BenQ W2700 / HT3550 Announcement and Owner’s Thread - Page 200 - AVS Forum | Home Theater Discussions And Reviews
 3258Likes
post #5971 of 6204 Old 03-11-2020, 04:20 AM
bori's Avatar
Quoted: 277 Post(s)
Liked: 145
Originally Posted by subacabra View Post
Quick search
Time for a newer model
Is the Onkyo TX-RZ820 a good replacement? As far as power?
bori is offline
post #5972 of 6204 Old 03-11-2020, 06:56 PM
subacabra's Avatar
Quoted: 1955 Post(s)
Liked: 5724
Should be fine but I have heard some of the newer models having issues with atmos and Xbox one, not sure if they fixed that.
bori likes this.
subacabra is offline
post #5973 of 6204 Old 03-11-2020, 11:18 PM
dcast01's Avatar
Quoted: 24 Post(s)
Originally Posted by xealo View Post
Ya mine was being persistent as well. I told him that this is my 4th Benq PJ. And knowing my luck, I would get a bad refurb. I begged for a 1 time courtesy of sending a new one.
Other than setting HDR to "Auto", no.
Oh crap, you returned 4 projectors!?
dcast01 is offline
post #5974 of 6204 Old 03-12-2020, 05:44 AM
Yellbean's Avatar
Quoted: 77 Post(s)
Liked: 121
Got my new baby home last night and (knock on wood) so far so good! At the moment throwing onto a 100" pulldown from 9.5 feet away.
Sent from my SM-N960U using Tapatalk
Living room: Sony 75x940D, Yamaha RX-A1080 receiver, Klipsch RP-8000F , Klipsch RP-504C, MA Radius 45s, Outlaw EX LFM 1-Plus, XBOX One S, PS 3, Roku Ultra
Cave: Panasonic 65ZT60, Denon x1300w receiver, Monitor Audio 5.1 RS6 / RS Center / RS 1 rears / MA AW100, PS4, PS2, & Roku Ultra
Last edited by Yellbean; 03-12-2020 at 05:49 AM. Reason: Sent duplicates of same pics
Yellbean is offline
post #5975 of 6204 Old 03-12-2020, 10:28 AM
xp0z3d's Avatar
Quoted: 79 Post(s)
Please recommend some good ceiling mount for HT 3550. I have a cheap one and its not letting me setup things perfectly with the screen. What is everyone using for mounting?
Yellbean likes this.
xp0z3d is offline
post #5976 of 6204 Old 03-12-2020, 11:08 AM
Quoted: 81 Post(s)
Liked: 34
No, I've owned 4 different BenQ models over the years, hence "loyal customer".
Anyways, I just got the new replacement today. Made on Sept 2019. So should be g2g I hope.
This is what I have. I recommended it to my cousin for his BenQ PJ and he loves it.
https://www.amazon.com/BenQ-CM00G3-U...4036526&sr=8-5
xealo is offline
post #5977 of 6204 Old 03-12-2020, 12:31 PM
dcast01's Avatar
Quoted: 24 Post(s)
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
This is a low profile mount if your ceiling is low...
dcast01 is offline
post #5978 of 6204 Old 03-12-2020, 01:51 PM
xp0z3d's Avatar
Quoted: 79 Post(s)
That looks good. Thank you!
The one I have is low profile and this time will try some with more space from ceiling.
xp0z3d is offline
post #5979 of 6204 Old 03-12-2020, 04:42 PM
Yellbean's Avatar
Quoted: 77 Post(s)
Liked: 121
I'm also looking for a ceiling mount but I need about as low profile as you can get.
Yellbean is offline
post #5980 of 6204 Old 03-12-2020, 04:45 PM
Yellbean's Avatar
Quoted: 77 Post(s)
Liked: 121
This is only my second day with this projector and love it BUT I'm a little confused about the HDR implementation. Some movies it looks good and other look way blowout (Gemini Man) for example. Any tips or tweaks on how to make HDR more watchable or should I just disable the HDR on the movies its looks bad on?
Yellbean is offline
post #5981 of 6204 Old 03-12-2020, 05:41 PM
Quoted: 81 Post(s)
Liked: 34
Originally Posted by JPHCCFC View Post
Just want to show you how effective my fan filter is. Hasn't affected noise or performance at all.. But definitely saved a lot of dust going through the unit.
Where did you buy that? I looked on Amazon and all pretty much look to be magnetic.
xealo is offline
post #5982 of 6204 Old 03-13-2020, 05:04 AM
JPHCCFC's Avatar
Quoted: 81 Post(s)
Liked: 27
It is magnetic but I use double sided tape to attach it. Bought from Amazon
xealo likes this.
JPHCCFC is offline
post #5983 of 6204 Old 03-13-2020, 12:27 PM
d3code's Avatar
Quoted: 131 Post(s)
Liked: 37
i just received my benq but i cant get it to project in border
i just received the benq ht3550 ( w2700)
picture quality is great however what is not so great, is that for the life of me i just cant get the projector project within the border. i already turned the whole wheel down to get it fit. but still it project around the border as you can see in the test screen picture. on the left size you can see the projected picture falls over the left border. what do i do wrong here?
also at startup the picture was actually upside down. so then by accident i chose Rear Ceiling instead of front ceiling. however i thought in the menu i could change this later on. and yes i could do it, but if i do, then the picture gets mirrored horizontal. also there is now way to do a hard reset to fix this. so now i am stuck forever as rear ceiling?
then i checked in the menu if i could change the size of the picture. but i can not. only keystone.
if check the table in the manual i have 120 inch diagonal screen. i checked how far the projector is and i sit around 157 inches 4000mm away from the screen.
i really dont understand it. because with the benq w1070 before i never had this problem. do i do something wrong?
d3code is offline
post #5984 of 6204 Old 03-13-2020, 01:59 PM
Quoted: 13 Post(s)
Liked: 6
Not sure if it will help but there is a physical vertical adjustment knob that if you adjust it back and forth it sometimes frees/allows the physical zoom knob to have more range. Again, not sure if it will work also but there are a few places on the menu that allows you to “reset to default/factory” and could get your image (back projection) back to normal.
ab373 is offline
post #5985 of 6204 Old 03-13-2020, 02:50 PM
dcast01's Avatar
Quoted: 24 Post(s)
Did you try updating the firmware to 1.05?...that might help.
dcast01 is offline
post #5986 of 6204 Old 03-13-2020, 03:08 PM
d3code's Avatar
Quoted: 131 Post(s)
Liked: 37
thanks will try it tommorow. so tired now. whole time trying everything. so annoying. specially since picture quality looks so nice! ah well have the whole weekend to figure this out. maybe i just add new holes in the ceiling and move it to make it fit.
d3code is offline
post #5987 of 6204 Old 03-13-2020, 03:09 PM
d3code's Avatar
Quoted: 131 Post(s)
Liked: 37
not yet would that actually help? i have no idea yet what firmware the projector is. will checkthis out tommorow. i did try to connect an usb stick to the projector. but it does not recognise it. maybe because its formatted as exfat32? will try fat32 tommorow. so tired now. brain needs sleeeeeeeep. but thanks for answering.
d3code is offline
post #5988 of 6204 Old 03-13-2020, 04:01 PM
dcast01's Avatar
Quoted: 24 Post(s)
You need to use a 3.0 usb thumb drive or else it won't work.
dcast01 is offline
post #5989 of 6204 Old 03-14-2020, 06:37 AM
d3code's Avatar
Quoted: 131 Post(s)
Liked: 37
i tried a usb 3.0 usbstick. i tried a 3.0 harddisk. does not work. both are exfat formatted though. is that a problem?
the benq manual does not do say anything about what formats it can read. ntfs, fat32, exfat, ext4 etc?
i also tried the usbstick in the mediaplayer port also did not work.
also the screen is still beyond the borders. played around with keystone does not work. also number on the screen are now being devided, same for the arrow. like its split in half.
factory reset did not work. sure i can change the language but it wont do the step before were you see the 4 pictures. for rear ceiling. front ceiling, table etc.
anybody any ideas, please let me know thanks. for sure will monday call benq to ask if they can help me as well. maybe i have a bad unit . i dont know.
d3code is offline
post #5990 of 6204 Old 03-14-2020, 08:45 AM
sage11x's Avatar
Quoted: 3055 Post(s)
Liked: 3170
Your projector is not square with your screen.
Bigger picture showing all 4 corners would help.
1. Disable the auto keystone to make sure you’re projecting a square image.
2. Make sure your projector is level. This is a bit tough with the Ht3550 as the case has a bit of a slant.
3. Determine if your projector is centered on your screen. The HT3550 has no horizontal adjustment so the lens needs to be dead center.
4. Lens shift and zoom. The Ht3550 has limited vertical lens shift but it should be enough to get a square image. Worst case you may need to adjust the height of your mount or re-enable keystone. If you do, however, DON’T use the auto keystone just adjust it yourself manually. IMO, Auto keystone is for quick and dirty setups not for permanent installation.
5. If all else fails check your screen/wall. My wall is not perfectly straight which caused my screen to be not perfectly perpendicular to the projector. I was able to adjust this at the screen by carefully adjusting the mounting screws but, honestly, this was more to satisfy my OCD than really improve the picture. The reason for buying a screen with a border is to projector just slightly into the border to hide a little bit of mounting sloppiness.
What to do if you find yourself stuck with no hope of rescue:
Consider yourself lucky that life has been good to you so far. Alternatively, if life hasn't been good to you so far, which given your present circumstances seems to be more likely, consider yourself lucky that it won't be troubling you much longer...
-- Excerpt from the Hitchhiker's Guide to the Galaxy.
sage11x is offline
post #5991 of 6204 Old 03-14-2020, 09:48 AM
Quoted: 81 Post(s)
Liked: 34
Cool thanks!
xealo is offline
post #5992 of 6204 Old 03-14-2020, 09:49 AM
Quoted: 81 Post(s)
Liked: 34
Reformat to fat32. And make sure you are using the USB 3.0 port.
xealo is offline
post #5993 of 6204 Old 03-14-2020, 10:05 AM
Quoted: 81 Post(s)
Liked: 34
Alright, so replacement unit appears to be off to a great start. First and foremost: the fan. So much quieter. No more of the intermittent whoo sound. Next, projector appears to be brighter and colors richer - most importantly even on eco lamp setting. The only thing I noticed that I hadn't seen in a while is the Iris pumping on medium or higher. I remember seeing it initially when I got the pj, but either my eyes got adjusted to it or the just quit being as drastic after the unit broke? Anyone else care to chime on why I'm seeing it all of a sudden again on this new unit?
xealo is offline
post #5994 of 6204 Old 03-14-2020, 12:51 PM
dcast01's Avatar
Quoted: 24 Post(s)
What do you mean by Iris pumping?
dcast01 is offline
post #5995 of 6204 Old 03-14-2020, 01:02 PM
Quoted: 81 Post(s)
Liked: 34
When the Auto Iris shifts, you can see an on-screen effect of the scene darkening or lightening akin to breathing(inhale and exhale is how I describe it) several times in rapid fashion. The more aggressive(high) the auto iris is, the more noticeable this effect tends to be in scenes that transition from light to dark or vice versa.
xealo is offline
post #5996 of 6204 Old 03-14-2020, 01:19 PM
JPHCCFC's Avatar
Quoted: 81 Post(s)
Liked: 27
What firmware was installed on it?
JPHCCFC is offline
post #5997 of 6204 Old 03-14-2020, 01:48 PM
diablo900t's Avatar
Quoted: 113 Post(s)
Liked: 72
While I don't own the 3550, I have the 5550 and there is variation by unit. My launch unit was replaced after a dead pixel and the Iris was hardly noticable in the brand new replacement.
Unfortunately, that unit also had a dead pixel far outside of the image area and appeared on my wall, so I rec'd another unit that had performance similar to my 1st.
Sent from my SM-N975U using Tapatalk
diablo900t is offline
post #5998 of 6204 Old 03-14-2020, 02:08 PM
dcast01's Avatar
Quoted: 24 Post(s)
I have my iris on high also and notice the effect to some extent that you talk about . Have you updated the firmware yet?
dcast01 is offline
post #5999 of 6204 Old 03-14-2020, 08:11 PM
Yellbean's Avatar
Quoted: 77 Post(s)
Liked: 121
I have only been using this projector for a few days. Is it just me but I think the the pic looks best with both BC and WCG turned off and the lamp in eco mode. I think I get the best blacks and most natural colors. In HDR I find putting it in wcg mode the colors are so dull to the point that I think it is malfunctioning. Is this normal or do I have an issue with my unit? Hopefully the attached pics show what I'm seeing. I am on the latest firmware.
Yellbean is offline
post #6000 of 6204 Old 03-14-2020, 08:17 PM
Yellbean's Avatar
Quoted: 77 Post(s)
Liked: 121
I do see the same thing. I didn't notice this before I updated the firmware.
Yellbean is offline
