BenQ W2700 / HT3550 Announcement and Owner’s Thread - Page 45 - AVS Forum | Home Theater Discussions And Reviews
 3123Likes
post #1321 of 5886 Old 02-27-2019, 07:45 AM
Quoted: 1128 Post(s)
Liked: 317
Originally Posted by sage11x View Post
I’m staring at the HT2050A and realizing they probably could have gotten even better contrast/black performance out of this model if they didn’t have so much damn light leaking out from around the lens. I never noticed it until now, after taking down the HT3550.
You can put a cable with the same thickness as the spacing between the lens case and the projector case. I can definitely see a halo in the upper middle of the screen when not using this mod.
Got the idea from here: https://www.soundandvision.com/conte...-review-page-2
Maybe I will put a plate as well to get rid of the ceiling halo as well.
@scottyroo
Could you try enabling SBS/TAB while at @120 hz?
scottyroo likes this.
noob00224 is online now
post #1322 of 5886 Old 02-27-2019, 07:50 AM
Liked: 1
Originally Posted by DLPdisciple View Post
Early March is quoted by a UK Dealer with the option to pre order but being sensible I expect slippage will move that to End March - that's when I expect to take delivery of mine (no date advised yet by my Dealer)
I emailed BenQ UK this morning and they advised a release date of early April. A bit disappointing as a UK dealer had told me 11th March.
mugatu9 is offline
post #1323 of 5886 Old 02-27-2019, 08:55 AM
tonybradley's Avatar
Quoted: 541 Post(s)
Liked: 228
A guy gets busy for almost a day and comes back and has a lot of catching up to do with the posts. All great info.
Question to anyone here who may know. I purchased a 25' AmazonBasics High-Speed HDMI Cable last year for my HT2050a. 4.5/5 stars with 18,590 reviews. However, the Description contradicts itself. In one place, it says "displays 4K Video at 24Hz, 1080p at 60Hz with 48-bit deep color and supports bandwidth of 10.2Gbps". In another section of the Description, it says it supports bandwidths up to 18Gbps.
If this cable truly only supports 10.2Gbps rather than 18Gbps, will I have issues running 4K with HDR to the HT3550? Also, Do you know via a display on the PJ when it senses 4K with HDR and turns on the HDR10 settings?
tonybradley is offline
post #1324 of 5886 Old 02-27-2019, 09:06 AM - Thread Starter
scottyroo's Avatar
Quoted: 617 Post(s)
Liked: 826
We have missed you!
You may have issues with that cable but it might be worth giving it a try.
HT3550 will automatically sense HDR content and put it into HDR 10 mode. In the top left corner it will say picture mode is HDR 10. You will definitely know when HDR content is detected
Sent from my iPhone using Tapatalk Pro
"The Bunker" | Dedicated Theater Build Under Suspended Slab Garage
Testing: BenQ HT5550 | Epson 5050UB | 160" Dragonfly™ Fixed AT Screen
Denon X6300H | 9.4.4 (7.2.4 Discrete) | 9x Episode 900 Series LCR/Surrounds | 4x Episode 1700 Series ATMOS Heights | 4x Episode 12" Evo Subs
Sony X700 | Xbox One X | NVIDIA Shield TV
scottyroo is offline
post #1325 of 5886 Old 02-27-2019, 09:08 AM - Thread Starter
scottyroo's Avatar
Quoted: 617 Post(s)
Liked: 826
@scottyroo
The projector overrides any refresh rate that you have set for yourself. It does the refresh rate for you at 120 Hz. Tested loads of SBS content but don’t have any top and bottom to test with.
noob00224 likes this.
post #1326 of 5886 Old 02-27-2019, 09:32 AM
Liked: 317
So if you set the projector at 120Hz, then select SBS or TAB from the projector menu (doesn't matter which), it stays at 120Hz?
https://www.youtube.com/results?sear...by+side+movies
https://www.youtube.com/results?sear...bottom&sp=mAEB
post #1327 of 5886 Old 02-27-2019, 09:35 AM - Thread Starter
scottyroo's Avatar
Quoted: 617 Post(s)
Liked: 826
No when the projector engages in 3D mode it will automatically set the refresh rate to 120hz as it needs to be at that refresh rate for the DLP Link 3D to work.
Start playing SBS 3D>Set projector 3D mode to SBS in settings>Profit
post #1328 of 5886 Old 02-27-2019, 09:39 AM
Liked: 317
What about frame packing and frame sequential?
post #1329 of 5886 Old 02-27-2019, 09:40 AM - Thread Starter
scottyroo's Avatar
Quoted: 617 Post(s)
Liked: 826
You can manually set the 3D mode to frame packing as well. When a 3D blu Ray is detected it automatically engages 3D. You do nothing.
sage11x likes this.
post #1330 of 5886 Old 02-27-2019, 09:40 AM
sage11x's Avatar
Quoted: 2979 Post(s)
Liked: 3086
I have that same cable. Thought it would work as it’s the size of a pipe. It didn’t.
The issue isn’t as much the quality of the cable but the length. Eventually I just rearranged my room to get the equipment closer to my projector. Honestly, having the equipment at the back of the room is one of my favorite things about having a projector: no clutter. I now run a 15’ Media Bridge with no issues.
I would try it first just to make sure. It may work or it may not— just be prepared to invest in a new cable. I’ve seen long runs of HDMI with the premium HDMI sticker attached (which is supposed to indicate bandwidth is sufficient for 4K/60) but you may also want to consider a fiber solution. I know they’re big bucks but I’ve seen a lot of positive comments about the quality.
What to do if you find yourself stuck with no hope of rescue:
Consider yourself lucky that life has been good to you so far. Alternatively, if life hasn't been good to you so far, which given your present circumstances seems to be more likely, consider yourself lucky that it won't be troubling you much longer...
-- Excerpt from the Hitchhiker's Guide to the Galaxy.
sage11x is offline
post #1331 of 5886 Old 02-27-2019, 09:44 AM - Thread Starter
scottyroo's Avatar
Quoted: 617 Post(s)
Liked: 826
I recommended this cable all the time. Cheap and is one of the most well constructed cables around. I use the 40’ length and get full 18gbps. The 40 footer is only $37
https://sewelldirect.com/premium-4k-hdmi-cable-40-ft-
post #1332 of 5886 Old 02-27-2019, 10:31 AM
Samfield's Avatar
Quoted: 55 Post(s)
Liked: 85
Nice quality cable at a good price and it's CL3 rated for safe, in-wall installation.
Samfield is online now
post #1333 of 5886 Old 02-27-2019, 10:37 AM
Greg Flowers's Avatar
Quoted: 12 Post(s)
For a 30 foot HDMI run, is it the consensus that a single cable is better or is two 15 foot cables with a repeater in the middle better? For that length should I be looking for an active or passive cable? Right now I'm looking at the 30 foot Monoprice certified premium cable. I know my current 30 foot Redmere cable won't cut it for 4K.
Greg Flowers is offline
post #1334 of 5886 Old 02-27-2019, 10:41 AM
Willy212's Avatar
Quoted: 35 Post(s)
Liked: 46
for preorder now on frys, annoying that now i can log on my reg account on avs with google log in .
for 1499
https://www.frys.com/search?search_t...toreName=false
Troy LaMont and Hannoo like this.
Willy212 is offline
post #1335 of 5886 Old 02-27-2019, 10:49 AM - Thread Starter
scottyroo's Avatar
Quoted: 617 Post(s)
Liked: 826
That cable I recommended does well at 40 feet. I have 12 months on mine and no issues with 4K hdr. If you are installing in wall it’s always a good idea to do conduit for future proofing fwiw
Greg Flowers likes this.
post #1336 of 5886 Old 02-27-2019, 11:04 AM
Karyudo's Avatar
Here is a schematic with precise measurements of mounting hole locations for the HT3550.
This is very useful, and mostly answers my question of several days ago. Do you happen to know where the lens centerline would lie on this diagram?
Nevermind! Now I see it in small print on the diagram!
Karyudo is offline
post #1337 of 5886 Old 02-27-2019, 11:05 AM
Dave in Green's Avatar
Quoted: 3965 Post(s)
Liked: 3134
I wouldn't put too much weight right now on things like exact input lag time of an engineering sample. That's one of many areas that could be improved in production samples with optimized firmware.
As far as the moving sales date it's important to realize that this can easily change with any imported product. For countries like the US that rely heavily on products imported from other countries delays can often be traced to backups at ports of entry. My wife operated a small retail business and spent many hours on the phone with unhappy customers complaining about back order delays. Most of the time the delays were due to backups at ports of entry where thousands of shipping containers were awaiting clearance from an inadequate number of customs inspectors.
Dave in Green is offline
post #1338 of 5886 Old 02-27-2019, 11:09 AM - Thread Starter
scottyroo's Avatar
Quoted: 617 Post(s)
Liked: 826
Yeah it’s in there. For reference though
Karyudo and noob00224 like this.
post #1339 of 5886 Old 02-27-2019, 11:11 AM
Liked: 317
You beat me to it.
Here is the entire manual. The depictions above are at page 40.
https://www.benq.com/en-us/support/d...50/manual.html
post #1340 of 5886 Old 02-27-2019, 12:12 PM
Quoted: 541 Post(s)
Liked: 228
I may be able to get by with a 20' cable. My equipment is in a recessed cabinet in the back of the room. Due to a beam and Trunk line in the back of the room, I had to do some crazy methods to install the drop ceiling. So moving a tile isn't an option unless I remove the ones from the back and work them all out like a puzzle Because of that, I can't do a straight shot from PJ to cabinet and down to the Denon Receiver. I'll have to play around with it to see the least amount of cable I can get away with. I could also place the Denon Receiver on the Top Shelf of the Cabinet to eliminate the Rise portion of the distance, but they are heavy and not sure how my 3/4" MDF shelf would like the heavy Denon. It's on the bottom shelf now that is supported by 2x4s.
That's a cheap price. $26 for a 25' cable. Just bookmarked that URL in case my current cable won't work. I don't mind spending $40 or so for a new cable that will work. I'd spend the $100+ for the Fiber cables if it's a must, but will try my current one then this Sewell first.
post #1341 of 5886 Old 02-27-2019, 12:32 PM
Liked: 9
For over a year now i've been the happy owner of a viewsonic px727-4k .
But I'm so glad that small 4k DLP's are improving so fast. Now I'm hopeful that my next upgrade ,2-3 years from now, will be a laser lit , 4k dlp, 2-3000 lumens output in dci-p3 mode,fast& smart dinamic iris combined maybe with laser dimming for great blacks and contrast,under 50ms lag and great lens ...all for under 1500$.
Andjar is offline
post #1342 of 5886 Old 02-27-2019, 03:15 PM
subacabra's Avatar
Quoted: 1836 Post(s)
Liked: 5261
Received this message from drop ship dept at B&H regarding shipping:
It is with my deepest regrets that I must inform you that the ship date for your order was moved to a later date due to the production getting delayed. The order is now scheduled to be shipped around March 29, 2019*.
subacabra is online now
post #1343 of 5886 Old 02-27-2019, 05:26 PM
xp0z3d's Avatar
Quoted: 77 Post(s)
@sage11x
@scottyroo
Any idea of how HT 3550 compares to Epson HC4000 or HC4010? I am currently considering buying a projector for my loft. There is some light during the day but my watching would be mostly late evenings and nights when the light would be 100% controlled. I plan to watch movies mostly. I understand with Epson you get more features like lens shift and lens memory, but based on picture quality which one would be a better choice?
xp0z3d is offline
post #1344 of 5886 Old 02-27-2019, 05:26 PM
sage11x's Avatar
Liked: 3086
I’ll retest when my unit comes back from the rework. It takes all of 30 seconds to do.
marinereef likes this.
sage11x is offline
post #1345 of 5886 Old 02-27-2019, 05:33 PM
Quoted: 541 Post(s)
Liked: 228
Do most of you connect your UHD Player Video/Audio Out to a Receiver and out of the Receiver to the Projector for HDR, or is it best to bring the Video directly from the UHD Player to the PJ? I recall hearing a lot of handshaking issues a year or more ago with UHD Players, Receivers and Projectors. Maybe no issues now.
post #1346 of 5886 Old 02-27-2019, 06:07 PM
sage11x's Avatar
Liked: 3086
Originally Posted by xp0z3d View Post
@sage11x
@scottyroo
Scott would be the better one to answer this as he had a 4000.
My (partly) uninformed opinion:
The HT3550 has a big resolution advantage but, despite how much better the BenQ is than it’s predecessors, I don’t expect it to keep up with the Epson’s blacks/contrast.
Everything else is tit for tat:
The Epson has lower lag but lacks the HT3550’s full bandwidth HDMI and crisp motion handling.
The HT3550 will auto detect HDR (instead of forcing you into the menu) and it’s MEMC works in 4K. Meanwhile the Epson has a motorized lens with memory that makes it possible to run a 2.35 screen without a costly A lens.
The HT3550 is small and handsome and makes too much noise in it’s normal lamp mode. The Epson is large and heavy and ugly and is way more placement flexible.
Both have DCI, both do HDR. The Epson has been lauded for it’s DCI-P3 color, meanwhile BenQ is getting plenty of early praise for it’s HDR PRO tone mapping.
They’re an interesting pair. I’m not convinced these two are competitors considering how much space separates them in price but I could be wrong. It seems like Epson is positioning the 4010 as a poor mans JVC (that’s a compliment) as I don’t see the 4010 outside of a dedicated home theater (can you imagine the Epson sitting on someone’s coffee table?). Meanwhile, BenQ is trying to assert themselves as the performance/value leader in 4K the same way they have in 1080p for so long. The HT3550 hits a price/performance sweet spot that it should appeal to enthusiasts and casual users alike.
sage11x is offline
post #1347 of 5886 Old 02-27-2019, 07:52 PM
xp0z3d's Avatar
Quoted: 77 Post(s)
I am thinking HC4000 which is currently selling for around $1499, and during sale went down to $1240 does share the same price range as HT3550. As I have been considering to get a PJ for a couple of months now, I have read a lot on HT 2550, TK800, HC4000 etc. And was having a hard time deciding between these, and now with HT 3550 choice is becoming harder.
n84china likes this.
xp0z3d is offline
post #1348 of 5886 Old 02-27-2019, 08:56 PM
chhanthony's Avatar
Quoted: 239 Post(s)
Liked: 127
Dear sage11x
May I know whether W2700 can do DCI-P3 in HDR10 mode?
Thank you!
Anthony Chan
AV Blog: http://www.avnewbie.com
Panasonic DP-UB9000EBK, Shield TV Pro 2019, Zidoo Z9S, Anthem AVM60, Krell KAV2250 X 2, Theater Amplifier Standard, M&K S-150 X 5, SS150 X 4, Martin Logan Descent-i and Thiel SS 2, SS2.2 and SI 1 Integrator, LG HU70LA, JK 126" Fixed Screen N4-FL/W1
chhanthony is offline
post #1349 of 5886 Old 02-27-2019, 09:10 PM
sage11x's Avatar
Liked: 3086
Originally Posted by chhanthony View Post
Dear sage11x
Thank you!
Yes it can you just have to switch on the Wide Color feature in the advanced picture menu.
sage11x is offline
post #1350 of 5886 Old 02-27-2019, 09:16 PM
sage11x's Avatar
Liked: 3086
The 4000 and 4010 are often lumped together but, from what I’ve read, the 4010 is a significant upgrade even if they didn’t maybe go far enough (it’s 2019, you shouldn’t have to manually switch between SDR and HDR).
There are a LOT of reviews of the 4000 out there so you should be able to get a good idea of what it’s all about. It’s a really good price that’s for sure.
sage11x is offline
