BenQ W2700 / HT3550 Announcement and Owner’s Thread - Page 74 - AVS Forum | Home Theater Discussions And Reviews
 2197Likes
post #2191 of 3930 Old 04-03-2019, 10:11 AM
subacabra's Avatar
Quoted: 1562 Post(s)
Liked: 4593
Originally Posted by jbnpaul View Post
I am not commenting on the image quality. But just comparing them against each other.
Don't you agre the second one though it doesn't use the filter have more color in it? Is there a difference between brilliant color settings or anything else?
Yes there's definitely a more colorful picture with the filter off.
I also prefer brilliant color off with the filter on, yet on with the filter off.
With filter engaged and brilliant color on, whites appear yellow ish.
With filter off and brilliant on they appear more white.
Hope that makes sense posting real quick at work.
subacabra is online now
post #2192 of 3930 Old 04-03-2019, 10:23 AM
jbnpaul's Avatar
Quoted: 104 Post(s)
Liked: 37
Ah yes. This makes prefect sense now. I have a 2550, so I know exactly what brilliant color does.
One of my favorite settings on 2550 is vivid mode with brilliant color. It is probably not very accurate but I love the image this way.
subacabra likes this.
jbnpaul is online now
post #2193 of 3930 Old 04-03-2019, 10:37 AM
Quoted: 460 Post(s)
Liked: 257
Originally Posted by mickey79 View Post
Crap!! I'm glad I checked this.
I'm not a ceiling mount person; not about to go up there and start doing the holes & stuff, and I have a slanted/tilted ceiling. Either way, I need a shelf-mount solution like the one I have.
I think I need to look at other offerings. Either JVC X790r or wait & see if Epson brings the TW9400 here.
OK, having said that, there is another way... but it will depend on your screen height and location.
You can increase the height of your shelf unit, by adding another shelf (say an 18in high bookcase or similar) and then hang the HT3550 inverted under the top shelf via a ceiling mount.
As an aside, when I do ceiling mounts on drywalled ceilings, I start by finding the joists with a stud finder, then I attach a piece of 1/2in, or thicker, pine shelving (or plywood) across the joists and then hang my ceiling mount from that via 1/2in wood screws. This is allows for flexible placement of the ceiling mount and creates the fewest actual holes in the drywall. The pine shelving or plywood strip can be painted to match the ceiling.
The ceiling mount will tilt and swivel to level the PJ regardless of ceiling slope.
Frank714 likes this.
DunMunro is online now
post #2194 of 3930 Old 04-03-2019, 11:22 AM
andy4theherd's Avatar
Quoted: 13 Post(s)
Need a recommendation for a ceiling mount. My Epson I replaced was 15' from screen and sitting on top of an equipment rack. Obviously, that's not going to work with the 3550.
andy4theherd is offline
post #2195 of 3930 Old 04-03-2019, 12:27 PM
jwhinham's Avatar
Benqdirect has the projector available to order with a stated 4/12 ship date.
Spaded21 and xp0z3d like this.
jwhinham is offline
post #2196 of 3930 Old 04-03-2019, 12:27 PM - Thread Starter
scottyroo's Avatar
Quoted: 613 Post(s)
Liked: 808
Originally Posted by sage11x View Post
Hm... when you say HDR and 3D off are you referring to a specific setting? The Bodnar outputs regular old 1080p SDR and it doesn't output 3D.
Yeah the signal never changed but when I turned those settings from 'Auto' to 'Off' and tested again, input lag dropped by 3-4ms. I can't explain why. Maybe turning them off allows signal to bypass a signal sensor?
"The Bunker" | Dedicated Theater Build Under Suspended Slab Garage
Testing: BenQ HT5550 | Epson 5050UB | 160" Dragonfly™ Fixed AT Screen
Denon X6300H | 9.4.4 (7.2.4 Discrete) | 9x Episode 900 Series LCR/Surrounds | 4x Episode 1700 Series ATMOS Heights | 4x Episode 12" Evo Subs
Sony X700 | Xbox One X | NVIDIA Shield TV
scottyroo is offline
post #2197 of 3930 Old 04-03-2019, 12:34 PM
sage11x's Avatar
Quoted: 2578 Post(s)
Liked: 2524
Oh wow! Alright I’ll try this and get back with you. I pride myself on rooting out extraneous processing but I didn’t even consider those. Good find. I’ll see if it makes a difference.
What to do if you find yourself stuck with no hope of rescue:
Consider yourself lucky that life has been good to you so far. Alternatively, if life hasn't been good to you so far, which given your present circumstances seems to be more likely, consider yourself lucky that it won't be troubling you much longer...
-- Excerpt from the Hitchhiker's Guide to the Galaxy.
sage11x is online now
post #2198 of 3930 Old 04-03-2019, 12:39 PM
file8761's Avatar
Quoted: 31 Post(s)
Originally Posted by Willy212 View Post
Streaming, fire tv 4k on netflix hdr.
Mostly use fire tv or Desktop .
But yeah it looks awesome.
tweaking the settings abit like i was told does make it look better , "for me"
But the fan noise @!#[email protected][email protected] , I should probably build a box around the projector.
So how bad is the fan noise compared to the W1070? This is what I'll be replacing and sits right above our heads. Ready to pull the trigger on ordering, but now another variable to consider. Thanks!
file8761 is offline
post #2199 of 3930 Old 04-03-2019, 12:45 PM - Thread Starter
scottyroo's Avatar
Quoted: 613 Post(s)
Liked: 808
Some people don't like it. I think its better than last year's HT2550 and TK800. I think the truth is that the fan noise is par for the course for this size of projector. My unit produces a very constant 'whoooooosh' and no weird anomalies in the sound profile. FWIW mine is about 5 feet above my head and I do not notice it at all with content playing. For context I also play my audio quite loud in my setup ... so the fan noise kinda melts away.
post #2200 of 3930 Old 04-03-2019, 12:55 PM
file8761's Avatar
Quoted: 31 Post(s)
Thanks for the fast response! Your projector placement is pretty much identical to mine. Same thing with my W1070, the fan noise is definitely there, but I don't notice it once I have content playing. I can deal with it for sure on the HT3550 as long as it's not too much louder than my current projector. I think I read every thread on this post, have been so excited for this upgrade as I need to stay within a certain budget. W1070 has been amazing and still puts out a nice picture, but I'm itching for that extra little something now for my Netflix 4K content, Xbox One X, and will need to start shopping for UHD Blu-Rays. Appreciate all your feedback throughout and the excellent level of detail in reviews!
scottyroo likes this.
file8761 is offline
post #2201 of 3930 Old 04-03-2019, 01:14 PM
kdupuis77's Avatar
Quoted: 38 Post(s)
Liked: 41
Thanks for the heads up! I ordered through Amazon in February and my date keeps slipping to the right... Now claiming it will arrive May 22nd? So I just placed and order with BenQ Direct and will just cancel whoever ships last I suppose. Really looking forward to trying this beast out as it'll be the first 4K display in our house. I spent a few hours last weekend ransacking my Blu-Ray collection for all the digital copy codes I never redeemed. Amazingly, I was able to get a little over a hundred movies into my iTunes library. Luckily, about 30 or so of these I was able to import directly and got the free 4K/HDR/Atmos upgrades from Apple, with the rest just being HD through Movies Anywhere. Come on BenQ, let's get that thing in the mail lol..
11ft x 13ft Theater Room w/ 2x rows of 2x Seatcraft Rialto Leather Powered Recliners
BenQ HT3550 4K XPR DLP projector w/ Silver Ticket 100" 16:9 Aspect Ratio Screen
Yamaha RX-V683BL AVR w/ Klipsch 5.2.2 Atmos Surround System
PS4 Slim, Xbox One S, Nintendo Switch, AppleTV 4K
kdupuis77 is offline
post #2202 of 3930 Old 04-03-2019, 02:23 PM
Quoted: 89 Post(s)
Liked: 33
How does the HT5550 compare noise wise?
Rob
PT-AE8000U | LG 55C7P | Oppo UDP-203 | Onkyo TX-NR636 | JBL 5.1
robl2 is offline
post #2203 of 3930 Old 04-03-2019, 05:14 PM
thadius65's Avatar
Quoted: 54 Post(s)
Liked: 24
I just cancelled my Amazon orders as I am tired of their pricing issue and unclear shipping dates. I ordered with BenQDirect with April 12th ship date with priority overnight.
thadius65 is offline
post #2204 of 3930 Old 04-03-2019, 05:30 PM
Quoted: 34 Post(s)
Liked: 2
Originally Posted by robl2 View Post
You can calculate all of this yourself using the excellent BenQ projector calculator: http://projectorcalculator.benq.com/
Thank you so much!
I used the tool to check the setup for my room.
My room is 3.5m Long. I plan to have a drop down screen in front of my oled tv. So I need around 20cm clearance from the front wall. Means I’m left with 3.3m.
Looking at the dimension of W5700, it seems like it is not an option for me. Min projection distance is more than 3m.
My table at my rear wall is around 1.12m tall. But I’m hoping to have the screen 1m from the ground. Which as you guys have highlighted the limited vertical shift on the W2700 won’t allow me to do so as well.
I have waited very very long for such a short throw 4k projector that is within my Budget. Even purchased the Long hdmi cable and 3D glasses in preparation for the arrival of the W2700. Haha.
Just thinking is it possible for me to tilt the w2700 a bit down?
cychua is offline
post #2205 of 3930 Old 04-03-2019, 05:39 PM
dbpaddler's Avatar
Quoted: 135 Post(s)
Liked: 75
Originally Posted by cychua View Post
Thank you so much!
You'd have to use keystone correction which will degrade your picture I'd imagine. Can't you put some sort of riser or smaller shelf setup on the table to elevate the projector more?
Or didn't someone mention using rubber feet and flipping the projector onto its top?
Sent from my SM-N960U1 using Tapatalk
dbpaddler is offline
post #2206 of 3930 Old 04-03-2019, 06:45 PM - Thread Starter
scottyroo's Avatar
Quoted: 613 Post(s)
Liked: 808
The HT5550 is a bit quieter. Noise profile is even deeper and more inaudible that’s the HT3550. However the iris actuation is a bit more audible on the HT5550.
post #2207 of 3930 Old 04-03-2019, 07:07 PM
Spaded21's Avatar
Quoted: 80 Post(s)
Liked: 36
I did the same. And no tax with BenQ so saving about $90.
curtlots and neotide like this.
7.2.4 BenQ/Marantz/HTD/Micca/SVS/Dayton
Spaded21 is offline
post #2208 of 3930 Old 04-03-2019, 08:11 PM
xp0z3d's Avatar
Quoted: 56 Post(s)
I ordered too but got tax on it. How did you not pay tax on it?
xp0z3d is offline
post #2209 of 3930 Old 04-03-2019, 08:12 PM
Samfield's Avatar
Quoted: 49 Post(s)
Liked: 69
Got tired of waiting on Busted Buy and ordered from Benq, as well. Site claims there's only 2 left after my order. Now it's time to flip my 3050.
Samfield is online now
post #2210 of 3930 Old 04-03-2019, 08:51 PM
curtlots's Avatar
Quoted: 165 Post(s)
Liked: 195
Now down to 1 left after I placed my order. Amazon still showing between April 19th and May 15th made this an easy decision.
curtlots is offline
post #2211 of 3930 Old 04-03-2019, 09:38 PM
subacabra's Avatar
Liked: 4593
Guardians of the Galaxy 2 looking pretty sweet! Actually liking brilliant color on now lol
post #2212 of 3930 Old 04-03-2019, 09:39 PM
yadfgp's Avatar
Quoted: 131 Post(s)
Liked: 78
Mine that I ordered from projection people last Thursday is to be delivered tomorrow!
I'll be upgrading from an Epson 3500.
yadfgp is offline
post #2213 of 3930 Old 04-03-2019, 09:42 PM
Willy212's Avatar
Quoted: 35 Post(s)
Liked: 45
Its not bad when the fan doesn't speed up , but when it does -_- yeah . Like i said its 3ft from me, some random video i uploaded . That buzz sound you can't really hear it, but the fan yes .I'm trying to give it a chance because i do love the colors/hdr, but summer is almost here .
I wish there were more options .
But if i do go for uhd60/4010/5040/acer v7850/h7850. I would probably only get around 96".
I can get 100" with those projector but i would have to move my room around yeah NTY.
Would of loved to build a hush box but ain't nobody got time for that .
Don't mind the mess work in progress .
Can't Drill much on these walls XD. cable management in the future .
Willy212 is offline
post #2214 of 3930 Old 04-03-2019, 10:35 PM
subacabra's Avatar
Liked: 4593
Here's a couple shots of Forza Horizon 4 and Far Cry 5 on the Xbox one x. Unreal. Loving this pj
(Yes that's why my name on here, love my Subies)
Little video
post #2215 of 3930 Old 04-04-2019, 03:35 AM
JonnyVee's Avatar
Quoted: 264 Post(s)
Liked: 162
My placement is similar. Fan noise on the HT2050 was not noticiable when the speakers were loud. Listening at low volumes was a little tough.
I’m thinking I might actually build a hush box this time. Anyone have some links to decent designs?
Rec Room: JVC x790 w/120" Silver Ticket screen, Denon x4400H 5.1.4 with Kef Q100 L/R, Q200 centre, T101 surrounds, Ci160er rear atmos, Energy Rc-Mini - front atmos, SVS PC-2000. Family Room: LG 65B7P OLED, Denon s730H 5.1 - Kef Q500, Q200c, Energy v-mini - surrounds. Calibration Gear: X-Rite i1Display Pro, Calman Home Enthusiast, trial & error, and a patient wife.
JonnyVee is offline
post #2216 of 3930 Old 04-04-2019, 05:39 AM
curtlots's Avatar
Quoted: 165 Post(s)
Liked: 195
What are your thoughts about black levels and contrast? I read on the internet that DLPs have "abysmal" black levels. I'm hoping the black levels are at least the equal and hopefully better than my Epson 8350. I would love to see a good pic that realistically displays the letterbox bars on a 2:35/1 movie.
curtlots is offline
post #2217 of 3930 Old 04-04-2019, 05:46 AM - Thread Starter
scottyroo's Avatar
Quoted: 613 Post(s)
Liked: 808
@sage11x you wanna take this one?
curtlots and subacabra like this.
post #2218 of 3930 Old 04-04-2019, 06:08 AM
home4sale2's Avatar
Quoted: 98 Post(s)
Liked: 54
I’ll take it as Sage and Scott have answered this and have made comments around contrast vs brightness differences, about every 10 posts or so, here and in Epson threads. Here’s a snippet from another thread.
“DLP has a lot of strengths but as you go up in price, contrast/blacks aren’t one of them. Personally, I tend to prefer DLP because I like the sharp image and high motion handling. The Ht5550 and UH1 are right in that range where ultra high contrast projectors (5040ub, 6040ub and the new 5050ub) start to become available. Those Epsons will have superior contrast blacks but at the expense of not being as sharp or nearly as crisp when it comes to motion. Still, contrast is an important aspect of picture quality and I’ll be interested to see how Scott’s comparison goes.”
home4sale2 is offline
post #2219 of 3930 Old 04-04-2019, 06:18 AM
curtlots's Avatar
Quoted: 165 Post(s)
Liked: 195
Yes, I've been reading all I can, but I have yet to see a picture clearly showing the letterbox bars and the difference between that, and a surrounding velvet or other true black border.
curtlots is offline
post #2220 of 3930 Old 04-04-2019, 06:20 AM
oBMTo's Avatar
Put in order with benqdirect last night. What mounts do people recommend? This will be my first time mounting a projector to a ceiling so looking for something easy to use.
Thinking about going with this mount: https://www.amazon.com/gp/product/B0...YFTRLN23&psc=1
oBMTo is offline
