BenQ W2700 / HT3550 Announcement and Owner’s Thread - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 2920Likes
post #361 of 5240 Old 01-11-2019, 06:02 AM
Frank714's Avatar
Quoted: 969 Post(s)
Liked: 429
I remain somewhat confused. To the right is the BenQ 2700 and to the left the BenQ W5700 which apparently doesn't have a devoted thread of its own, yet.
AFAIK the knobs on the top of the W5700 are for vertical and horizontal lens shift.
"It is only about things that do not interest one that one can give a really unbiased opinion, which is no doubt the reason why an unbiased opinion is always absolutely valueless." Oscar Wilde
Frank714 is offline
post #362 of 5240 Old 01-11-2019, 07:56 AM
sage11x's Avatar
Quoted: 2860 Post(s)
Liked: 2879
Originally Posted by longhornsk57 View Post
Well sadly I am returning my TK800.
I love everything about it except 3D. I watched a few movies and no matter what the picture is a tiny bit blurry and the color is off, like no contrast. That weird green tint is always there.
I hooked up my HD142X again to compare even using DLP Link and sure enough the color is better, contrast much better, and picture is more clear.
Sucks too because I love the 4K HDR presentation.
Anyone have any idea if these new BenQ units will rid the green tint and have a better 3D presentation? I think it's gotta be the DMD on the clarity.
Edit: @sage11x and @Dave in Green
You guys are research nuts. Looking at specs of TK800 it says it displays 3D at 720p. But the specs for the Optoma UHD51ALV which is the same thing rgbwrgbw xpr .47 DMD says it does 3D at 1080p
Is their a way to confirm this and if so is there a reason for it?
Will this PJ in the thread title have 1080p 3D without the weird green tint?
Not the right thread for this. I'd recommend posting this over in the TK800 thread. What I will say is I had a TK800 here for review and had no issues with green tint. I also had no issues with resolution-- the TK800 displayed Full HD 3D from my bluray player. The ONLY issue I had was with off brand glasses on HDMI input 1. The solution was to use the (rather pricey) BenQ OEM glasses or switch my input to HDMI 2. Again, you'll find a lot more information and help in the TK800 thread.
https://www.avsforum.com/forum/68-di...ew-thread.html
https://www.avsforum.com/forum/68-di...ounced-10.html
aerodynamics likes this.
What to do if you find yourself stuck with no hope of rescue:
Consider yourself lucky that life has been good to you so far. Alternatively, if life hasn't been good to you so far, which given your present circumstances seems to be more likely, consider yourself lucky that it won't be troubling you much longer...
-- Excerpt from the Hitchhiker's Guide to the Galaxy.
sage11x is offline
post #363 of 5240 Old 01-11-2019, 08:10 AM
sage11x's Avatar
Liked: 2879
The W5700 hasn’t been confirmed for stateside release yet. We also don’t know it’s price— it may end up in the >$3000 forum although I hope that’s not the case. Being that it uses the less expensive DLP47 my hope is it will come in close to the $2k mark. We need more mid range DLPs with better feature sets.
unretarded likes this.
sage11x is offline
post #364 of 5240 Old 01-11-2019, 08:24 AM
Quoted: 386 Post(s)
Liked: 166
Sage,
Thanks. The reason I also posted here was because I wanted to know if this PJ would have the same issue.
I'll try input 2 and see.
longhornsk57 is online now
post #365 of 5240 Old 01-11-2019, 08:26 AM
Dave in Green's Avatar
Quoted: 3879 Post(s)
Liked: 3062
@longhornsk57 , since I have no personal interest in 3D I've done little reading about it so I hope that others who know a lot more about 3D than I do can help you. One thing I will say is that it's fairly consistent in almost every projector review that when tested in brightest mode they show a green tint. That's because when trying to achieve maximum lumens color balance is thrown out the window in search of every last available lumen and green is usually the predominant color.
Since 3D is so much dimmer than 2D, projectors need to be in one of their brightest modes to produce a 3D image that isn't too dark. In some projectors this could result in a green tint to the 3D image. Many reviewers have commented that it's possible to remove most of the green tint in brightest mode by simply going in to the menu and individually adjusting down green brightness. You will lose some total lumens by reducing green lumens but you can get a more balanced color image. If I were you I would at least experiment with this before returning your TK800. Just reduce green brightness until the image looks balanced to your eyes and then see if it's still bright enough in 3D to suit your needs.
Dave in Green is offline
post #366 of 5240 Old 01-11-2019, 08:29 AM - Thread Starter
scottyroo's Avatar
Quoted: 616 Post(s)
Liked: 822
BenQ 2700 Announced
My TK800 unit didn’t have the issues with clarity or tint you are explaining. My unit also did 3D in full HD, not 720p. I’m happy to DM you a quick video of how my TK800 screen looks with 3D engaged.
The only complaint I had with the TK800 and HT2550 in regards to 3D is the manual nature of engaging 3D and the amount of time it took the 3D content recognition to handshake and engage.
My BenQ contact is a senior product manager and has had some good hands-on time with the projector. He shared some very encouraging updates on 3D improvements with the HT3550/W2700. 3D engagement and type will be automatically detected and engaged. It does this much quicker than current gen. Also more types are supported for those with their own digital 3D collection. It will lock to 3D type “Auto” on a 3D Blu Ray. On all other 3D content, user can change to Frame packing, Side by side, and Top-bottom.
He also shared that black level performance is much improved from the HT2550. A few side by side photos he sent of out of box comparisons I saw are encouraging. I have asked for some more side by side sample unit shots to share. Maybe Monday.
"The Bunker" | Dedicated Theater Build Under Suspended Slab Garage
Testing: BenQ HT5550 | Epson 5050UB | 160" Dragonfly™ Fixed AT Screen
Denon X6300H | 9.4.4 (7.2.4 Discrete) | 9x Episode 900 Series LCR/Surrounds | 4x Episode 1700 Series ATMOS Heights | 4x Episode 12" Evo Subs
Sony X700 | Xbox One X | NVIDIA Shield TV
scottyroo is offline
post #367 of 5240 Old 01-11-2019, 09:34 AM
Quoted: 386 Post(s)
Liked: 166
Please do DM me. Literally all I want is as good 3D as a standard 1080p 3D DLP does...
because I am still looking at getting THIS projector or the white slice variant and it still uses the same basic technology.
post #368 of 5240 Old 01-11-2019, 09:39 AM
bix26's Avatar
Quoted: 760 Post(s)
Liked: 405
I would consider waiting for the TK800M. With the revised chip it will likely be much better in terms of contrast and 3D detection. I doubt that it will cost anymore than the TK800 currently costs.
bix26 is offline
post #369 of 5240 Old 01-11-2019, 10:03 AM - Thread Starter
scottyroo's Avatar
Quoted: 616 Post(s)
Liked: 822
You are looking at Q2 for the TK800M. It will be interesting to see how much the DMD change alone (and a better lens) will affect contrast in the exact same chassis as the TK800.
While the DMD is changing, I don’t anticipate the processing chip structure changing in the TK800M. Meaning, the 3D detection will most likely be unchanged. That is my speculation alone though.
post #370 of 5240 Old 01-11-2019, 10:18 AM - Thread Starter
scottyroo's Avatar
Quoted: 616 Post(s)
Liked: 822
Its really hard to reproduce a 3D experience with a 2D camera on an iPhone - Hope this helps?
https://www.dropbox.com/s/2mxj814xzn...29.30.mov?dl=0
post #371 of 5240 Old 01-11-2019, 10:21 AM
Frank714's Avatar
Quoted: 969 Post(s)
Liked: 429
Here is a first hint from the Middle East: https://gear-up.me/dlp-proj-benq-w57...-uhd-hdmi.html
Supposedly somewhere around 3,000 €.
sage11x likes this.
Frank714 is offline
post #372 of 5240 Old 01-11-2019, 11:48 AM
Quoted: 90 Post(s)
Liked: 43
AFAIK the knobs on the top of the W5700 are for vertical and horizontal lens shift.[/QUOTE]
The same knobs as my BenQ HT4050. Not impressed how these knobs works, in the beginning I thought they were not working. But of course, the HT4050 only has 5% lens shift horizontal and 12% vertical.
Nordvarg is offline
post #373 of 5240 Old 01-11-2019, 12:00 PM
sage11x's Avatar
Liked: 2879
Yes so I have an update on this.
The W5700 will be called the HT5550 here in the US. As I suspected, this model will only be available through BenQ's dealer network.
sage11x is offline
post #374 of 5240 Old 01-11-2019, 12:08 PM
Quoted: 386 Post(s)
Liked: 166
That does somewhat. It still looks green as hell before the glasses which do admittedly mute it whereas the 1080p units don't have that.
I'll play with input 2 tonight and see if that makes any difference. The TK800M is an interesting unit and I may just wait till it comes out and hopefully fixed some of these issues.
post #375 of 5240 Old 01-11-2019, 12:30 PM
Pulse-Code Modulator's Avatar
Quoted: 14 Post(s)
Liked: 4
How does this BenQ dealer network work? Is there costs beyond the price of the PJ?
Pulse-Code Modulator is offline
post #376 of 5240 Old 01-11-2019, 12:50 PM
sage11x's Avatar
Liked: 2879
Dealer/installer network. Similar to the HT6050 and HT8050/9050. Similar to how Epson will sell you a 4050 through their dealer network but will sell you a 4010 direct to you at Best Buy. I doubt you’ll ever see this HT5550 sold on amazon, for example.
I recommend we keep the discussion here on this thread to the Ht3550/W2700 and, if someone wants, they can start a separate HT5550 thread. Just to keep the confusion to a minimum.
scottyroo likes this.
sage11x is offline
post #377 of 5240 Old 01-11-2019, 04:22 PM
Budget Pete's Avatar
https://www.justprojectors.com.au/benqw2700.htm
This same spec sheet is on a lot of Australian sites, no pricing yet.
How does this compare to Epson top e-shift machines, like the 9300?
Budget Pete is offline
post #378 of 5240 Old 01-11-2019, 11:08 PM
dreamer's Avatar
Quoted: 1495 Post(s)
Liked: 601
tHE ePSON IS ONLY HALF OF FULL 4K RESOLUTION.
sage11x likes this.
Kirk Ellis
BenQ TK800 VuTec 122" Screen, Harmon Kardon AVR 247
Psycoustic Mark III L&R Towers, Boston Center, Energy Take 5 Surrounds
dreamer is offline
post #379 of 5240 Old 01-11-2019, 11:28 PM
MJ DOOM's Avatar
Quoted: 235 Post(s)
Liked: 82
https://www.tvspecialists.com/jvc-lx...-optoma-uhd65/
I unfold the scroll, plant seeds to stampede the globe
When I'm deceased, by then the beast arise like yeast
to conquer peace leaving savages to roam in the streets.
MJ DOOM is online now
post #380 of 5240 Old 01-12-2019, 06:08 PM
thadius65's Avatar
Quoted: 55 Post(s)
Liked: 24
I am anxiously awaiting the HT3550. I currently have a W1070 that continues to serve me well. I reached out to BenQ North America this week to ask a few questions. One is to verify that the throw on the HT3550 was identical to the W1070 and they indicated "they are pretty much the same". I then asked if announcement was to be at CES and I did not get an answer. What I was told was "The HT3550 is not confirmed yet, but is scheduled for February or March". I asked for pricing and availability and that is all I could get. I guess I will hang around and wait like everyone else.
In the meantime, I am setting up a Dolby Atmos 5.2.4 with my new Marantz SR7012 and Paradigm speakers/subs. This will all be ready when the HT3550 is available to come home and join the show!
thadius65 is offline
post #381 of 5240 Old 01-12-2019, 06:24 PM - Thread Starter
scottyroo's Avatar
Quoted: 616 Post(s)
Liked: 822
Can confirm same throw, lens shift, and offset as W1070. Should be straight up swap. W1070 owners are big target audience for this projector.
Price will be $1,500-$1,700(ish).
Feb/Mar timeline is accurate.
Can’t wait!
post #382 of 5240 Old 01-12-2019, 06:50 PM
Quoted: 12 Post(s)
Liked: 6
Can’t wait!
This is what I wanted to hear.
Sent from my SM-G960U using Tapatalk
Jordon777 is offline
post #383 of 5240 Old 01-13-2019, 12:03 AM
Quoted: 26 Post(s)
Liked: 66
In the words of Phillip J Fry - "Shut up and take my money!"
sage11x and scottyroo like this.
DLPdisciple is offline
post #384 of 5240 Old 01-13-2019, 11:21 AM
Quoted: 22 Post(s)
Liked: 6
Is it correct that the new W2700/HT3550 will have 200 lumens LESS light output than W1700; ANSI 2000 lumens vs 2200 lumens? Will the dynamic iris compensate for the lesser light output of the W2700?
For us W1700 owners who might consider an upgrade, it is positive that the light border has been removed, and that they’ve made the W2700 USB-upgradable. In addition it would have been very tempting if the new unit gets much less switching time (HD>4K->HD and startup time) than the W1700, but we’ll probably have to wait until we have some reviews before we can be certain of that.
ET34 is offline
post #385 of 5240 Old 01-13-2019, 11:29 AM - Thread Starter
scottyroo's Avatar
Quoted: 616 Post(s)
Liked: 822
BenQ 2700 Announced
You’re on the right track.
Less lumens is due to new optical engine and filter with priority on color accuracy.
Not sure how dynamic iris could compensate for less light output at the high end since its purpose is to improve black levels in dark scenes.
While max green output may decrease, reality will be that the brightness difference on calibrated/best bright modes will be imperceptible compared to HT2550.
Light border will be gone, or rather the pond of mirrors decreased to the normal POM of every other DLP pre-xpr.
USB upgradable confirmed.
Switching time should be decreased with integrated SOC instead of 3 processor chips.
Also the dark plastic piece in front of the lens array is to solve for a gripe I’ve had on these projectors since my W1070. The ceiling halo. A very welcome solution!!
owizard and sage11x like this.
post #386 of 5240 Old 01-13-2019, 11:37 AM
subacabra's Avatar
Quoted: 1763 Post(s)
Liked: 5031
C'mon c'mon c'mon!! Release this pj already!!!
subacabra is online now
post #387 of 5240 Old 01-13-2019, 01:51 PM
bix26's Avatar
Quoted: 760 Post(s)
Liked: 405
The ceiling halo is a little annoying, I just hope that the lens cover reflections don’t pollute the light path too much.
bix26 is offline
post #388 of 5240 Old 01-14-2019, 03:53 AM
decay71's Avatar
Quoted: 27 Post(s)
Liked: 30
decay71 is offline
post #389 of 5240 Old 01-14-2019, 11:31 AM
Liked: 3
i hope the buy button is this week cuz lord watching anything on a 27" monitor ALSO TN monitor.....
come on benq give us that buy button .
PQWil is offline
post #390 of 5240 Old 01-14-2019, 02:44 PM
Liked: 2
I wonder if I should hold off until this has a pricetag and purchase button. 🤔🤔
sage11x and unretarded like this.
Joe IsCrazy is offline
