BenQ W2700 / HT3550 Announcement and Owner’s Thread - Page 126 - AVS Forum | Home Theater Discussions And Reviews
 3122Likes
post #3751 of 5872 Old 06-15-2019, 09:48 AM
Liked: 9
Thanks all for the suggestions on the 4K Blu-Ray Player. It sounds like I'll need to go down the MadVR rabbit hole when I rebuild my HTPC with UHD Blu-Ray.
I've been really happy with the HT3550 I got a couple weeks ago (just doing 4K HDR content via Roku Ultra currently). It's a May 2019 manufactured date and Rev 01-101. I upgraded the firmware to the new 1.0.1.
I don't have any CA issues that I can tell but I'm not on the far end on zoom and still projecting directly onto a wall (until I complete my screen install hopefully this weekend).
Shikamaru is offline
post #3752 of 5872 Old 06-15-2019, 10:22 AM
Fant's Avatar
Quoted: 25 Post(s)
I have a 3550 .. when I first got it the auto keystone correction worked .. now it doesn't seem to do anything .. anyone have this issue?
Sent from my ONEPLUS A6013 using Tapatalk
Fant is offline
post #3753 of 5872 Old 06-15-2019, 02:33 PM
coderguy's Avatar
Quoted: 2963 Post(s)
Liked: 1561
Originally Posted by sage11x View Post
I guess next to a $6000 native 4K NX9 the HT3550 might not stand out as much as I feel it stands out at-it’s-price. But that’s like saying my FRS/86 wouldn’t really stand out parked next to a 911. IMO it doesn’t change the fact that the 86 is a standout product at it’s price point. Context is important here and it’s something that is lacking in wirecutter’s ‘best for most folks’ format. Unfortunately, it’s that kind of format that scares people off from projectors— it did me for years. I was under the impression that you either had to spend thousands and thousands of dollars or simply settle.
JVC NX-9 MSRP = $17,999 usd
JVC NX-7 MSRP = $7,999 usd
JVC NX-5 MSRP = $5,999 usd
The old RS-540/x790 is a better deal for most people, and I generally agree that comparing this projector to a JVC is kind of silly given the price differential.
**Updated Projector Calculator Released NOV 2017**
-- www.webprojectorcalculator.com --
coderguy is offline
post #3754 of 5872 Old 06-16-2019, 03:26 PM
sage11x's Avatar
Quoted: 2976 Post(s)
Liked: 3082
I screwed up and said NX9 and not NX5. Good catch.
What to do if you find yourself stuck with no hope of rescue:
Consider yourself lucky that life has been good to you so far. Alternatively, if life hasn't been good to you so far, which given your present circumstances seems to be more likely, consider yourself lucky that it won't be troubling you much longer...
-- Excerpt from the Hitchhiker's Guide to the Galaxy.
sage11x is offline
post #3755 of 5872 Old 06-17-2019, 06:32 AM
Barry McKean's Avatar
Liked: 8
My keystone was on by default, and I never noticed it change by its self. I manually aligned the projector so it was nearly perfect anyway, but even when it is a bit off and I disable/enable auto keystone, it doesn't do anything. So not sure if it's broken, or it just doesn't work when it's fairly close to being aligned.
Barry McKean is offline
post #3756 of 5872 Old 06-17-2019, 07:06 AM
Liked: 8
I have started to notice faults with my W2700 now. I never used to get the split screen issue, but over the past 8 days or so I've started to get it. It would only happen for 2-3 seconds while the resolution changed and then it would be fine. I also started to get a longer black screen when shows were starting on NF and also Blu-rays on the Sony X700. Then a couple of days later, the black screen would then flicker with a green/blue colour cast. Is this what others have experienced? I've also noticed the screen going black a couple of times when about 2 minutes into a show on NF. This is random and doesn't happen all the time. When I stop the show and play it again, it doesn't happen, so I can't intentionally reproduce it. I have updated the firmware to 01-101 and so far the green/blue colour cast has stopped, but the black screen still remains. The only thing I have changed hardware wise was to swap over my HDMI cable from Out Sub to Out Main on my Onkyo TX-NR636, and to upgrade to a full 4K 60Hz HDMI cable to go from the X700 to the receiver. I wouldn't have thought that a better HDMI cable would make things worse.
Also, when I'm watching Sky, the edges of people and objects distort/pixelate with random black parts when there is motion above a certain speed. The firmware update didn't fix it. Again, this could be down to the HDMI cable or using the other HDMI port on the receiver. I'm going to try and use the old basic cheapo cable again to see if it's that or not. I'll put the cable back into Sub Out and see if that fixes it as well. I've got until the 24th of this month if I want to send it back for a replacement or a refund, but I'm wary that if I get a replacement it'll be worse. I'll decide over the next few days after some more testing.
Cheers,
Barry
post #3757 of 5872 Old 06-17-2019, 12:20 PM
SuperMiguel's Avatar
Quoted: 173 Post(s)
So had this projector for few days, and playing 4k hdr content looks amazing, but as soon as it goes into non HDR content where it needs to use the cinema preset, it gets very dull, like image is not bright enough
Also i keep reading that you need to mount this projector above your screen.. but i got this mount: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 that allows me to point the projector to where i want.. is this bad?
How much will it help this projector if i painted my room black (walls and ceilings) instead of the current white color?
SuperMiguel is offline
post #3758 of 5872 Old 06-17-2019, 12:57 PM
Quoted: 154 Post(s)
Liked: 32
Hi I thought about a portable floor rising projector but I have another option. This is not my first projector or projector screen. Tell me if this is a good idea or bad?
I could order just the screen material and make my own screen! The problem is it would need to be lightweight. Less than 4 lb. Mainly because I would want to hang it up on the wall maybe upside down big maybe. Depending on where the black part is for the no screen is. Then use command strips to connect it to the wall without holes.
Then when I don't want it out roll it up like a big tube all the way to my ceiling in the media room. Then when I need it roll it back down.
The problem is what is the best projector screen material to buy ?
ng4ever is offline
post #3759 of 5872 Old 06-17-2019, 01:46 PM
Sonyad's Avatar
Quoted: 251 Post(s)
Liked: 140
There's a whole section on DIY projector screens https://www.avsforum.com/forum/110-diy-screen-section/
Sonyad is offline
post #3760 of 5872 Old 06-17-2019, 02:22 PM
Quoted: 154 Post(s)
Liked: 32
Wink
Thank you.
ng4ever is offline
post #3761 of 5872 Old 06-17-2019, 03:02 PM
DocOrange88's Avatar
Quoted: 334 Post(s)
Liked: 211
Had to cancel my order with Best Buy, It's been a month and no projector.
DocOrange88 is offline
post #3762 of 5872 Old 06-17-2019, 03:06 PM
Quoted: 154 Post(s)
Liked: 32
I got mine from B&H Photo Video
ng4ever is offline
post #3763 of 5872 Old 06-17-2019, 07:47 PM
hobbs47's Avatar
Quoted: 469 Post(s)
Liked: 504
Really? I’ve had 2 in the past 2 weeks. (one exchange). Strange. They said it would take up to 2 weeks for each one and they both arrived within a few days.
Benq HT3550/LG OLED65B6P /Panny UB820 4k Bluray/Apple TV 4k
Nvidia Shield/HDFury AVRkey/Samsung HW-K950 Soundbar
hobbs47 is online now
post #3764 of 5872 Old 06-18-2019, 12:26 AM
chhanthony's Avatar
Quoted: 238 Post(s)
Liked: 127
Share my new setting @ v1.01
ID:	2581378   Click image for larger version
ID:	2581380   Click image for larger version
ID:	2581382   Click image for larger version
ID:	2581384   Click image for larger version
ID:	2581388   Click image for larger version
ID:	2581390   Click image for larger version
ID:	2581392   Click image for larger version
Anthony Chan
AV Blog: http://www.avnewbie.com
Panasonic DP-UB9000EBK, Shield TV Pro 2019, Zidoo Z9S, Anthem AVM60, Krell KAV2250 X 2, Theater Amplifier Standard, M&K S-150 X 5, SS150 X 4, Martin Logan Descent-i and Thiel SS 2, SS2.2 and SI 1 Integrator, LG HU70LA, JK 126" Fixed Screen N4-FL/W1
chhanthony is offline
post #3765 of 5872 Old 06-18-2019, 02:40 AM
Frank714's Avatar
Quoted: 973 Post(s)
Liked: 429
Can't comment on the quality of your mount, but make sure that the projector lens (and the case of the projector) is level with the top edge of your projected image / screen or slightly above it.
Already a black frame around the image tricks your brain into thinking to be seeing more contrast, if the surrounding walls and the ceiling (otherwise image reflection!) are black you increase this positive aspect (but for other purposes of daily life your room will feel much smaller!). Make certain you use a matt paint (!!!), otherwise the reflections of the projected image could drive you crazy.
"It is only about things that do not interest one that one can give a really unbiased opinion, which is no doubt the reason why an unbiased opinion is always absolutely valueless." Oscar Wilde
Frank714 is offline
post #3766 of 5872 Old 06-18-2019, 09:22 AM
bobbyt's Avatar
UPDATE: Read the original review and found my answer. 3D doesn't work in 4K mode. Totally forgot about that. Switching my Firestick to 1080p made it work. Guess I'll be using Plex on the Xbox to view ripped 3D, and keeping my Fire TV stick in 4K.
My 3550 came in from B&H yesterday. I've been testing it out before replacing my old Vivitek projector on the projector mount.
I put some 3D bluray rips on a USB drive, and they displayed correctly once I manually put the Benq into 3D SBS mode.
I then attached the USB drive to my LG UBK90 bluray player and could play the video (side-by-side), but it would not go into 3D mode when I tried switching it like I did before.
I used to play my ripped 3D blurays via Plex on my old sony 3d bluray player, but this LG doesn't have a Plex app.
I could play the ripped 3D blurays on my old Viewsonic (manually putting it in 3D mode) through the LG player's usb port, but it doesn't seem to work with the Benq.
Can anyone provide insight into this? Am I out of luck trying to play my ripped 3D Blurays with this combination of Benq and LG?
Also, my old projector would work on SBS 3D files played through Plex on a Fire TV Stick, no luck with the Benq.
bobbyt is offline
post #3767 of 5872 Old 06-18-2019, 12:39 PM
Liked: 3
What screen sizes and gain is everyone using with this projector? I was wanting to go with this projector, but after looking at projector centrals calculator i'm having doubts it's going to be bright enough.
The screen i'm looking at using is going to be 165" and a gain of 1 in a totally light controlled basement. PC's calculator is saying it's not going to be bright enough.
fletcherthunder is offline
post #3768 of 5872 Old 06-18-2019, 03:42 PM
NxNW's Avatar
Quoted: 127 Post(s)
Liked: 139
Permit me to advise 165 is in fact too much for this projector..
Huge, Bright Image
Accurate color, great features
Low Cost
Choose two
sage11x and Dehrig Richard like this.
NxNW is offline
post #3769 of 5872 Old 06-18-2019, 04:42 PM
glebonator's Avatar
I got a 135" screen and would say it's just about right. Feels noticeably bigger than a friend's 120" I was also initially considering, but without losing too much light. Dark scenes in various movies are still very visible, I mostly leave it on +1 HDR brightness and use HDR10 source material. Cinema mode for youtube/netflix also looks good. Kinda usable during the day but barely, but that's only because my room is completely not blacked out, might fix that eventually.
glebonator is offline
post #3770 of 5872 Old 06-18-2019, 05:59 PM
Quoted: 62 Post(s)
Liked: 46
Theater guy at our new home just sent this picture of our final product! Excited to get our blackout blinds in and to finally see this thing in action! He said he had no problem installing and had no issues testing the projector out. Can’t wait to see the picture in the light controlled room!
russdornisch is offline
post #3771 of 5872 Old 06-18-2019, 09:59 PM
theagent's Avatar
Quoted: 84 Post(s)
Finally got a proper screen. I'm experiencing a lot of flickering with dynamic iris on. I'm on the latest firmware, and I've tried low, medium, and high settings. I've tried switching to normal mode, doesn't make a difference. It's very distracting. Doesn't seem to be happening with DI off, but things just don't look as good. Is this normal? Seems like there's no point in using DI if it's the case.
edit: seems like there's still flickering with DI off. Just not as often.
edit2: okay, definitely a DI issue. Been testing with every combination of settings. As soon as I turn on DI the flickering starts.
theagent is offline
post #3772 of 5872 Old 06-18-2019, 10:07 PM
jfjer's Avatar
Quoted: 37 Post(s)
Liked: 25
To you guys who came from a 1080p dlp and upgraded to the BenQ W2700 / HT3550
1080p blu-rays how do they look upscaled compared to native 1080p ?
1080p upscaling is very important to me because i have a lot of 1080p blu-rays and im not seeing my self buying a lot of UHD blu rays(only the ones i watch over and over is going to be bought on UHD)
What im sure of is that i wont be able to see any screen door from where im sitting
what i fear though is that the picture with 1080p blu-ray upscaling could produce a softer image than my Benq w1070 delivers
Please tell me im wrong
Also do you notice better blacks compared to the older generations of DLP`s
Thanks for answers in advance
JVC DLA X500 - Benq W1070
jfjer is offline
post #3773 of 5872 Old 06-18-2019, 10:11 PM
subacabra's Avatar
Quoted: 1834 Post(s)
Liked: 5255
I watched a few regular blu rays on mine and they all looked great. Oblivion looked especially crisp and good. Think I have the pixel enhancer 4k on 8 for watching 1080p content.
Definitely better than on my ht2050.
sage11x and jfjer like this.
subacabra is online now
post #3774 of 5872 Old 06-18-2019, 10:27 PM
Quoted: 53 Post(s)
Liked: 24
is BenQ still issuing hardware revisions on this model? Just wondering when this will be safe to buy after they've worked all the bugs out.
wk11793 is offline
post #3775 of 5872 Old 06-18-2019, 10:30 PM
jfjer's Avatar
Quoted: 37 Post(s)
Liked: 25
Thank you for the quick answer, helps a lot with deciding what to go for
BenQ W2700 / HT3550 should be a perfect swap as it has just about the same throw distance as my Benq W1070
I was looking at the Sony HW45es and the HT5550 but they cant fill my 135 screen in my room because they need a longer throw distance than which i dont have
The Benq w1070 still looks stunning now and then believe it or not but after i recently got glasses i can now see some minor screen door
which is hard to unsee it once you see it
i have a 135" screen and im sitting 11-12 feet away
Did you notice any improvements in contrast and the blacks department coming from the ht2050
jfjer is offline
post #3776 of 5872 Old 06-18-2019, 11:33 PM
subacabra's Avatar
Liked: 5255
No problem!
There is definitely an improvement in blacks/contrast compared to the ht2050 but it's not mind blowing.
The biggest improvement to my eyes would be the hdr and the tone mapping, along with the clarity/resolution.
Watching hdr YouTube videos etc it really feels like you're watching a giant hdr capable tv.
My screen is only 106" but my room is(if need be) probably 95% light controlled even during the day.
jfjer likes this.
post #3777 of 5872 Old 06-19-2019, 04:43 AM
Quoted: 20 Post(s)
Still like 3d in a PJ but I use 3D MVC, most of my 3D MVC files work OK with my Himedia Q10 Pro from NAS, switched automatically most of times, sorry, can't tell about SBS nor Plex as I don't use them
pviader is offline
post #3778 of 5872 Old 06-19-2019, 06:44 AM
Liked: 8
After having done more testing with cables, etc. I think I'm going to have to send it back for a replacement. Hopefully the replacement will be better. My current one is experiencing more faults as the days go by. Last night I noticed that the screen would go blank and I couldn't hear any audio either. This lasted for about 6-8 seconds, and happened 3 times within 26 minutes. Rewinding the film and playing the missed part again was fine, but this is not great, and it hasn't done this before. Has anyone else had the same thing start to happen? I've been using this 10m HDMI cable https://www.amazon.co.uk/gp/product/...?ie=UTF8&psc=1 and I'm not sure if it's too long or not. When connected directly to my Sony X700, it plays films immediately, but when I try and go back to the main screen to see the apps (NF, YouTube, etc), it keeps saying no signal. When I connect it through my Onkyo 636 it works fine. My Onkyo doesn't support HDR, so I would prefer to connect the X700 directly to the W2700, and have the audio go through the receiver, as the picture is much better when connecting it directly to the X700.
Can anyone recommend a decent HDMI cable that is around 8-9m? I really don't need the 10m as I have roughly 1.5m looped up behind the receiver. It's just disappointing to have these faults, as the picture quality can be fantastic.
Cheers,
Barry
post #3779 of 5872 Old 06-19-2019, 07:00 AM
curtlots's Avatar
Quoted: 189 Post(s)
Liked: 215
Cheers,
Barry
Barry, I was having HDMI issues, particularly with my Sony UBP-X800 blu-ray player. Dish network and other sources came through ok though. For reference, I was using this 35' cable with claimed to support 4k at 60hz etc... but clearly was at its limit. https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
I finally bit the bullet and replaced it with a fiber optic HDMI cable. I wish I had done this sooner, all my sources come through crystal clear now, with no flickering. This is the cable I purchased: https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1 It's 50' long which is longer than I needed, but works flawlessly. They have shorter versions, but for whatever reason, the 50' is less money than some of their shorter versions.
Good luck.
curtlots is offline
post #3780 of 5872 Old 06-19-2019, 07:54 AM
Liked: 2
I cannot understand how this iris works. When I watch Alien or BR2049 (4K), I find that the iris works a lot, but with 2001 Space Odyssey, it does virtually nothing even set to High setting. What explains that?
Scizorhands is offline
