BenQ W2700 / HT3550 Announcement and Owner’s Thread - Page 140 - AVS Forum | Home Theater Discussions And Reviews
 2531Likes
post #4171 of 4441 Old 07-18-2019, 01:58 AM
Quoted: 128 Post(s)
This is weird my 50 foot HDMI cable I bought from monoprice won't work on my pc to my projector anymore.
It use to fine.
Doesn't make sense.
It worked fine with a roku when I tested it.
The other spare HDMI cable worked fine as well from my computer to my projector too.
I am lost for words.
It is a fiber cable.
ng4ever is offline
post #4172 of 4441 Old 07-18-2019, 06:02 AM
sage11x's Avatar
Quoted: 2693 Post(s)
Liked: 2660
Originally Posted by HuxFlux View Post
Havnt notised any flickering from the iris but in some movies on Netflix ive got a weird pulsating in the darker shadows?
It may have something to do with the format of the movie?
Ive testet many projectors with the movie ”bright” in 4K from Netflix and this pj handles the dark scenes very good!
But, notised i got the pulsating in the dark shadows using my Apple TV 4K! But watching the same movie, using my Windows 10 computer there is no pulsating in the darker shadows?
Tried normal/eco with iris off, low, middle and high!
Even in smarteco i get the same anoying pulsating in the dark scenes and this have been going on in all of my three w2700 that ive had!
Best regards mr HuxFlux
Sounds like it could be an incompatibility somewhere between your W10 PC and the Apple TV. Do you use the same exact settings for both? Does changing the iris setting or even turning it off effect anything?
What to do if you find yourself stuck with no hope of rescue:
Consider yourself lucky that life has been good to you so far. Alternatively, if life hasn't been good to you so far, which given your present circumstances seems to be more likely, consider yourself lucky that it won't be troubling you much longer...
-- Excerpt from the Hitchhiker's Guide to the Galaxy.
sage11x is online now
post #4173 of 4441 Old 07-18-2019, 07:36 AM
sage11x's Avatar
Liked: 2660
Originally Posted by dahly3889 View Post
Forgive my ignorance or if it's been explained earlier in the thread, but what's the deal with the rev numbers? I see people comparing 01-101 vs 02-101 and I'm sitting here with a 00-100. What's the difference?
I asked for clarification on this and the answer is, essentially, the rev number doesn’t matter. It’s an internal number BenQ uses to determine which batch the unit is from. Why are there different batches? Changes in manufacturing process or sometimes even part suppliers. But the bottom line is an 02 rev is not going to perform any better than an 00 or an 01. We can show that because there are owners here that have had the projector since jump without issue (myself included).
To be clear: I think the discussion is well intentioned. There are owners here who have had issues and it’s only natural to try and make sense of that or draw some correlation by saying: “I had this issue and it’s attributable to this...” The nature of forum discussion encourages this, in fact. But, in this instance at least, I think assigning any issues to the rev number is a bit like reading tea leaves. If you’re experiencing an issue with your projector you should contact BenQ. If you’re not experiencing an issue: then enjoy your projector and don’t worry about the rev number.
pviader likes this.
post #4174 of 4441 Old 07-18-2019, 07:44 AM
neotide's Avatar
Quoted: 22 Post(s)
It use to fine.
Doesn't make sense.
I have had two Monoprice fiber cables that were 30ft long and both exhibit drop issues. Monoprice wasn't helpful so I ditched them and put in a RUIPRO off Amazon. Several months have gone by now with no issues at all. Sorry for your trouble but hope you get it sorted.
sparky7 likes this.
AVR - Denon AVR-X4300H & NAD C 375BEE
Fronts - Magnepan MG12/QR / Center - Magnepan MGCC2
Satellites - 6 Monoprice Black Back 6.5 /Sub - SVS PB-1000
PRJ - BenQ HT3550 / SCN - SilverTicket STR-16992
Sources - Switch/PS4/Sony UBP-X800/Thorens TD166 MKII/Austin Audioworks Black Swan
neotide is offline
post #4175 of 4441 Old 07-18-2019, 10:13 AM
Quoted: 55 Post(s)
Liked: 25
I initially was going to just get 18Gbps rated copper cables for my 30 foot runs but after I did some research on this forum and elsewhere; the conclusion is that copper runs past 25' will start to exhibit quality and source drop issues when pushing through 4k60FPS HDR content. Anything 30' and over is probably guaranteed to result in issues.
neotide likes this.
xealo is offline
post #4176 of 4441 Old 07-18-2019, 10:16 AM
neotide's Avatar
Quoted: 22 Post(s)
That is the same reason I went with fiber as well. Just seems the Monoprice ones I tried were crap and would drop my signal regularly.
neotide is offline
post #4177 of 4441 Old 07-18-2019, 10:20 AM
subacabra's Avatar
Quoted: 1639 Post(s)
Liked: 4766
Originally Posted by Jeffrey Chiafu Hsieh View Post
Can you share which movies you prefer DI on high, middle and low? I have DI on low which I think it’s the best when watching Get Out. Same for La La Land. But for The Dark Knight Rises, I set it on high. Just curious if you see it differently?
Hey Jeffrey!
Since I've been using those hdr settings from Secrets of Home Theater and High Fidelity I've watched a handful of movies, as well as the compete season 3 of Stranger Things.
The only movie I noticed the flickering a decent amount was the uhd disc of It.
I also watched BR2049, Justice League, Deadpool, 13 Hours, Black Hawk Down, Dunkirk and maybe a couple others.
The flickering was very minimal, and not enough to distract me from the movies.
Stranger Things looked really nice too.
subacabra is online now
post #4178 of 4441 Old 07-18-2019, 10:36 AM
Quoted: 55 Post(s)
Liked: 25
Originally Posted by subacabra View Post
Hey Jeffrey!
I actually switched back to high DI and neither my wife nor I have been noticing any flickering. Kind of awesome lol.
xealo is offline
post #4179 of 4441 Old 07-18-2019, 10:45 AM
sage11x's Avatar
Liked: 2660
I ordered a ‘premium’ audio cable from monoprice once. The cheap rca connector just flaked to pieces when I tried to expand the connector a bit (they were ridiculously tight). I decided to hack off the connector and put on my own and when I cut the cable I found two of the most pathetic wires ran inside the thickest rubber casing I’d ever seen. The cable was literally 90% rubber.
I’ve stayed away from them ever since.
neotide likes this.
post #4180 of 4441 Old 07-18-2019, 12:48 PM
Settings in Apple tv is and what ive tried:
HDR 4K, 4.2.2 and 4.2.0
SDR 4K, RGB and ycbcr
And this have been on all of my w2700!
Asked a friend that got the w2700 and also he has the pulsating in the darker scenes especially in that movie?
Other than that this pj handles this movie much better than the uhd51 and makes it a joy to watch
Must be something to do with the tonemapping?
Best regards Mr HuxFlux
HuxFlux is offline
post #4181 of 4441 Old 07-18-2019, 01:01 PM
sage11x's Avatar
Liked: 2660
This “pulsing” sounds a bit like iris pumping. Does disabling or reducing the strength of the iris make any change in the effect?
post #4182 of 4441 Old 07-18-2019, 01:33 PM
vidwiz's Avatar
Is anyone familiar with the quality of 3d achieved by lg oled passive system? It is much better than any active system I ever saw. Care to comment on the 3d quality of this unit as compared to lg passive???
vidwiz is offline
post #4183 of 4441 Old 07-18-2019, 02:17 PM
I dont see any difference!
But i can hear a very low sound when the iris is on so i know its doing something
HuxFlux is offline
post #4184 of 4441 Old 07-18-2019, 02:49 PM
NxNW's Avatar
Quoted: 88 Post(s)
Liked: 91
anyone ever get an oppo-bdp-93 to make sound on an HT3550 over HDMI? video works fine including 3D.
i factory reset both, i've confirmed that both work with other devices, i've tried short copper cables cables active copper cables and active optical cables, i've reduced video resolution and color bit depth, LPCM vs bitstream, audio bit rate, anything i could find in any menu. i've tried all permutations of the two hdmi ports on the player vs two hdmi ports on display. looks like a straight bug.
yes i could probably bypass the HDMI connection and get it to work over mini stereo or optical SPDIF. but there's something annoying about this simple feature not working.
also in response to a couple issues that came up in recent posts, it's entirely plausible that optical HDMI cables can suddenly stop working, not least because they do contain active circuitry (and miniaturized circuitry at that) that can fail for various reasons.
and as for 3d, DLP link generally is excellent, possibly unmatched, when it comes to defeating crosstalk. if your LG has this completely solved then great! we can talk about how comfortable the glasses are vs horizontal resolution vs whatever. but in general it's just hard to beat DLP for 3D..
NxNW is offline
post #4185 of 4441 Old 07-19-2019, 09:46 AM
Quoted: 369 Post(s)
Liked: 176
I can attest to RUIPRO quality - zero issues (for a couple of years now) since I switched from cheaper fiber cable I used before ( I tried both Monoprice and another brand I don't remember). As they say - you get what you paid for...
LG OLED 55C6P | LG OLED 65B7A | Denon AVR X6200W | Denon AVR X4300H | Parasound 2125 and ATI 1506 Amps | Definitive Technology Speakers /w Earthquake SuperNova MKV-12 with 7.1.4 Atmos | LG UP970 and Oppo 203 UHD Players | Nvidia Shield | ATV4K | Roku Ultra | Amazon FireTV
TohaLA is offline
post #4186 of 4441 Old 07-19-2019, 12:08 PM
martlist's Avatar
I have exactly the same pulsing issue with my AppleTV and it is unaffected by the iris setting. From searching the web it seemed to be an AppleTV problem so I did some tests on both the AppleTV and Roku using Shazam! which heavily exhibits the problem for me in the dark scenes:
Pulsing:
  • AppleTV 4K played via TV app
No-pulsing:
  • AppleTV 4K played via Vudu app
  • Roku Ultra played via Vudu app
I think issue may be the HDR settings on the AppleTV. Will play with hose and retest.
martlist is offline
post #4187 of 4441 Old 07-19-2019, 12:39 PM
Samfield's Avatar
Quoted: 51 Post(s)
Liked: 83
Yeah, when I switched out my Monoprice "certified" 4K 25' copper cable for a RUIPRO fiber my problems disappeared. For whatever reason the Monoprice failed to transmit HDR after a couple months, although it worked fine when originally installed.
Samfield is offline
post #4188 of 4441 Old 07-19-2019, 02:57 PM
neotide's Avatar
Quoted: 22 Post(s)
Their "quality" is not controlled at the very least.
neotide is offline
post #4189 of 4441 Old 07-19-2019, 06:18 PM
Quoted: 42 Post(s)
Liked: 8
So I just got my unit from Amazon - Rev 01-101 May 2019. Unfortunately seems to be plagued with the half screen issue intermittently. This is on the latest firmware (1.0.2).
Also tried my go to HDR "stress test" - the graveyard scene in Harry Potter and the Goblet of Fire when ghosts emerge from the wands. The brights are mastered at a very high nit level - 3000 nits or so. The BenQ tone mapping struggled. The brights were so blown out the colors seemed inverted. The only way to get a visible image was to reduce contrast/brightness down to near 0. Here is a comparison on the BenQ vs my TCL 4K TV. This is with the same UHD player and cable. HDR brightness was set to 0 but reducing/raising did not help much.
Projector just also has this cheap feel to it. Not feeling too optimistic at this point.
ID:	2592668   Click image for larger version
wk11793 is offline
post #4190 of 4441 Old 07-20-2019, 07:46 AM
sage11x's Avatar
Liked: 2660
The HDR Pro Tone mapping is great but it’s not perfect. There’s no way that one tone map will work for every single movie especially considering there is no reference point or standard for HDR10 mastering. I’m surprised the HDR brightness adjustment didn’t change anything— that’s what I use.
Here’s the thing: projectors can’t really do HDR. HDR is a flat screen thing not a projector thing. For the most part I’ve had a fantastic experience with the HT3550 leaving HDR at 0 but I have run into some instances where a movie didn’t quite work there.
You’ll want to make sure that your player is not compressing the HDR dynamic range at all. In my case I use a Sony X800 which has an option to convert HDR to SDR— mostly those don’t work so shut it off (more on that below). The Sony also has a display type setting— leave it to TV and let the BenQ so the work.
There are options. You could purchase a Panasonic UB820 Blu-ray player. It’s popular among projector owners for having really good HDR/SDR conversion. I haven’t tried it myself but in tests I’ve seen it’s pretty much the only box with universal HDR to SDR that is worth a damn.
As for a “cheap feel”, well, not sure what to say. Compared to other projectors in it’s price range the HT3550 actually “feels” really nice to me. But I’m not sure what your point of reference is. Keep in mind the HT3550 is on the absolute bargain end of the 4K projector market. With the exception of a few less featured competitors and some discontinued models this is about the most affordable way to get into 4K today. In terms of BenQ’s lineup this is the second most affordable 4K model they sell. If you’re looking for more you may simply need to spend more.
post #4191 of 4441 Old 07-20-2019, 12:49 PM
Quoted: 42 Post(s)
Liked: 8
I was able to do more extensive testing today. The colors and sharpness are a marked improvement over the W1070. I also found motion handling pleasantly improved over the W1070 with no noticeable judder. Black levels and contrast are good for a DLP in this price range and also improved over the W1070 though not significantly.
Not a huge fan of the dynamic iris - I found even set to low there was visible pumping/flickering and a distracting clicking noise coming from the projector when engaged. This was less noticeable in action scenes but distracting in quieter dialogue-driven scenes. Not sure if I will use it but I am a little disappointed. Definitely needs more refinement.
WCG seems hit-or-miss. Some movies benefited from it while others seemed better with it off. I will have to play with the settings a bit to see if it can be improved. Seems to cast a blue tint over the image. I also felt like there was more fringing/CA with WCG engaged.
HDR tone mapping is generally very good for most films. The above example for GOF is more of an exception but even some HDR TVs have difficulty with that scene. I was able to switch to SDR and change settings on the blu-ray player to restore detail that was clipped while still keeping the 4K image. The half screen issue does keep popping up on occasion when I play with the settings so there are definitely still bugs that need to be worked out.
sage11x and DunMunro like this.
wk11793 is offline
post #4192 of 4441 Old 07-20-2019, 06:31 PM
determined's Avatar
Quoted: 34 Post(s)
Just confirming...the HT3550 will fit the universal mount that BenQ sells? BenQ CM00G3 Universal Ceiling Mount
determined is offline
post #4193 of 4441 Old 07-20-2019, 07:18 PM
sage11x's Avatar
Liked: 2660
Yes.
post #4194 of 4441 Old 07-20-2019, 07:49 PM
Quoted: 622 Post(s)
Liked: 326
Which UHD player are you using?
DunMunro is offline
post #4195 of 4441 Old 07-20-2019, 08:15 PM
Quoted: 42 Post(s)
Liked: 8
Panasonic UB200. It was the only cheap UHD player Panasonic ever produced for the U.S. (that I know of) and it's a few years old so no HDR optimizer like the newer UB820/UB900. I was hoping the US would get a UB420 but it doesn't seem like Panasonic is interested in producing an equivalent US model. The UB200 handles most of everything very well and does provide tone curve adjustments to reduce highlight clipping though it dulls the picture. I was able to get the scene to play properly by turning HDR off. My TCL TV though had no issues with the scene.
wk11793 is offline
post #4196 of 4441 Old 07-20-2019, 11:05 PM
Quoted: 128 Post(s)
Thanks everyone about the information on the wires! Just ordered a 12m RUIPRO fiber cable.
Hopefully not to long to interface with signal.
ng4ever is offline
post #4197 of 4441 Old 07-21-2019, 01:42 PM
munchcolo's Avatar
I'm unable to update firmware, keep getting message "There is no updated version in USB." I've tried everything, downloaded update from Benq, unzipped, copied to USB drive, go to menu, system setup advanced, firmware upgrade, but still get that message.
I tried different drives, formatted them to FAT32 (both quick format and full format). Nothing works, any ideas?
munchcolo is offline
post #4198 of 4441 Old 07-21-2019, 02:58 PM
munchcolo's Avatar
Never mind, finally got it updated after trying several times. I don't know what I did different, but it worked.
post #4199 of 4441 Old 07-21-2019, 05:15 PM
file8761's Avatar
Quoted: 34 Post(s)
Liked: 24
Let us know, I have the 10m version and solved all of my issues, especially with the stubborn Xbox One X!
file8761 is offline
post #4200 of 4441 Old 07-21-2019, 05:54 PM
Quoted: 128 Post(s)
Just got the 12m RUIPRO fiber cable still no signal makes no sense.
Not sure what to do next
ng4ever is offline
