BenQ W2700 / HT3550 Announcement and Owner’s Thread - Page 152 - AVS Forum | Home Theater Discussions And Reviews
 2960Likes
post #4531 of 5336 Old 09-03-2019, 05:45 PM
DaGamePimp's Avatar
Quoted: 664 Post(s)
Liked: 678
If I keep the HT3550 I am using 100 hours on the lamp before I calibrate and take measurements, I am on a 1.0 gain 133" 16:9 using WCG @ ~mid zoom/normal lamp (dark walls, acoustic ceiling and 100% light control). The image is perfectly acceptable on the new lamp in my set-up.
I posted this yesterday but figured I should wait until I had done some more comparison.
The HW45ES vs. the HT3550 (see image).
To be expected...
45ES is brighter while accurate, better contrast/black level, less noise
3550 has richer color using WCG
Not expected... coming soon.
- Jason
ng4ever and triathletewms like this.
HT = Epson 5050ub @133" / Marantz SR6013 7.3.4 Atmos / B&K 5000 II amp / Boston VR2/VR12/CR67 speakers / Rythmik 12" x2 / CV 15" / Panasonic UB820
Media Room = Sony 65x930e / Denon x3300 /Klipsch speakers /Velodyne subs /Sony x700 /PS4 Pro + PSVR/WiiU/PS3/360/Wii/ 2080 TI - 9900K PC / Multi-Arcade / Virtual Pinball TRE45ON
DaGamePimp is offline
post #4532 of 5336 Old 09-03-2019, 06:40 PM
gunbunnysoulja's Avatar
Quoted: 18 Post(s)
Can someone clarify the offset and if there is any flexibility? If the top of my (viewing) screen is at 77" height, and I have 83" ceiling height where the projector will be, where does the center lens need to be?
gunbunnysoulja is offline
post #4533 of 5336 Old 09-04-2019, 01:05 AM
Quoted: 660 Post(s)
Liked: 203
As per Benq's specification (Link):
Projection Offset 100%
By default, the center of the lens needs to be at the top of the visible edge of the screen.
Lens Shift Vertical up to +10% one direction only (no negative shift)
That is up to 110% offset, which is up to 10% of the screen height.
For an 100" screen height is 49", 10% is 4.9 inches. Above the top edge of the screen. This is where the center of the lens should be with maximum lens shift.
noob00224 is online now
post #4534 of 5336 Old 09-04-2019, 08:05 AM
Quoted: 29 Post(s)
Liked: 32
And if your ceiling is 83” then the projector will be lower than that once you mount it
Fastrabbit19 is online now
post #4535 of 5336 Old 09-04-2019, 09:50 AM
Quoted: 18 Post(s)
That is my primary concern because that certainly doesn't leave much room to mount the projector and have the center lens be above the top of the screen, including the projector itself. Especially with my ceiling below a sloped drop ceiling.
post #4536 of 5336 Old 09-04-2019, 11:28 AM
file8761's Avatar
Quoted: 43 Post(s)
Liked: 34
So I was just poking around the BenQ site and noticed an update in the Firmware section? I no longer see V1.0.2, and V1.0.1 shows yesterday's date? Anyone know what this is and if I should apply this update?
HT3550 Firmware & Change Notice
Language: File Size: 438.23 MB Version: V1.0.1
Operating System: Others Update: 2019/09/03
file8761 is offline
post #4537 of 5336 Old 09-04-2019, 12:01 PM
DaGamePimp's Avatar
Quoted: 664 Post(s)
Liked: 678
Question
I noticed that earlier today as well and it has me wondering if they made a version typo or perhaps discovered something wrong in v1.0.2 and reverted back to v1.0.1.
Maybe sage can seek clarification through his contact.
* If the change notice included in the file is accurate it is indeed v1.0.1, it's also a different size file than v1.0.2.
I would not use it until we have clarification from BenQ, if they are reverting then we should be told what the issue is with 1.0.2 (I would guess that most here are on 1.0.2).
- Jason
file8761 likes this.
post #4538 of 5336 Old 09-04-2019, 12:23 PM
Invisible Kid's Avatar
- Jason
The change notes are similar to those in v1.0.1, so it doesn't seem to be a typo, unless the txt is also a mistake and then the update is actually a newer one. I guess it's either a mistake or they have really removed v1.0.2 because of some reason ¯\_()_/¯
Edit: Sorry, I now see you have edited your comment to state also that, while I was answering.
DaGamePimp and file8761 like this.
Invisible Kid is offline
post #4539 of 5336 Old 09-04-2019, 12:27 PM
DaGamePimp's Avatar
Quoted: 664 Post(s)
Liked: 678
Indeed, we were posting this at the same time, the plot thickens!
- Jason
post #4540 of 5336 Old 09-04-2019, 12:35 PM
Quoted: 660 Post(s)
Liked: 203
The manual specifies the height of the projector is 127mm, with the lens at about two thirds from the bottom, where the mount would be.
Six inches minus the ~80mm/3 inches, only 3 to 2.5 inches of room would remain for the mount. Not sure if such thin mounts exist.
Also with the ceiling being sloped it's not clear if the mount could be angled.
In this situation the screen should be dropped to make room for the projector.
post #4541 of 5336 Old 09-04-2019, 01:11 PM
Quoted: 18 Post(s)
I'd have to DIY a custom mount for it to sit on probably. I found a low profile one that tilts but it'll be close in height.
I can't drop the screen as it's full height and is already on the floor.
post #4542 of 5336 Old 09-04-2019, 07:05 PM
Liked: 0
So they replied to my questions email, about the fans ramping up and down and the bottom right corner being curved and not square, with an RMA request. With all the other issues out there, not sure if I want to RMA it now to maybe get one with different issues.
MowgliCSM is offline
post #4543 of 5336 Old 09-04-2019, 07:30 PM
tibimakai's Avatar
Quoted: 197 Post(s)
Liked: 61
I'm in the same boat as you, 88" ceiling and I have only 6" from the ceiling to the white screen line.
At the moment I still have a 2050A, but looking seriously at this pj.
My setup is in the garage, so I can do whatever I want. I ended up using a pj lift(cheap on Ebay). The pj just pokes out from the ceiling, just a bit.
I also have a center speaker issue, I don't want it under the screen, since it is a garage. Not using for parking, but still, once in awhile I need to work on cars.
I have decided to build it into the ceiling/attic, in an angle. I have Klipsch RP-450C.
Initial plan it was to motorize it, and I actually made all the hardware, but I have decided against it, because of the limited "ceiling space".
It seems like, the 5550 would be a better choice.
Living Room: Samsung UN65JS8500,Onkyo TX-NR676,Klipsch R-28F,Klipsch RC-62II,Klipsch R-14S,Polk Audio 80 FX/RT(Atmos)
Bedroom: Samsung UN55MU6290,Onkyo TX-RZ610,Onkyo & Fluance speakers
Garage: Epson 5040UB,Elite Screens 125" motorized screen,2xKlipsch RP-160M,4xKlipsch RP-150M,Klipsch RP-450C ,2xKlipsch CDT-3800CII/2xCDT3650CII,Klipsch R115SW/R110SW
tibimakai is offline
post #4544 of 5336 Old 09-04-2019, 07:50 PM
Quoted: 51 Post(s)
They had me RMA my unit as well. Hoping they fix whatever it is and everything else is fine. Will update once I get it back.
wk11793 is offline
post #4545 of 5336 Old 09-04-2019, 11:32 PM
- Jason
Aaand v.1.0.2 is up again
DaGamePimp likes this.
post #4546 of 5336 Old 09-05-2019, 11:13 AM
DaGamePimp's Avatar
Quoted: 664 Post(s)
Liked: 678
Interesting.
Speculation on my part, but perhaps a 'fix' or a 'tweak' was being done on 1.0.2., IDK but it's very odd and would be interesting to find out what actually happened.
- Jason
ng4ever likes this.
post #4547 of 5336 Old 09-05-2019, 11:19 AM
Interesting.
- Jason
Not sure why that happened, but the new v1.0.2 file is identical to the previous one I had from the past (Same MD5 sum).
DaGamePimp, file8761 and ng4ever like this.
post #4548 of 5336 Old 09-06-2019, 07:25 AM
sage11x's Avatar
Quoted: 2893 Post(s)
Liked: 2909
No changes. 1.0.2 is safe to download and install. Just a temporary glitch as they were working on the site.
DaGamePimp, ng4ever and maglo125 like this.
What to do if you find yourself stuck with no hope of rescue:
Consider yourself lucky that life has been good to you so far. Alternatively, if life hasn't been good to you so far, which given your present circumstances seems to be more likely, consider yourself lucky that it won't be troubling you much longer...
-- Excerpt from the Hitchhiker's Guide to the Galaxy.
sage11x is online now
post #4549 of 5336 Old 09-06-2019, 02:06 PM
Quoted: 56 Post(s)
Originally Posted by TohaLA View Post
In the article he specifically states that chips on both end devices (on HDMI board where you plugin HDMI cable) may not equalize properly if cable length between them is longer or shorter than 6ft. Here is the paragraph:
"That means that cables both longer and shorter than 6 foot length will differ from the assumptions built into the electronics. This is EVEN MORE of a problem if the device at either end of the cable is an older HDMI device using older chips that use less sophisticated Equalization methods."
Update #2 : I gave it over a month to make sure that going to a little bit longer cable would fix my issue. Anyways, since switching to a 6 ft. copper cable between my source and receiver, I have had zero source drop issues so I think I can confidently say that your advice to get a longer cable worked. Thanks again.
xealo is offline
post #4550 of 5336 Old 09-07-2019, 09:26 AM
diablo900t's Avatar
Quoted: 46 Post(s)
Liked: 42
What's interesting is I have both of these same issues, but with the HT5550.
My dog knocked one of my speakers into my projector screen and I had a white image projected onto it while I was trying to repair and noticed the fan ramp up/hiccup and for a split second while it happened the image got very pixelated; I could see a very visible screen door effect. It seems like when the fan does that its toggling the XPR mode on/off and going from 1080p to 4k.
If you end up RMAing and get both issues fixed, let me know. The fan issue doesn't happen for me all the time and I can't see it from my seat position. I can also live with the slight curve for now.
Sent from my SM-N975U using Tapatalk
diablo900t is online now
post #4551 of 5336 Old 09-07-2019, 01:06 PM
Regarding the XPR problem, I've contacted BenQ Europe some weeks ago and this is what they said (Translated by me):
"When the processing needed to show a 4K signal takes place, our W2700 will, at the same time, detect the internal temperature to control the pixel shift; once the device reaches a certain level of temperature, the projector needs to re-calibrate to keep showing a 4K resolution. This "re-calibration" takes between 0.5 and 1 second, resulting in the observed phenomenon. During this time the resolution will be 1080p temporarily until the re-calibration process has ended, that it's when the resolution will be 4K again."
I have also observed the fans ramping up and down sometimes when it happens, although not always. So it might make sense...I hope they keep polishing some of those things in following updates though.
magnification and diablo900t like this.
post #4552 of 5336 Old 09-08-2019, 01:55 PM
magnification's Avatar
Quoted: 81 Post(s)
Liked: 83
If I'm reading that answer right, a pixel shifting system gets hotter than normal dlp ones. If that's the case, maybe this pixel shifting technology needs a better cooling system?
magnification is online now
post #4553 of 5336 Old 09-08-2019, 03:58 PM
If what they say is really the reason... Then I don't think the problem is it getting hot, but just that they need to account for the temperature oscilation to keep it calibrated. Makes sense?
post #4554 of 5336 Old 09-09-2019, 12:17 AM
Quoted: 13 Post(s)
Liked: 2
For owners and people that keep up with the ht3550 - did BenQ provide a firmware to enable 2.35 anamorphic aspect ratio for people with anamorphic lenses? It seems the bigger brother HT5550 got a firmware pushed to enable it, just wondering if the 3550 is being blessed as well? Thanks!
Quirky is offline
post #4555 of 5336 Old 09-09-2019, 06:10 AM
sage11x's Avatar
Liked: 2909
No and as far as I know there are no plans to bring that to the HT3550.
post #4556 of 5336 Old 09-09-2019, 09:34 AM
Quoted: 13 Post(s)
Liked: 2
Really unfortunate to hear (and kind of stupid on BENQ's part, I guess they hate money). Thank you for your quick reply.
Quirky is offline
post #4557 of 5336 Old 09-09-2019, 10:20 AM
sage11x's Avatar
Liked: 2909
I think they just don’t expect too many buyers in this price range to want that sort of functionality enough to spend the time and money to engineer it into the product. I mean, an A lens can easily cost more than the Ht3550 itself.
BenQ has quite a few models (HT9060, HT9050, LK990, LK970, HT8060, HT8050, W11000 and X12000) that have been engineered for use with the Panamorph Paladin lens. But those are all much higher market.
post #4558 of 5336 Old 09-09-2019, 10:55 AM
Quoted: 13 Post(s)
Liked: 2
Yeah, makes sense perhaps. But many sub $1000 1080p projectors had 2.35 standard for the longest time. It's just silly. I'm on the fence on buying a HT9050. I know lots of people hate on the blacks and lack of HDR (actually I dislike HDR so that part is moot for me). But the blacks are a bit concerning, but may very well give it a shot. Sorry, don't mean to hijack the thread. It's too bad about the HT3550, otherwise seems to have pretty glowing reviews from the community, but the lack of anamorphic lens 2.35 is a bigger concern to me than even very good blacks I guess. Cheers!
sage11x likes this.
Quirky is offline
post #4559 of 5336 Old 09-09-2019, 12:00 PM
Keith AP's Avatar
Quoted: 114 Post(s)
Liked: 87
I'm with you on the anamorphic modes for stretch and compression. My W1070 has it, but recent "budget" projectors are lacking in this regard. There were less expensive lenses before the latest Panamorph versions - that are still in the hands of enthusiasts - including myself. You could consider the HT5550, but note that the anamorphic modes on that projector do not presently work in 4K mode, only 1080P.
sage11x likes this.
Marantz AV7702mkII | Emotiva XPA-5 Gen3 | miniDSP 2x4HD for BEQ/BOSS filters
PSA MTM-210 (L/C/R) | Polk Monitor 35B (SR/SL)
Epson 5050UB - BenQ W1070 w/ Panamorph CineVista Lens | Oppo BDP-103
HSU VTF-3MK5 (dual subs)
Seymour Center Stage UF 2.35 AT Screen
Keith AP is offline
post #4560 of 5336 Old 09-09-2019, 02:02 PM
Quoted: 13 Post(s)
Liked: 2
Oh! That's very important clarification for the HT5550. If it's only on 1080p it's moot for my interest in that projector. Thank you for clarifying, I was under the impression the firmware worked across the spectrum. I guess I'll hop on the HT9050 and see if I can live with the mediocre black levels. And if not perhaps save more $$ for a Epson 6040 (or wait for a deeply discounted refurb). That's probably the cheapest thing I can think of that has good PQ, anamorphic stretch and 4K.
Quirky is offline
