BenQ W2700 / HT3550 Announcement and Owner’s Thread - Page 62 - AVS Forum | Home Theater Discussions And Reviews
 3291Likes
post #1831 of 6264 Old 03-21-2019, 01:32 PM - Thread Starter
scottyroo's Avatar
Quoted: 617 Post(s)
Liked: 831
Originally Posted by home4sale2 View Post
That's fairly visible, has the potential to drive me nuts or turn it off altogether.
Thanks for sharing. I didn’t see that behavior on screen with mine.
"The Bunker" | Dedicated Theater Build Under Suspended Slab Garage
Testing: BenQ HT5550 | Epson 5050UB | 160" Dragonfly™ Fixed AT Screen
Denon X6300H | 9.4.4 (7.2.4 Discrete) | 9x Episode 900 Series LCR/Surrounds | 4x Episode 1700 Series ATMOS Heights | 4x Episode 12" Evo Subs
Sony X700 | Xbox One X | NVIDIA Shield TV
scottyroo is offline
post #1832 of 6264 Old 03-21-2019, 01:46 PM
BrandonH's Avatar
Quoted: 106 Post(s)
Liked: 118
This is good to know I think, hopefully that means mine is a fluke of some sort, though Sage did say he could see something like that on his but said it wasn't as bad when I pointed him to that scene which seems to be a bit of a worst case scenario for that behavior.
BrandonH is offline
post #1833 of 6264 Old 03-21-2019, 01:53 PM
xp0z3d's Avatar
Quoted: 79 Post(s)
Originally Posted by curtlots View Post
With the delay in shipping taking place, even though I have an order placed for the 3550, I'm going to take some time investigating other projectors, starting with the Epson 4010. There are a couple good deals placing the 4010 only a few hundred higher than the 3550, including a couple extras. The 4010 seems like a worthy competitor to the 3550, easily beating it in areas such as lag, contrast, and placement. Decisions, decisions....
Last week I visited one of our local AV store. They had 4010 playing in a living room setting with an ALR screen. It looked perfect to me with light. I wish 4010 would come down in price couple of hundred more so then it will become a direct competitor to HT3550.
clotter62 likes this.
xp0z3d is offline
post #1834 of 6264 Old 03-21-2019, 03:26 PM
BrightBlade's Avatar
Quoted: 31 Post(s)
It appears the remote has two different buttons for power, one for on and one for off. I have always mapped the on/off button to a single on/off button on my main remote so I do not have to keep this one out and about just to turn on the projector. I then use CEC to turn on my AVR.
Is it possible to only use the on button (for example) to turn the projector on and off?
Est Sularus oth Mitha
BrightBlade is offline
post #1835 of 6264 Old 03-21-2019, 04:59 PM
chhanthony's Avatar
Quoted: 317 Post(s)
Liked: 139
Originally Posted by chhanthony View Post
I noted that W2700 have image delay even I turn the motion enchancer off, any idea can fix it?
Could be processing delay in your player too. Is it for all content?
Problem solved after hard reset tbe player.
Thanks for help.
home4sale2 likes this.
Anthony Chan
AV Blog: http://www.avnewbie.com
Panasonic DP-UB9000EBK, Shield TV Pro 2019, Zidoo Z9S, Anthem AVM60, Krell KAV2250 X 2, Theater Amplifier Standard, M&K S-150 X 5, SS150 X 4, Martin Logan Descent-i and Thiel SS 2, SS2.2 and SI 1 Integrator, LG HU70LA, JK 126" Fixed Screen N4-FL/W1
chhanthony is offline
post #1836 of 6264 Old 03-21-2019, 05:00 PM
chhanthony's Avatar
Quoted: 317 Post(s)
Liked: 139
Hi all,
Share some screen cap of my preliminary measurement
Measure equipment
CalMAN Video Pro
X-Rite i1 Pro 2
Klein Instruments K10-A
CalMAN VideoForge Pro
EDIT: I am using 126" JK 1.0 gain white screen with good light control
Hi, chhanthonyi,
Would you mind to show following set of data
1. 709 post cal
2. data of wide gamut w/o engaging HDR. (means native color gamut)
3. data of wide gamut HDR engaged
I believe the CMS of W2700 can achieve better result. I got several calibration experiences for HDR pj such as JVC 550/ 790/ 990/ UHZ68/UHD68. My experiences told better to cal the best result of 709 and then check the result of newer format.
By the way, can it by pass HDR mode from player, just let HT3550 do the HDR?
Hope can do calibration this weekend and will report asap.
Anthony Chan
post #1837 of 6264 Old 03-21-2019, 05:02 PM
chhanthony's Avatar
Quoted: 317 Post(s)
Liked: 139
I have not noticed any audio delay with the motion enhancer off, with it on I noticed the lip sync was a little off and would have had to adjust the delay in my amp to match.
In the Cine4Home review I noticed he said this about the iris: "The system works well overall and improves the black level significantly, but occasionally caused subtle jumps in brightness in our test scenes." That sounds a little bit like the flicker I've described on mine, though maybe not as bad as what I saw, because I think he would have emphasized it more if so.
Brandon
Prolbem solved after hard reset the player.
Thanks for help.
Anthony Chan
post #1838 of 6264 Old 03-21-2019, 06:41 PM
sage11x's Avatar
Quoted: 3058 Post(s)
Liked: 3175
Eh-- actually what I said was: "Not sure if it's as bad as what you're seeing."
That scene of the good place you sent me is probably the best example I've seen of the issue. There is some good news though-- I mentioned you in a comment over in my review thread. Btw, I'm trying to keep just review stuff over there as this thread moves so fast information gets buried quickly.
What to do if you find yourself stuck with no hope of rescue:
Consider yourself lucky that life has been good to you so far. Alternatively, if life hasn't been good to you so far, which given your present circumstances seems to be more likely, consider yourself lucky that it won't be troubling you much longer...
-- Excerpt from the Hitchhiker's Guide to the Galaxy.
sage11x is offline
post #1839 of 6264 Old 03-21-2019, 06:55 PM
BrandonH's Avatar
Quoted: 106 Post(s)
Liked: 118
Yes it sure does. Thanks, sorry I was trying to paraphrase what you said from memory. I'm glad they recognized that problem. If that fix requires the unit to be sent back that's unfortunate but will definitely be worth it.
Sent from my SM-G965U using Tapatalk
sage11x likes this.
BrandonH is offline
post #1840 of 6264 Old 03-21-2019, 08:30 PM
chhanthony's Avatar
Quoted: 317 Post(s)
Liked: 139
I see a few settings on ub900, curious if you tried them. Under advanced settings, deep color output defaults to 12 bit, change to 10bit?
Play with HLG/PQ settings?
24p is set to auto?
4K/60P(4:4:4) is selected? My default is off.
Trying to help, not an expert on this unit.
I would be interested in getting Chhanthony's perspective on the changes scottyroo recommends. I have the UB900 as well and same use cases as you described (Netflix). Thanks.
Thanks a lot! home4sale2
Problem solved, the Chroma Subsampling in UB900 should be set 4K (50/60) 4:4:4 instead of 4K (50/60) 4:2:0
home4sale2 and scottyroo like this.
Anthony Chan
post #1841 of 6264 Old 03-21-2019, 08:38 PM
home4sale2's Avatar
Quoted: 107 Post(s)
Liked: 63
Awesome, glad I was able to help. I have the same player and expecting to buy the same projector.
chhanthony likes this.
home4sale2 is offline
post #1842 of 6264 Old 03-21-2019, 09:01 PM
chhanthony's Avatar
Quoted: 317 Post(s)
Liked: 139
I have calibrated over 20+ HDR projectors including Sony W750 and JVC Z1, I would say the HDR performance of W2700 is incredible for this price range even double of it.
mR_Mo, home4sale2, sage11x and 7 others like this.
Anthony Chan
post #1843 of 6264 Old 03-22-2019, 12:44 AM
Liked: 4
This is good news to the ears.
hopefully I should get one before the year ends to replace my HT3050
dekin01 is offline
post #1844 of 6264 Old 03-22-2019, 03:11 AM
Quoted: 38 Post(s)
Question to benq w2700 owners.
How is the HDR image qualty in ECO mode vs Normal?
Would be nice to see comparison images in these modes
proddan is offline
post #1845 of 6264 Old 03-22-2019, 04:48 AM
sage11x's Avatar
Liked: 3175
Not much difference in picture quality. With the wide color feature off and the lamp in normal the HT3550 is bright enough to compete with some ambient light. In the dark you’ll only need eco.
With the wide color filter engaged you really need to run the projector in normal to get sufficient light output. That said, BenQ is tweaking this particular feature based on early feedback. I’m in New York now and last night they demonstrated an HT3550 running in wide color mode that was powering a 120” screen with some ambient light present. They’ve tweaked the firmware to squeeze more output out of the wide color mode. It looked good in the demonstration but I’ll reserve my final opinions until I can get this firmware running on my sample. I quite like the wide color mode right now but I also realize that it’s lowered output runs contrary to the trend of larger and brighter screens. Adjusting this feature means more people will be able to take advantage of it.
CallingMrBenzo and jimchao like this.
sage11x is offline
post #1846 of 6264 Old 03-22-2019, 05:21 AM
Quoted: 38 Post(s)
Thanks Sage for your quick response!
sage11x likes this.
proddan is offline
post #1847 of 6264 Old 03-22-2019, 11:39 AM
AV_Integrated's Avatar
Quoted: 1723 Post(s)
Liked: 1260
Probably not. You can look online to see if there is a power toggle command available, but most universal remotes support macros and the power on command is linked to the source selection. So, you press 'blu-ray' and it turns on the AVR and the projector, then switches the AVR to the proper input. The power button on the remote is STRICTLY used to turn the system off. That way you get consistent reliability from the remote and you don't use power toggles for any equipment as things will get out of sync.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #1848 of 6264 Old 03-22-2019, 01:04 PM
JonnyVee's Avatar
Quoted: 365 Post(s)
Liked: 293
Best Buy Canada has changed their posted release date from April 8th to May 1st.
https://www.bestbuy.ca/en-ca/product...13387428.aspx?
Projector and Screen: JVC x790 & 120" Stuart WallScreen StudioTek 130 G4
Audio: Denon x4400H 5.1.4 - Infinity R162 L/R, Infinity RC263 centre, Kef T101 surrounds, Kef Ci160er rear atmos, Energy V-Mini - front atmos, PSA v1512df (x2) & BOSS w/4 12” Subs
JonnyVee is offline
post #1849 of 6264 Old 03-22-2019, 01:23 PM
neotide's Avatar
Quoted: 22 Post(s)
Liked: 29
My guess is that is a placeholder since they don't know when they will ship with the lens QA issues. I emailed BenQ this morning inquiring since I didn't receive any official information with the ship date slipping. I was told they would have more information Monday and are "hoping" to ship the first week of April.
Like I told them however, I'm glad this slipped as BenQ isn't shipping a half baked product. Yes, we all want it but better to be done right the first time so ship it when it is ready as far as I'm concerned.
AVR - Denon AVR-X4300H & NAD C 375BEE
Fronts - Magnepan MG12/QR / Center - Magnepan MGCC2
Satellites - 6 Monoprice Black Back 6.5 /Sub - SVS PB-1000
PRJ - BenQ HT3550 / SCN - SilverTicket STR-16992
Sources - Switch/PS4/Sony UBP-X800/Thorens TD166 MKII/Austin Audioworks Black Swan
neotide is offline
post #1850 of 6264 Old 03-22-2019, 01:34 PM
Liked: 2
Yes I seen that too .... I don't think I can wait that long? ... my w1070 is on its last legs 4300 hours on its 4th bulb ...I can get a factory refurbished Uhd50 for $700 less or Uhd60 for $400 less then this ?? Pulling my hair out reading thread after thread ...watched every YouTube review etc ?? I need my 120 inch picture for Game of Thrones and NHL playoffs ! Want the Benq ...but super temped the just buy the Optoma and an extended warranty and move on with life.
Purcey007 is offline
post #1851 of 6264 Old 03-22-2019, 02:01 PM
JonnyVee's Avatar
Quoted: 365 Post(s)
Liked: 293
I don’t mind the wait. Nothing wrong with waiting while they work out the kinks. I’ll just “slum it” with the OLED.
neotide likes this.
JonnyVee is offline
post #1852 of 6264 Old 03-22-2019, 02:35 PM
Liked: 2
Oh man if my w1070 dies ...that means I have to move out of my cave in the basement... go upstairs and spend time with my wife watching something on her TV ... No chance of that happening
post #1853 of 6264 Old 03-22-2019, 04:05 PM
Troy LaMont's Avatar
Quoted: 316 Post(s)
Liked: 287
@sage11x , @scottyroo ,
Can you tell me if the projector can play 4K MKV files in H265 format? The manual only mentions H264. Also have either of you heard the price of replacement bulbs yet?
Theater: Onkyo TX-NR807, Polk LSi15, Polk LSiC, Polk LSiF/X, Velodyne HGS12, Optoma HD80 on 100" Elite Aeon screen
Bedroom: Yamaha WXA50, Samsung Q6FN (2018), Martin Logan Motion LX16, Pro SW100P 10" sub
Gaming: Xbox One X, Samsung UH750 Quantum Dot 28" UHD monitor
Troy LaMont is offline
post #1854 of 6264 Old 03-22-2019, 04:25 PM
sage11x's Avatar
Liked: 3175
Can you send me a file? I’ll try it for you.
I’ll ask about the lamp. I wanna say it was $250 but I could be wrong.
Also: did you ever try out those chroma test patterns with the XBOX One X?
Troy LaMont likes this.
sage11x is offline
post #1855 of 6264 Old 03-22-2019, 04:31 PM
Quoted: 316 Post(s)
Liked: 287
I'll DM you a link to a test file. I'll check out those chroma test patterns shortly as well.
sage11x likes this.
post #1856 of 6264 Old 03-22-2019, 05:04 PM
BrandonH's Avatar
Quoted: 106 Post(s)
Liked: 118
The only file I had like that was a standard def MKV HEVC file. It played, but there were subtitles I couldn't figure out how to get rid of. Hopefully Sage can test a HD or UHD file for you.
BrandonH is offline
post #1857 of 6264 Old 03-22-2019, 05:35 PM
chhanthony's Avatar
Quoted: 317 Post(s)
Liked: 139
Last night I turn wide color mode ON with color enchancer set to 2 and fresh tone 1 in normal mode, the brightness is more acceptable in my 126" screen and the color is very rich.
Anthony Chan
post #1858 of 6264 Old 03-22-2019, 05:48 PM
bud16415's Avatar
Quoted: 2482 Post(s)
Liked: 1339
Whats your screen gain?
Bud
bud16415 is offline
post #1859 of 6264 Old 03-22-2019, 05:51 PM
chhanthony's Avatar
Quoted: 317 Post(s)
Liked: 139
JK 126" 1.0 gain white screen.
bud16415 and JonnyVee like this.
Anthony Chan
post #1860 of 6264 Old 03-22-2019, 06:01 PM
elitegamer's Avatar
Probably a dumb question since the 3550 isn’t out yet but how would it compare to the tk800? What improvements would I see over the current tk800? My room is able to be completely dark but sometimes keep the door open for the kids
elitegamer is offline
