not marketing but the technical mistake, I found that page accidentally just googling any upcoming 4k projectors, they already removed all pages about it.
Optical Throw Ratio
1.13 - 1.47 (100" @ 2.5 m)
Zoom Ratio
1.3X
Lens
F/# = 1.9 - 2.47, f = 12 - 15.6 mm
Dimensions (W x H x D)(mm)
380 x 127 x 263
Net Weight (Kg/ lbs )
4.2 kg / 9.2 lbs
I have the HT2050, which has a 1.15 throw, and I’m projecting exactly 120” at my throw distance. If the throw ratio of 1.13 is correct I’ll be able to get 122”. Although, it also appears to be 0.5” (14mm) deeper, so the lens may be slightly more forward.
Either way, looks like slightly more flexibilty.
JonnyVee is offline
post #33 of 43 Old 11-05-2018, 11:02 AM
Quoted: 12 Post(s)
Liked: 8
Gaming input lag
Any word on what the gaming input lag would be for this?
I ultimately held off on the HT2550 and purchased the Benq 2050A because of it's 16ms input lag.
juic-E-juice likes this.
jordancferry is offline
post #34 of 43 Old 11-05-2018, 02:44 PM
juic-E-juice's Avatar
Quoted: 22 Post(s)
I'm interested in the same. While all the stats so far have me wanting to press B for "buy", gaming in 4K is the main reason I'm looking at new projectors. If this has low input lag, I'm all in.
BattleAxeVR likes this.
juic-E-juice is offline
post #35 of 43 Old 11-06-2018, 02:19 AM
Nuieve's Avatar
Quoted: 141 Post(s)
Liked: 47
Good progress with 4K. Very short on lumens still but progress nonetheless.
Still not even considering buying a 4k projector until I can buy massive amounts of used 4K blurays for under $5 and until Redbox will start renting them out. Otherwise there's nothing to watch in 4K yet... Hopefully in 2-3 years the above mentioned criteria will be met and 4k PJ will be under $1000.
Until then... just observing industry developments with great interest.
Nuieve is offline
post #36 of 43 Old 11-06-2018, 02:47 AM
JRock3x8's Avatar
Quoted: 1722 Post(s)
Liked: 532
I'm getting worried about those 4k blurays - so many people are streaming now those might not be a viable enough business for studios to keep making them.
JRock3x8 is offline
post #37 of 43 Old 11-06-2018, 04:50 AM
ToddUGA's Avatar
Quoted: 60 Post(s)
Liked: 64
I don't even own a 4K display yet but I've already started buying 4K UHD discs and just using the included Blu-ray until I do. Just trying to do my part.
n84china likes this.
ToddUGA is online now
post #38 of 43 Old 11-06-2018, 05:44 AM
JRock3x8's Avatar
Liked: 532
I don’t think there are enough of us. Adoption is much slower and the studios complained that blu Ray didn’t grow enough to cover their costs.
JRock3x8 is offline
post #39 of 43 Old 11-06-2018, 10:41 AM
Quoted: 519 Post(s)
Liked: 292
I don't really care what happens after UHD Blurays die off, I just want to collect all the back catalogue of remastered to HDR films and then keep those indefinitely, in high bitrate.
Codecs keep improving as does internet bandwidth so I'm not too worried about new content looking poor on better displays as time goes on. If anything, capture is getting better and better, so the idea that they wouldn't want to maintain the quality for those who are willing to pay for it seems silly to me. I'd certainly pay more for higher bitrate Netflix, and ideally pre-frame interpolated Netflix so I didn't have to do MEMC on my PC via Netflix rips. As it is right now, I have no choice but to rip all my content to my PC to watch it with smoothing on.
BattleAxeVR is offline
post #40 of 43 Old 11-06-2018, 12:58 PM
JRock3x8's Avatar
Liked: 532
I have never seen a stream that looks as good as a disc.
Troy LaMont likes this.
JRock3x8 is offline
post #41 of 43 Old 11-07-2018, 01:35 AM
Liked: 0
Hello again !!
The great dilemma! I have a UHD51 that I bought for € 1100 as new at Amazon and I am very happy, but it is true that for those of us who look closely at the halo it is annoying. Now I see that Benq takes out his W2700 in February and all the doubts assault me. Will Benq improve the Optoma image quality in addition to removing the halo? I can return the Optoma until the 26th, so I will not arrive in time to see Greg's analysis ... what do you think?
Quim Quim is offline
post #42 of 43 Old 11-07-2018, 02:35 AM
JRock3x8's Avatar
Liked: 532
Originally Posted by Quim Quim View Post
Hello again !!
So on the one hand nothing is worse than buyers remorse but on the other hand you will probably have to spend 50% more at least to get a PJ that’s maybe 10% better overall.
If I already had a 4k PJ up and running I’m not sure I would pull the chute for this.
Just my $0.02
JRock3x8 is offline
post #43 of 43 Old 01-02-2019, 01:37 PM
bdht's Avatar
Quoted: 173 Post(s)
Liked: 75
What program are you using for motion smoothing? I do the same. Madvrs frame blending at 60p for most content. And svp + frame blending for anime cgi like Knights of Sidonia, Blame, Godzilla, Ajin, Berserk etc.
bdht is offline
