BenQ W2700 / HT3550 Announcement and Owner’s Thread - Page 104 - AVS Forum | Home Theater Discussions And Reviews
 2202Likes
post #3091 of 3953 Old 05-13-2019, 12:37 PM
sage11x's Avatar
Quoted: 2582 Post(s)
Liked: 2527
Originally Posted by msankadi View Post
Can wcg and the dynamic iris both be switched on at the same time?
Of course!
The only features that can’t coexist are the iris and the ‘smarteco’ lamp dimming. If one is on then the other will be off.
msankadi likes this.
What to do if you find yourself stuck with no hope of rescue:
Consider yourself lucky that life has been good to you so far. Alternatively, if life hasn't been good to you so far, which given your present circumstances seems to be more likely, consider yourself lucky that it won't be troubling you much longer...
-- Excerpt from the Hitchhiker's Guide to the Galaxy.
sage11x is online now
post #3092 of 3953 Old 05-13-2019, 01:29 PM
Quoted: 49 Post(s)
Thisis just for my understanding : Hypothetically , If it was a minor issue would it have been better to use the projector for a couple of years and then avail the benq warranty? Do they create any problems to replace?
Sent from my Redmi Note 7 Pro using Tapatalk
Yes, you would go through Benq but since I'm within the return window with Amazon I'd rather go through them because it's much faster and convenient.
Keltron is online now
post #3093 of 3953 Old 05-13-2019, 01:39 PM
FreddieKU's Avatar
Liked: 1
I just purchased this from Amazon while it's out of stock. Is this place so tuned in that someone might have an idea of when Amazon will get more in stock?
FreddieKU is offline
post #3094 of 3953 Old 05-13-2019, 02:36 PM
subacabra's Avatar
Quoted: 1562 Post(s)
Liked: 4599
Watching the regular blu ray version of Oblivion and holy hell it looks great!!
subacabra is online now
post #3095 of 3953 Old 05-13-2019, 03:05 PM
Quoted: 49 Post(s)
They have been consistently replenishing their stock pretty quickly... should maybe ship out end of week/next week... no guarantees but it seems like availability is getting much better.
FreddieKU likes this.
post #3096 of 3953 Old 05-13-2019, 03:06 PM
home4sale2's Avatar
Quoted: 98 Post(s)
Liked: 54
I know you can override DI no matter what through the remote button (which I think is a firmware bug or maybe it's by design . This is irrespective of it being greyed out in Menu (ex. during HDR).
home4sale2 is offline
post #3097 of 3953 Old 05-13-2019, 03:47 PM
FreddieKU's Avatar
Liked: 1
Can anyone recommend a good ceiling mount for this? I need an extension likely as I have to take into account a ceiling fan. Ceiling is your standard apartment type ceiling but can figure out more specifics though I assume pulling something off the first listing on Amazon will meet my requirements.
TIA.
post #3098 of 3953 Old 05-13-2019, 06:37 PM
Brian18's Avatar
Quoted: 17 Post(s)
While watching 4k content on a roku suddenly everything just went to a 1/4 of the screen, then went back to normal it did this several times, any idea whats causing this
Brian18 is offline
post #3099 of 3953 Old 05-13-2019, 06:59 PM
Quoted: 49 Post(s)
Originally Posted by Keltron View Post
I get my 3rd replacement of this projector today from Amazon. Fingers crossed I have no issues! Fortunately the exchange process from Amazon is much better than other sellers.
Welp my replacement is much worse with color banding and color issues very similar to the first one I purchased from BenQ directly. I’ll be sending this one back. It’s a bummer that they haven’t worked out all the QA issues but if you can get a good one then the projector is great.
I’ll be keeping the first one I received from Amazon. It’s perfect in every way except the small white horizontal line at the bottom I previously posted. Amazon is offering a 10% discount to keep it because they don’t have any replacements available. Eventually I’ll just get it replaced through Benq once they work out everything.
post #3100 of 3953 Old 05-13-2019, 07:01 PM
Quoted: 28 Post(s)
Is the blue tint normal when you turn on WCG mode?
Delumine is offline
post #3101 of 3953 Old 05-13-2019, 07:02 PM
ensyed's Avatar
Quoted: 27 Post(s)
I have it connected to a 4K fire tv.
Netflix was showing 4K HDR content. I was messing around with the settings and suddenly Netflix is no longer showing 4K or HDR
When the 3550 searches source it says hdr10 so I assume it knows the fire tv is sending it 4K but Netflix doesn’t think so.
Is the hdr motion supposed to be off or low or what? I think I changed it and messed things up.
Thx
ensyed is offline
post #3102 of 3953 Old 05-13-2019, 07:07 PM
subacabra's Avatar
Liked: 4599
Just turn brilliant color on then off it'll go back to normal.
Hopefully firmware will fix all these little bugs.
post #3103 of 3953 Old 05-13-2019, 07:25 PM
ensyed's Avatar
Quoted: 27 Post(s)
Question Help: Netflix not showing 4K content on ht3550?
I have the ht3550 hooked up to a 4K fire tv stick. The projector recognizes the source as 2160p hdr10 4K but Netflix is showing only HD.
This happened after I was messing around with HDR and cinema settings. I reset the picture settings but Netflix is still not showing hdr or 4K for Amy show/movie.
Any ideas on what caused it and how to fix it. I tried turning everything offs and on but it’s not working.
Thx
ensyed is offline
post #3104 of 3953 Old 05-13-2019, 07:53 PM
Quoted: 28 Post(s)
Anyone know some good settings? I’m indecisive, if WCG has more color, why does it look more dull and greener?
Delumine is offline
post #3105 of 3953 Old 05-13-2019, 07:53 PM
Quoted: 29 Post(s)
Liked: 2
Is anyone else getting slightly weird colors in HDR mode?
The colors I have a problem with are yellows and blues. Yellows lean way too red and have a mustard like coloring to them and blues are way too bright and overpowering. Almost like a neon effect. I've played around with color settings but it is hard to fix these colors without ruining the look of the other colors. Colors in SDR mode look great though.
DrCoolface is offline
post #3106 of 3953 Old 05-13-2019, 08:01 PM
rontalley's Avatar
Quoted: 777 Post(s)
Liked: 385
My Optoma HD33 died on me a couple of days ago. It gave me PJ bliss for about 7 years. Only changed the bulb once. I put a meter on the lamp lead and it reads around 92v so I’m thinking the pj is good just the bulb went bad. Only about 200 hours on this one... However, when I changed the bulb last, the old one was still working...I put it back in and still no image.
Anyway, this led me to look to upgrade to a 4K. All my searches led me to the 3550. Now I’m scared to pull the trigger after reading all of the QC issues with this model.
Should I risk it and get the 3550 or go with the UHD50 which seems to be a winner.
Thoughts?
My Media Room
AVR 1-Yamaha RX-A3050 (7.2.4), AVR 2 Pioneer VSX-815-K(Used for 4ch Amp TF+TR)
Mains-Polk Audio RTi8, Center-Polk Audio CSi5, Surrounds-Polk Audio RTi4, Ceilings-Micca M-8C, Sub 1- UM18-22 (4cu.ft DIY) - iNuke 6000DSP Sub 2-Klipsch RW12D,
Projector-Looking, Screen-Da-Lite 100" Model B, TV-Vizio P-65 4K
rontalley is offline
post #3107 of 3953 Old 05-13-2019, 08:24 PM
Quoted: 28 Post(s)
1st image is with WCG turned off, but to my actual eyes it looks more vibrante
2nd image WCG is on, but it looks more dull.
I don’t understand how this mode is supposed to have more colors?
Delumine is offline
post #3108 of 3953 Old 05-13-2019, 09:38 PM
subacabra's Avatar
Liked: 4599
What screen is that?
post #3109 of 3953 Old 05-13-2019, 09:51 PM
Quoted: 28 Post(s)
84” elite motorized screen
Delumine is offline
post #3110 of 3953 Old 05-13-2019, 10:08 PM
subacabra's Avatar
Liked: 4599
Cool, I'm not a huge fan of the wcg. Just seems to have more pop etc with it off.
On certain movies such as BR2049 though it looks great.
Guess just something you have to get used to.
post #3111 of 3953 Old 05-13-2019, 10:09 PM
Quoted: 28 Post(s)
Yeah... I’m trying to force myself to get used to it
I do admit it does make reds, and water look more natural
Delumine is offline
post #3112 of 3953 Old 05-14-2019, 05:51 AM
Frank714's Avatar
Quoted: 880 Post(s)
Liked: 391
Sorry to hear that, was a great projector for 3D and had excellent Frame Interpolation. Hope my HD 8300 will still last me a while.
Contrast performance of the UHD 50 is probably worse than your old HD 33 - as the Digital Micromirror Devices decreased in size, so did contrast performance.
From everything I read about the BenQ HT 3550, I'm confident that you might consider it a worthy replacement of your HD 33, with the Optoma UHD 50 I'd have severe doubts.
"It is only about things that do not interest one that one can give a really unbiased opinion, which is no doubt the reason why an unbiased opinion is always absolutely valueless." Oscar Wilde
Frank714 is offline
post #3113 of 3953 Old 05-14-2019, 05:56 AM
ensyed's Avatar
Quoted: 27 Post(s)
After comparing tk800m and ht3550 side by side I realized that the ht3550 has more natural looking colors. Even my teen agreed.
And it is surprisingly bright enough for nature shows and sports even in a room with open windows.
Much much better than my w1070.
What if any changes should I make to the settings?
What is WCG?
I need to buy a motorized 110 screen. Any recommendations?
Thx
ensyed is offline
post #3114 of 3953 Old 05-14-2019, 06:51 AM
sage11x's Avatar
Liked: 2527
I’ve read this from a few members but this doesn’t work on my review sample. It does sometimes ‘confuse’ the menu but it doesn’t actually enable both features at the same time.
post #3115 of 3953 Old 05-14-2019, 08:21 AM
kdupuis77's Avatar
Quoted: 38 Post(s)
Liked: 41
I know you can override DI no matter what through the remote button (which I think is a firmware bug or maybe it's by design [IMG class=inlineimg]/forum/images/smilies/smile.gif[/IMG]. This is irrespective of it being greyed out in Menu (ex. during HDR).
Yeah I’ve got one of the 3550s that allow both DI and EcoSmart to be enabled at the same time via the remote. It makes for an interesting effect for sure lol.
11ft x 13ft Theater Room w/ 2x rows of 2x Seatcraft Rialto Leather Powered Recliners
BenQ HT3550 4K XPR DLP projector w/ Silver Ticket 100" 16:9 Aspect Ratio Screen
Yamaha RX-V683BL AVR w/ Klipsch 5.2.2 Atmos Surround System
PS4 Slim, Xbox One S, Nintendo Switch, AppleTV 4K
kdupuis77 is offline
post #3116 of 3953 Old 05-14-2019, 10:13 AM
jblade44's Avatar
Quoted: 38 Post(s)
What is WCG?
Thx
I returned my 3550 and was thinking of the TK800M.... other than color difference anything else jump out?
PS WCG= Wide Color Gamete
jblade44 is offline
post #3117 of 3953 Old 05-14-2019, 10:36 AM
Liked: 2
I'm also not very pleased by the performance of the HT3550.
I'm waiting for the announcement and the first tests of the real successor of the Tk800 later this year.
Ig3l is offline
post #3118 of 3953 Old 05-14-2019, 11:09 AM
Quoted: 49 Post(s)
I didn't like the HT3550 when I first got it. The colors were off and muted, and the brightness was terrible. Once I got a replacement for it, it has been much better and meets the expectations that I had for this projector. The only issue is that the QA has been terrible for these at launch. If you're able to purchase another one, give it another shot. I ordered a replacement from Amazon and it was just as defective as the first one that I got. I ended up keeping my current one with a small issue a small row of "dead pixels" at a 10% discount.
post #3119 of 3953 Old 05-14-2019, 11:14 AM
Quoted: 28 Post(s)
How can I tell if my unit is defective?
Is there a test I can run to determine the lumen/color output?
Delumine is offline
post #3120 of 3953 Old 05-14-2019, 11:15 AM
sage11x's Avatar
Liked: 2527
Besides the DCI P3 support?
Lens shift
Zoom range
Throw ratio
Motion Interpolation
Black levels
Dynamic iris
HDR Pro tone mapping
Native 24Hz capability
Factory calibration
neotide and msankadi like this.
